Migrate from Azure classic (formerly 'built-in') services to cloud services
  • Dynatrace Classic
  • How-to guide
  • 15-min read
From the Azure overview page, you can access Dynatrace classic services and cloud services for Azure monitoring. Both types of services share the same Azure resources. However, classic services use a predefined set of metrics, so configuring which metrics to monitor, or determining which ones are already monitored, is not supported.
Classic services vs cloud services
As previously mentioned, classic services and cloud services share the same Azure resources. However, cloud services support a wider range of configuration options, such as new metrics and customizable monitored metrics. To give you more customization options, we’ve started the following:
  • Adding more services to the Cloud services section so you can customize which metrics and dimensions you want to monitor.
  • Adding more metrics for cloud services; not only are they configurable, but you can now monitor much more than before.
  • Replacing the classic services with cloud services that have more configuration options regarding metrics and dimensions.
public-cloud-services-section-infographic
If you're using classic services, we recommend migrating to cloud services to take advantage of the wider range of customizable configuration options.
Impact of the migration
Even though classic and cloud services monitor the same Azure resources on Dynatrace side, they are monitored as two different entities.
  • They have different entity IDs and metric keys.
  • Data for each Dynatrace entity type is collected and stored separately.
  • Breaking change You need to adapt the configuration of dashboards, alerts, and management zones based on entity ID or metric keys with the monitored service type.
You do have the option to choose from a classic or cloud service to preserve historical data, for now. But be aware of the following:
  • Historical data is persisted on the classic services. If you switch back, monitored data will present gaps for the period in which the resources were monitored via the cloud service.
  • You can’t have both of them turned on simultaneously. Even though on Dynatrace side they’re two different services, the legacy and new versions monitor the same Azure resource. If you had two versions switched on simultaneously, you would be charged double for polling the same data twice.
  • If you turn on the new version, the classic version is turned off automatically, and vice versa.
  • There is no direct link between entities containing historical and new data.
  • Logs from Azure log forwarder are still linked to historical data and entities.
To monitor cloud services, you need to have Environment ActiveGate configured.
Changes in the UI
Your Azure overview page changes after configuring a new version of a service.
For example, let’s look at Azure Storage Account.
  • If the legacy Azure Storage Accounts service is configured, this is what the Storage accounts section of the Azure overview looks like.
azure-public-cloud-vct-dev1-storage
  • Select Cloud services to find new overview pages for the services.
azure-public-cloud-vct-dev1-services
  • After configuring Azure Storage Account, Azure Storage Blob, Azure Storage File, Azure Storage Queue, and Azure Storage Table services, this is what the Storage accounts section of the Azure overview looks like.
  • Additionally, you can configure metrics for cloud services via UI.
azure-settings-manage-services
azure-settings-storage-blob-services
Cloud services and their corresponding classic services
new Cloud serviceold Classic service
Azure API Management Service
Azure API Management services (classic) Deprecated
Azure Application Gateway
Azure Application Gateway (classic)
Azure Basic Load Balancer
Azure Load Balancer (classic)
Azure Gateway Load Balancer
Azure Standard Load Balancer
Azure Cache for Redis
Azure Redis (classic)
Azure Cosmos DB Account (GlobalDocumentDB)
Azure Cosmos DB (classic)
Azure Cosmos DB Account (MongoDB)
Azure IoT Hub
Azure IoT Hubs (classic)
Azure SQL Server
Azure SQL (classic)
Azure SQL Database (DTU)
Azure SQL (classic)
Azure SQL Database (vCore)
Azure SQL (classic)
Azure SQL elastic pool (DTU)
Azure SQL (classic)
Azure SQL elastic pool (vCore)
Azure SQL (classic)
Azure Storage accounts (classic)
Azure Storage Blob Services
Azure Storage File Services
Azure Storage Queue Services
Azure Storage Table Services
Metrics migration
Below you can find tables with classic services metrics and their corresponding cloud services metrics. Empty cells indicate the lack of an identical corresponding metric.
