Update an EdgeConnect configuration in Dynatrace with the EdgeConnect API by ID, including host patterns, mappings, OAuth client data, and metadata.
| PUT | SaaS | https://{your-environment-id}.apps.dynatrace.com/v1/edge-connects/{edgeConnectId} |
You provide the edgeConnectId path parameter and an EdgeConnect request body with fields such as id, name, hostPatterns, hostMappings, and OAuth client settings. The response confirms the EdgeConnect has been updated successfully.
To execute this request, you need a platform token or OAuth access token with app-engine:edge-connects:write scope. To learn how to obtain and use it, see Tokens and authentication.
| Parameter | Type | Description | In | Required |
| edgeConnectId | string | Specify the ID of the EdgeConnect | path | Required |
| body | Edge | Maps the specified host patterns to this EdgeConnect | body | Required |
EdgeConnect objectMaps the specified host patterns to this EdgeConnect
| Element | Type | Description | Required |
| id | string | - | Optional |
| name | Edge | - | Required |
| hostPatterns | Host | - | Required |
| hostMappings | Host | - | Optional |
| oauthClientId | string | Id of OAuth client used to connect by the EdgeConnect | Optional |
| oauthClientSecret | string | Secret of OAuth client used to connect by the EdgeConnect. Only provided when creating a new EdgeConnect. | Optional |
| oauthClientResource | string | Resource of OAuth client used to connect by the EdgeConnect. Only provided when creating a new EdgeConnect. | Optional |
| modificationInfo | Modification | - | Optional |
| metadata | Metadata | - | Optional |
| managedByDynatraceOperator | boolean | Flag to identify if an EdgeConnect is managed by the Dynatrace operator. False by default! | Optional |
EdgeConnectName objectHostPattern objectEither an IP, or a domain name which may contain a wildcard ('') as the leftmost label. If a '' is used, it must be followed by at least two labels.
HostMapping objectTodo
| from | string | - | Required |
| to | string | - | Required |
ModificationInfo object| Element | Type | Description | Required |
| lastModifiedBy | string | - | Required |
| lastModifiedTime | string | - | Required |
Metadata object| Element | Type | Description | Required |
| instances | Edge | - | Optional |
| oauthClientStatus | string | The status of the OAuth client The element can hold these values
| Optional |
EdgeConnectInstance object| Element | Type | Description | Required |
| version | string | - | Optional |
| instanceId | string | - | Optional |
This is a model of the request body, showing the possible elements. It has to be adjusted for usage in an actual request.
{"id": "11111111-2222-4444-3333-555555555555","name": "internal-services","hostPatterns": ["*.internal.org"],"hostMappings": [{"from": "test.local","to": "kubernetes.my.cluster.local"}],"oauthClientId": "dt0s02.AIOUP56P","oauthClientSecret": "dt0s02.AIOUP56P.5ODBJEQYBA4KLD2F6F6EHQZKYK5Q45RARKVCHICXKLMAXVVLIH2L6N5RLMDDY4QA","oauthClientResource": "urn:dtenvironment:wu31a2p3","modificationInfo": {"lastModifiedBy": "12345678-abcd-efgh-1234-123456789","lastModifiedTime": "2022-01-01T01:02:03.165Z"},"metadata": {"instances": [{"version": "1.46.2","instanceId": "string"}],"oauthClientStatus": "ACTIVE"},"managedByDynatraceOperator": false}
| Code | Type | Description |
| 200 | - | The EdgeConnect has been update successfully |
| 400 | Error | Bad Request |
| default | - | - |
ErrorResponse object| Element | Type | Description |
| error | Error | - |
Error object| Element | Type | Description |
| code | integer | - |
| message | string | - |
| details | Error | - |
ErrorDetails object| Element | Type | Description |
| constraintViolations | Constraint | - |
| missingScopes | string[] | - |
| missingPermissions | string[] | - |
ConstraintViolation object| Element | Type | Description |
| path | string | - |
| parameterLocation | string | - |
{"error": {"code": 1,"message": "string","details": {"constraintViolations": [{"error": {"code": 400,"message": "Constraints violated. Properties already exist in another configuration.","details": {"constraintViolations": [{"path": "hostPatterns[0]","message": "Host pattern must be unique across configurations.\nHost pattern 'myjira.com' already exists in EdgeConnect configuration 'InternalServices'."}]}}}],"missingScopes": ["string"],"missingPermissions": ["string"]}}}
