Classic (formerly 'built-in') AWS metrics
  • Dynatrace Classic
  • Reference
  • 1-min read
For information about differences between classic services and other services, see Migrate from AWS classic (formerly 'built-in') services to cloud services.
The table below lists all AWS metrics that Dynatrace collects by default when you enable AWS monitoring.
For all other metrics collected by Dynatrace per configurable AWS service, see the cloud services pages.
Metric keyNameUnitAggregations
builtin:cloud.aws.alb.connections.active
ALB number of active connections
Countautoavgmaxmin
builtin:cloud.aws.alb.connections.new
ALB number of new connections
Countautovalue
builtin:cloud.aws.alb.errors.alb.http4xx
ALB number of 4XX errors
Countautovalue
builtin:cloud.aws.alb.errors.alb.http5xx
ALB number of 5XX errors
Countautovalue
builtin:cloud.aws.alb.errors.target.http4xx
ALB number of 4XX target errors
Countautovalue
builtin:cloud.aws.alb.errors.target.http5xx
ALB number of 5XX target errors
Countautovalue
builtin:cloud.aws.alb.errors.rejCon
ALB number of rejected connections
Countautovalue
builtin:cloud.aws.alb.errors.targConn
ALB number of target connection errors
Countautovalue
builtin:cloud.aws.alb.errors.tlsNeg
ALB number of client TLS negotiation errors
Countautovalue
builtin:cloud.aws.alb.bytes
ALB number of processed bytes
Countautovalue
builtin:cloud.aws.alb.lcus
ALB number of consumed LCUs
Countautovalue
builtin:cloud.aws.alb.requests
ALB number of requests
Countautovalue
builtin:cloud.aws.alb.respTime
ALB target response time
Secondautoavgmaxmin
builtin:cloud.aws.asg.running
Number of running EC2 instances (ASG)
Countautoavgmaxmin
builtin:cloud.aws.asg.stopped
Number of stopped EC2 instances (ASG)
Countautoavgmaxmin
builtin:cloud.aws.asg.terminated
Number of terminated EC2 instances (ASG)
Countautoavgmaxmin
builtin:cloud.aws.az.running
Number of running EC2 instances (AZ)
Countautoavgmaxmin
builtin:cloud.aws.az.stopped
Number of stopped EC2 instances (AZ)
Countautoavgmaxmin
builtin:cloud.aws.az.terminated
Number of terminated EC2 instances (AZ)
Countautoavgmaxmin
builtin:cloud.aws.dynamo.capacityUnits.consumed.read
DynamoDB read capacity units
Countautovalue
builtin:cloud.aws.dynamo.capacityUnits.consumed.write
DynamoDB write capacity units
Countautovalue
builtin:cloud.aws.dynamo.capacityUnits.provisioned.read
DynamoDB provisioned read capacity units
Countautovalue
builtin:cloud.aws.dynamo.capacityUnits.provisioned.write
DynamoDB provisioned write capacity units
Countautovalue
builtin:cloud.aws.dynamo.capacityUnits.read
DynamoDB read capacity units %
Percent (%)autoavgmaxmin
builtin:cloud.aws.dynamo.capacityUnits.write
DynamoDB write capacity units %
builtin:cloud.aws.dynamo.errors.system
DynamoDB number of requests with HTTP 500 status code
Countautovalue
builtin:cloud.aws.dynamo.errors.user
DynamoDB number of requests with HTTP 400 status code
Countautovalue
builtin:cloud.aws.dynamo.requests.latency
DynamoDB number of successful request latency for operation
Millisecondautoavgmaxmin
builtin:cloud.aws.dynamo.requests.returnedItems
DynamoDB number of items returned by operation
Countautovalue
builtin:cloud.aws.dynamo.requests.throttled
DynamoDB number of throttled requests for operation
Countautovalue
builtin:cloud.aws.dynamo.throttledEvents.read
DynamoDB number of read throttled events
Countautovalue
builtin:cloud.aws.dynamo.throttledEvents.write
DynamoDB number of write throttled events
Countautovalue
builtin:cloud.aws.dynamo.tables
Number of tables for AvailabilityZone
Countautoavgmaxmin
builtin:cloud.aws.ebs.latency.read
EBS volume read latency
Secondautoavgmaxmin
builtin:cloud.aws.ebs.latency.write
EBS volume write latency
Secondautoavgmaxmin
builtin:cloud.aws.ebs.ops.consumed
EBS volume consumed OPS
Per secondautovalue
builtin:cloud.aws.ebs.ops.read
EBS volume read OPS
Per secondautoavgmaxmin
builtin:cloud.aws.ebs.ops.write
EBS volume write OPS
builtin:cloud.aws.ebs.throughput.percent
EBS volume throughput %
builtin:cloud.aws.ebs.throughput.read
EBS volume read throughput
builtin:cloud.aws.ebs.throughput.write