Classic service metric nameClassic service metric keyCloud service metric nameCloud service metric key
Failed requests
builtin:cloud.azure.apiMgmt.requests.failed
Requests
ext:cloud.azure.microsoft_apimanagement.service.requests:filter(or(eq("Gateway response code", "400"), eq("Gateway response code category", "5xx")))
Other requests
builtin:cloud.azure.apiMgmt.requests.other
Requests
ext:cloud.azure.microsoft_apimanagement.service.requests:filter(and(ne("Gateway response code category", "1xx"), ne("Gateway response code category", "2xx"), ne("Gateway response code", "300"), ne("Gateway response code", "301"), ne("Gateway response code", "304"), ne("Gateway response code", "307"), ne("Gateway response code", "400"), ne("Gateway response code", "401"), ne("Gateway response code", "403"), ne("Gateway response code", "429"), ne("Gateway response code category", "5xx")))
Successful requests
builtin:cloud.azure.apiMgmt.requests.successful
Requests
ext:cloud.azure.microsoft_apimanagement.service.requests:filter(or(eq("Gateway response code category", "1xx"), eq("Gateway response code category", "2xx"), eq("Gateway response code", "300"), eq("Gateway response code", "301"), eq("Gateway response code", "304"), eq("Gateway response code", "307")))
Total requests
builtin:cloud.azure.apiMgmt.requests.total
Requests
Unauthorized requests
builtin:cloud.azure.apiMgmt.requests.unauth
Requests
ext:cloud.azure.microsoft_apimanagement.service.requests:filter(or(eq("Gateway response code", "401"), eq("Gateway response code", "403"), eq("Gateway response code", "429")))
Capacity
builtin:cloud.azure.apiMgmt.capacity
Capacity
ext:cloud.azure.microsoft_apimanagement.service.capacity
Duration
builtin:cloud.azure.apiMgmt.duration
Overall duration of gateway requests
ext:cloud.azure.microsoft_apimanagement.service.duration
Healthy host count
builtin:cloud.azure.appGateway.backend.settings.pool.host.healthy
Healthy host count
ext:cloud.azure.microsoft_network.applicationgateways.healthyhostcount
Unhealthy host count
builtin:cloud.azure.appGateway.backend.settings.pool.host.unhealthy
ext:cloud.azure.microsoft_network.applicationgateways.unhealthyhostcount
Requests failed
builtin:cloud.azure.appGateway.backend.settings.traffic.requests.failed
Failed requests
ext:cloud.azure.microsoft_network.applicationgateways.failedrequests
Requests total
builtin:cloud.azure.appGateway.backend.settings.traffic.requests.total
Total requests
ext:cloud.azure.microsoft_network.applicationgateways.totalrequests
Response status
builtin:cloud.azure.appGateway.http.status.response
Response status
ext:cloud.azure.microsoft_network.applicationgateways.responsestatus
Current connections count
builtin:cloud.azure.appGateway.network.connections.count
Current connections
ext:cloud.azure.microsoft_network.applicationgateways.currentconnections
Network throughput
builtin:cloud.azure.appGateway.network.throughput
Throughput
ext:cloud.azure.microsoft_network.applicationgateways.throughput
Azure Load Balancers
Load balancer DIP TCP availability
builtin:cloud.azure.loadbalancer.availability.dipTcp
Health probe status
ext:cloud.azure.microsoft_network.loadbalancers.dipavailability:filter(eq("ProtocolType", "Tcp")) / 100
Load balancer DIP UDP availability
builtin:cloud.azure.loadbalancer.availability.dipUdp
Health probe status
ext:cloud.azure.microsoft_network.loadbalancers.dipavailability:filter(eq("ProtocolType", "Udp")) / 100
Load Balancer VIP availability
builtin:cloud.azure.loadbalancer.availability.vip
Data path availability
ext:cloud.azure.microsoft_network.loadbalancers.vipavailability / 100
SNAT connections successful
builtin:cloud.azure.loadbalancer.snatConnection.est
SNAT connection count
ext:cloud.azure.microsoft_network.loadbalancers.snatconnectioncount:filter(eq("ConnectionState" ,"Successful"))
