Create an EdgeConnect
  • Latest Dynatrace
  • Reference
  • Published Oct 13, 2026
Create an EdgeConnect in Dynatrace with the EdgeConnect API, setting host patterns, mappings, and optional OAuth client details in one request.
POSTSaaShttps://{your-environment-id}.apps.dynatrace.com/v1/edge-connects
Overview
You can either specify a UUID in the request body or a random UUID will be assigned to the created EdgeConnect configuration.
The name must not be longer than 50 characters and must be 'RFC 1123' compliant. The OAuth client ID is optional. If no OAuth client ID is provided an OAuth client must be generated for that EdgeConnect. This additionally requires the oauth2:clients:manage scope allowing generation of OAuth clients with the app-engine:edge-connects:connect scope, e.g. via the following policy statement: ALLOW oauth2:clients:manage where oauth2:scopes='app-engine:edge-connects:connect' The oauth2:clients:manage scope is not required if you provide an OAuth client ID.
The OAuth client ID, secret and resource will be returned in the response. The OAuth client secret is not retrievable later on.
Authentication
To execute this request, you need a platform token or OAuth access token with app-engine:edge-connects:write scope. To learn how to obtain and use it, see Tokens and authentication.
Parameters
ParameterTypeDescriptionInRequired
bodyEdgeConnect
Maps the specified host patterns to this EdgeConnect
bodyRequired
Request body objects
The EdgeConnect object
ElementTypeDescriptionRequired
idstring-Optional
nameEdgeConnectName-Required
hostPatternsHostPattern[]-Required
hostMappingsHostMapping[]-Optional
oauthClientIdstring
Id of OAuth client used to connect by the EdgeConnect
Optional
oauthClientSecretstring
Secret of OAuth client used to connect by the EdgeConnect. Only provided when creating a new EdgeConnect.
Optional
oauthClientResourcestring
Resource of OAuth client used to connect by the EdgeConnect. Only provided when creating a new EdgeConnect.
Optional
modificationInfoModificationInfo-Optional
metadataMetadata-Optional
managedByDynatraceOperatorboolean
Flag to identify if an EdgeConnect is managed by the Dynatrace operator. False by default!
Optional
The EdgeConnectName object
The HostPattern object
Either an IP, or a domain name which may contain a wildcard ('') as the leftmost label. If a '' is used, it must be followed by at least two labels.
The HostMapping object
Todo
fromstring-Required
tostring-Required
The ModificationInfo object
lastModifiedBystring-Required
lastModifiedTimestring-Required
The Metadata object
instancesEdgeConnectInstance[]-Optional
oauthClientStatusstring
The status of the OAuth client
The element can hold these values
  • ACTIVE
  • INACTIVE
  • PENDING_DELETION
  • DELETED
Optional
The EdgeConnectInstance object
versionstring-Optional
instanceIdstring-Optional
Request body JSON model
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
"id": "11111111-2222-4444-3333-555555555555",
"name": "internal-services",
"hostPatterns": [
"*.internal.org"
"hostMappings": [
"from": "test.local",
"to": "kubernetes.my.cluster.local"
"oauthClientId": "dt0s02.AIOUP56P",
"oauthClientSecret": "dt0s02.AIOUP56P.5ODBJEQYBA4KLD2F6F6EHQZKYK5Q45RARKVCHICXKLMAXVVLIH2L6N5RLMDDY4QA",
"oauthClientResource": "urn:dtenvironment:wu31a2p3",
"modificationInfo": {
"lastModifiedBy": "12345678-abcd-efgh-1234-123456789",
"lastModifiedTime": "2022-01-01T01:02:03.165Z"
"metadata": {
"instances": [
"version": "1.46.2",
"instanceId": "string"
"oauthClientStatus": "ACTIVE"
"managedByDynatraceOperator": false
Response
Response codes
CodeTypeDescription
201EdgeConnect
The EdgeConnect has been created successfully
400ErrorResponse
Bad Request
default--
Response body objects
idstring-
oauthClientIdstring
metadataMetadata-
Todo
fromstring-
tostring-
The Metadata object
  • ACTIVE
  • INACTIVE
  • PENDING_DELETION
  • DELETED
versionstring-
instanceIdstring-
The ErrorResponse object
errorError-
The Error object
codeinteger-
messagestring-
detailsErrorDetails-
The ErrorDetails object
constraintViolationsConstraintViolation[]-
missingScopesstring[]-
missingPermissionsstring[]-
The ConstraintViolation object
messagestring-
pathstring-
parameterLocationstring-
Response body JSON models
"hostPatterns": [
"*.internal.org"
"hostMappings": [
"metadata": {
"instances": [
"error": {
"code": 1,
"message": "string",
"details": {
"constraintViolations": [
"error": {
"code": 400,
"message": "Constraints violated. Properties already exist in another configuration.",
"details": {
"path": "hostPatterns[0]",
"message": "Host pattern must be unique across configurations.\nHost pattern 'myjira.com' already exists in EdgeConnect configuration 'InternalServices'."
"missingScopes": [
"string"
"missingPermissions": [
"string"
Related tags
Platform APIDynatrace Platform
