New Documentation articles
  • Latest Dynatrace
  • Release notes
This page lists all new or significantly changed Dynatrace Documentation topics, sorted by week of publication.
Sep 21, 2026
  • Best practices for upgrading to Latest Dynatrace
  • Upgrade queue monitoring to service message processing
  • Scope your upgrade to Latest Dynatrace
  • Enrich your observability signals
  • Upgrade management zones to IAM and segments
  • Upgrade observability data and settings
  • Partition your Grail data
  • Upgrade configurations and settings
  • Upgrade classic dashboards
  • Upgrade metric alerting and maintenance windows
  • Upgrade team-based and global alerting
  • Upgrade remaining entities and metrics
  • Upgrade your API integrations and tokens
  • Best practices for scoping the upgrade to Latest Dynatrace
  • Best practices for cloud enrichment
  • Best practices for enrichment with central enrichment rules
  • Best practices for metadata enrichment
  • Best practices for RUM data access controls
  • Best practices for upgrading management zones to segments
  • Best practices for upgrading classic cloud monitoring
  • Best practices for a logs bucket strategy
  • Best practices for data partitioning
  • Best practices for upgrading SLOs
  • Best practices for upgrading dashboards
  • Best practices for upgrading alerting profiles and problem notifications to workflows
  • Best practices for upgrading security notifications
  • Best practices for upgrading App Observability API endpoints
Sep 14, 2026
  • Get started with Dynatrace QuickStart
  • Upgrade from Classic problem notifications to personal email notifications
  • Upgrade from Classic problem notification to simple workflows
  • Settings 2.0 schemas that are removed in Latest Dynatrace
  • Application snapshots OpenPipeline use cases
Sep 07, 2026
  • Set up automated release validation with Site Reliability Guardian
  • Upgrade from management zones to segments
  • Scope Dynatrace configuration with DQL matchers
  • Configure cost allocation
  • Configure security context
  • Upgrade from service naming rules to service naming in Latest Dynatrace
  • Workload identity federation
  • Migrate from management zones to security contexts for Synthetic monitors
Aug 31, 2026
  • Enrich OpenTelemetry with primary Grail fields and tags
  • Set up file-based endpoints and credentials
  • Run SQL extensions on Kubernetes
  • Custom JDBC drivers
  • Monitored pod Kubernetes metadata enrichment
  • Kubernetes resource planning
  • Configure custom TLS certificates for SQL Extension Executor pods
  • Troubleshoot SQL extensions on Kubernetes
  • Investigate database performance and dependencies in Services
  • Database query monitoring in Services
  • Synthetic monitors in Smartscape
  • Zoom Workplace extension
  • Enable Dynatrace SQL database extensions
  • Database blocking queries and deadlocks in Dynatrace
  • Database monitoring approaches
  • Health alerts and warning signals in Databases app
  • Database health score overview
  • Databases app concepts
  • Database statements and execution plans in Dynatrace
Aug 24, 2026
  • Configure central enrichment rules
  • Enrich AWS telemetry with primary Grail fields and tags
  • Enrich Azure telemetry with primary Grail fields and tags
  • Enrich Google Cloud telemetry with primary Grail fields and tags
  • Run agent evaluations in Dynatrace
  • Explain log records with AI
  • Arista extension
  • Zscaler Internet Access (ZIA) extension
  • Data extraction stage in OpenPipeline
  • Davis stage in OpenPipeline
  • Metric extraction stage in OpenPipeline
Aug 17, 2026
  • Transition from frequent issue detection
  • Build a sub-workflow
  • Personalize Assist responses
  • Configure enterprise identity management
  • Query consumption and segments
  • Extend extension pipelines with pipeline groups
  • Ingest AWS logs from Amazon S3
  • AWS logs
  • Monitor Azure Functions on Plans for Linux
  • Drill down to frontend context from Distributed Tracing app
  • Upgrade to New Database Monitoring
  • Effective pod resources
  • CloudWatch Logs via Amazon Data Firehose
  • Delete a mobile frontend
  • Delete a web frontend in RUM
Jul 27, 2026
  • Key concepts
  • Frequently asked questions
  • View DPS consumption with ready-made usage dashboards
  • AI Observability metrics reference
  • Problem investigation mode
  • Explore service topology with service map
  • Access control
  • Migrate from CSI driver to ephemeral volumes
  • Migrate to public registry
  • Actions for Slack Connector
  • Slack Connector message examples
  • Slack Connector Markdown reference
  • Set up Slack Connector
  • Get started with Slack Connector
  • Convert topology
  • Convert unified analysis (UA) pages
  • Update your tenant configuration
  • User action instrumentation
  • Specify a logical ancestor for user interactions
Jul 13, 2026
  • Best practices for avoiding overalerting
  • Choose how to ingest data into Dynatrace
  • ActiveGate health overview
  • Fleet Management
  • OneAgent health overview
  • Organize your data with primary Grail fields and tags
  • Primary Grail fields and tags
  • Best practices for enriching primary Grail fields and tags
  • Enrich Kubernetes telemetry with primary Grail fields and tags
  • Enrich OneAgent telemetry with primary Grail fields and tags
  • Plan your tagging strategy
  • Maintenance windows
  • Azure overview
  • Manage your AWS connections via API
  • Monitoring configuration fields
  • Set primary Grail tag rules in OpenPipeline
  • OpenPipeline self-monitoring metrics
  • Get started with OneAgent and AI Observability
  • Get started with Microsoft Agent Framework and AI Observability
  • Add an image to a dashboard
  • Network metrics
  • Vinyl Cache extension
  • Get started with network device monitoring
  • Scrape Prometheus metrics with the OTel Collector
  • Scrape Prometheus metrics with the OTel Collector (standard)
Jun 18, 2026
  • Cost Intelligence with Dynatrace Assist
  • Differences between classic auto-tagging and primary Grail tags
  • Analyze log patterns
  • Calculate your consumption of Data Egress (DPS)
  • Data overview (DPS)
  • Get started with OpenInference and AI Observability
  • Enrich threat observables with AbuseIPDB
  • Create custom enrichment connections
  • Enrich threat observables with VirusTotal
  • Ingest Black Duck security findings and scan events
  • Ingest JFrog security findings and audit logs
  • Ingest Wiz cloud configuration findings and audit logs
  • Service naming
  • Mask user interactions for mobile frontends
Jun 09, 2026
  • How pricing works
  • Your first year with DPS
  • Manage your costs
  • Monitor daily LLM cost burn rate using records-based custom alerts
  • definity extension
  • Cost allocation via OpenPipeline
  • Ingest Checkmarx security findings, scan events, and audit logs
  • Ingest CrowdStrike detection findings
  • Ingest Kyverno compliance findings
  • Log delivery and reliability
  • How-to guides
  • Analyze performance from frontend to backend
  • Frontend-backend linking
  • Session Replay for mobile frontends
  • Configure Session Replay for Android
  • Configure Session Replay for iOS
  • Session Replay for web frontends
  • Activate Session Replay for web frontends and configure cost and traffic control
  • Session Replay in an environment with strong privacy requirements for web frontends
  • Configure frontend-backend linking for web frontends
May 18, 2026
  • Session Replay
  • Activate Session Replay for web applications
  • Technical restrictions for Session Replay for web applications
  • How-to guides
  • Network topology
  • Configure cost and traffic control
  • Session Replay configuration
  • Configure opt-in mode
  • Configure resource capture
  • Configure masking
  • Configure URL exclusion
May 11, 2026
  • Network flows
  • OneAgent network connection monitoring
May 11, 2026
  • Reporting options in Notebooks
  • Calculate your consumption of Database Monitoring (DPS)
