List EdgeConnects
  • Latest Dynatrace
  • Reference
  • Published Oct 13, 2026
List EdgeConnects in Dynatrace with the EdgeConnect API, using filters, paging, and optional extra fields to refine the returned configurations.
GETSaaShttps://{your-environment-id}.apps.dynatrace.com/v1/edge-connects
Overview
You use the filter, page, page-size, and add-fields query parameters to control which EdgeConnect configurations appear and how much detail you receive. The response returns a list of all EdgeConnects.
Authentication
To execute this request, you need a platform token or OAuth access token with app-engine:edge-connects:read scope. To learn how to obtain and use it, see Tokens and authentication.
Parameters
ParameterTypeDescriptionInRequired
add-fieldsstring
Provide a comma separated list of additional properties to be included in the response.
queryOptional
filterstring
The filter parameter for filtering the set of returned resources If this parameter is omitted, no filtering is applied and all states will be returned.
Filtering by string type parameters name, modificationInfo.lastModifiedBy when using one of the operators contains, starts-with and ends-with is case insensitive.
When using the operators =and !=, filtering is case sensitive.
The following fields are legal filtering parameters - any other field names will result in a HTTP 400 response:
  • name, supported operators: =, !=, contains, starts-with, ends-with
  • hostPatterns, supported operators: =, !=, contains, starts-with, ends-with
  • oauthClientId, supported operators: =, !=, contains, starts-with, ends-with
  • modificationInfo.lastModifiedTime, supported operators: =, !=, <, <=, >, >=
  • modificationInfo.lastModifiedBy, supported operators: =, !=, contains, starts-with, ends-with
The following constraints apply:
  • Field names are case-sensitive.
  • Conditions can be connected via operators and and or. A single condition can be negated by not.
  • Strings must be enclosed in single quotes. e.g. name contains 'my-string'
  • Single quotes within a string must be escaped with a backslash: e.g. name starts-with 'it\'s a string'
  • Maximum nesting depth (via brackets) is 2.
  • Maximum length is 256 characters.
Examples:
  • name starts-with 'game-'
  • modificationInfo.lastModifiedTime >= '2022-07-01T00:10:05.000Z' and not (name contains 'new')
queryOptional
pageinteger
The index of the page to return. The first page will be returned if this parameters isn't specified.
queryOptional
page-sizeinteger
The number of resources to return in a single request. 1000 by default.
queryOptional
Response
Response codes
CodeTypeDescription
200EdgeConnects
A list of all EdgeConnects
default--
Response body objects
The EdgeConnects object
ElementTypeDescription
edgeConnectsEdgeConnect[]-
totalCountinteger
Total number of currently configured EdgeConnects
The EdgeConnect object
Maps the specified host patterns to this EdgeConnect
idstring-
nameEdgeConnectName-
hostPatternsHostPattern[]-
hostMappingsHostMapping[]-
oauthClientIdstring
Id of OAuth client used to connect by the EdgeConnect
oauthClientSecretstring
Secret of OAuth client used to connect by the EdgeConnect. Only provided when creating a new EdgeConnect.
oauthClientResourcestring
Resource of OAuth client used to connect by the EdgeConnect. Only provided when creating a new EdgeConnect.
modificationInfoModificationInfo-
metadataMetadata-
managedByDynatraceOperatorboolean
Flag to identify if an EdgeConnect is managed by the Dynatrace operator. False by default!
The EdgeConnectName object
The HostPattern object
Either an IP, or a domain name which may contain a wildcard ('') as the leftmost label. If a '' is used, it must be followed by at least two labels.
The HostMapping object
Todo
fromstring-
tostring-
The ModificationInfo object
lastModifiedBystring-
lastModifiedTimestring-
The Metadata object
instancesEdgeConnectInstance[]-
oauthClientStatusstring
The status of the OAuth client
The element can hold these values
  • ACTIVE
  • INACTIVE
  • PENDING_DELETION
  • DELETED
The EdgeConnectInstance object
versionstring-
instanceIdstring-
Response body JSON models
"edgeConnects": [
"id": "11111111-2222-4444-3333-555555555555",
"name": "internal-services",
"hostPatterns": [
"*.internal.org"
"hostMappings": [
"from": "test.local",
"to": "kubernetes.my.cluster.local"
"oauthClientId": "dt0s02.AIOUP56P",
"oauthClientSecret": "dt0s02.AIOUP56P.5ODBJEQYBA4KLD2F6F6EHQZKYK5Q45RARKVCHICXKLMAXVVLIH2L6N5RLMDDY4QA",
"oauthClientResource": "urn:dtenvironment:wu31a2p3",
"modificationInfo": {
"lastModifiedBy": "12345678-abcd-efgh-1234-123456789",
"lastModifiedTime": "2022-01-01T01:02:03.165Z"
"metadata": {
"instances": [
"version": "1.46.2",
"instanceId": "string"
"oauthClientStatus": "ACTIVE"
"managedByDynatraceOperator": false
"totalCount": 1
Related tags
Platform APIDynatrace Platform
