Multidimensional analysis
  • Dynatrace Classic
  • How-to guide
  • 4-min read
The Multidimensional analysis view enables you to analyze web requests of your services with fine-tuned filtering, so you can focus your analysis on the dimensions that matter most. This view is easily configurable and serves as a convenient entry point for in-depth analysis of your services.
With multidimensional analysis, you can investigate custom views: Top web requests, Database statements, and Exception analysis.
To access the Multidimensional analysis page
  1. Go to Multidimensional Analysis.
  2. Choose one of the analysis options that you want to investigate, or Create analysis view.
Pre-defined views
Top web requests
Analyze the most frequent and most expensive web requests.
Top database statements
Analyze the most frequent and most expensive database statements.
Exception analysis
Understand and analyze all code-level exceptions.
Data source
Multidimensional analysis uses trace and request data as its data source, which includes information on distributed traces and requests.
  • For timeframes shorter than two hours, a higher resolution (below 1 minute) is used.
  • For larger amounts of data, especially for longer timeframes or unfiltered analysis, sampling is applied: only a fraction of trace and request data is used.
  • To view the information about the data used for analysis and suggestions on how to improve accuracy, hover over Refine.
  • To include more data to the analysis, select Refine.
Multidimensional analysis vs charts
Unlike Data Explorer, multidimensional analysis uses trace and request data, not metric data, so values on multidimensional analysis charts might differ from values on custom charts.
Configure view
In Configure view, you can set up multiple filtering capabilities. The view updates automatically as you change the parameters.
ParameterDescription
Metric
The metric to be analyzed.
Aggregation
How the metric values are aggregated. Available aggregations depend on the selected metric.
Split mode
How dimensions specified in Split by dimension are treated.
  • Split by services—each dimension is displayed separately for each service.
  • Merge by services—same dimensions from different services are merged into one.
Split by dimension
A list of dimensions by which the requests are split.
You can specify several dimensions. Place your cursor in the input field to see the available options. The requests are split by dimension in the specified order.
Filter requests
Filter the requests to be included to the view. Place your cursor in the input field to see the available options.
Criteria of the same type are grouped by OR logic. Criteria of different types are grouped by AND logic.
You can export the table data in a comma-separated values (CSV) file.
  1. In the lower-right corner of the page, select Show export menu More.
    Show export menu
    Show export menu
  2. Select Export visible data or Export table data.
    OptionExported dataFieldsNumber of entries
    Export visible data
    The currently displayed area of the table, taking into account applied filters
    Only visible data
    Up to 100 top dimensions
    Export table data
    All table data
    All the available data related to top dimensions
View
Top database statements page
The chart shows the top 15 dimensions (all other dimensions are aggregated into a single dimension) and the table beneath contains up to 85 more dimensions, bringing the total number of chartable dimensions to 100. The view instantly adapts to the changes you make in the Configure view pane.
In the Actions column of the table, you can select:
  • Filter Filter to filter the view for the specified dimension.
  • More (…) to access further analysis options from the Analyze menu.
For timeframes containing data older than 10 days, you can turn on Show data retention to better understand which data is available for which period directly from the chart.
Save view
Once the view is configured, you can save it for quick access in the future. Just select Save view and provide a name.
Dynatrace provides several views out of the box:
  • Exception analysis
  • Top database statements
  • Top web requests
Calculated service metric
You can save the configured view as a calculated service metric, which you can use just like any other Dynatrace metric, for example for charting or data export via API.
Only new data is written to calculated metrics; retrospective data is not included.
Limits
  • Only new data is written to calculated metrics; retrospective data is not included.
  • You can have up to 500 enabled calculated metrics per environment and up to 100 enabled calculated metrics per service.
  • Classic calculated metrics support at most 100 dimension values. This is referred to as the "top X" rule, as you can select fewer depending on your configuration. However you choose the top 100 dimension values, the remaining dimensions are aggregated into a single timeseries and the dimension value is accessible through a special remainder dimension. The remainder filter condition allowing you to filter on this remainder dimension.
  • Grail calculated service metrics with cardinality higher than 2000 within any 5-minute window in the past 2 weeks or since the last metric change are automatically disabled in Grail. Enabling such metrics on Grail is not allowed. If the metric is already enabled on Grail, you are informed of the metric rejection via the Metric & Dimensions Usage + Rejections ready-made dashboard. To enable a Classic metric on Grail and keep collecting incoming data on Grail, make sure cardinality stays below the limit.
To create a calculated service metric from a multidimensional analysis view
  2. Select Create analysis view.
  3. Optional Select the management zone. The new metric will be restricted to data from this zone.
  4. Configure the view. Find the description of available options in the Configure view section above.
  5. In the View pane, select Create metric.
    Create calculated metric
  6. Specify the name for the metric. The name is added to the metric key automatically.
  7. Optional If needed, customize the metric key.
    Once a metric is created, you can't change its key.
  8. Optional If you want to fine-tune your metric, select Advanced options to configure additional parameters of the metric. For details, see Calculated metrics for services.
  9. Select Create metric.
Related topics
  • Service metrics API
  • Calculated metrics for services
Related tags
Application ObservabilityMultidimensional AnalysisMultidimensional Analysis
