Dynatrace Operator
  • Latest Dynatrace
  • 6-min read
Operator
Dynatrace Operator manages the automated rollout, configuration, and lifecycle of Dynatrace components. It uses custom resources of kind DynaKube and EdgeConnect.
Update windows currently do not apply in Kubernetes environments.
Dynatrace Operator's functionality is tied to custom resources. These resources define which features are enabled. When a custom resource is created, Dynatrace Operator triggers an initial reconciliation to ensure that the desired state is achieved. The reconciliation process regularly detects changes in the Cluster and adjusts the state accordingly. The frequency of reconciliation decreases after the initial rollout, as fewer changes are typically made.
On startup, Dynatrace Operator registers the webhook with the Kubernetes API. During each reconcile loop, Dynatrace Operator checks for changes in custom resources to:
  • Update status of custom resources
  • Ensure that initial startup of managed components meets requirements
  • Manage workloads
  • Register components on the Dynatrace server
Dynatrace Operator reconciles its own custom resources only within its deployment namespace.
Namespaces monitored by Dynatrace Operator should be configured as follows:
  • Label namespaces according to namespaceSelector so the webhook can mutate Pods.
  • Ensure prerequisites for injection exist in injected namespaces.
Resource requirements
Default configuration:
  • 1 replica per Cluster
A single Dynatrace Operator replica is typically sufficient due to leader election. Additional replicas will only activate when the current leader terminates and a new one is elected.
A Dynatrace Operator container has predefined CPU and memory requests and limits. To customize these values during deployment with Helm, modify the values.yaml file.
Resource configuration with Helm
operator:
requests:
cpu: 50m
memory: 64Mi
limits:
cpu: 100m
memory: 128Mi
Permissions and privileges
A full list of resources accessed by Dynatrace Operator is available in the Security documentation. Network traffic and figures are documented in the Network traffic documentation.
Webhook
Dynatrace webhook modifies Pod definitions to inject Dynatrace code modules for Application observability. It also validates DynaKube definitions and converts DynaKubes with older API versions.
Webhook configurations are managed by Dynatrace Operator and are updated periodically. These updates ensure that the Kubernetes API can continue to communicate with the webhook.
Key functions
  • Pod mutation—The webhook mutates Pods by modifying their definitions to include necessary metadata for Application observability.
    • Attaches Init container to download (in case no CSI driver is used) and configure the code modules on Pod startup.
    • Attaches CSI volumes, if configured, so CSI driver can handle volume creation.
    • Modifies Pod definitions for metadata enrichment.
  • Namespace mutation—The webhook mutates namespaces to enable the monitoring of Pods within those namespaces.
    • Adds labels to namespaces so the webhook can listen to Pod CREATE events.
    Webhook configurations only support a static namespace selector. The required label is added to newly created namespaces.
  • Configuration validation
    • Check custom resources, like DynaKubes, contain valid configuration when they are created or updated
      • Different validation depending on the fields, some are required and some need to conform to more specific rules
    • Provide helpful warning/error messages if validation fails
    Check DynaKube parameters and EdgeConnect parameters for more information on each field!
  • Conversion between versions
    • Ensures compatibility between different versions of the custom resource definitions
    • Converts older versions of the custom resource to the storage version, that is understood by Dynatrace Operator
  • 2 replicas per cluster (can be scaled up to increase availability)
The Dynatrace Webhook container has default requests and limits defined. If you want to set different resource requests or limits, you can do so when deploying Dynatrace Operator with Helm.
To set resource limits, modify the values.yaml. See the default configuration below.
webhook:
requests:
cpu: 300m
memory: 128Mi
limits:
cpu: 300m
memory: 128Mi
A full list of resources that are accessed by the webhook can be found in Dynatrace Operator security. Ingress and egress is documented in Network traffic.
CSI driver
The Dynatrace Operator CSI driver provides Dynatrace code modules for the application Pods, while minimizing storage usage, and load on the Dynatrace environment. In addition, it provides writable volume storage for OneAgent utilizing ephemeral local volumes.
  • For applicationMonitoring configurations, it provides the necessary OneAgent binary for application monitoring to the Pods on each Node as a read-only mount.
  • For hostMonitoring configurations, it provides a writable folder for the OneAgent configurations when a read-only host file system is used.
  • For cloudNativeFullStack, it provides both of the above.
Minimizes downloads by downloading the code modules once per Node and storing them on the Node's filesystem.
  • With the CSI driver, injecting 100 Pods spread across three nodes would result in just 3 Code Module downloads.
  • Without the CSI driver, each Pod would need to download its own code modules, so injecting 100 Pods would result in the download of 100 code modules.
Minimizes storage usage by storing the code modules on the Node's filesystem, and creating an OverlayFs mount for each injected Pod.
  • With the CSI driver, injecting 100 Pods spread across three nodes would result in the storage of only 3 code modules.
  • Without the CSI driver, each Pod stores a Code Module, so injecting 100 Pods would result in the storage of 100 code modules.
For details on where the OneAgent files and logs are stored on the Kubernetes nodes (with and without CSI driver), see Storage requirements.
  • 1 replica per Node (deployed via DaemonSet)
The CSI driver provisioner does not have any predefined resource limits. However, if you want to set resource limits or modify resource limits for other containers of the CSI driver, you can do so when deploying Dynatrace Operator with Helm.
To set resource limits for the provisioner container, modify the values.yaml. See the example configuration below.
  • Increase CPU to accelerate unpacking and installation of code modules (important for fast node startup and initialization)
  • Increasing memory does not have an impact on performance
provisioner:
resources:
requests:
cpu: 300m
memory: 100Mi
limits:
cpu: 300m
memory: 100Mi
server:
resources:
requests:
cpu: 50m
memory: 100Mi
limits:
cpu: 50m
memory: 100Mi
The Dynatrace Operator CSI driver requires elevated permissions to create and manage mounts on the host system. Specifically, the mountPropagation: Bidirectional permission is needed on the volume where the CSI driver stores the code modules. This permission is only available for privileged containers.
A full list of resources that are accessed by the CSI driver can be found in the Security documentation.
Ingress and Egress is documented in the Network traffic documentation.