SNAT connections pending
builtin:cloud.azure.loadbalancer.snatConnection.pending
ext:cloud.azure.microsoft_network.loadbalancers.snatconnectioncount:filter(eq("ConnectionState" ,"Pending"))
SNAT connections failed
builtin:cloud.azure.loadbalancer.snatConnection.rej
ext:cloud.azure.microsoft_network.loadbalancers.snatconnectioncount:filter(eq("ConnectionState" ,"Failed"))
Bytes received
builtin:cloud.azure.loadbalancer.traffic.byteIn
Byte count
ext:cloud.azure.microsoft_network.loadbalancers.bytecount:filter(eq("Direction", "In"))
Bytes sent
builtin:cloud.azure.loadbalancer.traffic.byteOut
Byte count
ext:cloud.azure.microsoft_network.loadbalancers.bytecount:filter(eq("Direction", "Out"))
Packets received
builtin:cloud.azure.loadbalancer.traffic.packetIn
Packet count
ext:cloud.azure.microsoft_network.loadbalancers.packetcount:filter(eq("Direction", "In"))
Packets sent
builtin:cloud.azure.loadbalancer.traffic.packetOut
Packet count
ext:cloud.azure.microsoft_network.loadbalancers.packetcount:filter(eq("Direction", "Out"))
SYN packets received
builtin:cloud.azure.loadbalancer.traffic.packetSynIn
SYN count
ext:cloud.azure.microsoft_network.loadbalancers.syncount:filter(eq("Direction", "In"))
SYN packets sent
builtin:cloud.azure.loadbalancer.traffic.packetSynOut
SYN count
ext:cloud.azure.microsoft_network.loadbalancers.syncount:filter(eq("Direction", "Out"))
Cache hits
builtin:cloud.azure.redis.cache.hits
Cache hits
ext:cloud.azure.microsoft_cache.redis.cachehits
Cache misses
builtin:cloud.azure.redis.cache.misses
Cache misses
ext:cloud.azure.microsoft_cache.redis.cachemisses
Read bytes/s
builtin:cloud.azure.redis.cache.read
Cache read
ext:cloud.azure.microsoft_cache.redis.cacheread
Write bytes/s
builtin:cloud.azure.redis.cache.write
Cache write
ext:cloud.azure.microsoft_cache.redis.cachewrite
Get commands
builtin:cloud.azure.redis.commands.get
Gets
ext:cloud.azure.microsoft_cache.redis.getcommands
Set commands
builtin:cloud.azure.redis.commands.set
Sets
ext:cloud.azure.microsoft_cache.redis.setcommands
Total no. of processed commands
builtin:cloud.azure.redis.commands.total
Total operations
ext:cloud.azure.microsoft_cache.redis.totalcommandsprocessed
No. of evicted keys
builtin:cloud.azure.redis.keys.evicted
Evicted keys
ext:cloud.azure.microsoft_cache.redis.evictedkeys
No. of expired keys
builtin:cloud.azure.redis.keys.expired
Expired keys
ext:cloud.azure.microsoft_cache.redis.expiredkeys
Total no. of keys
builtin:cloud.azure.redis.keys.total
Total keys
ext:cloud.azure.microsoft_cache.redis.totalkeys
Used memory
builtin:cloud.azure.redis.memory.used
Used memory
ext:cloud.azure.microsoft_cache.redis.usedmemory
Used memory RSS
builtin:cloud.azure.redis.memory.usedRss
Used memory RSS
ext:cloud.azure.microsoft_cache.redis.usedmemoryrss
Connected clients
builtin:cloud.azure.redis.connected
Connected clients
ext:cloud.azure.microsoft_cache.redis.connectedclients
Server load
builtin:cloud.azure.redis.load
Server load
ext:cloud.azure.microsoft_cache.redis.serverload
Processor time
builtin:cloud.azure.redis.processorTime
CPU
ext:cloud.azure.microsoft_cache.redis.percentprocessortime
Azure Cosmos Database
Available Storage
builtin:cloud.azure.cosmos.availableStorage
Data Usage
builtin:cloud.azure.cosmos.dataUsage
Data usage
ext:cloud.azure.microsoft_documentdb.databaseaccounts.datausage
Document Count
builtin:cloud.azure.cosmos.documentCount
Document count
ext:cloud.azure.microsoft_documentdb.databaseaccounts.documentcount
Document Quota
builtin:cloud.azure.cosmos.documentQuota
Document quota
ext:cloud.azure.microsoft_documentdb.databaseaccounts.documentquota
Index Usage
builtin:cloud.azure.cosmos.indexUsage
Index usage
ext:cloud.azure.microsoft_documentdb.databaseaccounts.indexusage
Metadata Requests
