Monitor AWS Lambda
  • Dynatrace Classic
  • How-to guide
  • 1-min read
  • Published Mar 06, 2024
For information about differences between classic services and other services, see Migrate from AWS classic (formerly 'built-in') services to cloud services.
Dynatrace ingests metrics for multiple preselected namespaces, including AWS Lambda. You can view metrics for each service instance, split metrics into multiple dimensions, and create custom charts that you can pin to your dashboards.
Prerequisites
To enable monitoring for this service, you need
  • ActiveGate version 1.197+
  • For Dynatrace SaaS deployments, you need an Environment ActiveGate or a Multi-environment ActiveGate.
    For role-based access in SaaS deployment, you need an Environment ActiveGate installed on an Amazon EC2 host.
  • Dynatrace version 1.200+
  • An updated AWS monitoring policy to include the additional AWS services.
To update the AWS IAM policy, use the JSON below, containing the monitoring policy (permissions) for all supporting services.
JSON predefined policy for all supporting services
"Version": "2012-10-17",
"Statement": [
"Sid": "VisualEditor0",
"Effect": "Allow",
"Action": [
"acm-pca:ListCertificateAuthorities",
"apigateway:GET",
"apprunner:ListServices",
"appstream:DescribeFleets",
"appsync:ListGraphqlApis",
"athena:ListWorkGroups",
"autoscaling:DescribeAutoScalingGroups",
"cloudformation:ListStackResources",
"cloudfront:ListDistributions",
"cloudhsm:DescribeClusters",
"cloudsearch:DescribeDomains",
"cloudwatch:GetMetricData",
"cloudwatch:GetMetricStatistics",
"cloudwatch:ListMetrics",
"codebuild:ListProjects",
"datasync:ListTasks",
"dax:DescribeClusters",
"directconnect:DescribeConnections",
"dms:DescribeReplicationInstances",
"dynamodb:ListTables",
"dynamodb:ListTagsOfResource",
"ec2:DescribeAvailabilityZones",
"ec2:DescribeInstances",
"ec2:DescribeNatGateways",
"ec2:DescribeSpotFleetRequests",
"ec2:DescribeTransitGateways",
"ec2:DescribeVolumes",
"ec2:DescribeVpnConnections",
"ecs:ListClusters",
"eks:ListClusters",
"elasticache:DescribeCacheClusters",
"elasticbeanstalk:DescribeEnvironmentResources",
"elasticbeanstalk:DescribeEnvironments",
"elasticfilesystem:DescribeFileSystems",
"elasticloadbalancing:DescribeInstanceHealth",
"elasticloadbalancing:DescribeListeners",
"elasticloadbalancing:DescribeLoadBalancers",
"elasticloadbalancing:DescribeRules",
"elasticloadbalancing:DescribeTags",
"elasticloadbalancing:DescribeTargetHealth",
"elasticmapreduce:ListClusters",
"elastictranscoder:ListPipelines",
"es:ListDomainNames",
"events:ListEventBuses",
"firehose:ListDeliveryStreams",
"fsx:DescribeFileSystems",
"gamelift:ListFleets",
"glue:GetJobs",
"inspector:ListAssessmentTemplates",
"kafka:ListClusters",
"kinesis:ListStreams",
"kinesisanalytics:ListApplications",
"kinesisvideo:ListStreams",
"lambda:ListFunctions",
"lambda:ListTags",
"lex:GetBots",
"logs:DescribeLogGroups",
"mediaconnect:ListFlows",
"mediaconvert:DescribeEndpoints",
"mediapackage-vod:ListPackagingConfigurations",
"mediapackage:ListChannels",
"mediatailor:ListPlaybackConfigurations",
"opsworks:DescribeStacks",
"qldb:ListLedgers",
"rds:DescribeDBClusters",
"rds:DescribeDBInstances",
"rds:DescribeEvents",
"rds:ListTagsForResource",
"redshift:DescribeClusters",
"robomaker:ListSimulationJobs",
"route53:ListHostedZones",
"route53resolver:ListResolverEndpoints",
"s3:ListAllMyBuckets",
"sagemaker:ListEndpoints",
"sns:ListTopics",
"sqs:ListQueues",
"storagegateway:ListGateways",
"sts:GetCallerIdentity",
"swf:ListDomains",
"tag:GetResources",
"tag:GetTagKeys",
"transfer:ListServers",
"workmail:ListOrganizations",
"workspaces:DescribeWorkspaces"
"Resource": "*"
If you don't want to add permissions to all services, and just select permissions for certain services, consult the table below. The table contains a set of permissions that are required for All AWS cloud services and, for each supporting service, a list of optional permissions specific to that service.
