ActiveGate container image
  • Latest Dynatrace
  • 2-min read
Dynatrace supports running ActiveGate in a container. As an example of a container-based deployment, this page describes how to deploy container-based ActiveGate using a StatefulSet on Kubernetes/OpenShift.
Prerequisites
  1. Create an access token with InstallerDownload scope
  2. Create an authentication token
  3. Determine the ActiveGate communication endpoints and authentication. Use the GET connectivity information for ActiveGate API.
  4. Get your kube-system namespace UUID
    How to extract the kube-system namespace UUID
    Run the command below and save the UUID from the output for later use.
    kubectl get namespace kube-system -o jsonpath='{.metadata.uid}'
    oc get namespace kube-system -o jsonpath='{.metadata.uid}'
System requirements
A Dynatrace ActiveGate image is supported on a variety of Kubernetes and OpenShift versions. For a complete list, see Technology support - Kubernetes.
Images are available for the following architectures:
  • x86-64
  • ARM64 (AArch64)
  • s390x
  • PPC64le
Container registries
To prioritize seamless integration with your tooling and adaptability to your needs, we offer our container images in various ways to maximize flexibility:
  • Dynatrace built-in registry default
  • Public registries
  • Bring your own private registry Recommended
Please note that multi-arch Dynatrace container images, ensuring compatibility across various platforms are available from public registries only. Dynatrace built-in registry provides only x86-64 images.
Deployment
Dynatrace provides signed container images to ensure authenticity and integrity, along with SBOMs that list all included software components. Verifying the signatures and reviewing the SBOMs enables effective vulnerability management and risk mitigation. For verification details, see Verify Software Bill of Materials (SBOM) Attestation.
  1. Create a dedicated namespace.
    kubectl create namespace dynatrace
    oc adm new-project --node-selector="" dynatrace
  2. Create a secret that holds the authentication details to the Dynatrace server used by ActiveGate.
    kubectl -n dynatrace create secret generic dynatrace-tokens \
    --from-literal=tenant-token=<YOUR_TENANT_TOKEN> \
    --from-literal=auth-token=<YOUR_AUTH_TOKEN>
    oc -n dynatrace create secret generic dynatrace-tokens \
    You need to replace
    • <YOUR_TENANT_TOKEN> with the tenantToken value obtained in Prerequisites from the connectivity information.
    • <YOUR_AUTH_TOKEN> with the individual ActiveGate token obtained in Prerequisites.
  3. Create an ag-deployment-example.yaml file with the following content:
    apiVersion: v1
    kind: Service
    metadata:
    namespace: dynatrace
    spec:
    type: ClusterIP
    selector:
    app.kubernetes.io/component: activegate
    component.dynatrace.com/feature: activegate
    ports:
    - protocol: TCP
    port: 443
    targetPort: ag-https
    apiVersion: apps/v1
    kind: StatefulSet
    metadata:
    labels:
    spec:
    podManagementPolicy: Parallel
    serviceName: ""
    selector:
    matchLabels:
    template:
    metadata:
    labels:
    spec:
    affinity:
    nodeAffinity:
    requiredDuringSchedulingIgnoredDuringExecution:
    nodeSelectorTerms:
    - matchExpressions:
    - key: kubernetes.io/arch
    operator: In
    values:
    - <CPU_ARCHITECTURE>
    - key: kubernetes.io/os
    operator: In
    values:
    - linux
    containers:
    - name: activegate
    image: <REPOSITORY_URL>/dynatrace-activegate:<IMAGE_TAG>
    imagePullPolicy: Always
    ports:
    - containerPort: 9999
    protocol: TCP
    env:
    - name: DT_TENANT
    value: <YOUR_ENVIRONMENT_ID>
    - name: DT_SERVER
    value: <YOUR_COMMUNICATION_ENDPOINTS>
    - name: DT_ID_SEED_NAMESPACE
    value: dynatrace
    - name: DT_ID_SEED_K8S_CLUSTER_ID
    value: <YOUR_KUBE-SYSTEM_NAMESPACE_UUID>
    - name: DT_CAPABILITIES
    value: restInterface,kubernetes_monitoring,MSGrouter,metrics_ingest
    - name: DT_DEPLOYMENT_METADATA
    value: orchestration_tech=handcrated-ag-sts;script_version=none;orchestrator_id=none
    - name: DT_DNS_ENTRY_POINT
    value: https://$(DYNATRACE_ACTIVEGATE_SERVICE_HOST):$(DYNATRACE_ACTIVEGATE_SERVICE_PORT)/communication
    volumeMounts:
    - name: dynatrace-tokens
    mountPath: /var/lib/dynatrace/secrets/tokens