builtin:cloud.azure.cosmos.metadataRequests
Metadata requests
ext:cloud.azure.microsoft_documentdb.databaseaccounts.metadatarequests
Normalized request units consumption
builtin:cloud.azure.cosmos.normalizedRUConsumption
Normalized ru consumption
ext:cloud.azure.microsoft_documentdb.databaseaccounts.normalizedruconsumption
Provisioned Throughput
builtin:cloud.azure.cosmos.provisionedThroughput
Provisioned throughput
ext:cloud.azure.microsoft_documentdb.databaseaccounts.provisionedthroughput
Replication Latency
builtin:cloud.azure.cosmos.replicationLatency
P99 replication latency
ext:cloud.azure.microsoft_documentdb.databaseaccounts.replicationlatency
Total number of request units
builtin:cloud.azure.cosmos.requestUnits
Total request units
ext:cloud.azure.microsoft_documentdb.databaseaccounts.totalrequestunits
Total number of requests
builtin:cloud.azure.cosmos.requests
Total requests
ext:cloud.azure.microsoft_documentdb.databaseaccounts.totalrequests
Service Availability
builtin:cloud.azure.cosmos.serviceAvailability
Service availability
ext:cloud.azure.microsoft_documentdb.databaseaccounts.serviceavailability
Azure Iot Hub
Commands abandoned
builtin:cloud.azure.iotHub.command.abandoned
C2D messages abandoned
ext:cloud.azure.microsoft_devices.iothubs.c2d_commands_egress_abandon_success
Commands completed
builtin:cloud.azure.iotHub.command.completed
C2D message deliveries completed
ext:cloud.azure.microsoft_devices.iothubs.c2d_commands_egress_complete_success
Commands rejected
builtin:cloud.azure.iotHub.command.rejected
C2D messages rejected
ext:cloud.azure.microsoft_devices.iothubs.c2d_commands_egress_reject_success
Connected devices
builtin:cloud.azure.iotHub.device.connected
Connected devices
ext:cloud.azure.microsoft_devices.iothubs.connecteddevicecount
Number of throttling errors
builtin:cloud.azure.iotHub.device.dailyThroughputThrottling
ext:cloud.azure.microsoft_devices.iothubs.d2c_telemetry_ingress_sendthrottle
Total device data usage
builtin:cloud.azure.iotHub.device.dataUsage
Total device data usage Total device data usage (preview)
ext:cloud.azure.microsoft_devices.iothubs.devicedatausage ext:cloud.azure.microsoft_devices.iothubs.devicedatausagev2
Total devices
builtin:cloud.azure.iotHub.device.registered
Total devices
ext:cloud.azure.microsoft_devices.iothubs.totaldevicecount
Messages delivered to the built-in endpoint (messages/events)
builtin:cloud.azure.iotHub.eventHub.builtInEventHub.messages.delivered
Routing - messages delivered to messages/events
ext:cloud.azure.microsoft_devices.iothubs.d2c_endpoints_egress_builtin_events
Message latency for the built-in endpoint (messages/events)
builtin:cloud.azure.iotHub.eventHub.builtInEventHub.averageLatencyMs
Routing - message latency for messages/events
ext:cloud.azure.microsoft_devices.iothubs.d2c_endpoints_latency_builtin_events
Messages delivered to Event Hub endpoints
builtin:cloud.azure.iotHub.eventHub.messages.delivered
Routing - messages delivered to event hub
ext:cloud.azure.microsoft_devices.iothubs.d2c_endpoints_egress_eventhubs
Message latency for event hub endpoints
builtin:cloud.azure.iotHub.eventHub.averageLatencyMs
Routing - message latency for event hub
ext:cloud.azure.microsoft_devices.iothubs.d2c_endpoints_latency_eventhubs
Dropped messages
builtin:cloud.azure.iotHub.messages.dropped
Routing - telemetry messages dropped
ext:cloud.azure.microsoft_devices.iothubs.d2c_telemetry_egress_dropped
Invalid messages
builtin:cloud.azure.iotHub.messages.invalidForAllEndpoints
Routing - telemetry messages incompatible
ext:cloud.azure.microsoft_devices.iothubs.d2c_telemetry_egress_invalid
Orphaned messages
builtin:cloud.azure.iotHub.messages.orphaned
Routing - telemetry messages orphaned
ext:cloud.azure.microsoft_devices.iothubs.d2c_telemetry_egress_orphaned