Permissions required for AWS monitoring integration:
  • "cloudwatch:GetMetricData"
  • "cloudwatch:GetMetricStatistics"
  • "cloudwatch:ListMetrics"
  • "sts:GetCallerIdentity"
  • "tag:GetResources"
  • "tag:GetTagKeys"
  • "ec2:DescribeAvailabilityZones"
Complete list of permissions for cloud services
NamePermissions
All monitored Amazon services Requiredcloudwatch:GetMetricData,
cloudwatch:GetMetricStatistics,
cloudwatch:ListMetrics,
sts:GetCallerIdentity,
tag:GetResources,
tag:GetTagKeys,
AWS Certificate Manager Private Certificate Authorityacm-pca:ListCertificateAuthorities
Amazon MQ
Amazon API Gatewayapigateway:GET
AWS App Runnerapprunner:ListServices
Amazon AppStreamappstream:DescribeFleets
AWS AppSyncappsync:ListGraphqlApis
Amazon Athenaathena:ListWorkGroups
Amazon Aurorards:DescribeDBClusters
Amazon EC2 Auto Scalingautoscaling:DescribeAutoScalingGroups
Amazon EC2 Auto Scaling (built-in)autoscaling:DescribeAutoScalingGroups
AWS Billing
Amazon Keyspaces
AWS Chatbot
Amazon CloudFrontcloudfront:ListDistributions
AWS CloudHSMcloudhsm:DescribeClusters
Amazon CloudSearchcloudsearch:DescribeDomains
AWS CodeBuildcodebuild:ListProjects
Amazon Cognito
Amazon Connect
Amazon Elastic Kubernetes Service (EKS)eks:ListClusters
AWS DataSyncdatasync:ListTasks
Amazon DynamoDB Accelerator (DAX)dax:DescribeClusters
AWS Database Migration Service (AWS DMS)dms:DescribeReplicationInstances
Amazon DocumentDBrds:DescribeDBClusters
AWS Direct Connectdirectconnect:DescribeConnections
Amazon DynamoDBdynamodb:ListTables
Amazon DynamoDB (built-in)dynamodb:ListTables,
Amazon EBSec2:DescribeVolumes
Amazon EBS (built-in)ec2:DescribeVolumes
Amazon EC2 API
Amazon EC2 (built-in)ec2:DescribeInstances
Amazon EC2 Spot Fleetec2:DescribeSpotFleetRequests
Amazon Elastic Container Service (ECS)ecs:ListClusters
Amazon ECS Container Insightsecs:ListClusters
Amazon ElastiCache (EC)elasticache:DescribeCacheClusters
AWS Elastic Beanstalkelasticbeanstalk:DescribeEnvironments
Amazon Elastic File System (EFS)elasticfilesystem:DescribeFileSystems
Amazon Elastic Inference
Amazon Elastic Map Reduce (EMR)elasticmapreduce:ListClusters
Amazon Elasticsearch Service (ES)es:ListDomainNames
Amazon Elastic Transcoderelastictranscoder:ListPipelines
Amazon Elastic Load Balancer (ELB) (built-in)elasticloadbalancing:DescribeInstanceHealth,
elasticloadbalancing:DescribeListeners,
elasticloadbalancing:DescribeLoadBalancers,
elasticloadbalancing:DescribeRules,
elasticloadbalancing:DescribeTags,
Amazon EventBridgeevents:ListEventBuses
Amazon FSxfsx:DescribeFileSystems
Amazon GameLiftgamelift:ListFleets
AWS Glueglue:GetJobs
Amazon Inspectorinspector:ListAssessmentTemplates
AWS Internet of Things (IoT)
AWS IoT Analytics
Amazon Managed Streaming for Kafkakafka:ListClusters