    - name: truststore-volume
    mountPath: /opt/dynatrace/gateway/jre/lib/security/cacerts
    readOnly: true
    subPath: k8s-local.jks
    - name: server-certs-storage
    mountPath: /var/lib/dynatrace/gateway/ssl
    - name: ag-lib-gateway-config
    mountPath: /var/lib/dynatrace/gateway/config
    - name: ag-lib-gateway-temp
    mountPath: /var/lib/dynatrace/gateway/temp
    - name: ag-lib-gateway-data
    mountPath: /var/lib/dynatrace/gateway/data
    - name: ag-log-gateway
    mountPath: /var/log/dynatrace/gateway
    - name: ag-tmp-gateway
    mountPath: /var/tmp/dynatrace/gateway
    livenessProbe:
    failureThreshold: 2
    httpGet:
    path: /rest/state
    port: ag-https
    scheme: HTTPS
    initialDelaySeconds: 30
    periodSeconds: 30
    successThreshold: 1
    timeoutSeconds: 1
    readinessProbe:
    failureThreshold: 3
    httpGet:
    path: /rest/health
    port: ag-https
    scheme: HTTPS
    periodSeconds: 15
    successThreshold: 1
    timeoutSeconds: 1
    resources:
    requests:
    cpu: 500m
    memory: 512Mi
    limits:
    cpu: 1000m
    memory: 1.5Gi
    securityContext:
    allowPrivilegeEscalation: false
    capabilities:
    drop:
    - all
    privileged: false
    readOnlyRootFilesystem: true
    runAsNonRoot: true
    seccompProfile:
    type: RuntimeDefault
    initContainers:
    - name: certificate-loader
    workingDir: /var/lib/dynatrace/gateway
    command: ['/bin/bash']
    args: ['-c', '/opt/dynatrace/gateway/k8scrt2jks.sh']
    volumeMounts:
    - mountPath: /var/lib/dynatrace/gateway/ssl
    volumes:
    emptyDir: {}
    secret:
    secretName: dynatrace-tokens
    emptyDir: {}
    emptyDir: {}
    emptyDir: {}
    emptyDir: {}
    emptyDir: {}
    emptyDir: {}
    updateStrategy:
    type: RollingUpdate
  4. Modify your deployment YAML file.
    Add environment configuration details to the ag-deployment-example.yaml file, making sure to replace:
    • CPU_ARCHITECTURE with your CPU architecture. Possible values are amd64, arm64, s390x, and ppcle64
    • <REPOSITORY_URL> with one of the supported registries
    • <IMAGE_TAG> with correct image tag (examples)
    • <YOUR_ENVIRONMENT_ID> with your environment ID
      To determine your environment ID, see the syntax below.
      • SaaS: https://{your-environment-id}.live.dynatrace.com
      • Managed: https://{your-domain}/e/{your-environment-id}
    • <YOUR_COMMUNICATION_ENDPOINTS> with the value of communicationEndpoints obtained in Prerequisites from the connectivity information
      The list of server communication endpoints (communicationEndpoints) may change over time.
    • <YOUR_KUBE-SYSTEM_NAMESPACE_UUID> with the kube-system namespace UUID obtained in Prerequisites
      For PPC64le architecture, additional configuration is required. For details, see ActiveGate container image.
    Options:
    • Optional Enable AppArmor if available.
      AppArmor profile
      To maintain compatibility with a wider array of Kubernetes clusters, the AppArmor profile is not specified in ag-deployment-example.yaml. If AppArmor is available on your Kubernetes cluster, we recommend that you additionally annotate StatefulSet with a runtime/default profile.
      spec:
      template:
      metadata:
      annotations:
      container.apparmor.security.beta.kubernetes.io/activegate: runtime/default
    • Optional Apply resource limits according to sizing hints.
      K8S monitoring and agent routing sizing hints
      The table below lists suggested ActiveGate CPU and memory sizes according to the number of pods:
      Number of podsCPUMemory
      Up to 100 pods
      500 millicores (mCores)
      512 mebibytes (MiB)
      Up to 1,000 pods
      1,000 millicores (mCores)
      1 gibibyte (GiB)
      Up to 5,000 pods
      1,500 millicores (mCores)
      2 gibibytes (GiB)
      Over 5,000 pods
      over 1,500 millicores (mCores)1
      over 2 gibibytes (GiB)1
      1
      Actual figures depend on your environment.
      These limits should be taken as a guideline. They're designed to prevent ActiveGate startup process slowdown and excessive node resource usage. The default values cover a large range of different cluster sizes; you can modify them according to your needs, based on the ActiveGate self-monitoring metrics.
    For additional configuration options, see Containerized ActiveGate configuration.