Telemetry message send attempts
builtin:cloud.azure.iotHub.messages.sendAttempts
ext:cloud.azure.microsoft_devices.iothubs.d2c_telemetry_ingress_allprotocol
Telemetry messages sent
builtin:cloud.azure.iotHub.messages.sent
ext:cloud.azure.microsoft_devices.iothubs.d2c_telemetry_ingress_success
Messages matching fallback condition
builtin:cloud.azure.iotHub.messages.sentToFallback
Routing - messages delivered to fallback
ext:cloud.azure.microsoft_devices.iothubs.d2c_telemetry_egress_fallback
Message latency for service bus queue endpoints
builtin:cloud.azure.iotHub.serviceBus.queues.averageLatencyMs
Routing - message latency for service bus queue
ext:cloud.azure.microsoft_devices.iothubs.d2c_endpoints_latency_servicebusqueues
Messages delivered to service bus queue endpoints
builtin:cloud.azure.iotHub.serviceBus.queues.messagesDelivered
Routing - messages delivered to service bus queue
ext:cloud.azure.microsoft_devices.iothubs.d2c_endpoints_egress_servicebusqueues
Message latency for service bus topic endpoints
builtin:cloud.azure.iotHub.serviceBus.topics.averageLatencyMs
Routing - message latency for service bus topic
ext:cloud.azure.microsoft_devices.iothubs.d2c_endpoints_latency_servicebustopics
Messages delivered to service bus topic endpoints
builtin:cloud.azure.iotHub.serviceBus.topics.messagesDelivered
Routing - messages delivered to service bus topic
ext:cloud.azure.microsoft_devices.iothubs.d2c_endpoints_egress_servicebustopics
Message latency for storage endpoints
builtin:cloud.azure.iotHub.storageEndpoints.avgLatencyMs
Routing - message latency for storage
ext:cloud.azure.microsoft_devices.iothubs.d2c_endpoints_latency_storage
Blobs written to storage
builtin:cloud.azure.iotHub.storageEndpoints.blobsWritten
Routing - blobs delivered to storage
ext:cloud.azure.microsoft_devices.iothubs.d2c_endpoints_egress_storage_blobs
Data written to storage
builtin:cloud.azure.iotHub.storageEndpoints.bytesWritten
Routing - data delivered to storage
ext:cloud.azure.microsoft_devices.iothubs.d2c_endpoints_egress_storage_bytes
Messages delivered to storage endpoints
builtin:cloud.azure.iotHub.storageEndpoints.messageDelivered
Routing - messages delivered to storage
Azure SQL Server
Azure SQL Databases
Blocked by firewall
builtin:cloud.azure.sqlDatabase.connections.blockedByFirewall
Blocked by firewall
ext:cloud.azure.microsoft_sql.servers.databases.blocked_by_firewall
Failed connections
builtin:cloud.azure.sqlDatabase.connections.failed
Failed connections - system errors Failed connections - user errors
ext:cloud.azure.microsoft_sql.servers.databases.connection_failedext:cloud.azure.microsoft_sql.servers.databases.connection_failed_user_error
Successful connections
builtin:cloud.azure.sqlDatabase.connections.successful
ext:cloud.azure.microsoft_sql.servers.databases.connection_successful
DTU limit
builtin:cloud.azure.sqlDatabase.dtu.limit.count
DTU limit
ext:cloud.azure.microsoft_sql.servers.databases.dtu_limit
DTU used
builtin:cloud.azure.sqlDatabase.dtu.limit.used
DTU used
ext:cloud.azure.microsoft_sql.servers.databases.dtu_used
DTU percentage
builtin:cloud.azure.sqlDatabase.dtu.consumptionPerc
DTU percentage
ext:cloud.azure.microsoft_sql.servers.databases.dtu_consumption_percent
Data I/O percentage
builtin:cloud.azure.sqlDatabase.io.dataRead
Data IO percentage
ext:cloud.azure.microsoft_sql.servers.databases.physical_data_read_percent
Log I/O percentage
builtin:cloud.azure.sqlDatabase.io.logWrite
Log IO percentage
ext:cloud.azure.microsoft_sql.servers.databases.log_write_percent
Database size percentage
builtin:cloud.azure.sqlDatabase.storage.percent
Data space used percent
ext:cloud.azure.microsoft_sql.servers.databases.storage_percent
Total database size
builtin:cloud.azure.sqlDatabase.storage.totalBytes
Data space used
