Trace .NET Lambda functions
  • 9min
Dynatrace uses OpenTelemetry to monitor AWS Lambda invocations.
Prerequisites
Ensure that you use a supported AWS Lambda runtime and that you have followed the initial configuration steps described in Monitor AWS Lambda with OpenTelemetry before using the packages below.
The following NuGet packages can be used to cover different aspects of AWS Lambda tracing:
  • recommended OpenTelemetry.Instrumentation.AWSLambda version 1.2.0-beta.1+—contains methods to trace incoming AWS Lambda invocations, such as calls triggered by AWS SQS/SNS messages.
  • recommended OpenTelemetry.Instrumentation.AWS version 1.1.0-beta.1+—traces outgoing AWS SDK calls to other AWS Lambda invocations and calls to AWS services, such as DynamoDB, SQS, and SNS.
  • required Dynatrace.OpenTelemetry.Instrumentation.AwsLambda—enables linking through outgoing AWS Lambda Invoke SDK calls from one Lambda to another. This is the only way to link these kinds of requests; however, if you don't need such linking or don't use the AWS Lambda client SDK to invoke or receive other Lambda invocations, you can replace the package with Dynatrace.OpenTelemetry.
Installation
Any of the above-listed packages can be installed via the CLI. For example, Dynatrace.OpenTelemetry.Instrumentation.AwsLambda can be installed using the following command:
dotnet add package Dynatrace.OpenTelemetry.Instrumentation.AwsLambda
Some packages may require you to specify a version explicitly or use the --prerelease command line flag, such as dotnet add package --prerelease OpenTelemetry.Instrumentation.AWSLambda.
Compatibility with OpenTelemetry and System.Diagnostics.DiagnosticSource versions
Periodically, we need to upgrade the minimum version of the OpenTelemetry NuGet package our components depend on, and consequently, the minimum version of the System.Diagnostics.DiagnosticSource library. This table lists the compatibility between Dynatrace.OpenTelemetry, OpenTelemetry, and System.Diagnostics.DiagnosticSource versions.
Dynatrace.OpenTelemetry version
Minimum OpenTelemetry version
Minimum System.Diagnostics.DiagnosticSource version
1.273 and earlier
1.1.0
5.0.1
1.275+
1.3.1
6.0.0
You don't usually need to worry about these dependencies as they're defined for you in our NuGet package. This means that when you upgrade Dynatrace.OpenTelemetry, NuGet might implicitly upgrade your OpenTelemetry or System.Diagnostics.DiagnosticSource version if you are currently on an earlier one.
Initialization
The initialization code for AWS Lambda tracing in your Function.cs file could look as follows (where Function is the configured Lambda handler class):
using System.Threading.Tasks;
using Amazon.Lambda.Core;
using Dynatrace.OpenTelemetry;
using Dynatrace.OpenTelemetry.Instrumentation.AwsLambda;
using OpenTelemetry;
using OpenTelemetry.Instrumentation.AWSLambda;
using OpenTelemetry.Trace;
[assembly: LambdaSerializer(typeof(Amazon.Lambda.Serialization.SystemTextJson.DefaultLambdaJsonSerializer))]
namespace Examples.AwsFunctionApp
public class Function
private static readonly TracerProvider TracerProvider;
static Function()
DynatraceSetup.InitializeLogging();
TracerProvider = Sdk.CreateTracerProviderBuilder()
.AddDynatrace()
// Configures AWS Lambda invocations tracing
.AddAWSLambdaConfigurations(c => c.DisableAwsXRayContextExtraction = true)
// Instrumentation for creation of span (Activity) representing AWS SDK call.
// Can be omitted if there are no outgoing AWS SDK calls to other AWS Lambdas and/or calls to AWS services like DynamoDB and SQS.
.AddAWSInstrumentation(c => c.SuppressDownstreamInstrumentation = true)
// Adds injection of Dynatrace-specific context information in certain SDK calls (e.g. Lambda Invoke).
// Can be omitted if there are no outgoing calls to other Lambdas via the AWS Lambda SDK.
.AddDynatraceAwsSdkInjection()
.Build();
  • Setting the option DisableAwsXRayContextExtraction to true is required to skip Amazon X-Ray parent extraction, which may conflict with the Dynatrace propagation.
  • If the option SuppressDownstreamInstrumentation is set to true, HTTP child nodes will not be shown under AWS SDK calls.
