Migrate from AWS classic (formerly 'built-in') services to cloud services
  • Dynatrace Classic
  • How-to guide
  • 9-min read
From the AWS overview page, you can access Dynatrace classic services and cloud services for AWS monitoring. Both types of services share the same AWS resources. However, classic services use a predefined set of metrics, so configuring which metrics to monitor, or determining which ones are already monitored, is not supported.
Classic services vs cloud services
As previously mentioned, classic services and cloud services share the same AWS resources. However, cloud services support a wider range of configuration options, such as new metrics and customizable monitored metrics. To give you more customization options, we’ve started the following:
  • Adding more services to the Cloud services section so you can customize which metrics you want to monitor.
  • Adding more metrics for cloud services; not only are they configurable, but you can now monitor much more than before.
  • Replacing the classic services with cloud services that have more configuration options regarding metrics.
AWS E2E Cloud services infographic
If you're using classic services, we recommend migrating to cloud services to take advantage of the wider range of customizable configuration options.
AWS Lambda
If you're using OneAgent integration for your Lambdas, we recommend Lambda migration. Since the release of Dynatrace version 1.283, we show data for the new Lambda service together with OneAgent data on the Lambda service page.
Impact of the migration
Even though classic and cloud services monitor the same AWS resources on Dynatrace side, they are monitored as two different entities.
  • They have different entity IDs and metric keys.
  • Due to their different implementations, they may detect different numbers of instances. Cloud services show only instances with metrics.
  • Data for each Dynatrace entity type is collected and stored separately.
  • Breaking change You need to adapt the configuration of dashboards, alerts, and management zones based on entity ID or metric keys with the monitored service type.
You currently have the option to choose from a classic or cloud service to preserve historical data, but be aware of the following:
  • Historical data is persisted on the classic services. If you switch back, monitored data will present gaps for the period in which the resources were monitored via the cloud service.
  • You can’t have both of them turned on simultaneously. Even though on the Dynatrace side they’re two different services, the legacy and new versions monitor the same AWS resource. If you had two versions switched on simultaneously, you would be charged double for polling the same data twice.
  • If you turn on the new version, the classic version is turned off automatically, and vice versa.
  • There is no direct link between
    • Entities containing historical and new data.
    • Cloud service data and data coming from OneAgent for opaque Amazon RDS—not linked to the new cloud service page with CloudWatch metrics.
  • Logs from Amazon Data Firehose to Amazon RDS are still being linked to the historical data and entity RELATIONAL_DATABASE_SERVICE.
  • Events or problems that would have been auto-detected on the historical (classic) data might not be automatically raised. Alerting rules are not provided for these cloud services:
    • Amazon RDS
    • Amazon EBS
    • AWS Lambda—predefined metric event configuration is provided but needs to be manually enabled.
To monitor cloud services, you need to have Environment ActiveGate configured.
Changes in the UI
Your AWS overview page changes after configuring a new version of a service.
For example, let’s have a look at Amazon EBS.
  • If the legacy Amazon EBS (classic) service is configured, this is what the EBS volumes section of the AWS overview looks like.
    EBS volumes section 1
  • If the Amazon EBS cloud service is configured, this is what the EBS volumes section of the AWS overview looks like.
    EBS volumes section 2
  • Select Cloud services to find new overview pages for the services.
    Amazon EBS
    Amazon EBS
  • Additionally, you can configure metrics for cloud services via the web UI.
    AWS Settings Manage services
    Settings Amazon EBS
    Settings Amazon EBS
Cloud services and their corresponding classic services
new Cloud serviceold Classic service
Amazon EC2 Auto Scaling
Amazon EC2 Auto Scaling (classic)
Amazon DynamoDB
Amazon DynamoDB (classic)
Amazon EBS
AWS Lambda
AWS Lambda (classic)
Amazon RDS
Amazon RDS (classic)
Metrics migration
Below you can find tables with classic services metrics and their corresponding cloud services metrics. Empty cells indicate the lack of an identical corresponding metric.
You can find more details about accessing these in Grail on this page.
The ext: prefix is used by metrics from OneAgent extensions and ActiveGate extensions, and also by classic metrics for AWS integration.
Despite the naming similarities, AWS integration metrics are not based on extensions.