In-Memory OLTP storage percent
builtin:cloud.azure.sqlDatabase.storage.xtpPercent
ext:cloud.azure.microsoft_sql.servers.databases.xtp_storage_percent
CPU percentage
builtin:cloud.azure.sqlDatabase.cpuPercent
CPU percentage
ext:cloud.azure.microsoft_sql.servers.databases.cpu_percent
Deadlocks
builtin:cloud.azure.sqlDatabase.deadlocks
Deadlocks
ext:cloud.azure.microsoft_sql.servers.databases.deadlock
Sessions percentage
builtin:cloud.azure.sqlDatabase.sessions
Sessions percentage
ext:cloud.azure.microsoft_sql.servers.databases.sessions_percent
Workers percentage
builtin:cloud.azure.sqlDatabase.workers
Workers percentage
ext:cloud.azure.microsoft_sql.servers.databases.workers_percent
Azure SQL Database elastic pools
Storage limit
builtin:cloud.azure.sqlElasticPool.dtu.storage.limitBytes
Data max size
ext:cloud.azure.microsoft_sql.servers.elasticpools.storage_limit
builtin:cloud.azure.sqlElasticPool.dtu.storage.percent
ext:cloud.azure.microsoft_sql.servers.elasticpools.storage_percent
Storage used
builtin:cloud.azure.sqlElasticPool.dtu.storage.usedBytes
Data space used
ext:cloud.azure.microsoft_sql.servers.elasticpools.storage_used
In-memory OLTP storage percent
builtin:cloud.azure.sqlElasticPool.dtu.storage.xtpPercent
In - memory OLTP storage percent
ext:cloud.azure.microsoft_sql.servers.elasticpools.xtp_storage_percent
DTU percentage
builtin:cloud.azure.sqlElasticPool.dtu.consumption
DTU percentage
ext:cloud.azure.microsoft_sql.servers.elasticpools.dtu_consumption_percent
eDTU limit
builtin:cloud.azure.sqlElasticPool.edtu.limit
EDTU limit
ext:cloud.azure.microsoft_sql.servers.elasticpools.edtu_limit
eDTU used
builtin:cloud.azure.sqlElasticPool.edtu.used
EDTU used
ext:cloud.azure.microsoft_sql.servers.elasticpools.edtu_used
Data I/O percentage
builtin:cloud.azure.sqlElasticPool.io.dataRead
Data IO percentage
ext:cloud.azure.microsoft_sql.servers.elasticpools.physical_data_read_percent
Log I/O percentage
builtin:cloud.azure.sqlElasticPool.io.logWrite
Log IO percentage
ext:cloud.azure.microsoft_sql.servers.elasticpools.log_write_percent
CPU percentage
builtin:cloud.azure.sqlElasticPool.cpuPercent
CPU percentage
ext:cloud.azure.microsoft_sql.servers.elasticpools.cpu_percent
Sessions percentage
builtin:cloud.azure.sqlElasticPool.sessions
Sessions percentage
ext:cloud.azure.microsoft_sql.servers.elasticpools.sessions_percent
Workers percentage
builtin:cloud.azure.sqlElasticPool.workers
Workers percentage
ext:cloud.azure.microsoft_sql.servers.elasticpools.workers_percent
Transactions count
builtin:cloud.azure.storage.blob.transactions
Transactions
ext:cloud.azure.microsoft_storage.storageaccounts.blobservices.transactions
E2E success latency
builtin:cloud.azure.storage.blob.transactions.network.latency.success.e2e
Success E2E latency
Server success latency
builtin:cloud.azure.storage.blob.transactions.network.latency.success.server
Success server latency
ext:cloud.azure.microsoft_storage.storageaccounts.blobservices.successserverlatency
Egress bytes
builtin:cloud.azure.storage.blob.transactions.network.egress
Egress
ext:cloud.azure.microsoft_storage.storageaccounts.blobservices.egress
Ingress bytes
builtin:cloud.azure.storage.blob.transactions.network.ingress
Ingress
ext:cloud.azure.microsoft_storage.storageaccounts.blobservices.ingress
Blob capacity
builtin:cloud.azure.storage.blob.capacity
Blob capacity
ext:cloud.azure.microsoft_storage.storageaccounts.blobservices.blobcapacity
Blob container count
builtin:cloud.azure.storage.blob.containers
ext:cloud.azure.microsoft_storage.storageaccounts.blobservices.containercount
Blob count
builtin:cloud.azure.storage.blob.entities
Blob count
ext:cloud.azure.microsoft_storage.storageaccounts.blobservices.blobcount
Transactions count
builtin:cloud.azure.storage.file.transactions
Transactions
