The OTel Collector provides extensive support for Kubernetes cluster and workload monitoring. It supports various receivers to collect critical metrics about the Kubernetes cluster, nodes, and objects.
This use case explains how to set up your Collector to get full visibility into your Kubernetes clusters through ready-made dashboards provided by
Dashboards.
Dynatrace recommends using the Dynatrace Operator for Kubernetes monitoring. However, this use case is designed specifically for OpenTelemetry users who choose not to deploy the Dynatrace Operator. It leverages pure OpenTelemetry data, which is not integrated into the Dynatrace Kubernetes application. Despite this, it provides ready-made Kubernetes dashboards and enables users to create custom dashboards and notebooks using the collected telemetry data.
See Collector Deployment and Collector Configuration on how to set these up with the configurations provided below.
Configure the following rbac.yaml file with your Kubernetes instance, to allow the Collector to use the Kubernetes API with the service-account authentication type.
apiVersion: v1kind: ServiceAccountmetadata:labels:app: otelcol-dtname: otelcol-dt---apiVersion: rbac.authorization.k8s.io/v1kind: ClusterRolemetadata:name: otelcol-dtlabels:app: otelcol-dtrules:- apiGroups:- ""resources:- events- namespaces- namespaces/status- nodes- nodes/spec- nodes/stats- nodes/proxy- persistentvolumes- persistentvolumeclaims- pods- pods/status- replicationcontrollers- replicationcontrollers/status- resourcequotas- servicesverbs:- get- list- watch- apiGroups:- appsresources:- daemonsets- deployments- replicasets- statefulsetsverbs:- get- list- watch- apiGroups:- batchresources:- jobs- cronjobsverbs:- get- list- watch- apiGroups:- autoscalingresources:- horizontalpodautoscalersverbs:- get- list- watch- apiGroups:- coordination.k8s.ioresources:- leasesverbs:- get- list- watch- create- update- patch- delete---apiVersion: rbac.authorization.k8s.io/v1kind: ClusterRoleBindingmetadata:name: otelcol-dtlabels:app: otelcol-dtroleRef:apiGroup: rbac.authorization.k8s.iokind: ClusterRolename: otelcol-dtsubjects:- kind: ServiceAccountname: otelcol-dtnamespace: default
extensions:health_check:endpoint: 0.0.0.0:13133k8s_leader_elector:auth_type: "serviceAccount"lease_name: k8smonitoringlease_namespace: ${env:POD_NAMESPACE}receivers:otlp:protocols:grpc:endpoint: 0.0.0.0:4317k8s_events:auth_type: "serviceAccount"k8s_leader_elector: k8s_leader_electorkubelet_stats:auth_type: "serviceAccount"collection_interval: 10snode: '${env:K8S_NODE_NAME}'extra_metadata_labels:- k8s.volume.typek8s_api_config:auth_type: "serviceAccount"endpoint: "https://${env:K8S_NODE_NAME}:10250"insecure_skip_verify: truemetric_groups:- node- pod- container- volumek8s_cluster:auth_type: "serviceAccount"collection_interval: 10sk8s_leader_elector: k8s_leader_electorallocatable_types_to_report:- cpu- memory- podsnode_conditions_to_report:- Ready- MemoryPressure- PIDPressure- DiskPressure- NetworkUnavailablemetrics:k8s.node.condition:enabled: truek8s.pod.status_reason:enabled: trueprocessors:cumulativetodelta:max_staleness: 25hfilter:error_mode: ignoremetrics:metric:- 'IsMatch(name, "k8s.volume.*") and resource.attributes["k8s.volume.type"] == nil'- 'resource.attributes["k8s.volume.type"] == "configMap"'- 'resource.attributes["k8s.volume.type"] == "emptyDir"'- 'resource.attributes["k8s.volume.type"] == "secret"'transform:error_mode: ignoretrace_statements: &dynatrace_transformations# Set attributes taken from k8s metadata.- context: resourcestatements:- set(attributes["k8s.cluster.name"], "${env:CLUSTER_NAME}")- set(attributes["k8s.workload.kind"], "job") where IsString(attributes["k8s.job.name"])- set(attributes["k8s.workload.name"], attributes["k8s.job.name"]) where IsString(attributes["k8s.job.name"])- set(attributes["k8s.workload.kind"], "cronjob") where IsString(attributes["k8s.cronjob.name"])- set(attributes["k8s.workload.name"], attributes["k8s.cronjob.name"]) where IsString(attributes["k8s.cronjob.name"])- set(attributes["k8s.workload.kind"], "daemonset") where IsString(attributes["k8s.daemonset.name"])- set(attributes["k8s.workload.name"], attributes["k8s.daemonset.name"]) where IsString(attributes["k8s.daemonset.name"])- set(attributes["k8s.workload.kind"], "statefulset") where IsString(attributes["k8s.statefulset.name"])- set(attributes["k8s.workload.name"], attributes["k8s.statefulset.name"]) where IsString(attributes["k8s.statefulset.name"])- set(attributes["k8s.workload.kind"], "replicaset") where IsString(attributes["k8s.replicaset.name"])- set(attributes["k8s.workload.name"], attributes["k8s.replicaset.name"]) where IsString(attributes["k8s.replicaset.name"])- set(attributes["k8s.workload.kind"], "deployment") where IsString(attributes["k8s.deployment.name"])- set(attributes["k8s.workload.name"], attributes["k8s.deployment.name"]) where IsString(attributes["k8s.deployment.name"])# remove the delete statements if you want to preserve these attributes- delete_key(attributes, "k8s.deployment.name")- delete_key(attributes, "k8s.replicaset.name")- delete_key(attributes, "k8s.statefulset.name")- delete_key(attributes, "k8s.daemonset.name")- delete_key(attributes, "k8s.cronjob.name")- delete_key(attributes, "k8s.job.name")# Set attributes from metadata specified in Dynatrace and set through the Dynatrace Operator.