Code Monitoring is a DPS capability that provides real-time, code-level visibility into running applications, enabling developers to debug and analyze production code without redeployments or issue reproduction.
This page explains how Code Monitoring consumption is calculated, and how you can manage your Code Monitoring spend in Dynatrace.
Code Monitoring consumption is primarily tied to the use of
Live Debugger. For more information, see Live Debugger.
Code Monitoring consumption is measured in container-hours, using the Code Monitoring rate card item.
In the context of Code Monitoring, a container represents a concurrent process monitored at the code level. For containerized workloads, each container with OneAgent running counts as one concurrent process. For non-containerized workloads, each concurrent process running on the host is counted individually.
In the context of Code Monitoring, a concurrent process is an instrumented process that is actively running and reporting code-level data to Dynatrace. When multiple instrumented processes run on a single host, each process is counted separately and all counts are summed toward container-hour consumption.
The unit of measure for Code Monitoring. Container-hours are used to calculate Code Monitoring consumption, and apply to both containerized and non-containerized workloads. Containerization is not required to use Live Debugger or to be billed for Code Monitoring.
Each container-hour of Code Monitoring includes:
10 days of retention.
Live Debugger snapshots under fair use.
Fair use means usage that aligns with typical customer patterns, your contracted consumption, and the feature's intended purpose. As a guideline, this means 6 GiB per 24-hour interval (equivalent to 0.05 GiB per container-hour), pooled across all containers within the 24-hour interval.
If your usage materially exceeds fair use, Dynatrace may notify you and subsequently apply charges at the applicable line item on the rate card.
Each concurrent process that is actively monitored generates one container-hour of consumption per hour. Consumption is independent of container memory size, CPU allocation, or the language/runtime being monitored.
Dynatrace is built for elastic cloud-native environments where services are often short-lived, which is the case for containerized and ephemeral workloads. Therefore, billing granularity for container-hour consumption is calculated in 15-minute intervals. One 15-minute interval is equivalent to 0.25 container-hours. If a process is monitored for fewer than 15 minutes in a given interval, its consumption is rounded up to 15 minutes.
The figure below illustrates how container-hour consumption is calculated over the course of an entire hour (four 15-minute intervals).
The following example demonstrates how to calculate your monthly cost for Code Monitoring.
Calculations are based on the following list prices (which may differ from your rate card prices):
One month is equivalent to 30 days, 24 hours per day.
250 concurrent processes are under code-level monitoring:
200 containerized processes running continuously, 24 hours per day.
50 non-containerized concurrent processes running across hosts, 24 hours per day.
Dynatrace provides several ways to monitor and analyze your Code Monitoring consumption.
License managers can view usage and costs in Account Management.
For more information, see Overview (Dynatrace Platform Subscription).
Billing usage events (billing_usage_event) are system events emitted by Dynatrace that represent the authoritative record of billable usage. Use them to build reliable cost dashboards and chargeback reports by host, Kubernetes namespace, cloud account, or cost-center tag.
Each billing usage event for Code Monitoring contains:
Total Code Monitoring usage over time:
fetch dt.system.events| filter event.kind == "BILLING_USAGE_EVENT" and event.type == "Code Monitoring"| dedup event.id| fieldsAdd day = formatTimestamp(bin(timestamp, 24h), format: "yyyy-MM-dd")| summarize totalUsage = sum(billed_container_hours), by: {day}| sort day desc
Query Code Monitoring consumption programmatically via the Account Management API for integration with external reporting systems. You can also query the underlying metrics through the Environment API – Metrics API v2.
Yes. You can opt in to Code Monitoring at the level of specific process groups, Kubernetes namespaces, clusters, or the entire environment. You are billed only for the processes that you have opted-in to for code-level monitoring.
Yes. Code Monitoring can be combined with any other rate card item. The most common pairings are with:
Code Monitoring is only available for DPS customers with a SaaS environment. It requires OneAgent version 1.309+ with the Java Live-Debugger and/or Node.js Live-Debugger OneAgent features enabled. The OneAgent must be deployed in Full-Stack, Infrastructure, or Discovery monitoring mode (with container code-module injection).
Consumption is not affected by container size. A container-hour is independent of the container's memory size, CPU requests, or resource limits. Each monitored concurrent process contributes one container-hour per hour, regardless of how large or small it is.
With per process billing, each time a process restarts, it’s counted as a new process and billed from the start of a new 15-minute interval. Occasional restarts, such as during deployments, can have a minor impact on consumption. Frequent restarts, such as a process caught in a crash loop, can increase consumption, so we recommend resolving them promptly.
Each concurrent process running on a host is treated as a unique container for the purpose of container-hour consumption calculations. A host with multiple instrumented processes consumes the total container-hours of all those processes combined.
Yes. Live Debugger is included in the Code Monitoring capability at no additional charge beyond the container-hours consumed. This includes plugins for Visual Studio Code and JetBrains IDEs.
Yes. Container-hours are consumed as long as the instrumented process is running and being monitored at code level, regardless of whether the process is actively serving traffic. To reduce consumption, terminate or scale down processes you do not need monitored, or disable Observability for Developers for the relevant process groups.
Billing usage events for Code Monitoring are dimensioned by host and, where applicable, by Kubernetes cluster/namespace or cloud account identifiers (AWS account, Azure subscription, GCP project). You can also assign usage to a team or product by setting the dt.cost.costcenter and dt.cost.product fields on host entities, and use Account Management to set up chargeback rules. For more information, see Cost Allocation.
Dynatrace currently does not charge for usage in excess of the amount allowed under your fair-use quota. However, if your usage consistently or significantly exceeds the fair-use quota, contact your account team to discuss your requirements.
A container-hour includes 10 days of snapshot retention. If your use case requires retention beyond this period, contact your account team to discuss your requirements and available options.