  5. Deploy ActiveGate.
    kubectl apply -f ./ag-deployment-example.yaml
    oc apply -f ./ag-deployment-example.yaml
  6. To verify that ActiveGate has successfully connected to the Dynatrace server, go to Deployment Status > ActiveGates.
  2. Create a secret that holds the environment URL and authentication details for this registry.
    kubectl -n dynatrace create secret docker-registry dynatrace-docker-registry \
    --docker-server=<YOUR_ENVIRONMENT_URL> \
    --docker-username=<YOUR_ENVIRONMENT_ID> \
    --docker-password=<YOUR_INSTALLER_DOWNLOAD_TOKEN>
    oc -n dynatrace create secret docker-registry dynatrace-docker-registry \
    --docker-password=<YOUR_INSTALLER_DOWNLOAD_TOKEN> -n dynatrace
    You need to replace
    • <YOUR_ENVIRONMENT_URL> with your environment URL (without https://). Example: abc12345.live.dynatrace.com
    • <YOUR_ENVIRONMENT_ID> with the Docker account username (the same as the ID in your environment URL above).
    • <YOUR_INSTALLER_DOWNLOAD_TOKEN> with the access token with InstallerDownload scope you created in Prerequisites
  3. Create a secret that holds the authentication details to the Dynatrace server used by ActiveGate.
    You need to replace
  4. Create an ag-deployment-example.yaml file with the following content:
    apiVersion: v1
    kind: Service
    metadata:
    spec:
    type: ClusterIP
    selector:
    ports:
    - protocol: TCP
    port: 443
    apiVersion: apps/v1
    kind: StatefulSet
    metadata:
    labels:
    spec:
    serviceName: ""
    selector:
    matchLabels:
    template:
    metadata:
    labels:
    spec:
    affinity:
    nodeAffinity:
    nodeSelectorTerms:
    - matchExpressions:
    operator: In
    values:
    - amd64
    operator: In
    values:
    - linux
    containers:
    - name: activegate
    image: <YOUR_ENVIRONMENT_URL>/linux/activegate:raw
    ports:
    protocol: TCP
    env:
    - name: DT_TENANT
    - name: DT_SERVER
    value: dynatrace
    volumeMounts:
    readOnly: true
    livenessProbe:
    failureThreshold: 2
    httpGet:
    path: /rest/state
    port: ag-https
    scheme: HTTPS
    periodSeconds: 30
    successThreshold: 1
    timeoutSeconds: 1
    readinessProbe:
    failureThreshold: 3
    httpGet:
    path: /rest/health
    port: ag-https
    scheme: HTTPS
    periodSeconds: 15
    successThreshold: 1
    timeoutSeconds: 1
    resources:
    requests:
    cpu: 500m
    memory: 512Mi
    limits:
    cpu: 1000m
    memory: 1.5Gi
    securityContext:
    capabilities:
    drop:
    - all
    privileged: false
    runAsNonRoot: true
    seccompProfile:
    initContainers:
    volumeMounts:
    imagePullSecrets:
    - name: dynatrace-docker-registry
    volumes:
    emptyDir: {}
    secret:
    emptyDir: {}
    emptyDir: {}
    emptyDir: {}
    emptyDir: {}
    emptyDir: {}
    emptyDir: {}
    updateStrategy:
    type: RollingUpdate
  5. Modify your deployment YAML file.
    Options:
    • Optional You can change the image version by using different version tag
      Versions
      • raw—The latest available image
      • 1.sprint.patchlevel-raw—An image for a particular ActiveGate version (for example, 1.297.0-raw)
      AppArmor profile
      spec:
      template:
      metadata:
      annotations:
      Up to 100 pods
      512 mebibytes (MiB)
      Up to 1,000 pods
      1 gibibyte (GiB)
      Up to 5,000 pods
      2 gibibytes (GiB)
      Over 5,000 pods
      1
  6. Deploy ActiveGate.
  7. To verify that ActiveGate has successfully connected to the Dynatrace server, go to Deployment Status > ActiveGates.
Additional configuration for PPC64le architecture
To finish setup of containerized ActiveGate on PPC64le architecture, two more steps are needed:
  1. Increase the number of CPU cores: To match the performance of the x86-64 architecture, the CPU core count should be increased by a factor of four.
  2. Reduce the number of ActiveGate threads:
    • Create custom properties as described in Advanced configuration
    • Add the following lines to custom.properties:
      [com.compuware.apm.webserver]
      threadpool-max-size=30
      async-worker-pool-coresize=60
To achieve better performance, we highly recommend applying the steps above.
Dedicated deployments
  • To monitor Kubernetes/Openshift, select one of the following:
    • Use Dynatrace Operator
    • Deploy ActiveGate directly as a StatefulSet
  • To collect logs from Kubernetes, use Log Monitoring.
FIPS-compliant images
ActiveGate version 1.315+
There is a dedicated, FIPS-compliant ActiveGate image available. See ActiveGate FIPS compliance for information on requirements, limitations, where to get the image, and how to verify the deployment.