  • Handle customer complaints via e-commerce web app
  • Provide Digital Experience Monitoring (DEM) compliance in Dynatrace
  • Troubleshoot mobile banking apps without collection of PII
  • Technology bundle processors for logs
  • Azure events
  • Azure logs
  • Azure logs and events
  • Manage buckets for RUM
  • Analyze user behavior with DQL
  • Monitor web performance with DQL
May 04, 2026
  • Use segments with Anomaly Detection custom alerts
  • Palo Alto Panorama extension
  • Best practices for optimizing network monitoring cost
  • Smartscape node and edge extraction in OpenPipeline
  • Define custom topology via OpenPipeline
  • Dynatrace web UI cookies
  • Configure RUM cookie attributes in RUM on the latest Dynatrace
Apr 27, 2026
  • Duplicate a Site Reliability guardian
  • Business Observability with Insights
  • Digital Experience Monitoring with Insights
  • Ingest Google Artifact Registry vulnerability findings
  • Get started with configuration deletion for Monaco
  • Get started with configuration deployment for Monaco
  • Get started with Dynatrace configuration for Monaco
  • Configure service detection for OneAgent in Service Detection v2
Apr 20, 2026
  • Best practices for optimizing metrics cost
  • Assign ownership teams to Smartscape nodes
  • Automate team updates using a workflow and Ownership actions
  • Create and manage teams for Smartscape node ownership
  • Retrieve team ownership to define responsibility
  • Enrich threat observables with Security Enrichment
  • Configure startup probes for Dynatrace Operator components
  • Control RUM at the process group level
Apr 13, 2026
  • Cloud Foundry extension
  • Ingest Docker Scout vulnerability findings and scan events
  • Ingest GitLab security findings and audit logs
Apr 06, 2026
  • Migrate classic processing rules to OpenPipeline
  • Account audits API - GET account audits
  • Ingest Kubernetes logs with OneAgent
  • About Dynatrace licenses, accounts, environments, and users
  • Primary Grail tags for Synthetic
  • Health alerts for frontends
  • Analyze and alert in RUM on the latest Dynatrace
Mar 30, 2026
  • Primary Grail fields and tags enrichment through OneAgent
  • Use Grail buckets to partition data
  • Add annotations to a dashboard
  • Implement Log module self-monitoring
  • Use journald to ingest systemd journal logs with the OpenTelemetry Collector
  • Exclude XHR and Fetch requests from monitoring
  • Customize UI element naming for user interactions
Mar 23, 2026
  • Optimize log retention and reduce scanned data volume
  • Create AWS connection via API and AWS CLI
  • Built-in metrics in RUM on the latest Dynatrace
  • Activate new browser monitor experience
Mar 16, 2026
  • Set up Kubernetes Operations Agent
  • Set up Security Association Agent
  • agctl - Command-line interface for ActiveGate
  • Use segments for Synthetic
  • Ingest Mend Renovate vulnerability findings and scans
Mar 09, 2026
  • Notifications API - POST filter notifications
  • Set up Security Insights Report Agent
  • Set up Vulnerability Verification Agent
  • Python 3.10 end of support
  • Explore your DPS for Hybrid subscription with dashboards
  • Dynatrace Platform Subscription for hybrid setups (DPS for Hybrid)
  • Compliance Assistant
  • Account Management audit log examples
  • Account Management audit logs
  • SNMP generic server extension
  • Monitor hosts that send OpenTelemetry data to Dynatrace
  • User sessions in web frontends
Mar 02, 2026
  • Add and access validation insight links
  • Workflow templates
  • Subscription overview (DPS for Hybrid)
  • Get started with OpenTelemetry and AI Observability
  • Cisco UCS C-Series extension
  • Cisco UCS M-Series extension
  • Warning events
  • Associate user interactions with features and UI components
Feb 23, 2026
  • Alerting and notifications
  • OpenTelemetry
  • OpenAI Observability
  • OpenTelemetry Host Monitoring extension
  • Security Posture Management compliance standards
  • Configure user interaction capturing for mobile frontends
Feb 16, 2026
  • Smartscape
  • Smartscape concepts
  • Automate vulnerability remediation with Atlassian Rovo Dev and Dynatrace
  • Smartscape in-context views
  • View topology
  • Visual Resolution Path
  • AWS EC2 ecosystem overview
  • Smartscape views
  • Infrastructure overview
  • Kubernetes overview
  • Problem graph
  • Service dependency graph
  • Smartscape on Grail view
  • Adaptive Traffic Management concepts
  • Span and trace context propagation in Distributed Traces Classic
  • Log pre-processing with OpenPipeline with ready-made bundles
  • JSON log processing with unescaped nested JSON strings
  • Sizing guide for Dynatrace ActiveGates in the Kubernetes monitoring use-case
  • Configure the beacon origin allowlist
  • Finalize the initial setup for your agentless frontend
  • Finalize the initial setup for your auto-injected frontend
Feb 02, 2026
  • Enable automatic OpenTelemetry OTLP exporter configuration
  • ClusterRole aggregation for Kubernetes monitoring
  • Create a new AWS connection
  • Clouds app
  • Migration of DynaKube v1beta5 to v1beta6
  • Data collected with Dynatrace database monitoring
  • Get started with database monitoring
  • Monitor IBM DB2 database
  • Monitor MariaDB database
  • Monitor Microsoft SQL database
  • Monitor MySQL database
  • Monitor Oracle database
  • Monitor PostgreSQL database
  • Monitor SAP HANA database
  • Monitor Snowflake database
Jan 26, 2026
  • Automatically process logs at ingestion
  • Pre-process logs with OpenPipeline with ready-made bundles
  • OpenTelemetry to Dynatrace semantic mapping
  • Exception analysis
  • Leverage enhanced endpoints for SDv1
  • Monitor service message processing
  • Response time analysis
  • Data privacy in RUM on the latest Dynatrace
  • Radware Alteon Load Balancer extension
  • Reduce span-based and metric-based cardinality
  • Ingest JSON and TXT logs
  • Configure URL path pattern matching in Service Detection v2
  • Configure data privacy settings for web frontends
Jan 19, 2026
  • Extract metrics from spans and distributed traces
  • Page load waterfall
  • Configure data privacy settings for mobile frontends
Jan 12, 2026
  • Owner-based access control in OpenPipeline
  • Set access control in OpenPipeline
  • Extract a metric from user events
  • Extract a metric from user sessions
Dec 22, 2025
  • Site Reliability guardian event structure
  • Assess coverage
  • Explore findings
  • RUM metrics migration
  • Subscription or license overview
  • Ingest Qualys vulnerability findings, scan events, and audit logs
  • Create scheduled scan in Sensitive Data Center
  • Account limits API
  • Platform tokens API
  • Service user management API
Dec 15, 2025
  • Automate cloud misconfiguration triaging and remediation with Kiro CLI and Dynatrace
  • Enable Experience Analytics
  • Stonebranch Universal Automation Center extension
  • Enhance your account security with MFA TOTP
  • Data model in RUM on the latest Dynatrace
  • Concepts for web frontends
  • Pages, views, and navigations in RUM on the latest Dynatrace
  • User actions in web frontends
Dec 08, 2025
  • Optimize engineering flow metrics using Jira data
  • Upgrade Third‑party and Code‑level vulnerabilities to the 3rd generation experience
  • Adjust the log message
  • Sensitive Data Center
Dec 01, 2025
  • Uninstall OneAgent on Solaris
  • Control the RUM JavaScript version in RUM on the latest Dynatrace
  • Adapt CSP rules for RUM on the latest Dynatrace
  • Configure the beacon endpoint for web frontends in RUM on the latest Dynatrace
  • Roll out RUM selectively for your frontends in RUM on the latest Dynatrace
  • Anomaly Detection DQL writing guide
  • Anomaly Detection DQL optimization guide
Nov 24, 2025
  • Use traces, DQL, and logs to spot patterns
  • Relationship between the RUM on the latest Dynatrace and RUM Classic
  • Dynatrace Intelligence (Preview)
  • Mobile frontends