Amazon Kinesis Data Analyticskinesisanalytics:ListApplications
Amazon Data Firehosefirehose:ListDeliveryStreams
Amazon Kinesis Data Streamskinesis:ListStreams
Amazon Kinesis Video Streamskinesisvideo:ListStreams
AWS Lambdalambda:ListFunctions
AWS Lambda (built-in)lambda:ListFunctions,
lambda:ListTags
Amazon Lexlex:GetBots
Amazon Application and Network Load Balancer (built-in)elasticloadbalancing:DescribeInstanceHealth,
Amazon CloudWatch Logslogs:DescribeLogGroups
AWS Elemental MediaConnectmediaconnect:ListFlows
AWS Elemental MediaConvertmediaconvert:DescribeEndpoints
AWS Elemental MediaPackage Livemediapackage:ListChannels
AWS Elemental MediaPackage Video on Demandmediapackage-vod:ListPackagingConfigurations
AWS Elemental MediaTailormediatailor:ListPlaybackConfigurations
Amazon VPC NAT Gatewaysec2:DescribeNatGateways
Amazon Neptunerds:DescribeDBClusters
AWS OpsWorksopsworks:DescribeStacks
Amazon Polly
Amazon QLDBqldb:ListLedgers
Amazon RDSrds:DescribeDBInstances
Amazon RDS (built-in)rds:DescribeDBInstances,
rds:DescribeEvents,
Amazon Redshiftredshift:DescribeClusters
Amazon Rekognition
AWS RoboMakerrobomaker:ListSimulationJobs
Amazon Route 53route53:ListHostedZones
Amazon Route 53 Resolverroute53resolver:ListResolverEndpoints
Amazon S3s3:ListAllMyBuckets
Amazon S3 (built-in)s3:ListAllMyBuckets
Amazon SageMaker Batch Transform Jobs
Amazon SageMaker Endpoint Instancessagemaker:ListEndpoints
Amazon SageMaker Endpointssagemaker:ListEndpoints
Amazon SageMaker Ground Truth
Amazon SageMaker Processing Jobs
Amazon SageMaker Training Jobs
AWS Service Catalog
Amazon Simple Email Service (SES)
Amazon Simple Notification Service (SNS)sns:ListTopics
Amazon Simple Queue Service (SQS)sqs:ListQueues
AWS Systems Manager - Run Command
AWS Step Functions
AWS Storage Gatewaystoragegateway:ListGateways
Amazon SWFswf:ListDomains
Amazon Textract
AWS IoT Things Graph
AWS Transfer Familytransfer:ListServers
AWS Transit Gatewayec2:DescribeTransitGateways
Amazon Translate
AWS Trusted Advisor
AWS API Usage
AWS Site-to-Site VPNec2:DescribeVpnConnections
AWS WAF Classic
AWS WAF
Amazon WorkMailworkmail:ListOrganizations
Amazon WorkSpacesworkspaces:DescribeWorkspaces
Example of JSON policy for one single service.
JSON policy for Amazon API Gateway
"Statement": [
"Effect": "Allow",
"Action": [
"apigateway:GET",
"tag:GetResources",
"tag:GetTagKeys",
"Resource": "*"
In this example, from the complete list of permissions you need to select
  • "apigateway:GET" for Amazon API Gateway
  • "cloudwatch:GetMetricData", "cloudwatch:GetMetricStatistics", "cloudwatch:ListMetrics", "sts:GetCallerIdentity", "tag:GetResources", "tag:GetTagKeys", and "ec2:DescribeAvailabilityZones" for All AWS cloud services.