EBS volume write throughput
builtin:cloud.aws.ebs.idleTime
EBS volume idle time %
builtin:cloud.aws.ebs.queue
EBS volume queue length
Countautoavgmaxmin
builtin:cloud.aws.ec2.cpu.usage
EC2 CPU usage %
builtin:cloud.aws.ec2.disk.readOps
EC2 instance storage read IOPS
builtin:cloud.aws.ec2.disk.readRate
EC2 instance storage read rate
kB/sautoavgmaxmin
builtin:cloud.aws.ec2.disk.writeOps
EC2 instance storage write IOPS
builtin:cloud.aws.ec2.disk.writeRate
EC2 instance storage write rate
kB/sautoavgmaxmin
builtin:cloud.aws.ec2.net.rx
EC2 network data received rate
Byte/secondautoavgmaxmin
builtin:cloud.aws.ec2.net.tx
EC2 network data transmitted rate
builtin:cloud.aws.elb.errors.backend.connection
CLB backend connection errors
Countautovalue
builtin:cloud.aws.elb.errors.backend.http2xx
CLB number of backend 2XX errors
Countautovalue
builtin:cloud.aws.elb.errors.backend.http3xx
CLB number of backend 3XX errors
Countautovalue
builtin:cloud.aws.elb.errors.backend.http4xx
CLB number of backend 4XX errors
Countautovalue
builtin:cloud.aws.elb.errors.backend.http5xx
CLB number of backend 5XX errors
Countautovalue
builtin:cloud.aws.elb.errors.elb.http4xx
CLB number of 4XX errors
Countautovalue
builtin:cloud.aws.elb.errors.elb.http5xx
CLB number of 5XX errors
Countautovalue
builtin:cloud.aws.elb.errors.frontend
CLB frontend errors percentage
builtin:cloud.aws.elb.hosts.healthy
CLB number of healthy hosts
Countautoavgmaxmin
builtin:cloud.aws.elb.hosts.unhealthy
CLB number of unhealthy hosts
Countautoavgmaxmin
builtin:cloud.aws.elb.latency
CLB latency
Secondautoavgmaxmin
builtin:cloud.aws.elb.reqCompl
CLB number of completed requests
Countautovalue
builtin:cloud.aws.lambda.concExecutions
LambdaFunction concurrent executions count
Countautoavgcountmaxminsum
builtin:cloud.aws.lambda.duration
LambdaFunction code execution time.
Millisecondautoavgcountmaxminsum
builtin:cloud.aws.lambda.errors
LambdaFunction number of failed invocations with HTTP 4XX status code
Countautovalue
builtin:cloud.aws.lambda.errorsRate
LambdaFunction rate of failed invocations to all invocations %
builtin:cloud.aws.lambda.invocations
LambdaFunction number of times a function is invoked
Countautovalue
builtin:cloud.aws.lambda.provConcExecutions
LambdaFunction provisioned concurrent executions count
Countautovalue
builtin:cloud.aws.lambda.provConcInvocations
LambdaFunction provisioned concurrency invocation count
Countautovalue
builtin:cloud.aws.lambda.provConcSpilloverInvocations
LambdaFunction provisioned concurrency spillover invocation count
Countautovalue
builtin:cloud.aws.lambda.throttlers
LambdaFunction throttled function invocation count
Countautovalue
builtin:cloud.aws.nlb.flow.active
NLB number of active flows
Countautoavgmaxmin
builtin:cloud.aws.nlb.flow.new
NLB number of new flows
Countautovalue
builtin:cloud.aws.nlb.tcp.reset.client
NLB number of client resets
Countautovalue
builtin:cloud.aws.nlb.tcp.reset.elb
NLB number of resets
Countautovalue
builtin:cloud.aws.nlb.tcp.reset.target
NLB number of target resets
Countautovalue
builtin:cloud.aws.nlb.bytes
NLB number of processed bytes
Countautovalue
builtin:cloud.aws.nlb.lcus
NLB number of consumed LCUs
Countautovalue
builtin:cloud.aws.rds.cpu.usage
RDS CPU usage %
builtin:cloud.aws.rds.latency.read
RDS read latency
Secondautoavgmaxmin
builtin:cloud.aws.rds.latency.write
RDS write latency
Secondautoavgmaxmin
builtin:cloud.aws.rds.memory.freeable
RDS freeable memory
Byteautoavgmaxmin
builtin:cloud.aws.rds.memory.swap
RDS swap usage
Byteautoavgmaxmin
builtin:cloud.aws.rds.net.rx
RDS network received throughput
builtin:cloud.aws.rds.net.tx
RDS network transmitted throughput
builtin:cloud.aws.rds.ops.read
RDS read IOPS
builtin:cloud.aws.rds.ops.write
RDS write IOPS
builtin:cloud.aws.rds.throughput.read
RDS read throughput
builtin:cloud.aws.rds.throughput.write
RDS write throughput
builtin:cloud.aws.rds.connections
RDS connections
Countautoavgmaxmin
builtin:cloud.aws.rds.free
RDS free storage space %
builtin:cloud.aws.rds.restarts
RDS restarts
Countautovalue
Related tags
Infrastructure ObservabilityAWS