  • Customize web frontend monitoring using the JavaScript API
  • Optimize DQL cost with Dynatrace Intelligence (Preview)
  • Summarize open problems with Dynatrace Intelligence (Preview)
  • Capture event and session properties for mobile frontends
  • Additional configuration for mobile frontends
  • Capture event and session properties for web frontends
  • Additional configuration for web frontends
  • Enable RUM on the latest Dynatrace for your RUM Classic web applications
  • Policy management API - DELETE a policy boundary
  • Policy management API - GET all policy boundaries
  • Policy management API - GET a policy boundary
  • Policy management API - Boundaries
  • Policy management API - POST a policy boundary
  • Policy management API - PUT a policy boundary
Nov 17, 2025
  • Set up Grail permissions for Metrics
  • Set up Grail permissions for OpenTelemetry
  • Set up Grail permissions for telemetry from Kubernetes and Kubernetes workloads
  • Automate vulnerability remediation with GitHub Copilot and Dynatrace
  • Terraform tutorials overview
Nov 10, 2025
  • Scatterplot visualization
  • Configure automatic injection in RUM on the latest Dynatrace
  • Configure the Real User Monitoring code source in RUM on the latest Dynatrace
  • Use Subresource Integrity (SRI) in RUM on the latest Dynatrace
Nov 03, 2025
  • Explore supported Extensions
  • Ingest Sonatype Lifecycle security events and audit logs
  • Configure advanced permissions with security context
  • Understand extensions data sources
  • Web frontends
  • Initial setup for web frontends
  • Set up agentless RUM in RUM on the latest Dynatrace
  • Set up an auto-injected frontend in RUM on the latest Dynatrace
  • Set up host name determination in RUM on the latest Dynatrace
  • Select a snippet format in RUM on the latest Dynatrace
Oct 27, 2025
  • Push logs with Cloudflare
  • Access workflow management functionality
  • Get notified about workflow changes
  • Actions for Text Processing Connector
  • Text Processing Connector
  • Install and update Chromium for Linux
  • Manage private locations
  • Proxy for private locations
Oct 20, 2025
  • AI Observability (preview)
  • Monaco resource management
  • Ingest NetFlow records into Dynatrace
  • Monaco configuration YAML file - list of special configuration types
  • Monaco configuration YAML file - list of type fields
  • Monaco configuration YAML file structure
  • Install a Synthetic-enabled ActiveGate
  • Private synthetic locations
  • Requirements for private Synthetic locations
Oct 13, 2025
  • Settings
  • Send email notifications for problems
  • Send Slack notifications for problems
  • Scaling
Sep 29, 2025
  • Using facets
Sep 22, 2025
  • Dynatrace Platform Subscription API
  • Set budget alerts
  • DPS permissions
  • License Dynatrace
  • OpenTelemetry licensing
  • Set up an Anomaly Detection custom alert via API
Sep 08, 2025
  • Monaco API support and access permission handling
  • Work with Dynatrace Monaco CLI commands
  • Monaco concepts
  • Getting started with Dynatrace Monaco
  • Terraform API support and access permission handling
  • Terraform CLI commands
  • Set up automated notification
  • Migration guides for DynaKube apiVersions
  • New RUM APIs
  • Synthetic alerting overview
  • Migration of DynaKube v1beta1 to v1beta5
  • Migration of DynaKube v1beta2 to v1beta5
  • Migration your v1beta3 DynaKube to v1beta5
  • Migration your v1beta4 DynaKube to v1beta5
  • Kubernetes Enhanced Object Visibility Preview
Sep 01, 2025
  • Accelerate root cause analysis
  • Deployment API - View ARNs for AWS Lambda layers
Aug 25, 2025
  • Using facets
Aug 18, 2025
  • Detect threats in cloud-native environments using workflows
  • Ingest SonarQube security and quality events, metrics, and audit logs
Aug 04, 2025
  • Histogram metrics
  • Business Insights
  • Stream Logs with Cribl
  • Lookup data in Grail
  • Ingest Microsoft Sentinel security events
  • Failure Analysis (Early Access)
  • GET inline code
  • GET JavaScript tag
  • GET OneAgent JavaScript tag with SRI
  • RUM manual insertion tags API
Jul 28, 2025
  • Discover relevant troubleshooting guides with Dynatrace Intelligence agentic and generative AI
Jul 21, 2025
  • Using facets
Jul 14, 2025
  • Upgrade Classic SLOs
  • List and work with your guardians
  • End-of-life announcements
  • Manage live or draft workflows
  • Ingest GitHub Advanced Security security events and audit logs
  • Using facets
  • Proof of Concept
Jul 07, 2025
  • Ingest NetFlow packets
Jun 30, 2025
  • Kubernetes metrics migration guide
Jun 23, 2025
  • Grail security table migration guide
Jun 16, 2025
  • Observe Argo CD deployment and application health with Dashboards and SDLC events
  • Windows event logs
  • Customize endpoint detection in Service Detection v2
  • Customize failure detection in Service Detection v2
  • Customize service detection in Service Detection v2
  • Customize service splitting in Service Detection v2
Jun 09, 2025
  • Automated threat-alert triaging
Jun 02, 2025
  • AWS Marketplace private offer
May 26, 2025
  • ActiveGate FIPS compliance
  • Dynatrace Investigations concepts
  • Threat Observability concepts
  • Threats & Exploits concepts
  • Vulnerabilities concepts
  • Security Posture Management concepts
May 19, 2025
  • Speed up incident response with Dynatrace Investigations reference time
  • Log Monitoring from Journald (Logs Classic)
May 12, 2025
  • Ingest Microsoft Entra ID sign-in logs
  • Ingest Runecast Analyzer compliance findings
May 05, 2025
Apr 30, 2025
  • Vulnerability evaluation
  • Use cases for monitoring rules
Apr 14, 2025
  • Ingest Amazon GuardDuty security findings
Apr 07, 2025
  • Microsoft Power BI
  • Enrich with OneAgent (non-containerized)
Mar 31, 2025
  • Enable Observability for Developers
  • Live Debugger
  • Ingest Microsoft Defender for Cloud security events
  • Observability for Developers additional settings
  • Live Debugger breakpoints
  • Live Debugger concepts
  • Live Debugger IDE integration
  • Live Debugger
  • Live Debugger quick start
  • Live Debugger Setup
Mar 24, 2025
  • Security events ingest
Mar 17, 2025
  • Ingest monitoring
  • Business process monitoring
  • Business reporting
  • Business events end-to-end example
  • Ingest Akamai security logs and events
  • Ingest Harbor vulnerability findings, scans, and audit logs
  • Dynatrace Intelligence limits
Mar 03, 2025
  • Ingest Snyk vulnerability findings, scans, and audit logs
Feb 24, 2025
  • Synthetic architecture and communication
  • Dynatrace Assist question examples
  • Dynatrace Assist context-aware conversations
  • Ask Dynatrace Assist
Feb 19, 2025
  • Compliance and resilience
  • Identity and Access Management concepts
  • Identity and Access Management Limits
  • Ingest AWS Security Hub security findings
  • Analyze Amazon API Gateway access logs with Dynatrace Investigations
  • Resolve incidents faster with Dynatrace Investigations templates
  • Kong AI Gateway
  • NVIDIA NIM
  • AI data governance with Amazon Bedrock
  • Metadata enrichment of all telemetry originating from kubernetes workloads
  • Configure enrichment directory
  • Cost & Carbon Optimization
  • Anomaly Detection status types
  • Dynatrace Intelligence Problems use cases
Jan 06, 2025
  • Resource attributes
Dec 23, 2024
  • Create service-level objectives (SLOs)
  • Service-Level Objectives overview
  • Permissions for service-level objective (SLO) tiles in a dashboard
  • Add a service-level objective (SLO) tile to a dashboard
  • Edit a service-level objective (SLO) tile in a dashboard
  • View the details of a service-level objective (SLO) tile in a dashboard
  • OpenPipeline integration types for security events
  • Ingest Tenable vulnerability findings, scan events, and audit logs
  • Mask sensitive data
Dec 16, 2024
  • Microsoft Azure Arc-enabled servers
  • Synthetic App
Dec 09, 2024
  • Stay compliant with Security Posture Management
  • Discovery & Coverage app