AWS endpoints that need to be reachable from ActiveGate with corresponding AWS services
EndpointService
autoscaling.<REGION>.amazonaws.comAmazon EC2 Auto Scaling (built-in), Amazon EC2 Auto Scaling
lambda.<REGION>.amazonaws.comAWS Lambda (built-in), AWS Lambda
elasticloadbalancing.<REGION>.amazonaws.comAmazon Application and Network Load Balancer (built-in), Amazon Elastic Load Balancer (ELB) (built-in)
dynamodb.<REGION>.amazonaws.comAmazon DynamoDB (built-in), Amazon DynamoDB
ec2.<REGION>.amazonaws.comAmazon EBS (built-in), Amazon EC2 (built-in), Amazon EBS, Amazon EC2 Spot Fleet, Amazon VPC NAT Gateways, AWS Transit Gateway, AWS Site-to-Site VPN
rds.<REGION>.amazonaws.comAmazon RDS (built-in), Amazon Aurora, Amazon DocumentDB, Amazon Neptune, Amazon RDS
s3.<REGION>.amazonaws.comAmazon S3 (built-in)
acm-pca.<REGION>.amazonaws.comAWS Certificate Manager Private Certificate Authority
apigateway.<REGION>.amazonaws.comAmazon API Gateway
apprunner.<REGION>.amazonaws.comAWS App Runner
appstream2.<REGION>.amazonaws.comAmazon AppStream
appsync.<REGION>.amazonaws.comAWS AppSync
athena.<REGION>.amazonaws.comAmazon Athena
cloudfront.amazonaws.comAmazon CloudFront
cloudhsmv2.<REGION>.amazonaws.comAWS CloudHSM
cloudsearch.<REGION>.amazonaws.comAmazon CloudSearch
codebuild.<REGION>.amazonaws.comAWS CodeBuild
datasync.<REGION>.amazonaws.comAWS DataSync
dax.<REGION>.amazonaws.comAmazon DynamoDB Accelerator (DAX)
dms.<REGION>.amazonaws.comAWS Database Migration Service (AWS DMS)
directconnect.<REGION>.amazonaws.comAWS Direct Connect
ecs.<REGION>.amazonaws.comAmazon Elastic Container Service (ECS), Amazon ECS Container Insights
elasticfilesystem.<REGION>.amazonaws.comAmazon Elastic File System (EFS)
eks.<REGION>.amazonaws.comAmazon Elastic Kubernetes Service (EKS)
elasticache.<REGION>.amazonaws.comAmazon ElastiCache (EC)
elasticbeanstalk.<REGION>.amazonaws.comAWS Elastic Beanstalk
elastictranscoder.<REGION>.amazonaws.comAmazon Elastic Transcoder
es.<REGION>.amazonaws.comAmazon Elasticsearch Service (ES)
events.<REGION>.amazonaws.comAmazon EventBridge
fsx.<REGION>.amazonaws.comAmazon FSx
gamelift.<REGION>.amazonaws.comAmazon GameLift
glue.<REGION>.amazonaws.comAWS Glue
inspector.<REGION>.amazonaws.comAmazon Inspector
kafka.<REGION>.amazonaws.comAmazon Managed Streaming for Kafka
models.lex.<REGION>.amazonaws.comAmazon Lex
logs.<REGION>.amazonaws.comAmazon CloudWatch Logs
api.mediatailor.<REGION>.amazonaws.comAWS Elemental MediaTailor
mediaconnect.<REGION>.amazonaws.comAWS Elemental MediaConnect
mediapackage.<REGION>.amazonaws.comAWS Elemental MediaPackage Live
mediapackage-vod.<REGION>.amazonaws.comAWS Elemental MediaPackage Video on Demand
opsworks.<REGION>.amazonaws.comAWS OpsWorks
qldb.<REGION>.amazonaws.comAmazon QLDB
redshift.<REGION>.amazonaws.comAmazon Redshift
robomaker.<REGION>.amazonaws.comAWS RoboMaker
route53.amazonaws.comAmazon Route 53
route53resolver.<REGION>.amazonaws.comAmazon Route 53 Resolver
api.sagemaker.<REGION>.amazonaws.comAmazon SageMaker Endpoints, Amazon SageMaker Endpoint Instances
sns.<REGION>.amazonaws.comAmazon Simple Notification Service (SNS)
sqs.<REGION>.amazonaws.comAmazon Simple Queue Service (SQS)
storagegateway.<REGION>.amazonaws.comAWS Storage Gateway
swf.<REGION>.amazonaws.comAmazon SWF
transfer.<REGION>.amazonaws.comAWS Transfer Family
workmail.<REGION>.amazonaws.comAmazon WorkMail
workspaces.<REGION>.amazonaws.comAmazon WorkSpaces
Enable monitoring
To learn how to enable service monitoring, see Enable service monitoring.