# For more info: https://docs.dynatrace.com/docs/shortlink/k8s-metadata-telemetry-enrichment- context: resourcestatements:- merge_maps(attributes, ParseJSON(attributes["metadata.dynatrace.com"]), "upsert") where IsMatch(attributes["metadata.dynatrace.com"], "^\\{")- delete_key(attributes, "metadata.dynatrace.com")metric_statements: *dynatrace_transformationslog_statements: *dynatrace_transformationsk8sattributes:extract:metadata:- k8s.pod.name- k8s.pod.uid- k8s.pod.ip- k8s.deployment.name- k8s.replicaset.name- k8s.statefulset.name- k8s.daemonset.name- k8s.job.name- k8s.cronjob.name- k8s.namespace.name- k8s.node.name- k8s.cluster.uid- k8s.container.nameannotations:- from: podkey_regex: metadata.dynatrace.com/(.*)tag_name: $$1- from: podkey: metadata.dynatrace.comtag_name: metadata.dynatrace.compod_association:- sources:- from: resource_attributename: k8s.pod.name- from: resource_attributename: k8s.namespace.name- sources:- from: resource_attributename: k8s.pod.ip- sources:- from: resource_attributename: k8s.pod.uid- sources:- from: connectionexporters:otlp_http:endpoint: ${env:DT_ENDPOINT}headers:Authorization: "Api-Token ${env:DT_API_TOKEN}"service:extensions:- health_check- k8s_leader_electorpipelines:metrics/node:receivers:- kubelet_statsprocessors:- filter- k8sattributes- transform- cumulativetodeltaexporters:- otlp_httpmetrics:receivers:- k8s_clusterprocessors:- k8sattributes- transform- cumulativetodeltaexporters:- otlp_httplogs:receivers:- k8s_eventsprocessors:- transformexporters:- otlp_httptraces:receivers:- otlpprocessors:- k8sattributes- transformexporters:- otlp_http
Validate your settings to avoid any configuration issues.
It is recommended to set the max_staleness parameter of the cumulativetodelta processor to a value higher than how often the Collector receives metrics (e.g., how often metrics via OTLP are received, or how long the Prometheus scrape interval is). This ensures that no references to abandoned metric streams accumulate in memory over time.
For our configuration, we configured the following components:
Under receivers, we specify the following receivers as active receiver components for our deployment:
otlp: To accept OTLP traces.k8sevents: To receive Kubernetes events from the Kubernetes API server. 1k8s_cluster: To receive cluster-level metrics and entity events from the Kubernetes API server.kubelet_stats: To receive node-level metrics. This receiver requires the environment variable K8S_NODE_NAME to be set to spec.nodeName using the Kubernetes Downward API (see example).The k8sevents receiver is currently in alpha stage and may undergo significant changes. Despite its early stage of maturity, it has been included in the Dynatrace distribution of the Collector to support early adoption and experimentation. Be aware that stability, performance, and feature completeness are not guaranteed at this stage.
Under processors, we specify the following processors:
filter: To filter Kubernetes attributes.
k8sattributes: To extract and provide pod data.
transform: To transform Kubernetes metrics. This requires the environment variable CLUSTER_NAME to be set with the name of the cluster. Set the variable value to an arbitrary name that you want your cluster to show up with inside Dynatrace.
cumulativetodelta: To enable conversion of cumulative metrics.
Under exporters, we specify the otlp_http exporter and configure it with our Dynatrace API URL and the required authentication token.
For this purpose, we set the following two environment variables and reference them in the configuration values for endpoint and Authorization.
DT_ENDPOINT contains the base URL of the Dynatrace API endpoint (for example, https://{your-environment-id}.live.dynatrace.com/api/v2/otlp)DT_API_TOKEN contains the API tokenUnder extensions, we specify the k8sleaderelector extension to choose the leader of the agent replicas, which is going to scrape and export cluster-level telemetry.
This ensures that only one collector instance scrapes the data at a time to avoid telemetry duplication.
Under service, we assemble our receiver, processor, and exporter objects into pipelines for traces, metrics, and logs. These pipelines allow us to send OpenTelemetry signals via the Collector instance and have them automatically enriched with additional Kubernetes-specific details.
To make these dashboards available in your tenant, install the OpenTelemetry Dashboards app via the Dynatrace Hub.
For how to find and use ready-made dashboards, see Ready-made dashboards.
When accessing the dashboards, you have the following choices:
Data is ingested using the OpenTelemetry protocol (OTLP) via the Dynatrace OTLP APIs and is subject to the API's limits and restrictions. For more information see:
