You provide the edgeConnectId path parameter to rotate the secret for the EdgeConnect's autogenerated OAuth client. The response confirms the OAuth client secret was rotated successfully.
Authentication
To execute this request, you need a platform token or OAuth access token with oauth2:clients:manage scope. To learn how to obtain and use it, see Tokens and authentication.
"message":"Constraints violated. Properties already exist in another configuration.",
"details":{
"constraintViolations":[
"path":"hostPatterns[0]",
"message":"Host pattern must be unique across configurations.\nHost pattern 'myjira.com' already exists in EdgeConnect configuration 'InternalServices'."