View service metrics
You can view the service metrics in your Dynatrace environment either on the custom device overview page or on your Dashboards page.
View metrics on the custom device overview page
To access the custom device overview page
  1. Go to Technologies Technologies & Processes Classic.
  2. Filter by service name and select the relevant custom device group.
  3. Once you select the custom device group, you're on the custom device group overview page.
  4. The custom device group overview page lists all instances (custom devices) belonging to the group. Select an instance to view the custom device overview page.
View metrics on your dashboard
You can also view metrics in the Dynatrace web UI on dashboards. There is no preset dashboard available for this service, but you can create your own dashboard.
To check the availability of preset dashboards for each AWS service, see the list below.
Preset dashboard availability list
AWS servicePreset dashboard
Amazon EC2 Auto Scaling (built-in)Not applicable
AWS Lambda (built-in)Not applicable
Amazon Application and Network Load Balancer (built-in)Not applicable
Amazon DynamoDB (built-in)Not applicable
Amazon EBS (built-in)Not applicable
Amazon EC2 (built-in)Not applicable
Amazon Elastic Load Balancer (ELB) (built-in)Not applicable
Amazon RDS (built-in)Not applicable
Amazon S3 (built-in)Not applicable
AWS Certificate Manager Private Certificate AuthorityNot applicable
All monitored Amazon servicesNot applicable
Amazon API GatewayNot applicable
AWS App RunnerNot applicable
Amazon AppStreamApplicable
AWS AppSyncApplicable
Amazon AthenaApplicable
Amazon AuroraNot applicable
Amazon EC2 Auto ScalingApplicable
AWS BillingApplicable
Amazon KeyspacesApplicable
AWS ChatbotApplicable
Amazon CloudFrontNot applicable
AWS CloudHSMApplicable
Amazon CloudSearchApplicable
AWS CodeBuildApplicable
Amazon CognitoNot applicable
Amazon ConnectApplicable
AWS DataSyncApplicable
Amazon DynamoDB Accelerator (DAX)Applicable
AWS Database Migration Service (AWS DMS)Applicable
Amazon DocumentDBApplicable
AWS Direct ConnectApplicable
Amazon DynamoDBNot applicable
Amazon EBSNot applicable
Amazon EC2 Spot FleetNot applicable
Amazon EC2 APIApplicable
Amazon Elastic Container Service (ECS)Not applicable
Amazon ECS Container InsightsApplicable
Amazon Elastic File System (EFS)Not applicable
Amazon Elastic Kubernetes Service (EKS)Applicable
Amazon ElastiCache (EC)Not applicable
AWS Elastic BeanstalkApplicable
Amazon Elastic InferenceApplicable
Amazon Elastic TranscoderApplicable
Amazon Elastic Map Reduce (EMR)Not applicable
Amazon Elasticsearch Service (ES)Not applicable
Amazon EventBridgeApplicable
Amazon FSxApplicable
Amazon GameLiftApplicable
AWS GlueNot applicable
Amazon InspectorApplicable
AWS Internet of Things (IoT)Not applicable
AWS IoT Things GraphApplicable
AWS IoT AnalyticsApplicable
Amazon Managed Streaming for KafkaApplicable
Amazon Kinesis Data AnalyticsNot applicable
Amazon Data FirehoseNot applicable
Amazon Kinesis Data StreamsNot applicable
Amazon Kinesis Video StreamsNot applicable
AWS LambdaNot applicable
Amazon LexApplicable
Amazon CloudWatch LogsApplicable
AWS Elemental MediaTailorApplicable
AWS Elemental MediaConnectApplicable
AWS Elemental MediaConvertApplicable