Amazon Auto scaling group
Classic service metric nameClassic service metric keyCloud service metric nameCloud service metric key
Number of running EC2 instances (ASG)
builtin:cloud.aws.asg.running
Number of stopped EC2 instances (ASG)
builtin:cloud.aws.asg.stopped
Number of terminated EC2 instances (ASG)
builtin:cloud.aws.asg.terminated
Amazon DynamoDB
DynamoDB read capacity units
builtin:cloud.aws.dynamo.capacityUnits.consumed.read
ConsumedReadCapacityUnits Sum
ext:cloud.aws.dynamodb.consumedReadCapacityUnitsSumext:cloud.aws.dynamodb.consumedReadCapacityUnitsByGlobalSecondaryIndexName
DynamoDB write capacity units
builtin:cloud.aws.dynamo.capacityUnits.consumed.write
ConsumedWriteCapacityUnits Sum
ext:cloud.aws.dynamodb.consumedWriteCapacityUnitsSumext:cloud.aws.dynamodb.consumedWriteCapacityUnitsSumByGlobalSecondaryIndexName
DynamoDB provisioned read capacity units
builtin:cloud.aws.dynamo.capacityUnits.provisioned.read
ProvisionedReadCapacityUnits Sum
ext:cloud.aws.dynamodb.provisionedReadCapacityUnitsSumext:cloud.aws.dynamodb.provisionedReadCapacityUnitsSumByGlobalSecondaryIndexName
DynamoDB provisioned write capacity units
builtin:cloud.aws.dynamo.capacityUnits.provisioned.write
ProvisionedWriteCapacityUnits Sum
ext:cloud.aws.dynamodb.provisionedWriteCapacityUnitsSumext:cloud.aws.dynamodb.provisionedWriteCapacityUnitsSumByGlobalSecondaryIndexName
DynamoDB read capacity units %
builtin:cloud.aws.dynamo.capacityUnits.read
calculated
100 * ext:cloud.aws.dynamodb.consumedReadCapacityUnitsSum / ext:cloud.aws.dynamodb.provisionedReadCapacityUnitsSum
DynamoDB write capacity units %
builtin:cloud.aws.dynamo.capacityUnits.write
calculated
100 * ext:cloud.aws.dynamodb.consumedWriteCapacityUnitsSum / ext:cloud.aws.dynamodb.provisionedWriteCapacityUnitsSum
DynamoDB number of requests with HTTP 500 status code
builtin:cloud.aws.dynamo.errors.system
SystemErrors Sum (by Operation)
ext:cloud.aws.dynamodb.SystemErrorsSumByOperation
DynamoDB number of requests with HTTP 400 status code
builtin:cloud.aws.dynamo.errors.user
UserErrors Sum (by Region)
ext:cloud.aws.dynamodb.UserErrorsSum
DynamoDB number of successful request latency for operation
builtin:cloud.aws.dynamo.requests.latency
SuccessfulRequestLatency (by Operation)
ext:cloud.aws.dynamodb.successfulRequestLatencyByOperation
DynamoDB number of items returned by operation
builtin:cloud.aws.dynamo.requests.returnedItems
ReturnedItemCount Sum (by Operation)
ext:cloud.aws.dynamodb.returnedItemCountSumByOperation
DynamoDB number of throttled requests for operation
builtin:cloud.aws.dynamo.requests.throttled
ThrottledRequests Sum (by Operation)
ext:cloud.aws.dynamodb.ThrottledRequestsSumByOperation
DynamoDB number of read throttled events
builtin:cloud.aws.dynamo.throttledEvents.read
ReadThrottleEvents Sum
ext:cloud.aws.dynamodb.ReadThrottleEventsSumext:cloud.aws.dynamodb.ReadThrottleEventsSumByGlobalSecondaryIndexName
DynamoDB number of write throttled events
builtin:cloud.aws.dynamo.throttledEvents.write
WriteThrottleEvents Sum
ext:cloud.aws.dynamodb.WriteThrottleEventsSumext:cloud.aws.dynamodb.WriteThrottleEventsSumByGlobalSecondaryIndexName
Number of tables for AvailabilityZone
builtin:cloud.aws.dynamo.tables
Amazon EBS
EBS volume read latency
builtin:cloud.aws.ebs.latency.read
EBS volume write latency
builtin:cloud.aws.ebs.latency.write
EBS volume consumed OPS
builtin:cloud.aws.ebs.ops.consumed
VolumeConsumedReadWriteOps Sum
ext:cloud.aws.ebs.volumeConsumedReadWriteOps
EBS volume read OPS
builtin:cloud.aws.ebs.ops.read
VolumeReadOps Sum
ext:cloud.aws.ebs.volumeReadOpsSum
EBS volume write OPS
builtin:cloud.aws.ebs.ops.write
VolumeWriteOps Sum
ext:cloud.aws.ebs.volumeWriteOpsSum
EBS volume throughput %
builtin:cloud.aws.ebs.throughput.percent
VolumeThroughputPercentage
ext:cloud.aws.ebs.volumeThroughputPercentage
EBS volume read throughput
builtin:cloud.aws.ebs.throughput.read
calculated
ext:cloud.aws.ebs.volumeReadBytes / ext:cloud.aws.ebs.volumeTotalReadTime
EBS volume write throughput
builtin:cloud.aws.ebs.throughput.write
calculated
ext:cloud.aws.ebs.volumeWriteBytes / ext:cloud.aws.ebs.volumeTotalWriteTime
EBS volume idle time %
builtin:cloud.aws.ebs.idleTime
EBS volume queue length
builtin:cloud.aws.ebs.queue
VolumeQueueLength Sum
ext:cloud.aws.ebs.volumeQueueLengthSum
AWS Lambda
LambdaFunction concurrent executions count
builtin:cloud.aws.lambda.concExecutions
ConcurrentExecutions Sum
ext:cloud.aws.lambda.concurrentExecutionsSumext:cloud.aws.lambda.concurrentExecutionsSumByResourceext:cloud.aws.lambda.concurrentExecutionsSumByRegion
LambdaFunction code execution time.