Tracing incoming AWS Lambda calls
Example 1: Trace an AWS Lambda invoked via AWS SDK
In addition to the initialization part provided above, the handler method of a Lambda invoked via AWS SDK could look as follows:
// Use initialization code from the "Initialization" section of the docs
public Task FunctionHandlerAsync(object input, ILambdaContext context)
var propagationContext = AwsLambdaHelpers.ExtractPropagationContext(context);
return AWSLambdaWrapper.TraceAsync(TracerProvider, FunctionHandlerInternalAsync, input, context, propagationContext.ActivityContext);
private Task FunctionHandlerInternalAsync(object input, ILambdaContext context)
// This is just an example of function handler and should be replaced by actual code.
return Task.CompletedTask;
  • A parent context is extracted explicitly using the AwsLambdaHelpers class from the Dynatrace.OpenTelemetry.Instrumentation.AwsLambda package.
  • An activity tracing the incoming request and the handler is created by the TraceAsync method.
  • TraceAsync should be used when you trace an async function or a function returning a task. That way, the activity ends only when the task completes.
Example 2: Trace an AWS Lambda invoked via Amazon API Gateway (incoming HTTP request)
In addition to the initialization part provided above, the Lambda handler invoked via Amazon API Gateway could look as follows:
using Amazon.Lambda.APIGatewayEvents;
public APIGatewayHttpApiV2ProxyResponse FunctionHandler(APIGatewayHttpApiV2ProxyRequest request, ILambdaContext context)
return AWSLambdaWrapper.Trace(TracerProvider, FunctionHandlerInternal, request, context);
private APIGatewayHttpApiV2ProxyResponse FunctionHandlerInternal(APIGatewayHttpApiV2ProxyRequest request, ILambdaContext context)
return new APIGatewayHttpApiV2ProxyResponse
StatusCode = 200,
Body = "Example function result",
  • A parent context is extracted from the incoming request in the Trace (or TraceAsync) method.
  • An activity tracing the incoming request and the handler is created by the Trace method.
  • In general, the Trace/TraceAsync methods support any trigger, but extended support is available for the APIGatewayProxyRequest and APIGatewayHttpApiV2ProxyRequest trigger types. For more details about request/response types, consult the GitHub documentation.
  • Trace should only be used when you have a function returning something other than a Task. For the asynchronous handler, TraceAsync should be used instead.
Example 3: Tracing without the AwsLambda package
If you prefer not to use the OpenTelemetry.Instrumentation.AWSLambda package, you can manually create an activity for Lambda. Note that this involves quite a bit of work, as Dynatrace requires certain activity tags (span attributes) to detect the service (conforming to the OpenTelemetry FaaS trace conventions and resource conventions). You also need to manually extract the parent context.
For this example, only the Dynatrace.OpenTelemetry.Instrumentation.AwsLambda package is required.
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.Reflection;
using OpenTelemetry.Context.Propagation;
private static readonly ActivitySource ActivitySource;
static Function()
var activitySourceName = Assembly.GetExecutingAssembly().GetName().Name;
ActivitySource = new ActivitySource(activitySourceName);
.AddSource(activitySourceName)
.AddDynatrace()
.Build();
public static IEnumerable<KeyValuePair<string, object>> GetFunctionTags(ILambdaContext context, string trigger)
return new KeyValuePair<string, object>[]
new("faas.name", context.FunctionName),
new("faas.id", context.InvokedFunctionArn),
new("faas.trigger", trigger),
new("cloud.platform", "aws_lambda"),
new("cloud.provider", "aws"),
new("cloud.region", Environment.GetEnvironmentVariable("AWS_REGION")),
public APIGatewayProxyResponse FunctionHandler(APIGatewayHttpApiV2ProxyRequest apiGatewayProxyEvent, ILambdaContext context)
try
var parentContext = ExtractParentContext(apiGatewayProxyEvent, context);
using var activity = ActivitySource.StartActivity(ActivityKind.Server, parentContext, GetFunctionTags(context, "http"));
return new APIGatewayProxyResponse
StatusCode = 200,
catch (Exception ex)
context.Logger.LogLine($"Exception occurred while handling request: {ex.Message}");
throw;
finally
TracerProvider?.ForceFlush();
private static ActivityContext ExtractParentContext(APIGatewayHttpApiV2ProxyRequest apiGatewayProxyEvent, ILambdaContext context)
if (propagationContext == default)
propagationContext = Propagators.DefaultTextMapPropagator.Extract(default, apiGatewayProxyEvent, HeaderValuesGetter);
return propagationContext.ActivityContext;
private static IEnumerable<string> HeaderValuesGetter(APIGatewayHttpApiV2ProxyRequest apiGatewayProxyEvent, string name) =>
(apiGatewayProxyEvent.Headers != null && apiGatewayProxyEvent.Headers.TryGetValue(name.ToLowerInvariant(), out var value)) ? new[] { value } : null;
Tracing AWS SDK calls
You can use open-source instrumentation NuGet packages to trace Amazon DynamoDB calls using client like AmazonDynamoDBClient or SQS and SNS calls using clients like AmazonSQSClientor AmazonSimpleNotificationServiceClient.