AWS Elemental MediaPackage LiveApplicable
AWS Elemental MediaPackage Video on DemandApplicable
Amazon MQApplicable
Amazon VPC NAT GatewaysNot applicable
Amazon NeptuneApplicable
AWS OpsWorksApplicable
Amazon PollyApplicable
Amazon QLDBApplicable
Amazon RDSNot applicable
Amazon RedshiftNot applicable
Amazon RekognitionApplicable
AWS RoboMakerApplicable
Amazon Route 53Applicable
Amazon Route 53 ResolverApplicable
Amazon S3Not applicable
Amazon SageMaker Batch Transform JobsNot applicable
Amazon SageMaker EndpointsNot applicable
Amazon SageMaker Endpoint InstancesNot applicable
Amazon SageMaker Ground TruthNot applicable
Amazon SageMaker Processing JobsNot applicable
Amazon SageMaker Training JobsNot applicable
AWS Service CatalogApplicable
Amazon Simple Email Service (SES)Not applicable
Amazon Simple Notification Service (SNS)Not applicable
Amazon Simple Queue Service (SQS)Not applicable
AWS Systems Manager - Run CommandApplicable
AWS Step FunctionsApplicable
AWS Storage GatewayApplicable
Amazon SWFApplicable
Amazon TextractApplicable
AWS Transfer FamilyApplicable
AWS Transit GatewayApplicable
Amazon TranslateApplicable
AWS Trusted AdvisorApplicable
AWS API UsageApplicable
AWS Site-to-Site VPNApplicable
AWS WAF ClassicApplicable
AWS WAFApplicable
Amazon WorkMailApplicable
Amazon WorkSpacesApplicable
Available metrics
This service monitors a part of AWS Lambda (AWS/Lambda). While you have this service configured, you can't have AWS Lambda (built-in) service turned on.
FunctionName is the main dimension.
NameDescriptionUnitStatisticsDimensionsRecommended
AsyncEventAgeThe time between when Lambda successfully queues the event and when the function is invoked.MillisecondsMultiFunctionName, Resource
AsyncEventAgeMillisecondsMultiFunctionName
AsyncEventAgeMillisecondsMultiRegion
AsyncEventsDroppedThe number of events that are dropped without successfully executing the function.CountSumFunctionName, Resource
AsyncEventsDroppedCountSumFunctionName
AsyncEventsDroppedCountSumRegion
AsyncEventsReceivedThe number of events that Lambda successfully queues for processing.CountSumFunctionName, Resource
AsyncEventsReceivedCountSumFunctionName
AsyncEventsReceivedCountSumRegion
ConcurrentExecutionsThe number of function instances that are processing events.CountMaximumFunctionName, Resource
ConcurrentExecutionsCountMaximumFunctionName
ConcurrentExecutionsCountSumFunctionName, Resource
ConcurrentExecutionsCountSumFunctionNameApplicable
ConcurrentExecutionsCountSumRegionApplicable
DeadLetterErrorsFor asynchronous invocation, the number of times that Lambda attempts to send an event to a dead-letter queue (DLQ) but fails.CountSumFunctionName, Resource
DeadLetterErrorsCountSumFunctionName
DeadLetterErrorsCountSumRegion
DestinationDeliveryFailuresFor asynchronous invocation and supported event source mappings, the number of times that Lambda attempts to send an event to a destination but fails.CountSumFunctionName, Resource
DestinationDeliveryFailuresCountSumFunctionName
DestinationDeliveryFailuresCountSumRegion
DurationThe amount of time that your function code spends processing an event.MillisecondsMultiFunctionName, Resource
DurationMillisecondsMultiFunctionNameApplicable
DurationMillisecondsMultiRegionApplicable
