Scrape Prometheus metrics with the OTel Collector
  • Latest Dynatrace
  • How-to guide
  • 1-min read
  • Published Jun 23, 2026
The OTel Collector can scrape Prometheus endpoints and forward the resulting metrics to Dynatrace. Choose one of two deployment modes based on your scaling and reliability needs.
Prometheus
Standard (recommended)
A metric ingestion architecture that auto-scales, provides redundancy, and handles high-volume Prometheus workloads on Kubernetes. Recommended for most production environments.
Prometheus
Simplified
A single Collector for a small and static set of endpoints that don't need auto-scaling or redundancy.
How to choose
CriteriaStandardSimplified
Best for
Production environments
Small and static target sets, demos
Architecture
Target Allocator, scraper, and gateway pools
A single Collector
Auto-scaling
Yes, with Horizontal Pod Autoscalers
No
Redundancy
Yes
No
Target discovery
Automatic via ServiceMonitor, PodMonitor, and ScrapeConfig CRDs
Simple service discovery or static endpoint configuration
Platform
Kubernetes
Any
Scaling
If the simplified deployment runs out of headroom but you don't yet need the standard architecture, you can run multiple independent simplified Collectors, each scraping a distinct set of targets (for example, one per namespace or team).
  • This keeps the same single-Collector configuration.
  • You must partition targets yourself.
  • There is no shared auto-scaling.
Because of this, we recommend the standard setup (which scales automatically) for most use cases.
For general information about scaling the Collector, see How to scale the OTel Collector.
Related tags
Application Observability
