For extended capabilities and workflow automation (for example, enabling targeted notification and problem remediation), see Workflows Connectors and actions.
With a Slack problem-notification integration, your teams will always be aware of potential risks within applications, services, and infrastructure. Your teams can also use a Dynatrace-integrated Slack channel to discuss incidents, evaluate solutions, and link to similar problems.
Copy the generated Webhook URL to your clipboard. The Webhook URL should look like this: https://hooks.slack.com/services/T00000000/B00000000/XXXXXXXXXXXXXXXXXXXXXXXX.
In Dynatrace, go to Settings > Integration > Problem notifications.
Select Add notification.
Select Slack from the available notification types.
Enter the following information:
Display name
This is the freeform name of this integration that will be displayed in Dynatrace on Settings > Integration > Problem notifications when you finish this configuration.
URL
Paste the webhook URL
Channel
Enter the name of a Slack channel
Message
Enter a custom message; it can contain text and problem-related placeholders
Placeholders
The Available placeholders section of the configuration page lists placeholders you can use for this integration. Placeholders are automatically replaced with actual values.
