Limit API calls to AWS using tags
  • Dynatrace Classic
  • How-to guide
  • 2-min read
  • Published Jul 19, 2017
By default, Dynatrace monitors all Amazon Web Services that have been specified in your permission policy. Optionally, you can use tagging to limit the AWS resources (AWS service instances) that are monitored by Dynatrace.
Add tags in AWS
To add a tag
  1. Sign in to your AWS Management Console and go to the dashboard of the service you want to tag.
  2. Select Instances to see a list of your environments, then select an instance.
  3. In the panel below the list, select Tags.
  4. Select Add/Edit tags, then select Create tag.
  5. Enter a tag key/value pair (for example, 'monitor_dynatrace' for Key, and 'true' for Value).
  6. Select Save.
Dynatrace monitoring tags work for built-in: EC2, RDS, ELB, EBS, auto-scaling groups, DynamoDB, Lambda, and most cloud services. Expand the table below to see which services can be filtered by tags.
Tag filtering per service
NameTags monitoring & filtering
Amazon EC2 Auto Scaling (built-in)
yes
AWS Lambda (built-in)
yes
Amazon Application and Network Load Balancer (built-in)
yes
Amazon DynamoDB (built-in)
yes
Amazon EBS (built-in)
yes
Amazon EC2 (built-in)
yes
Amazon Elastic Load Balancer (ELB) (built-in)
yes
Amazon RDS (built-in)
yes
Amazon S3 (built-in)
yes
AWS Certificate Manager Private Certificate Authority
yes
Amazon API Gateway
yes
AWS App Runner
yes
Amazon AppStream
yes
AWS AppSync
yes
Amazon Athena
yes
Amazon Aurora
yes
AWS Billing
Amazon Keyspaces
yes
AWS Chatbot
Amazon CloudFront
yes
AWS CloudHSM
yes
Amazon CloudSearch
AWS CodeBuild
yes
Amazon Cognito
Amazon Connect
AWS DataSync
yes
Amazon DynamoDB Accelerator (DAX)
yes
AWS Database Migration Service (AWS DMS)
yes
Amazon DocumentDB
yes
AWS Direct Connect
yes
Amazon DynamoDB
yes
Amazon EBS
yes
Amazon EC2 Spot Fleet
Amazon EC2 API
Amazon Elastic Container Service (ECS)
yes
Amazon ECS Container Insights
yes
Amazon Elastic File System (EFS)
yes
Amazon Elastic Kubernetes Service (EKS)
yes
Amazon ElastiCache (EC)
yes
AWS Elastic Beanstalk
yes
Amazon Elastic Inference
yes
Amazon Elastic Transcoder
Amazon Elastic Map Reduce (EMR)
yes
Amazon Elasticsearch Service (ES)
yes
Amazon EventBridge
yes
Amazon FSx
yes
Amazon GameLift
AWS Glue
yes
Amazon Inspector
yes
AWS Internet of Things (IoT)
AWS IoT Things Graph
AWS IoT Analytics
Amazon Managed Streaming for Kafka
yes
Amazon Kinesis Data Analytics
yes
Amazon Data Firehose
yes
Amazon Kinesis Data Streams
yes
Amazon Kinesis Video Streams
yes
AWS Lambda
yes
Amazon Lex
yes
Amazon CloudWatch Logs
yes
AWS Elemental MediaTailor
yes
AWS Elemental MediaConnect
AWS Elemental MediaConvert
yes
AWS Elemental MediaPackage Live
yes
AWS Elemental MediaPackage Video on Demand
yes
Amazon MQ
Amazon VPC NAT Gateways
yes
Amazon Neptune
yes
AWS OpsWorks
yes
Amazon Polly
Amazon QLDB
yes
Amazon RDS
yes
Amazon Redshift
yes
Amazon Rekognition
AWS RoboMaker
yes
Amazon Route 53
yes
Amazon Route 53 Resolver
yes
Amazon S3
yes
Amazon SageMaker Batch Transform Jobs
Amazon SageMaker Endpoints
yes
Amazon SageMaker Endpoint Instances
yes
Amazon SageMaker Ground Truth
Amazon SageMaker Processing Jobs
Amazon SageMaker Training Jobs
AWS Service Catalog
Amazon Simple Email Service (SES)
Amazon Simple Notification Service (SNS)
yes
Amazon Simple Queue Service (SQS)
yes
AWS Systems Manager - Run Command
AWS Step Functions
AWS Storage Gateway
yes
Amazon SWF
Amazon Textract
AWS Transfer Family
yes
AWS Transit Gateway
yes
Amazon Translate
AWS Trusted Advisor
AWS API Usage
AWS Site-to-Site VPN
yes
AWS WAF Classic
AWS WAF
Amazon WorkMail
yes
Amazon WorkSpaces
yes
Configure Dynatrace to use AWS tags
Dynatrace enables you to use up to 10 AWS tags at a time. Once configured, Dynatrace takes tagged services into account when querying performance counters.
AWS tag key/value pairs are executed with an OR operator. Keys don't need to be unique.
Tag-based AWS monitoring offers a lot of flexibility and is particularly helpful if:
  • You leverage multiple Dynatrace environments and you want to monitor distinct AWS services running under the same AWS account.
    Tag examples: monitor_dynatrace : myenvironment1; monitor_dynatrace : myenvironment2
  • You need to monitor the same AWS account, but distinguish between production and staging services.
    Tag examples:
    monitor_dynatrace : production; monitor_dynatrace : staging
To assign tags to a specific AWS instance
  1. Set up Dynatrace for AWS monitoring.
  2. In Dynatrace, go to Settings > Cloud and virtualization > AWS and select the AWS instance.
  3. For Resources to be monitored, select Monitor resources selected by tags.
  4. Enter the Key and Value.
  5. Select Save.
Related tags
Infrastructure ObservabilityAWS