To set up tracing of AWS SDK calls,
  1. Make sure that the following packages are added to your project:
    • OpenTelemetry.Instrumentation.AWSLambda
    To learn more about the packages, see Prerequisites
  2. After you add packages to your project, add the following initialization code:
    static Function()
    .AddDynatrace()
    c.DisableAwsXRayContextExtraction = true;
    c.SetParentFromBatch = true;
    // Instrumentation used for tracing outgoing calls to AWS services via AWS SDK (including Amazon DynamoDB, SQS/SNS).
    // Can be omitted if no outgoing AWS SDK calls expected.
    .Build();
    • SuppressDownstreamInstrumentation
      When set to true, HTTP child nodes will not be shown under AWS SDK calls.
    • SQS SetParentFromBatch
      It controls whether the parent Activity should be set when a potentially batched event is received where multiple parents would be available (e.g. SQS). When set to true the parent is set using one of the received messages. Else, the parent is not set. In both cases, links will be created.
    • DisableAwsXRayContextExtraction
      We reccomend to set it to true to skip Amazon X-Ray parent extraction and avoid conflicts with the Dynatrace propagation.
Tracing of Amazon DynamoDB operations
To trace Amazon DynamoDB calls, set up AWS SDK instrumentation. No additional code is required.
In the following example, the DynamoDB operations DescribeTable, UpdateItem, and GetItem are represented as separate span child nodes with a common parent outbound-aws-dotnet in eu-central-1 (Lambda function performing DynamoDB operations):
AWS Lambda .NET DynamoDB spans
Tracing of outgoing SQS/SNS messages
To trace outgoing SQS/SNS messages, set up AWS SDK instrumentation. No additional code is required.
Tracing of incoming SQS/SNS messages
To trace incoming SQS/SNS messages,
  1. Set up AWS SDK instrumentation.
  2. Wrap the function handler into one of the tracing methods of the AWSLambdaWrapper class:
using Amazon.Lambda.SQSEvents;
static Function()
// See "Set up tracing for AWS SDK calls" section above.
public Task Handler(SQSEvent sqsEvent, ILambdaContext context) =>
AWSLambdaWrapper.TraceAsync(tracerProvider, HandlerInternal, sqsEvent, context);
private Task HandlerInternal(SQSEvent sqsEvent, ILambdaContext context)
// This is just an example of async function handler and it should be replaced by actual code.
Special considerations for HttpClient instrumentation
Because with AWS Lambda the function execution environment might be suspended at any time after the function handler execution, the span export might be interrupted or delayed (for example, in some cases, the span might not be exported at all) and outgoing HTTP requests will typically appear only with the next function invocation.
However, outgoing HTTP request activities related to AWS Runtime API might be captured by OpenTelemetry HttpClient instrumentation in the current function invocation, even if unexpected. To avoid unexpected outgoing HTTP requests in the current function invocation, we recommend configuring the following filter when initializing the HttpClient instrumentation.
var tracerProvider = Sdk.CreateTracerProviderBuilder()
// Initialization code similar to previous examples...
.AddHttpClientInstrumentation(op =>
op.FilterHttpRequestMessage = req => Activity.Current?.Parent?.IsAllDataRequested ?? false;
.Build();
Support of .NET Lambda functions with container images
Starting from .NET 6, Lambda functions can be built and deployed as container images. Initialization and tracing for Managed .NET runtime apply to container image functions without any changes.
