You can keep track of current service-level objectives related to a Kubernetes/OpenShift workload on the Kubernetes workload details pages.
An SLO is directly connected to a workload when the entity selector of an SLO meets the following criteria:
"CLOUD_APPLICATION".To see only SLOs that are directly connected to the workload, make sure that Show only directly connected SLOs is turned on.
An SLO isn't directly connected to a workload when, in the entity selector of an SLO, no entity ID is provided.
Example: When generic values such as type("CLOUD_APPLICATION"),tag("slo") are provided, the query results in all SLOs for all workloads, including the current workload.
To see SLOs that are not directly connected to the workload, turn off Show only directly connected SLOs.
Select Details to view a chart of the respective SLO metrics.
In Actions, select
If no SLOs are found, you can
Select a different timeframe in the upper-right corner.
Select Add SLO to create an SLO in the SLO wizard.
