This page refers to classic dashboards created using the
Dashboards Classic functionality integrated with Dynatrace Classic.
Dashboards app in the latest Dynatrace, see Dashboards for related documentation.
Dashboards app in the latest Dynatrace.You can automatically create a new dashboard tile from any Dynatrace page that includes a Pin to dashboard button. All you need is edit permission for the dashboard. In this example, we create a new dashboard, so you are guaranteed to have edit permission.
We start by creating an empty dashboard.
Dashboards Classic.Filtered Dashboard), and select Create.Filtered Dashboard.Now we create a tile based on a filtered view of the Hosts page and pin the tile to the empty dashboard.
Go to
Hosts Classic.
Set a filter on the list. In this example, we set Data center: GdaĆsk, Poland.
On the Filtered by line, start typing to select a filter
Select or type a value
For more common filters, you can select a filter directly from the Quick filters column of the Hosts page.
Select Pin to dashboard.
Dynatrace displays a preview of the tile and asks you to select the dashboard to which you want to pin it. The list of dashboards is searchable: select in the list and start typing to filter the list, and then select the dashboard from the filtered list.
Select a dashboard (in this example, Filtered Dashboard) and select Pin. This creates the tile and pins it to that dashboard.
Select Open dashboard.
The formerly empty dashboard now opens in edit mode with the new tile selected for editing. You can make optional settings to this tile before saving it. For a Host health tile, you have the following options:
Select Done.
The dashboard is displayed with the new tile representing hosts in GdaĆsk, Poland.
Now we have a tile that's specific to the hosts in the GdaĆsk, Poland, data center.
Optional
To add a meaningful label to your tile
Select Edit to edit your dashboard.
Drag a Header tile from the Edit dashboard pane to your dashboard.
This will be the title of your tile.
Edit the header text. In this example, we use Gdansk hosts.
Drag your Header tile into position above your Hosts tile.
Depending on the position of your Hosts tile on the dashboard, you may need to drag both tiles to new positions so you can fit the Header tile over the Hosts tile.
Select Done.
To change the filters on your tile
On your dashboard, select the tile to display the Hosts table with your filter applied.
Add or delete filters.
In this example, we keep Data center: GdaĆsk, Poland and add Operating system: Linux. Because we have changed the filters, the Update dashboard tile button is enabled so you can save changes.
Select Update dashboard tile.
The new filter settings are saved to the tile. In this example, the tile on your dashboard displays the health of hosts matching Data center: GdaĆsk, Poland and Operating system: Linux, and it opens the Hosts page with those filters.
To return to the dashboard, select the dashboard button in the upper-left corner of Dynatrace.
Instead of updating a tile, you might want to save a new copy of the tile. For example, you might want multiple similar tiles but with each tile filtered for a different operating system.
Tile cloning can save you a lot of work. For example, suppose you want your dashboard to display three visualizations that are identical except that they each query a different host. The easiest solution is to create the first visualization, experiment with the visualization settings until it's perfect, and then clone it twice. After that, you just need to edit the clones to query the other two hosts.
To pin the cloned tiles to the same dashboard
Dashboards Classic.To pin the cloned tiles to another existing dashboard, or to create another dashboard and pin the clones to it
Dashboards Classic.
