Dynatrace Operator release notes version 0.10.0
  • Latest Dynatrace
  • Release notes
  • Published Dec 15, 2022
Release date: Nov 30, 2022
New features and enhancements
  • Warning Breaking change ActiveGate token support is now enabled by default.
    • An additional API token scope is required: activeGateTokenManagement.create
    • To disable it, set feature.dynatrace.com/activegate-authtoken=false
  • You can configure build label propagation from pod to environment variables.
  • You can configure the CSI driver log garbage collection interval.
  • Recommended labels are added to the Dockerfile and release image.
Troubleshoot subcommand
  • Unless the --dynakube parameter is provided, all DynaKubes in the given namespace are analyzed.
  • All errors detected by the troubleshoot subcommand are now displayed.
Labels and annotations
  • You can disable webhook injection for a pod in a monitored namespace with the following pod annotation: dynatrace.com/inject=false.
  • Configurable labels and annotations for OneAgent and ActiveGate are added to the DynaKube custom resource.
Feature flags
  • You can configure release label propagation by setting the feature.dynatrace.com/label-version-detection=true feature flag in DynaKube.
  • You can configure a more aggressive garbage collection on the CSI driver:
    • The MAX_UNMOUNTED_VOLUME_AGE environment variable on the provisioner container of the CSI driver pod sets the interval in days.
Helm
  • The csidriver.maxUnmountedVolumeAge parameter has been added to set the MAX_UNMOUNTED_VOLUME_AGE environment variable.
Resolved issues
  • Fixed the missing pod metadata for the enrichment file in case OneAgent injection is disabled.
  • Fixed ActiveGate StatefulSet recreation when labeled externally.
  • Fixed custom image handling in the troubleshoot subcommand.
  • Fixed the missing readOnlyRootFilesystem for ActiveGate init container in case the feature flag is set.
  • Reduced the default memory usage for Dynatrace Operator components by reducing logger instances.
  • Lowered the default CSI driver OneAgent log garbage collection interval to seven days.
References
See the GitHub release notes.
Related tags
Dynatrace Platform
