Profiling and optimization
  • Overview
  • 1-min read
  • Published Sep 25, 2018
Apart from automated problem detection, Dynatrace offers you a set of analysis tools that you can use to manually detect problems.
  • CPU profiling highlights the biggest CPU consumers in your environment and allows you to drill down to the method level of a CPU problem.
  • Memory dump analysis and Process crashes enable you to detect application crashes on Windows and Linux and analyze the core dumps of these crashes.
To access profiling and optimization options
  1. Go to Profiling & Optimization.
  2. Select the analysis option you want to investigate among CPU profiling, Memory dumps, and Process crashes.
Related tags
Application Observability