  • Kubernetes Security Posture Management
  • Get started with Kubernetes Security Posture Management (KSPM)
  • Supported compliance standards and technologies
  • Assess coverage
  • Concepts
  • Gain insights
  • Get started with Security Posture Management app
  • Security Posture Management app
  • Review findings
  • Share findings
Dec 02, 2024
  • Analyze AWS CloudTrail logs with Dynatrace Investigations
  • Detect threats against your AWS Secrets with Dynatrace Investigations
  • API for Dashboards and Notebooks
  • System requirements
  • Use cases
Nov 22, 2024
  • Set up Jenkins Connector
  • Service users
  • Create and configure an HTTP monitor
  • HTTP monitors
  • HTTP monitors reporting results
Nov 11, 2024
  • Detect performance issues
  • Runtime contextualization of container findings
  • JDBC monitoring configuration
  • Host metrics
Nov 04, 2024
  • Dynatrace Intelligence agentic and generative AI data privacy and security
  • Query with natural language
  • Dynatrace Intelligence agentic and generative AI prompt examples
  • Dynatrace Intelligence agentic and generative AI FAQ
  • Getting started with Dynatrace Intelligence agentic and generative AI
  • Dynatrace Intelligence agentic and generative AI overview
  • Tips for writing better prompts
  • Create log alerts for a log event or summary of log data
  • Create a custom alert
Oct 28, 2024
  • Cost Allocation
  • Dynatrace Platform Subscription API - GET cost allocation
  • Dynatrace Platform Subscription API - Cost allocation
  • Dynatrace Platform Subscription API - manage cost allocation
Oct 21, 2024
  • Predict and autoscale Kubernetes workloads
Oct 14, 2024
  • Detect problems with Logs
  • Platform tokens
Sep 30, 2024
  • Discover coverage gaps in security scans
Sep 23, 2024
  • Launchpads
Sep 16, 2024
  • Platform tokens
  • Policy boundaries
Sep 09, 2024
  • GitHub for Workflows actions
  • Set up GitHub for Workflows
  • Available actions in GitLab for Workflows
  • Configure GitLab for Workflows
  • GitLab for Workflows
Sep 02, 2024
  • Automate and orchestrate security findings
  • Ingest and process custom security findings
  • Visualize and analyze security findings
  • Collaborate with other apps
  • Vulnerabilities
  • Manage remediation
  • Prioritize vulnerabilities
  • Transform and filter
Aug 26, 2024
Aug 12, 2024
  • Monitor z/OS logs
Aug 05, 2024
  • Ingest vulnerability findings in OCSF format
Jul 29, 2024
  • OpenPipeline limits
Jul 22, 2024
  • Monitored entities API - security context
  • Grant access to entities with security context
  • Ingest AWS ECR vulnerability findings
  • Ingest custom security events via API
  • Synthetic for Workflows
  • Create a NAM monitor
  • NAM monitor metrics
  • Network availability monitoring
  • Configure auto-update for Dynatrace Operator managed components
Jul 08, 2024
  • OpenPipeline
Jul 01, 2024
  • Filter field
  • RUM cookie names API - GET cookie names
  • Sample data
Jun 24, 2024
  • Syslog ingestion (Logs Classic)
  • Syslog ingestion
Jun 10, 2024
  • Red Hat Ansible Automation
  • Red Hat Event-Driven Ansible
Jun 03, 2024
  • Configure OpenTelemetry tracing with Istio
  • Unified services
  • Migrate from classic full stack to application monitoring mode
  • Migrate from classic full stack to cloud native full stack mode
  • Migrate from cloud native full stack to application monitoring mode
  • Deployment migration guides
May 27, 2024
  • Metrics powered by Grail (DPS)
  • Anomaly detection configuration
May 20, 2024
  • Notebooks and Dashboards use cases
  • Distributed traces
  • Workflows use cases
May 06, 2024
  • Privacy Rights
Apr 29, 2024
  • Extend event observability
  • Remote environment data
  • DQL query action for Workflows
  • HTTP request action for Workflows
  • Workflows actions
  • Run JavaScript action for Workflows
Apr 22, 2024
  • Stream Kubernetes logs with Fluent Bit (Logs Classic)
  • Dynatrace Intelligence for Notebooks
  • Compute histogram summaries
Apr 08, 2024
  • Upgrade to the latest Dynatrace
Apr 01, 2024
  • Network configurations
  • Using network zones in Kubernetes
  • Auto-update for Dynatrace Operator
  • Manage Dynatrace deployments using GitOps
  • Ingest Kubernetes DNS logs from AWS
  • Azure Machine - Azure Arc
  • Azure OpenAI
  • Azure Recovery Services Vault
Mar 25, 2024
  • Threat hunting and forensics
Mar 14, 2024
  • Platform Engineering
  • Dynatrace use cases
  • Data Observability
  • Configure Envoy for Dynatrace
  • Log Monitoring in Kubernetes (Logs Classic)
  • Release validation
  • Infrastructure & Operations
  • Dynatrace Extensions Python SDK
  • Account configuration for Monaco account management
  • Instant Intrusion Response
  • Databases app
  • Email for Workflows
  • Event triggers for workflows
  • Predictive Kubernetes operations
  • Install Dynatrace Operator add-on for AWS Elastic Kubernetes Service (AWS EKS)
  • Deploy OneAgent using AWS Systems Manager Distributor
Jan 15, 2024
  • DQL examples for security data
  • Deployment API - GET the latest available ActiveGate image version
  • Manually instrument your application using OneAgent SDK for Android
  • Provision EdgeConnect for Dynatrace environment
Dec 18, 2023
  • Migrate ActiveGate extension
  • Migrate OneAgent extension
  • Manage users and groups with SAML in Dynatrace SaaS
Dec 04, 2023
  • Migrate from AWS built-in services to cloud services
  • Migrate from Azure built-in services to cloud services
Nov 22, 2023
  • Ownership app
  • Metrics API v2 - Best practices
  • Analyze and optimize query performance
  • DQL commands
  • Azure for Workflows
Nov 06, 2023
  • Troubleshooting Log Management and Analytics
  • Log ingestion warnings
  • Troubleshooting Log Monitoring Classic
  • Event analysis and correlation
  • Red Hat Ansible for Workflows
Oct 09, 2023
  • Guardian execution context
  • Effective customer support with session segmentation
  • Dynatrace Operator network configuration
  • Vulnerabilities API - POST remediation item tracking links
  • Service detection rules
  • Alert on common Kubernetes misconfigurations and detect anomalies with Kubernetes metrics
Sep 25, 2023
  • EdgeConnect parameters
Sep 18, 2023
  • OpenTelemetry troubleshooting
  • Metrics on Grail examples
  • Configure and deploy EdgeConnect
  • Collector Configuration
  • Collector deployment
  • OpenTelemetry Collector
  • Collector References
  • Troubleshooting RUM for custom applications
  • Troubleshooting RUM for mobile apps
  • Containerized ActiveGate volumes
  • Store the ActiveGate image in a private registry
  • Containerized ActiveGate configuration
  • Differences between containerized and host-based ActiveGates
  • ActiveGate container image
  • Batch OTLP requests
  • Transform OTLP gRPC
  • Collector use cases
  • Ingest data from Jaeger
  • Enrich from Kubernetes
  • Apply memory limits
  • Scrape data from Prometheus
  • Ingest data from Zipkin
  • Connecting log data to traces (Logs Classic)
  • PagerDuty for Workflows
  • Set up EdgeConnect
  • Unified service
Sep 04, 2023
  • Grail data model
  • Vulnerabilities API - POST mute vulnerabilities
  • Vulnerabilities API - POST unmute vulnerabilities
  • Vulnarabilities API - POST mute remediation items
  • Vulnerabilities API - POST unmute remediation items
  • Create anomaly detection metric
  • Creating log metric
  • Unified service
  • Amazon DynamoDB monitoring
  • Amazon EBS monitoring
  • AWS Lambda monitoring
  • Amazon RDS monitoring
  • Integrate on Google Cloud Functions .NET
  • Azure API Management Service monitoring
  • Azure Application Gateway monitoring
  • Azure Basic Load Balancer monitoring
  • Azure Cache for Redis monitoring
  • Azure Container App monitoring
  • Azure Container Apps Environment monitoring
  • Azure Cosmos DB Account (GlobalDocumentDB) monitoring
  • Azure Cosmos DB Account (MongoDB) monitoring
  • Azure Gateway Load Balancer monitoring
  • Azure IoT Hub monitoring
  • Azure SQL Database (DTU) monitoring