ext:cloud.azure.microsoft_storage.storageaccounts.fileservices.transactions
E2E success latency
builtin:cloud.azure.storage.file.transactions.network.latency.success.e2e
Success E2E latency
ext:cloud.azure.microsoft_storage.storageaccounts.fileservices.successe2elatency
builtin:cloud.azure.storage.file.transactions.network.latency.success.server
ext:cloud.azure.microsoft_storage.storageaccounts.fileservices.successserverlatency
Egress bytes
builtin:cloud.azure.storage.file.transactions.network.egress
Egress
ext:cloud.azure.microsoft_storage.storageaccounts.fileservices.egress
Ingress bytes
builtin:cloud.azure.storage.file.transactions.network.ingress
Ingress
ext:cloud.azure.microsoft_storage.storageaccounts.fileservices.ingress
File capacity
builtin:cloud.azure.storage.file.capacity
File capacity
ext:cloud.azure.microsoft_storage.storageaccounts.fileservices.filecapacity
File share count
builtin:cloud.azure.storage.file.containers
File share count
ext:cloud.azure.microsoft_storage.storageaccounts.fileservices.filesharecount
File count
builtin:cloud.azure.storage.file.entities
File count
ext:cloud.azure.microsoft_storage.storageaccounts.fileservices.filecount
Transactions count
builtin:cloud.azure.storage.queue.transactions
Transactions
ext:cloud.azure.microsoft_storage.storageaccounts.queueservices.transactions
E2E success latency
builtin:cloud.azure.storage.queue.transactions.network.latency.success.e2e
Success E2E latency
ext:cloud.azure.microsoft_storage.storageaccounts.queueservices.successe2elatency
builtin:cloud.azure.storage.queue.transactions.network.latency.success.server
ext:cloud.azure.microsoft_storage.storageaccounts.queueservices.successserverlatency
Egress bytes
builtin:cloud.azure.storage.queue.transactions.network.egress
Egress
ext:cloud.azure.microsoft_storage.storageaccounts.queueservices.egress
Ingress bytes
builtin:cloud.azure.storage.queue.transactions.network.ingress
Ingress
ext:cloud.azure.microsoft_storage.storageaccounts.queueservices.ingress
Queue capacity
builtin:cloud.azure.storage.queue.capacity
Queue capacity
ext:cloud.azure.microsoft_storage.storageaccounts.queueservices.queuecapacity
Queue count
builtin:cloud.azure.storage.queue.containers
Queue count
ext:cloud.azure.microsoft_storage.storageaccounts.queueservices.queuecount
Queue message count
builtin:cloud.azure.storage.queue.entities
Queue message count
ext:cloud.azure.microsoft_storage.storageaccounts.queueservices.queuemessagecount
Transactions count
builtin:cloud.azure.storage.table.transactions
Transactions
ext:cloud.azure.microsoft_storage.storageaccounts.tableservices.transactions
builtin:cloud.azure.storage.table.transactions.network.latency.success.server
ext:cloud.azure.microsoft_storage.storageaccounts.tableservices.successserverlatency
E2E success latency
builtin:cloud.azure.storage.table.transactions.network.latency.success.server.e2e
Success E2E latency
ext:cloud.azure.microsoft_storage.storageaccounts.tableservices.successe2elatency
Egress bytes
builtin:cloud.azure.storage.table.transactions.network.egress
Egress
ext:cloud.azure.microsoft_storage.storageaccounts.tableservices.egress
Ingress bytes
builtin:cloud.azure.storage.table.transactions.network.ingress
Ingress
ext:cloud.azure.microsoft_storage.storageaccounts.tableservices.ingress
Table capacity
builtin:cloud.azure.storage.table.capacity
Table capacity
ext:cloud.azure.microsoft_storage.storageaccounts.tableservices.tablecapacity
Table count
builtin:cloud.azure.storage.table.containers
Table count
ext:cloud.azure.microsoft_storage.storageaccounts.tableservices.tablecount
Table entity count
builtin:cloud.azure.storage.table.entities
Table entity count
ext:cloud.azure.microsoft_storage.storageaccounts.tableservices.tableentitycount
Related tags
Infrastructure ObservabilityAzure
