DQL extraction and parsing commands
  • Latest Dynatrace
  • Reference
parse
Parses a record field and puts the result(s) into one or more fields as specified in the pattern.
The parse command works in combination with the Dynatrace Pattern Language for parsing strings.
Syntax
parse expression, pattern [, preserveFieldsOnFailure] [, parsingPrerequisite]
Parameters
Basic example
Example: Parse log content
The following example parses the content field, which shows the content of a log line. The parse command adds the parsed fields to the set of fields of the record.
data record(content="117.16.75.9--[14/Mar/2016:23:34:25 +0200] GET//setup.php HTTP/1.1 404 474")
| parse content, "IPV4:ip LD HTTPDATE:time ']' LD:text"
Query result:
contentiptimetext
117.16.75.9--[14/Mar/2016:23:34:25 +0200] GET//setup.php HTTP/1.1 404 474117.16.75.92016-03-14T21:34:25.000Z" GET//setup.php HTTP/1.1 404 474"
Example: Handle parsing failures when overwriting fields
The following example parses the content field preserving existing fields specified in the pattern if parsing fails for the record.
data record(content = "1,alice,192.168.1.1"),
record(content = "2,,10.6.24.18", username = "bob"),
record(content = "3,mallory,192.168.1.3")
| parse content, "( INT:sequence LD:username IPADDR:ip)(fs=',')",
preserveFieldsOnFailure: true
Query result:
Example: Conditional parsing of log content
The following example conditionally parses the content field. The parsingPrerequisite parameter of the parse command determines which records to parse.
data record(content = "2016-03-14 23:37:07;www.example.com (192.168.0.1)"),
record(content = "2016-03-14 23:37:06;www.example.com")
| parse content, "TIMESTAMP ';'LD ( '(' IPADDR:server ')' )",
parsingPrerequisite: contains(content,"(")
Query result:
Practical example
Example: Apache access logs
In the following example, the parse command extracts all the relevant fields from Apache access logs.
fetch logs
| filter dt.entity.process_group == "PROCESS_GROUP-628E1D4CAD1B41B9"
| fieldsKeep content
| parse content, """(IPADDR:'http.client_ip' | [! \n]+):host
' ' ('-' | NSPACE:ident)
' ' ('-' | (DATA{1,8096}:auth >>(' [' HTTPDATE)))
' ' '[' HTTPDATE:event_time ']'
' ' (('\"' [A-Z-_]+:'http.method' ' ' LD{0,8096}:uri ' ' LD{3,10}:'http.flavor' '\"')
| DQS:invalid_request
' ' LONG:'http.status_code'
' ' (LONG:'http.response.content_length' | '-')
(' ' DQS:referer (' ' DQS:user_agent)?)?"""
| summarize count = count(), by: { http.status_code }
Added fields override existing fields
In case of identical names, fields added by the parse command override the existing fields. When two identical field names are specified in the DQL statement, a warning "The field <fieldName> overrides an existing field." is returned.
Related tags
Dynatrace Platform