  • Azure SQL Database (vCore) monitoring
  • Azure SQL elastic pool (DTU) monitoring
  • Azure SQL elastic pool (vCore) monitoring
  • Azure SQL Server monitoring
  • Azure Standard Load Balancer monitoring
  • Trace .NET Lambda functions
Aug 14, 2023
  • Using OpenTelemetry with Dynatrace
  • User and error events
Aug 07, 2023
  • Open with
  • Performance
  • User permissions for workflows
  • Ingest OpenTelemetry traces
  • Attacks API
  • Security problems API - GET remediation item details
  • Security problems API - GET remediation item entities
  • Ingest OpenTelemetry metrics
Jul 31, 2023
  • Query monitored entities in Grail
  • DevSecOps Lifecycle Coverage with Snyk
  • Performance
Jul 24, 2023
  • Introduction to OpenTelemetry
  • Application Security FAQ
  • Tags and management zones for AWS integration
  • Limit API calls to Azure
  • Tags and management zones for Azure integration
Jul 17, 2023
  • Set up agentless Real User Monitoring
Jul 10, 2023
  • Ingest OpenTelemetry logs
Jun 26, 2023
  • Diagnostic messages for distributed traces
  • Analyze database services (new page)
  • Service analysis (classic page)
  • Service analysis (new page)
Jun 19, 2023
  • Monitor AWS Lambda
Jun 12, 2023
  • Dynatrace for AI Observability
  • Dynatrace for OpenAI Observability
  • Dynatrace for TensorFlow and Keras Observability
  • Dynatrace Intelligence DQL examples
  • JMX data source
  • JMX data source reference
Jun 05, 2023
  • Dedicated performance profile configuration
  • Forecast analysis
  • Migrate from Cloud Automation to Site Reliability Guardian
  • DPS subscription history
  • Use case - Setting log alert
May 15, 2023
  • Dynatrace Hub
  • Notebooks
  • Share documents
  • AppEngine
  • AutomationEngine
  • Upgrade from Managed to SaaS deployment
  • Navigate Dynatrace platform
  • Ownership app
  • Dashboards
  • Edit visualizations for Notebooks and Dashboards
  • Upgrading Log Monitoring
  • Built-in metrics on Grail
  • Data visualizations
  • DPS license management
  • AppEngine Functions (Serverless Functions) (DPS)
  • Application Security (DPS)
  • Automation (DPS)
  • Real User and Synthetic Monitoring (DPS)
  • Log Analytics (DPS)
  • Events powered by Grail (DPS)
  • Host monitoring (DPS)
  • Dynatrace Platform Subscription (DPS)
  • Platform extensions (DPS)
  • Adaptive Traffic Management for Dynatrace SaaS
  • Forecast analysis
  • DPL Architect
  • Site Reliability Guardian
  • Introduction to workflows
  • Business Flow
  • Carbon Impact
  • Explore Business Events
  • Salesforce Insights
  • Jira for Workflows
  • Slack for Workflows
  • Instrument mobile apps with Dynatrace .NET MAUI NuGet package
  • Containerized, auto-scalable private Synthetic locations on Kubernetes
  • Istio/Envoy proxy metrics
  • Monitor AWS resources based on tags
  • Monitor Azure resources based on tags
  • Host availability
  • OpenTelemetry interoperability
  • OpenTelemetry interoperability in Java
  • OpenTelemetry interoperability in Node.js
  • OpenTelemetry interoperability in Python
Apr 24, 2023
  • Manage IBM Database extensions
  • Manage MySQL extensions
  • Manage PostgreSQL extensions
  • Manage SAP Hana Database extensions
  • Manage Snowflake Database extensions
  • IBM Database monitoring configuration
  • MySQL monitoring configuration
  • PostgreSQL monitoring configuration
  • SAP Hana Database monitoring configuration
  • Snowflake Database monitoring configuration
  • Troubleshoot MV3-related issues in browser monitors
Apr 17, 2023
Apr 03, 2023
  • Assign ownership teams to monitored entities
  • Best practices for entity ownership
  • Ownership
  • Create and manage teams for entity ownership
Mar 27, 2023
  • OneAgent privileges for container monitoring
  • Get started with Android monitoring
Mar 08, 2023
  • Configuration as Code
  • Instrument C++ applications with OpenTelemetry Metrics
  • Stream Syslog to Dynatrace with Fluentd
  • Troubleshoot Azure monitoring setup
  • Monitor file access of CICS applications
Feb 20, 2023
  • Extension security
  • Hub items API
  • Get started with Vulnerability Analytics
  • Log dashboards strategies
  • Monitoring rules - Code-level Vulnerability Analytics
  • Filter or change status of code-level vulnerabilities
  • Code-level vulnerabilities
  • Application Security overview
  • Third-party vulnerabilities
Feb 06, 2023
  • Settings 2.0
  • Stream logs to Dynatrace with Fluent Bit
  • Log content transformation
  • Monitor service-level objectives in Kubernetes/OpenShift
  • Adjust Apdex settings for custom applications
  • Configure key user actions for custom applications
  • Adaptive Traffic Management for Dynatrace Managed
  • Configure key user actions for mobile applications
  • Create custom user action names for mobile applications
  • Adjust Apdex settings for web applications
  • Configure key user actions for web applications
  • Change user experience score thresholds for web applications
Jan 30, 2023
  • Configure Apdex settings
  • Configure user experience score thresholds
  • Context-based Apdex analysis
  • Create custom names for mobile user actions
  • Capture additional interaction types
Jan 23, 2023
  • Universally Unique Identifiers
  • DQL Use cases
Jan 09, 2023
  • Log Management and Analytics default limits
  • DQL matcher in logs
  • Log Management and Analytics use cases
  • Log ingestion API
  • Log ingestion via OneAgent
Dec 26, 2022
  • Get started with Application Security
  • Get started with Runtime Application Protection
  • Application Security and monitoring modes
  • How vulnerabilities are evaluated
  • Davis Security Advisor calculations
  • Manage third-party vulnerabilities
Dec 19, 2022
  • Business event metric extraction
  • Dynatrace Operator release notes
Dec 12, 2022
  • Monitor key requests
Dec 05, 2022
  • Security problems API - GET problem events
Nov 21, 2022
  • Event topology extraction and mapping
  • Cluster preferences settings
Nov 14, 2022
  • DQL Best practices
  • Positional Matchers
  • Configure OpenTelemetry metrics ingest
  • OpenTelemetry metrics
  • OpenTelemetry metrics in Dynatrace
  • Best practices for OpenTelemetry metrics
  • OpenTelemetry metrics ingest API
  • OpenTelemetry Metrics Limitations
  • Performance
  • OpenTelemetry traces FAQ
  • Send metrics via AWS Distro for OpenTelemetry
  • Send metrics via the Dynatrace OpenTelemetry metrics exporter
  • Send metrics via the OpenTelemetry collector
  • Send metrics via OTLP (OpenTelemetry Protocol) metrics exporter
  • Alert on common Kubernetes/OpenShift issues
Nov 07, 2022
  • Business events end-to-end use case
  • Check your application health
Oct 31, 2022
  • Dynatrace Grail
  • Business event analysis in Dynatrace
  • Basic concepts of Dynatrace Business Observability
  • Business event capture in Dynatrace
  • RUM business event enrichment
  • Business event processing in Dynatrace
  • Business Observability examples
  • Business Observability in Dynatrace
  • DQL compared to SQL and more
  • How to use DQL queries
  • DQL language reference
  • Dynatrace Query Language
  • Log buckets and retention
  • Log on Grail examples
  • Log powered by Grail processing
  • DQL commands
  • DQL data types
  • DQL functions
  • DQL operators
  • Sensitive data masking
  • Log timestamp configuration
  • Metric events for alerting
  • Metric key events
  • Metric selector events
  • Seasonal baseline for metric events
  • Migrate role-based permissions to Dynatrace IAM
Oct 24, 2022
  • Red Hat Quarkus monitoring
Oct 17, 2022
  • Credential vault API
  • Remote configuration management API
  • Log storage configuration
  • Merged services
  • Custom API definitions
Oct 10, 2022
  • DDUs for Log Management and Analytics
  • Reverse proxy or load balancer for OneAgent
  • ActiveGate plugin module custom configuration
  • Extension Execution Controller custom configuration
  • End-to-end guide for monitoring AWS services
  • Monitor Kubernetes/OpenShift services
Sep 26, 2022
  • OneAgent log ingest API