ErrorsThe number of invocations that result in a function error.CountSumFunctionName, Resource
ErrorsCountSumFunctionNameApplicable
ErrorsCountSumRegionApplicable
InvocationsThe number of times that your function code is invoked, including successful invocations and invocations that result in a function error.CountSumFunctionName, Resource
InvocationsCountSumFunctionNameApplicable
InvocationsCountSumRegionApplicable
IteratorAgeFor DynamoDB, Kinesis, and Amazon DocumentDB event sources, the age of the last record in the event.MillisecondsMultiFunctionName, Resource
IteratorAgeMillisecondsMultiFunctionName
IteratorAgeMillisecondsMultiRegion
OffsetLagFor self-managed Apache Kafka and Amazon Managed Streaming for Apache Kafka (Amazon MSK) event sources, the difference in offset between the last record written to a topic and the last record that your function's consumer group processed.MillisecondsMultiFunctionName, Resource
OffsetLagMillisecondsMultiFunctionName
OffsetLagMillisecondsMultiRegion
PostRuntimeExtensionsDurationThe cumulative amount of time that the runtime spends running code for extensions after the function code has completed.MillisecondsMultiFunctionName, ResourceApplicable
PostRuntimeExtensionsDurationMillisecondsMultiFunctionName
PostRuntimeExtensionsDurationMillisecondsMultiRegionApplicable
ProvisionedConcurrencyInvocationsThe number of times that your function code is invoked using provisioned concurrency.CountSumFunctionName, ResourceApplicable
ProvisionedConcurrencyInvocationsCountSumFunctionName
ProvisionedConcurrencyInvocationsCountSumRegionApplicable
ProvisionedConcurrencySpilloverInvocationsThe number of times that your function code is invoked using standard concurrency when all provisioned concurrency is in use.CountSumFunctionName, Resource
ProvisionedConcurrencySpilloverInvocationsCountSumFunctionName
ProvisionedConcurrencySpilloverInvocationsCountSumRegion
ProvisionedConcurrencyUtilizationFor a version or alias, the value of ProvisionedConcurrentExecutions divided by the total amount of provisioned concurrency allocated.CountSumFunctionName, Resource
ProvisionedConcurrencyUtilizationCountSumFunctionName
ProvisionedConcurrencyUtilizationCountSumRegion
ProvisionedConcurrentExecutionsThe number of function instances that are processing events using provisioned concurrency.CountSumFunctionName, ResourceApplicable
ProvisionedConcurrentExecutionsCountSumFunctionName
ProvisionedConcurrentExecutionsCountSumFunctionName, Resource
ProvisionedConcurrentExecutionsCountSumFunctionNameApplicable
ProvisionedConcurrentExecutionsCountSumRegionApplicable
RecursiveInvocationsDroppedThe number of times that Lambda has stopped invocation of your function because it's detected that your function is part of an infinite recursive loop.CountSumFunctionName, Resource
RecursiveInvocationsDroppedCountSumFunctionName
RecursiveInvocationsDroppedCountSumRegion
ThrottlesThe number of invocation requests that are throttled.CountSumFunctionName, Resource
ThrottlesCountSumFunctionNameApplicable
ThrottlesCountSumRegionApplicable
UnreservedConcurrentExecutionsFor a Region, the number of events that functions without reserved concurrency are processing.CountSumRegion
Related tags
Infrastructure ObservabilityAWS
