Use cases
  • Latest Dynatrace
  • 1-min read
  • Published Oct 11, 2023
The Kubernetes app Kubernetes (new) enhances the management and monitoring of your Kubernetes environment. It enables a range of functionalities.
  • Health and performance monitoring
    • Access detailed views of your clusters that display all critical health signals for resources such as nodes, namespaces, and workloads.
    • Automatically discover, and track the status and performance of, nodes and pods.
    • View metrics, events, and logs from the pods and nodes in a single interface.
    • Gain a high-level overview of all your clusters, regardless of the cloud services they're hosted on.
  • Resource efficiency and optimization
    • Understand the overall utilization of resources across your clusters.
    • Identify workloads that are consuming the most resources.
    • Analyze workloads to determine which ones are under-resourced and adjust resource allocations.
Find detailed descriptions of various use cases below.