  • Monitor container groups
  • Monitor Google Cloud Run Managed
  • iOS configuration keys
  • Info.plist file
  • OneAgent for iOS auto-instrumentation features
Sep 19, 2022
  • Monitor custom JMX metrics on z/OS
Sep 08, 2022
  • Management-zone security and metrics
  • Multiple monitoring environments
  • ActiveGate group
  • Email integration for security notifications
  • Data safety form for Android
  • Delete your application
  • Cross-environment tracing
  • Out-of-memory (OOM) and out-of-threads (OOT) events and alerting
  • Settings API - GET effective values
  • Monitor vulnerabilities in Kubernetes/OpenShift
  • End-to-end guide for monitoring Azure services
  • Instrument SwiftUI controls
Jul 04, 2022
  • On-demand synthetic monitor executions for CI/CD
  • Instrument Node.js applications with OpenTelemetry Metrics
Jun 27, 2022
  • Sensitive data Masking
  • Set up Kubernetes/OpenShift monitoring with Helm
Jun 20, 2022
  • OpenTelemetry metric concepts
  • Best practices for OpenTelemetry traces
  • Instrument .NET applications with OpenTelemetry Metrics
  • Instrument Java applications with OpenTelemetry Metrics
Jun 13, 2022
  • Dynatrace Azure native integration
  • Azure Managed Instance for Apache Cassandra Monitoring
Jun 06, 2022
  • Authentication
  • Cloud Automation user permissions
  • Attack Protection rules
  • Attack Protection
  • Manage attacks
  • Manage code-level vulnerabilities
  • Log processing
  • Log processing examples
  • Integrate OpenTelemetry Node.js on Google Cloud Functions
  • Integrate OpenTelemetry on Google Cloud Functions
  • Dynatrace Pattern Language
May 30, 2022
  • Troubleshoot network monitoring
  • Log rotation patterns
  • Supported timestamp formats
  • Start/stop/restart a cluster
  • Start/stop/restart a node
May 23, 2022
  • Distribute custom dashboards with your extensions
  • Extend built-in unified analysis pages
  • Create specialized unified analysis pages
  • Message queues
  • Analyze queues
  • Queue concepts
  • IBM MQ tracing
  • Configure message queue monitoring
  • Queue tags and management zones
  • Cluster event notifications
  • Set up a load balancer for Dynatrace Managed
  • Integrate OpenTelemetry Node.js on Azure Functions consumption plan
May 16, 2022
  • Security problems API - GET vulnerable functions
  • Geographic regions API
  • Deployment options on Kubernetes/OpenShift
  • Dynatrace component permissions for Kubernetes/OpenShift
  • Configuration options for Dynatrace Operator on Kubernetes/OpenShift
  • DynaKube parameters for Dynatrace Operator on Kubernetes/OpenShift
  • Get started with Kubernetes/OpenShift monitoring
May 09, 2022
  • Troubleshoot sign-in issues
  • Stream logs to Dynatrace with Fluentd on Kubernetes
  • Stream logs to Dynatrace with Logstash
  • Set up request naming
May 02, 2022
  • Top database statements
  • Monitor persistent volume claims on Kubernetes
  • Monitor Google Cloud Functions
  • Monitor Azure Functions consumption plan
  • Integrate OpenTelemetry .NET on Azure Functions consumption plan
  • Integrate OpenTelemetry on Azure Functions consumption plan
  • Customize the zRemote module
Apr 25, 2022
  • Dynatrace license lifecycle
  • Log Monitoring
  • Log Monitoring FAQ
  • Log Monitoring default limits
  • Log data acquisition
  • Log Monitoring configuration
  • External vault integration
  • Manage Oracle Database extensions
  • SQL data source
  • Oracle Database monitoring configuration
Apr 18, 2022
  • Send logs to Dynatrace with Fluentd
  • Extend Dynatrace with domain-specific web UI
  • Customize data with extensions
  • Distributed tracing powered by PurePath® technology
  • Metrics API FAQ
  • Manage SNMP extensions
  • Manage WMI extensions
  • OpenTelemetry Glossary
  • OpenTelemetry basics
  • OpenTelemetry Protocol (OTLP) specification
  • Troubleshoot Data Explorer
  • Manage Prometheus extensions
  • OpenTelemetry automatic and manual instrumentation
  • OpenTelemetry context propagation
  • OpenTelemetry data capture and span privacy settings
  • OpenTelemetry exceptions and error handling
  • OpenTelemetry trace concepts
  • OpenTelemetry span kind
  • IBM MQ tracing
Apr 04, 2022
  • Metric units API - GET convert units
  • Process availability
  • Process group detection
  • Deployment API - View the latest OneAgent version for AWS Lambda
  • Deployment API - View process module configuration for OneAgent
  • Configure RUM cookie domain
  • Real User Monitoring for process groups
  • Link cross-origin XHR user actions and their PurePaths
Mar 28, 2022
  • Trace Google Cloud Functions with OpenTelemetry Go
  • Trace Google Cloud Functions with OpenTelemetry JS
  • Trace Azure Functions with OpenTelemetry .NET
Mar 21, 2022
  • Data protection at Dynatrace
  • Configure Session Replay on crashes for Android
Mar 07, 2022
  • Problem lifecycle and important timings
  • Default AWS metrics
  • Default Azure metrics
Feb 28, 2022
  • Authentication
  • Cloud Automation configuration
  • Set up Cloud Automation
  • Cloud Automation requirements
Feb 21, 2022
  • Extended network monitoring
  • Metric units API
  • SLO management with management-zone permissions
  • OpenTelemetry trace ingest API
Feb 15, 2022
  • Serverless compute support matrix
  • TLS 1.0 and 1.1 end-of-support for RUM data
  • Cloud provider log forwarding
  • Metric ingestion protocol
  • Instrument Erlang/Elixir applications with OpenTelemetry
  • Instrument Go applications with OpenTelemetry
  • Set up Kubernetes monitoring with Helm
  • Set up OpenShift monitoring with Helm
  • Send Micrometer metrics to Dynatrace
  • Leverage user action and user session properties for mobile and custom apps
  • Leverage user action and user session properties for web applications
  • Define user action and user session properties for custom apps
  • AWS Lambda log enrichment with OpenTelemetry
  • Define user action and user session properties for mobile apps
  • Define user action and user session properties for web applications
Jan 24, 2022
  • Unregister Managed cluster
  • Google Virtual Private Cloud monitoring
  • Google reCAPTCHA Enterprise monitoring
  • Google Network Topology monitoring
  • Google Network Security monitoring
  • NetApp on Google Cloud monitoring
  • Google Memorystore monitoring
  • Google Managed Microsoft AD monitoring
  • Google Cloud supported service metrics
  • Google Hybrid Connectivity monitoring
  • Google Kubernetes Engine monitoring
  • Google Cloud SQL monitoring
  • Google Firebase monitoring
  • Google Filestore monitoring
  • Google Firestore in Datastore mode monitoring
  • Google Dataproc monitoring
  • Google Dataflow monitoring
  • Google Cloud Data Loss Prevention monitoring
  • Google Compute Engine monitoring
  • Google Cloud Tasks monitoring
  • Google Cloud Storage Transfer Service monitoring
  • Google Cloud Storage monitoring
  • Google Cloud Spanner monitoring
  • Google Cloud Run monitoring
  • Google Cloud Router monitoring
  • Google Cloud Pub/Sub monitoring
  • Google Cloud Pub/Sub Lite monitoring
  • Google Cloud Operations suite monitoring
  • Google Cloud Load Balancing monitoring
  • Google Cloud IoT Core monitoring
  • Google Cloud Functions monitoring
  • Google Cloud Firestore monitoring
  • Google Cloud DNS monitoring
  • Google Cloud Composer monitoring
  • Google Cloud Bigtable monitoring
  • Google BigQuery monitoring
  • Google Assistant Smart Home monitoring
  • Google App Engine monitoring
  • Google APIs monitoring
  • Google Apigee monitoring
  • Google AI Platform monitoring
  • Dynatrace GCP Function helm deployment role
  • Alternative deployment scenarios
  • Deploy the Dynatrace GCP metric integration in GCP Cloud Function
  • Migrate to GCP integration version 1.0
Jan 17, 2022
  • Jira integration for security problem notifications
  • Log analysis with PurePath
  • Update log events per cluster for Log Monitoring
  • Enable Log Monitoring
  • Get Log Monitoring status
  • Troubleshoot Log Monitoring
