Delete an EdgeConnect
  • Latest Dynatrace
  • Reference
  • Published Oct 13, 2026
Delete an EdgeConnect configuration in Dynatrace with the EdgeConnect API by ID, and remove its autogenerated OAuth client when applicable.
DELETESaaShttps://{your-environment-id}.apps.dynatrace.com/v1/edge-connects/{edgeConnectId}
Overview
You provide the edgeConnectId path parameter to delete the specified EdgeConnect configuration. If the configuration used an autogenerated OAuth client, the operation also requires oauth2:clients:manage for the app-engine:edge-connects:connect scope.
Authentication
To execute this request, you need a platform token or OAuth access token with app-engine:edge-connects:delete scope. To learn how to obtain and use it, see Tokens and authentication.
Parameters
ParameterTypeDescriptionInRequired
edgeConnectIdstring
Specify the ID of the EdgeConnect
pathRequired
Response
Response codes
CodeDescription
204
The EdgeConnect configuration was deleted successfully
default-
Related tags
Platform APIDynatrace Platform