builtin:cloud.aws.lambda.duration
Duration
ext:cloud.aws.lambda.durationext:cloud.aws.lambda.durationByResourceext:cloud.aws.lambda.durationByRegion
LambdaFunction number of failed invocations with HTTP 4XX status code
builtin:cloud.aws.lambda.errors
Errors Sum
ext:cloud.aws.lambda.errorsSumext:cloud.aws.lambda.errorsSumByResourceext:cloud.aws.lambda.errorsSumByRegion
LambdaFunction rate of failed invocations to all invocations %
builtin:cloud.aws.lambda.errorsRate
calculated
100 * ext:cloud.aws.lambda.errorsSum / ext:cloud.aws.lambda.invocationsSum
LambdaFunction number of times a function is invoked
builtin:cloud.aws.lambda.invocations
Invocations Sum
ext:cloud.aws.lambda.invocationsSumext:cloud.aws.lambda.invocationsSumByResourceext:cloud.aws.lambda.invocationsSumByRegion
LambdaFunction provisioned concurrent executions count
builtin:cloud.aws.lambda.provConcExecutions
ProvisionedConcurrentExecutions Sum
ext:cloud.aws.lambda.provisionedConcurrentExecutionsSumext:cloud.aws.lambda.provisionedConcurrentExecutionsSumByResourceext:cloud.aws.lambda.provisionedConcurrentExecutionsSumByRegion
LambdaFunction provisioned concurrency invocation count
builtin:cloud.aws.lambda.provConcInvocations
ProvisionedConcurrencyInvocations Sum
ext:cloud.aws.lambda.provisionedConcurrencyInvocationsSumext:cloud.aws.lambda.provisionedConcurrencyInvocationsSumByResourceext:cloud.aws.lambda.provisionedConcurrencyInvocationsSumByRegion
LambdaFunction provisioned concurrency spillover invocation count
builtin:cloud.aws.lambda.provConcSpilloverInvocations
ProvisionedConcurrencySpilloverInvocations Sum
ext:cloud.aws.lambda.provisionedConcurrencySpilloverInvocationsSumext:cloud.aws.lambda.provisionedConcurrencySpilloverInvocationsSumByResourceext:cloud.aws.lambda.provisionedConcurrencySpilloverInvocationsSumByRegion
LambdaFunction throttled function invocation count
builtin:cloud.aws.lambda.throttlers
Throttles Sum
ext:cloud.aws.lambda.throttlesSumext:cloud.aws.lambda.throttlesSumByResourceext:cloud.aws.lambda.throttlesSumByRegion
Amazon RDS
RDS CPU usage %
builtin:cloud.aws.rds.cpu.usage
CPUUtilization
ext:cloud.aws.rds.cpuUtilizationext:cloud.aws.rds.cpuUtilizationByRegionDatabaseClassext:cloud.aws.rds.cpuUtilizationByRegionDBClusterIdentifierext:cloud.aws.rds.cpuUtilizationByRegionext:cloud.aws.rds.cpuUtilizationByRegionEngineNameext:cloud.aws.rds.cpuUtilizationByRegionDBClusterIdentifierRole
RDS read latency
builtin:cloud.aws.rds.latency.read
ReadLatency
ext:cloud.aws.rds.readLatencyext:cloud.aws.rds.readLatencyByRegionDatabaseClassext:cloud.aws.rds.readLatencyByRegionDBClusterIdentifierext:cloud.aws.rds.readLatencyByRegionext:cloud.aws.rds.readLatencyByRegionEngineNameext:cloud.aws.rds.readLatencyByRegionDBClusterIdentifierRole
RDS write latency
builtin:cloud.aws.rds.latency.write
WriteLatency
ext:cloud.aws.rds.writeLatencyext:cloud.aws.rds.writeLatencyByRegionDatabaseClassext:cloud.aws.rds.writeLatencyByRegionDBClusterIdentifierext:cloud.aws.rds.writeLatencyByRegionext:cloud.aws.rds.writeLatencyByRegionEngineNameext:cloud.aws.rds.writeLatencyByRegionDBClusterIdentifierRole