  • Log Monitoring
Dec 20, 2021
  • Set up Azure log forwarding
Dec 13, 2021
  • Self-monitoring metrics
  • ActiveGate tokens API
Dec 06, 2021
  • Stream logs to Dynatrace with FluentD on OpenShift
  • Migrate to Dynatrace Operator - OpenShift
  • Deploy OneAgent on OpenShift for application-only monitoring
  • Stream logs to Dynatrace with FluentD on Kubernetes
  • Migrate to Dynatrace Operator - Kubernetes
  • Deploy OneAgent on Kubernetes for application-only monitoring
  • Create custom metrics from user sessions
Nov 29, 2021
  • Diagnostic archives for Dynatrace Managed installations
  • Organize your environment using host groups
Nov 22, 2021
  • Private self-monitoring environment
  • Local self-monitoring environment
  • Hosted self-monitoring environment
  • Self-monitoring
  • Set up metric events for alerting
  • Set up integration with Azure Monitor
  • Set up monitoring notifications with Azure Alerts
  • Set up Azure monitoring
  • Amazon MQ monitoring
  • Remediation tracking
  • Create Prometheus extension
  • Security problems API - PUT mute status of a remediation item
  • Security problems API - GET list remediation items
  • Events API v2 - POST an event
Nov 08, 2021
  • Webhook integration
  • Send data to Dynatrace with OpenTelemetry
Oct 11, 2021
  • Application Security metrics
Sep 27, 2021
  • Set up generic log ingestion for the Dynatrace integration in Google Kubernetes Engine (GKE)
  • Prerequisites for the Dynatrace integration in Google Kubernetes Engine (GKE)
  • Parameters for Dynatrace integration with Google Kubernetes Engine (GKE)
  • Set up the Dynatrace GCP function in a Kubernetes container (GKE)
  • deploy Dynatrace integration in Google Kubernetes Engine (GKE)
Sep 20, 2021
  • Update user
  • Create users
  • Create user
  • Get users
  • Get user
  • Delete user
  • ActiveGate diagnostics
  • Manage vulnerabilities
Sep 06, 2021
  • Integrate OneAgent with Azure Spring Apps
Aug 30, 2021
  • Troubleshoot monitoring issues for AWS Lambda
  • OpenTelemetry interoperability on AWS Lambda
  • Deploy OneAgent on AWS Lambda container images
  • Deploy OneAgent as AWS Lambda extension
  • Integrate OneAgent on AWS Lambda
Aug 23, 2021
  • Instrument hybrid apps
  • "New: User session analysis"
  • Log events
  • Log custom attributes
  • Azure SQL Data Warehouse (legacy)
  • Events API v2
Aug 16, 2021
  • AWS App Runner monitoring
Aug 09, 2021
  • Enable or disable SELinux
Jul 26, 2021
  • DDUs for custom Davis events
  • DDUs for custom traces (Trace API)
  • Ingest OpenTelemetry trace data
  • Metric selector in custom metric events
  • Security-monitoring rules
Jul 19, 2021
  • Cloud Automation
Jul 12, 2021
  • Get started with Cloud Automation quality gates
  • Cloud Automation FAQ
  • Before you begin with Cloud Automation quality gates]
  • Cloud Automation
  • Dynatrace menu
Jun 28, 2021
  • Manage private Synthetic locations
Jun 21, 2021
  • Monitoring consumption
Jun 14, 2021
  • Set up AWS log forwarding
Jun 07, 2021
  • Deploy ActiveGate in a VM for OpenShift monitoring
  • Deploy ActiveGate in a VM for Kubernetes monitoring
  • Add log sources
May 31, 2021
  • Best practices for scaling tagging and management-zone rules
  • Declarative process grouping
  • Management zones and Log Monitoring
  • Custom metric metadata
May 24, 2021
  • Cluster node capabilities
  • Configure cluster nodes responsibilities
  • Get cluster nodes configuration
  • Get cluster nodes configuration request status
  • Get cluster nodes configuration current status
  • Get cluster information about known cluster nodes
  • Cluster API v1
  • OpenTelemetry metric ingestion
  • Log Monitoring API v2 - POST ingest logs
  • Log viewer
  • Log metrics
  • Generic Log Ingestion
  • Log Monitoring
  • Log Monitoring
  • Metrics API - Metric expressions
May 10, 2021
  • Extensions 2.0 concepts
  • Extensions 2.0 hands-on exercise
  • Create extension YAML file
  • Manage Extensions 2.0 lifecyle
  • Export extension assets
  • Sign extension
  • Create WMI extension
  • Create SNMP extension
May 04, 2021
  • Monitor Prometheus metrics
  • Integrate Amazon CloudWatch Metric Streams
  • Update Dynatrace Managed
  • Estimate cluster backup size
  • Version detection strategies
  • Monitor releases with Dynatrace
  • Issue-tracking integration
  • Enrich metrics with Dynatrace-specific dimensions
  • Davis Security Score calculations
  • Release monitoring
Apr 26, 2021
Apr 19, 2021
  • Azure SQL Database Hyperscale monitoring
  • Google Cloud supported service monitoring
  • Accessibility
  • Topology model
Apr 12, 2021
  • IAM services reference
  • Manage IAM policies
  • Manage group permissions with IAM policies
  • Manage policies and groups with Dynatrace IAM
Apr 06, 2021
  • Adaptive Data Retention
  • Deploy ActiveGate in OpenShift as a StatefulSet
  • OpenShift deployment overview
  • Deploy ActiveGate in Kubernetes as a StatefulSet
  • Kubernetes deployment overview
  • Calculated metrics for services
  • Service analysis
  • User session analysis (new)
  • User details
  • Multidimensional analysis
Mar 22, 2021
  • Trello integration
  • Get started with Extensions
Mar 15, 2021
  • Troubleshoot Google Cloud monitoring setup
  • Deploy Dynatrace integration using a Google Cloud function
  • Monitor your Google Cloud services with Dynatrace
  • Share dashboards
  • Global dashboard settings
  • Preset dashboards
  • Edit dashboard JSON
  • Pin tiles to your dashboard
  • Available tiles
Mar 08, 2021
  • Instrument mobile app with Dynatrace Xamarin NuGet Package
  • Rack-aware Managed deployment
  • Rack-aware conversion using restore
  • Rack-aware conversion using replication
  • Rotate tenant token
  • Missing data alert for custom metric events
  • Advanced metric queries for custom metric events
  • Metrics browser
  • Tenant tokens API
Feb 22, 2021
  • Metrics API - Metric selector transformation
Feb 15, 2021
  • Limit VMware infrastructure monitoring using permissions
  • Sign-in page customization
Feb 08, 2021
  • Memory dump analysis
Jan 25, 2021
Jan 18, 2021
  • Deploy OneAgent on AWS Fargate
  • Failure detection API
Jan 04, 2021
  • Store cluster SSL certificate
  • Get cluster SSL certificate storage status
  • Get cluster SSL certificate details
Dec 28, 2020
  • Enable Session Replay on crashes
Dec 14, 2020
  • Store Dynatrace images in private registries - OpenShift
  • Store Dynatrace images in private registries - Kubernetes
  • HTTP monitor metrics
  • Synthetic details for HTTP monitors
  • Monitor Application Security
  • Service-level objectives
  • Environment API v2 - Entity selector
  • Service-level objectives API
  • AWS PrivateLink API
Dec 07, 2020
  • Deploy OneAgent as Lambda extension
  • User privacy for iOS
Nov 30, 2020
  • ServiceNow integration
Nov 23, 2020
  • OneAgent security on Windows
  • OneAgent security on Linux
  • OneAgent security on AIX
  • OneAgent file aging mechanism
  • Update cluster password policy
  • Get cluster password policy
  • Test cluster proxy configuration
  • HA - Test proxy configuration from specific data center
  • Set or update cluster proxy configuration
  • HA - Set or update proxy configuration for specific data center
  • Get cluster proxy configuration
  • HA - Get proxy configuration for specific data center
  • HA - Get proxy configurations for all data centers
  • Delete cluster proxy configuration
  • HA - Delete proxy configuration in specific data center
  • Service detection rules API
  • Mobile and custom app API
Nov 16, 2020
  • Export licensing data
  • Export license data
  • Access tokens
  • Dynatrace API - Tokens and authentication
Nov 09, 2020
  • Synthetic locations API v2 - PUT a location
  • Synthetic locations API v2 - POST a location
  • Synthetic nodes API v2 - GET a node
  • Synthetic nodes API v2 - GET all nodes
  • Synthetic locations API v2 - GET all locations
  • Synthetic locations API v2 - GET a location
  • Synthetic locations API v2 - DELETE a location
