Get matching EdgeConnects for a URL
  • Latest Dynatrace
  • Reference
  • Published Oct 13, 2026
Get the matching EdgeConnect for a URL in Dynatrace with the EdgeConnect API, plus alternative EdgeConnects with more general host patterns.
GETSaaShttps://{your-environment-id}.apps.dynatrace.com/v1/edge-connects:match
Overview
You provide the url query parameter to check which EdgeConnect matches that URL and which alternatives also match. The response returns the matched EdgeConnect and considered alternatives that are more general.
Authentication
To execute this request, you need a platform token or OAuth access token with app-engine:edge-connects:read scope. To learn how to obtain and use it, see Tokens and authentication.
Parameters
ParameterTypeDescriptionInRequired
urlstring
The URL which is used to check if there are any EdgeConnects with matching host patterns configured. Must be RFC 2396 compliant and use "http" or "https" as its scheme
queryRequired
Response
Response codes
CodeTypeDescription
200MatchedResponse
The matched EdgeConnect and considered alternatives which are more general
400ErrorResponse
Bad Request
default--
Response body objects
The MatchedResponse object
ElementTypeDescription
matchedMatchedEdgeConnect
Contains information about the EdgeConnect and the matched pattern
secondaryMatchingMatchedEdgeConnect[]-
The MatchedEdgeConnect object
idstring-
nameEdgeConnectName-
matchedPatternstring-
metadataMetadata-
The EdgeConnectName object
The Metadata object
instancesEdgeConnectInstance[]-
oauthClientStatusstring
The status of the OAuth client
The element can hold these values
  • ACTIVE
  • INACTIVE
  • PENDING_DELETION
  • DELETED
The EdgeConnectInstance object
versionstring-
instanceIdstring-
The ErrorResponse object
errorError-
The Error object
codeinteger-
messagestring-
detailsErrorDetails-
The ErrorDetails object
constraintViolationsConstraintViolation[]-
missingScopesstring[]-
missingPermissionsstring[]-
The ConstraintViolation object
messagestring-
pathstring-
parameterLocationstring-
Response body JSON models
"matched": {
"id": "11111111-2222-4444-3333-555555555555",
"name": "internal-services",
"matchedPattern": "string",
"metadata": {
"instances": [
"version": "1.46.2",
"instanceId": "string"
"oauthClientStatus": "ACTIVE"
"secondaryMatching": [
Related tags
Platform APIDynatrace Platform
