The following applies to VMware only. For other virtualization platforms, you only need to install OneAgent for virtualized host monitoring, as the monitoring of virtualization management layers is supported only for VMware.
When you set up VMware monitoring, you can manage the infrastructural elements (such as hosts and VMs) that you want Dynatrace to monitor by setting or adjusting permissions in vCenter.
See the examples below for details on how to manage user permissions for your VMs.
To monitor all VMs in a resource pool (or any other "parent" in VMware infrastructure hierarchy), you need to
To assign users read-only permission to your VMware hosts
+ sign.Because a VM might migrate to a different host at a later time, we recommend that you enable Dynatrace monitoring (add read-only permissions) on all hosts to which your VM might migrate.
To assign users read-only permission to the resource pool
+ sign.After assigning users read-only permission to your VMware hosts and to the resource pool, the hosts and VMs to which you granted permissions will be visible in Dynatrace.
To exclude a single VM from Dynatrace monitoring, such as a VM that inherited read-only permissions from its parent, you need to remove user read permissions for the respective VM.
To remove a user's read permissions for a VM
+ sign.To add a single VM to Dynatrace monitoring, you need to assign users read-only permission to the respective VM.
To assign users read-only permission to a VM
+ sign.
