Monitor z/OS logs
  • Latest Dynatrace
  • 4-min read
zRemote module version 1.297+ zDC module version 1.291+
Log analysis is typically one of the first steps in troubleshooting application problems. When a critical issue arises, having the right logs helps you understand what is happening within your applications.
Dynatrace can automatically discover and collect logs from monitored IBM CICS regions and IBM IMS subsystems. All collected logs are enriched with metadata to map them to the entity model of z/OS hosts (logical partitions) and z/OS processes (regions and subsystems). This allows you to extend your root cause analysis for any issue identified by Dynatrace Intelligence causal AI with logs automatically linked to your applications.
To learn more about related use cases, see Log Management and Analytics.
The following log sources are supported:
  • CICS module version 1.291+ MSGUSR DD statement for IBM CICS regions
  • IMS module version 1.295+ Primary and secondary master terminal for IBM IMS subsystems
Log Management and Analytics requires a license:
  • For Dynatrace Platform Subscription, a Log Management and Analytics capability.
  • For Dynatrace classic licensing, Davis data units.
Get started
Collection of logs from z/OS requires a Log ingest rule. You can get started by using one of the existing built-in rules.
Step 1
Activate log ingest rule
Step 2 optional
Mask sensitive log data
Step 3
Analyze log data
Step 1 Activate log ingest rule
Go to Settings and select Log Monitoring > Log ingest rules.
Activate one of the following built-in rules to ingest discovered logs from your IBM CICS regions and IBM IMS subsystems to Dynatrace.
RuleConditionScope
z/OS CICS message user
Log source is: z/OS CICS message user
Log record level is any of: ERROR or WARN
Environment
z/OS IMS master terminal
Log source is any of: z/OS IMS primary master or z/OS IMS secondary master
Environment
z/OS log settings
z/OS log settings
Limit the scope of rules
If necessary, you can limit the scope of a log ingest rule to a specific group of LPARs (hosts group) or LPAR (host) so that logs are ingested only for those.
To do this, define a Log ingest rule with the required scope (host group or host).
Control which logs are ingested
If necessary, you can use attributes to precisely control which logs are ingested.
To do this, define a Log ingest rule with specific attributes so that only logs that match those attributes are ingested. For example, you can use the following attributes.
AttributeDescriptionSearch dropdown logic
Log source
Matching is based on a Log source attribute. For CICS, select the z/OS CICS message user. For IMS, select either or both of z/OS IMS primary master or z/OS IMS secondary master.
Can be entered manually. No time limit.
Log record level1
Matching is based on the level of the log record. It supports the following values: alert, critical, debug, emergency, error, info, none, notice, severe, warn.
Log content
Matching is based on the content of the log; wildcards are supported in the form of an asterisk.
Process group
Matching is based on the process group ID.
Entities visible in the last 3 days are listed.
1
Log record level attribute, transformed by OneAgent, is different than the log status attribute transformed by the Dynatrace server. Learn more by accessing the Automatic log enrichment page.
Step 2 optional Mask sensitive log data
Configure masking of sensitive data as described in Sensitive data masking in OneAgent.
Step 3 Analyze log data
With Dynatrace Log Analytics, you can analyze telemetry data and extend observability use cases for IBM Z mainframes.
For example, you can quickly investigate specific error log lines in the Log Viewer. Thanks to the enriched log data, the log lines are connected to the respective z/OS Host page.
z/OS logs in Log viewer
z/OS logs on Host page
You can also perform advanced queries in Notebooks with the Dynatrace Query Language (DQL). For example, with DQL, you can quickly query all abends or drill down into specific job statistics.
DQL query for z/OS logs
FAQ
Which metadata is added to the ingested z/OS logs?
All ingested logs are enriched with the following metadata: dt.process.name, host.name, log.source, os.name, zos.job_id, zos.job_name, zos_job_step_id, dt.entity.host, dt.entity.process_group, dt.entity.process_group_instance, and dt.source_entity.
This metadata is used to map the logs to the entity model of z/OS processes.
