With the AWS Systems Manager Distributor you can distribute and automatically deploy OneAgent on your EC2 instances using the AWS Systems Manager Distributor.
Before you start deploying the DynatraceOneAgent distributor package, make sure your Amazon EC2 instances meet the following prerequisites:
AWS tags on instance metadata are turned off by default at launch. To allow them follow the official AWS documentation.
AWS Systems Manager must be set up for your AWS account and AWS Systems Manager Agent (SSM Agent) must be installed on the EC2 instances where you want to deploy DynatraceOneAgent distributor package. Follow the AWS Systems Manager Quick Setup or more comprehensive Setting up AWS Systems Manager.
The DynatraceOneAgent distributor package is supported on the following operating systems:
Support for ARM64 architecture, including AWS Graviton processors, is in Early Access release.
Dynatrace OneAgent distributor package requires Wget installed on your Linux-based instance. If there's no Wget installed on your instance, the OneAgent distributor package will install it for you automatically. Wget is necessary to download the latest OneAgent version.
AWS CLI is required if you're using Parameter Store or Secrets Manager to store the PaaS token. If there's no AWS CLI installed, the OneAgent distributor package will install the latest version.
If your instance is running AWS CLI version 1, you need to add the SSM_DYNATRACE_TOKEN_REGION parameter with the region where your instance is running to the SSM Distributor configuration, as region autodiscovery via EC2 IMDS is only available in AWS CLI version 2.
Deploying OneAgent using AWS Systems Manager Distributor is currently not supported if you set Dynatrace Managed Cluster as the SSM_DYNATRACE_URL parameter value.
To install the DynatraceOneAgent distributor package
Open the AWS Systems Manager console.
In the navigation panel, select Distributor.
On the Distributor page, select Third party and select the DynatraceOneAgent package.
Select the installation mode. You can install or update the DynatraceOneAgent package one time or schedule the installation. For details on installing the Distributor packages, see AWS Systems Manager Distributor documentation.
To configure the DynatraceOneAgent package installation, add the parameters to the Additional Arguments field of the Systems Manager Run Command.
The parameters require a PaaS token.
To provide a PaaS token, we recommend using a centralized cloud secret management system, such as AWS Secrets Manager or Parameter Store.
Provide a PaaS token via AWS Secrets Manager Recommended
Create a secret:
aws secretsmanager create-secret --name dynatrace-paas-token --secret-string "paas_token_value"
Add an IAM policy to the IAM role attached to your EC2 instance(s) that grants access to retrieve the secret from the Secrets Manager. Here's an example policy that's attached to the IAM role (other options can be found in the AWS User Guide):
{"Version": "2012-10-17","Statement": [{"Effect": "Allow","Action": "secretsmanager:GetSecretValue","Resource": "arn:aws:secretsmanager:us-east-2:123456789012:secret:dynatrace-paas-token"}]}
If your Secret is encrypted with a CMK KMS Key, you also need to grant Decrypt permissions on both: the IAM role and the KMS Key policy. For more information, check the AWS Secrets Manager documentation.
Provide the secret name via SSM_DYNATRACE_TOKEN_SECRET_ID on the SSM Distributor package parameters. Example:
{"SSM_DYNATRACE_URL" : "https://environment.live.dynatrace.com/","SSM_DYNATRACE_TOKEN_SECRET_ID" : "dynatrace-paas-token"}
Provide a PaaS token via Parameter Store Recommended
Create a SecureString parameter type.
aws ssm put-parameter --name "dynatrace-paas-token" --value "paas_token_value" --type "SecureString"
Add an IAM policy to the IAM role attached to your EC2 instance(s) that grants access to retrieve the secret from the Parameter Store. Here's an example policy. For more information, check the AWS Systems Manager Documentation.
{"Version": "2012-10-17","Statement": [{"Effect": "Allow","Action": ["ssm:GetParameter"],"Resource": "arn:aws:ssm:us-east-2:123456789012:parameter/dynatrace-paas-token"}]}
Provide the secret name via SSM_DYNATRACE_TOKEN_PARAMETER_NAME on the SSM Distributor parameters. Example:
{"SSM_DYNATRACE_URL" : "https://environment.live.dynatrace.com/","SSM_DYNATRACE_TOKEN" : "abcdefghij123456",}
Provide a PaaS token via SSM_DYNATRACE_TOKEN env variable. not-recommended
Using the SSM_DYNATRACE_TOKEN parameter is not secure because the PaaS token will be visible in the Run Command history.
{"SSM_DYNATRACE_URL" : "https://your-tenant.live.dynatrace.com/","SSM_DYNATRACE_HOST_GROUP" : "MY-HOST-GROUP","SSM_DYNATRACE_MONITORING_MODE" : "infra-only","SSM_DYNATRACE_APP_LOG_CONTENT_ACCESS" : "true","SSM_DYNATRACE_TOKEN_SECRET_ID" : "dynatrace-paas-token"}
Verify the installation.
Initiating DynatraceOneAgent_ 1.0.51 installPlugin aws:runPowerShellScript ResultStatus Successinstall output: Running install.ps1Installing Dynatrace OneAgent on Windows...script version: 1.0.51Configuration parameters:- Dynatrace URL: https://environment.live.dynatrace.com/--quietInstalling Dynatrace Package on Windows...- downloading agent from: https://environment.live.dynatrace.com/ to: %PROGRAMDATA%\Amazon\SSM\Packages\DynatraceOneAgent_\1.0.51\Dynatrace-OneAgent-Windows.exe- running installation- cleaning upDoneSuccessfully installed DynatraceOneAgent_ 1.0.51
Restart all processes that you want to monitor. You’ll be prompted with a list of the processes that need to be restarted. Note that you can restart your processes at any time, even during your organization’s next planned maintenance period. Though until all processes have been restarted, you’ll only see a limited set of metrics, for example CPU or memory consumption.
The DynatraceOneAgent distributor package provides a number of Dynatrace-specific parameters that map directly to the following OneAgent installation parameters.
Learn more about customizing OneAgent installation on Linux and Windows.
| Distributor parameter | Maps to OneAgent parameter | Default value | Description |
| environment specific | The address of the OneAgent communication endpoint, which is a Dynatrace component that OneAgent sends data to. Depending on your deployment, it can be a Dynatrace SaaS cluster or an ActiveGate. A Dynatrace Managed Cluster is currently not supported. Note: Make sure you add a trailing slash at the end of URL (for example, |
| unset | The name of a host group you want to assign the host to. |
| fullstack | When set to |
| true | When set to |
| N/A | N/A | The PaaS token secret name or ARN in Secrets Manager, used to get the PaaS token value. |
| N/A | N/A | The PaaS token parameter name in Parameter Store, used to get the PaaS token value. |
| N/A | N/A | Optional AWS region used to get a secret from a different region. If not set, the AWS CLI auto discovers the instance region. (This parameter is required if you're running AWS CLI v1, as it can't discover the instance region from EC2 IMDS). |
| N/A | N/A | The PaaS token used to download the OneAgent installer. Using the |
Remember that SSM_DYNATRACE_TOKEN_PARAMETER_NAME and SSM_DYNATRACE_TOKEN_SECRET_ID are mutually exclusive. Choose either one.
