AppEngine - EdgeConnect API
  • Latest Dynatrace
  • Reference
  • Published Oct 13, 2026
Manage Dynatrace AppEngine EdgeConnect configurations, list, create, get, update, delete, rotate OAuth client secrets, and match URL host patterns.
Building a Dynatrace app?
Use the @dynatrace-sdk/client-app-engine-edge-connect SDK client instead of calling this API directly — it handles authentication, typing, and the environment URL for you. This REST reference is for external and automation use.
Overview
EdgeConnect API manages EdgeConnect configurations that specify which HTTP requests matching what URL host patterns will be forwarded to and executed by that EdgeConnect. This enables forwarding of HTTP requests done in the Dynatrace runtime to resources in private networks secured by a deployed EdgeConnect.
Authentication
Platform API endpoints use Platform token and OAuth client authentication. Attach a platform token or OAuth access token to the Authorization HTTP header using the Bearer scheme.
--header 'Authorization: Bearer <platform-token-or-oauth-access-token>'
For details, see Tokens and authentication and Platform tokens.
Endpoints
  • List EdgeConnects (GET /edge-connects)
  • Create an EdgeConnect (POST /edge-connects)
  • Get an EdgeConnect (GET /edge-connects/{edgeConnectId})
  • Update an EdgeConnect (PUT /edge-connects/{edgeConnectId})
  • Delete an EdgeConnect (DELETE /edge-connects/{edgeConnectId})
  • Rotate an EdgeConnect OAuth client secret (POST /edge-connects/{edgeConnectId}/oauthClient:rotate)
  • Get matching EdgeConnects for a URL (GET /edge-connects:match)
Related tags
Platform APIDynatrace Platform