  • Public Synthetic locations
  • Top web requests
Nov 02, 2020
  • OneAgent diagnostics
Oct 26, 2020
  • Monitor OpenShift metrics
  • Monitor Kubernetes metrics
  • Amazon VPC NAT Gateways
  • Amazon Simple Storage Service (S3)
  • Amazon Simple Queue Service (SQS)
  • Amazon Simple Notification Service (SNS)
  • Amazon Simple Email Service (SES)
  • Amazon SageMaker (Batch Transform Jobs, Endpoint Instances, Endpoints, Ground Truth, Processing Jobs, Training Jobs)
  • Amazon Redshift
  • Amazon Kinesis (Data Analytics, Data Firehose, Data Streams, Video Streams)
  • AWS IoT
  • AWS Glue
  • Amazon Elasticsearch Service (ES)
  • Amazon ElastiCache
  • Amazon Elastic MapReduce (EMR)
  • Amazon Elastic File System (EFS)
  • Amazon Elastic Container Service (ECS)
  • Amazon EC2 Spot Fleet
  • Amazon Cognito
  • Amazon CloudFront
  • Amazon Aurora
  • Amazon API Gateway
Oct 19, 2020
  • Integrate OneAgent on Web App for Containers
  • Amazon Inspector
  • AWS Billing
  • Telegraf
  • DynatraceStatsD
  • Metric scripting integration
  • OneAgent metric API
  • Metric ingestion
  • Problems API v2
Oct 12, 2020
  • Web application configuration API
  • Geographic regions - IP mapping headers API
  • Geographic regions - IP address mapping rules API
  • Content resources API
  • Allowed beacon domains API
Oct 05, 2020
  • Azure Web Application Firewall (WAF) Policy on Azure CDN
  • Azure Time Series Insights (Environment, Event Source)
  • Azure Stream Analytics
  • Azure Storage Sync
  • Azure Network Watcher (Connection Monitor, Connection Monitor Preview)
  • Azure DNS Zone
  • Azure Device Provisioning Service (DPS)
  • Azure Data Share
  • Azure Data Explorer
  • Azure AI - Translator
  • Azure AI - Text Analytics
  • Azure AI - Speech
  • Azure AI - QnA Maker
  • Azure AI - Personalizer
  • Azure AI - Language Understanding (LUIS)
  • Azure AI - Language Understanding (LUIS) Authoring
  • Azure AI - Ink Recognizer
  • Azure AI - Immersive Reader
  • Azure AI - Face
  • Azure AI - Custom Vision Training
  • Azure AI - Custom Vision Prediction
  • Azure AI - Content Moderator
  • Azure AI - Computer Vision
  • Azure AI - Bing Spell Check
  • Azure AI - Bing Search
  • Azure AI - Bing Entity Search
  • Azure AI - Bing Custom Search
  • Azure AI - Bing Autosuggest
  • Azure AI - Anomaly Detector
  • Azure AI - All In One
  • Azure Blockchain
  • Azure Application Insights
  • Azure Synapse Analytics (Synapse Workspace, Apache Spark pool, SQL pool)
  • Azure App Service (App Service Plan, Web App Deployment Slot)
  • AWS WAF
  • AWS Trusted Advisor
  • Amazon Translate
  • Amazon Textract
  • AWS Service Catalog
  • Amazon MSK (Kafka)
  • Amazon Lex
  • Amazon Keyspaces (Cassandra)
  • AWS IoT Things Graph
  • AWS IoT Analytics
  • Amazon GameLift
  • AWS Elemental MediaPackage (Live)
  • Amazon ECS Container Insights
  • Amazon EC2 API
  • Amazon DocumentDB (with MongoDB compatibility)
  • AWS DataSync
  • AWS API Usage
  • Amazon CloudSearch
  • Amazon Athena
Sep 28, 2020
  • Metrics ingestion protocol
  • Built-in metrics - SaaS
  • Built-in metrics - Managed
  • Metric ingestion
  • Metrics API - POST ingest data points
Sep 21, 2020
  • Data Explorer
Sep 14, 2020
  • Azure Relay
  • Azure Power BI
  • Azure Notification Hub
  • Azure Mesh Application
  • Azure Media Services
  • Azure Key Vault
  • Azure IoT Central Applications
  • Azure Container Registry
  • Azure App Configuration
  • AWS Transit Gateway
  • AWS Systems Manager Run Command
  • Amazon Simple Workflow Service (SWF)
  • Amazon Route 53
  • Amazon Route 53 Resolver
  • AWS OpsWorks
  • Amazon MQ
  • AWS Elastic Beanstalk
  • AWS Direct Connect
  • AWS CodeBuild
  • Amazon CloudWatch Logs
  • AWS Chatbot
  • Amazon AppStream 2.0
  • Rebuild data center
  • Disaster recovery from backup
  • Disaster recovery
  • Exclude disks and network traffic from host monitoring
Sep 07, 2020
  • Supported authentication methods in Synthetic Monitoring
Aug 31, 2020
  • Management zone rules
Aug 24, 2020
  • Azure Storage Account Classic (Blob, File, Queue, Table)
  • Azure Spring Apps
  • Azure SignalR
  • Azure NetApp Files
  • Azure Machine Learning
  • Azure Integration Service Environment
  • Azure ExpressRoute Circuit
  • Amazon WorkSpaces
  • Amazon WorkMail
  • AWS WAF Classic
  • AWS Transfer Family
  • AWS Storage Gateway
  • AWS Step Functions
  • Amazon Rekognition
  • Amazon Neptune
  • Amazon FSx
  • AWS Elemental MediaTailor
  • AWS Elemental MediaConvert
  • AWS Elemental MediaConnect
  • Amazon Elastic Transcoder
  • Amazon Elastic Inference
  • Amazon EC2 Auto Scaling
  • Amazon DynamoDB
  • AWS Database Migration Service
  • Amazon Connect
  • AWS CloudHSM (V2)
  • AWS AppSync
  • Service analysis timings
Aug 17, 2020
  • DNS configuration for Dynatrace Managed
Aug 10, 2020
  • Azure Search Service
  • Azure Public IP Address
  • Azure Private DNS Zone
  • Azure Network Interface
  • Azure Maps Account
  • Azure Logic Apps
  • Azure Firewall
  • Azure Event Hubs (Clusters)
  • Azure Event Grid (Domain, Topic, System Topic)
  • Azure Data Lake Storage Gen1
  • Azure Data Lake Analytics
  • Azure Data Factory (V1, V2)
  • Azure Container Instances
  • Azure Automation Account
  • Host availability
Aug 03, 2020
  • AWS VPN
  • AWS RoboMaker
  • Amazon QLDB
  • Amazon Polly
  • Amazon EventBridge
  • Amazon EKS
  • Amazon supporting services
Jul 27, 2020
  • Configure custom SSL certificate on ActiveGate
  • Static thresholds for custom metric events
  • Auto-adaptive baselining for custom metric events
  • Alerting rules evaluation
Jul 20, 2020
  • Managed system requirements
  • Managed hardware requirements
Jul 13, 2020
  • Azure Virtual Network Gateway
  • Azure Virtual Machines (classic)
  • Azure Traffic Manager
  • Azure SQL Managed Instance
  • Azure HDInsight
  • Azure Front Door
  • Azure Database for PostgreSQL
  • Azure Database for MySQL
  • Azure Database for MariaDB
  • Azure Batch
  • Azure Services monitoring
  • Managed hardware recommendations for cloud deployments
  • Data privacy and exchange in Managed deployments
  • Calculate Dynatrace monitoring consumption
  • Synthetic calculations
  • Secure development controls
Jul 06, 2020
  • Download OneAgent to z/OS
  • Add second data center
  • Managed deployment scenarios
  • Dynatrace Managed multi-data-center
Jun 29, 2020
Jun 22, 2020
  • Automated injection of deep-code monitoring on AIX
  • Deploy OneAgent on OpenShift via OperatorHub
  • Tibco EMS
  • Real User Monitoring browser extension API
Jun 15, 2020
  • Deploy OneAgent on AWS Elastic Beanstalk
  • OneAgent configuration via command-line interface
  • Supported connectivity schemes for ActiveGates
  • Network zones
  • Network zones API
Jun 08, 2020
  • Deploy OneAgent Operator on OpenShift
  • Deploy OneAgent Operator on Kubernetes
  • Okta SCIM configuration for Dynatrace
  • Azure SCIM configuration for Dynatrace
  • Manage users and groups with SCIM in Dynatrace SaaS
Jun 01, 2020
  • Deploy OneAgent on Elastic Container Service
May 25, 2020
  • Elastic Kubernetes Service
May 18, 2020
  • Monitor your Kubernetes clusters with Dynatrace
  • OneAgent extensions tutorial
  • Customize JMX extensions
May 11, 2020
  • Migrate OneAgent Operator to a new Dynatrace OpenShift tenant
  • Migrate OneAgent Operator to a new Dynatrace Kubernetes tenant
May 04, 2020
  • Data security controls
Apr 27, 2020
  • Application detection rules
Apr 14, 2020
  • Monitor OpenShift workloads and cloud applications
  • Monitor Kubernetes workloads and cloud applications
  • Configure and manage user sessions
  • Update cluster user sessions configuration
  • Get cluster user sessions
  • Get cluster user sessions configuration
  • Delete user sessions of a given user
  • Change state of access request
  • Grant remote access permission
  • Get cluster access request
  • Get all cluster access requests
  • Search patterns in log data and parse results
Related tags
Dynatrace Platform