RDS freeable memory
builtin:cloud.aws.rds.memory.freeable
FreeableMemory
ext:cloud.aws.rds.freeableMemoryext:cloud.aws.rds.freeableMemoryByRegionDatabaseClassext:cloud.aws.rds.freeableMemoryByRegionDBClusterIdentifierext:cloud.aws.rds.freeableMemoryByRegionext:cloud.aws.rds.freeableMemoryByRegionEngineNameext:cloud.aws.rds.freeableMemoryByRegionDBClusterIdentifierRole
RDS swap usage
builtin:cloud.aws.rds.memory.swap
SwapUsage
ext:cloud.aws.rds.swapUsageext:cloud.aws.rds.swapUsageByRegionDatabaseClassext:cloud.aws.rds.swapUsageByRegionDBClusterIdentifierext:cloud.aws.rds.swapUsageByRegionext:cloud.aws.rds.swapUsageByRegionEngineNameext:cloud.aws.rds.swapUsageByRegionDBClusterIdentifierRole
RDS network received throughput
builtin:cloud.aws.rds.net.rx
NetworkReceiveThroughput
ext:cloud.aws.rds.networkReceiveThroughputext:cloud.aws.rds.networkReceiveThroughputByRegionDatabaseClassext:cloud.aws.rds.networkReceiveThroughputByRegionDBClusterIdentifierext:cloud.aws.rds.networkReceiveThroughputByRegionext:cloud.aws.rds.networkReceiveThroughputByRegionEngineNameext:cloud.aws.rds.networkReceiveThroughputByRegionDBClusterIdentifierRole
RDS network transmitted throughput
builtin:cloud.aws.rds.net.tx
NetworkTransmitThroughput
ext:cloud.aws.rds.networkTransmitThroughputext:cloud.aws.rds.networkTransmitThroughputByRegionDatabaseClassext:cloud.aws.rds.networkTransmitThroughputByRegionDBClusterIdentifierext:cloud.aws.rds.networkTransmitThroughputByRegionext:cloud.aws.rds.networkTransmitThroughputByRegionEngineNameext:cloud.aws.rds.networkTransmitThroughputByRegionDBClusterIdentifierRole
RDS read IOPS
builtin:cloud.aws.rds.ops.read
ReadIOPS
ext:cloud.aws.rds.readIOPSext:cloud.aws.rds.readIOPSByRegionDatabaseClassext:cloud.aws.rds.readIOPSByRegionext:cloud.aws.rds.readIOPSByRegionEngineName
RDS write IOPS
builtin:cloud.aws.rds.ops.write
WriteIOPS
ext:cloud.aws.rds.writeIOPSext:cloud.aws.rds.writeIOPSByRegionDatabaseClassext:cloud.aws.rds.writeIOPSByRegionext:cloud.aws.rds.writeIOPSByRegionEngineName
RDS read throughput
builtin:cloud.aws.rds.throughput.read
ReadThroughput
ext:cloud.aws.rds.readThroughputext:cloud.aws.rds.readThroughputByRegionDatabaseClassext:cloud.aws.rds.readThroughputByRegionext:cloud.aws.rds.readThroughputByRegionEngineName
RDS write throughput
builtin:cloud.aws.rds.throughput.write
WriteThroughput
ext:cloud.aws.rds.writeThroughputext:cloud.aws.rds.writeThroughputByRegionDatabaseClassext:cloud.aws.rds.writeThroughputByRegionext:cloud.aws.rds.writeThroughputByRegionEngineName
RDS connections
builtin:cloud.aws.rds.connections
DatabaseConnections Sum
ext:cloud.aws.rds.databaseConnectionsSumByRegionDatabaseClassext:cloud.aws.rds.databaseConnectionsSumByRegionDBClusterIdentifierext:cloud.aws.rds.databaseConnectionsSumByRegionext:cloud.aws.rds.databaseConnectionsSumByRegionEngineNameext:cloud.aws.rds.databaseConnectionsSumByRegionDBClusterIdentifierRole
RDS free storage space %
builtin:cloud.aws.rds.free
RDS restarts
builtin:cloud.aws.rds.restarts
Related tags
Infrastructure ObservabilityAWS
