Conversion and casting functions
  • Latest Dynatrace
  • Reference
Conversion functions convert the expression or value from one data type to another type.
Converting data types
Functions prefixed with as(Type) ensure that a value is of a target type. If the data type is incompatible, they return null. These functions are applicable after parsing.
| parse content, "LD'DQL 'KVP{LD:key'='(LONG:valueLong| BOOLEAN:valueBoolean| [!;]*:valueStr)';'?}:q"
| fields timestamp, asLong(q[workTime])
Casting input data type to the target data type matrix
The as*T will try to cast the input to T but won't perform any conversions, it will cause an exception for strongly typed fields (marked as Not applicable ) and null for incompatible data types (empty cell).
asT(arg) => if(typeOf(arg) == ’T’, arg)
as*TasNumberasIntegerasLongasDoubleasStringasBooleanasTimestampasDurationasTimeframeasGeopointasIpAddressasSummaryStatsasBinaryasArrayasRecord
IntegerIntegerApplicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicable
LongLongNot applicableApplicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicable
DoubleDoubleNot applicableNot applicableApplicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicable
StringNot applicableNot applicableNot applicableNot applicableApplicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicable
BooleanNot applicableNot applicableNot applicableNot applicableNot applicableApplicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicable
TimestampNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableApplicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicable
DurationNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableApplicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicable
TimeframeNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableApplicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicable
GeopointNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableApplicableNot applicableNot applicableNot applicableNot applicableNot applicable
IpAddressNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableApplicableNot applicableNot applicableNot applicableNot applicable
BinaryNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableApplicableNot applicableNot applicable
ArrayNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableApplicableNot applicable
RecordNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableNot applicableApplicable
V<Integer>V<Integer>Applicable
V<Long>V<Long>Applicable
V<Double>V<Double>Applicable
V<String>Applicable
V<Boolean>Applicable
V<Timestamp>Applicable
V<Duration>Applicable
V<Timeframe>Applicable
V<Geopoint>Applicable
V<IpAddress>Applicable
V<SummaryStats>Applicable
V<Binary>Applicable
V<Array>Applicable
V<Record>V<Record>
asArray
Returns array value if the value is array, otherwise, returns null.
Syntax
asArray(value)
Parameters
Returns
The data type of the returned value is array.
Examples
Example 1
data record(a = array(2, 3, 7, 7, 1)),
record(a = "DQL is awesome!"),
record(a = 3.14)
| fieldsAdd type(a), asArray(a)
Query result:
atype(a)asArray(a)
[2, 3, 7, 7, 1]array[2, 3, 7, 7, 1]
DQL is awesome!stringnull
3.14doublenull
asBinary
Returns binary value (byte array) if the value is binary, otherwise, returns null.
Syntax
asBinary(value)
Parameters
Returns
The data type of the returned value is binary.
Examples
Example 1
data record(a = 3.14),
record(a = "dynatrace"),
record(a = true),
record(a = decodeBase64ToBinary("ZHluYXRyYWNl"))
| fieldsAdd type(a), asBinary(a)
Query result:
atype(a)asBinary(a)
3.14doublenull
dynatracestringnull
truebooleannull
ZHluYXRyYWNlbinaryZHluYXRyYWNl
asBoolean
Returns boolean value if the value is boolean, otherwise, returns null.
Syntax
asBoolean(value)
Parameters
Returns
The data type of the returned value is boolean.
Examples
Example 1
data record(a = true),
record(a = "true"),
record(a = 1)
| fieldsAdd type(a), asBoolean(a)
Query result:
asDouble
Returns double value if the value is double, otherwise, returns null.
Syntax
asDouble(value)
Parameters
Returns
The data type of the returned value is double.
Examples
Example 1
data record(a = 3),
record(a = 3.14),
record(a = "3.14")
| fieldsAdd type(a), asDouble(a)
Query result:
asDuration
Returns duration value if the value is duration, otherwise, returns null.
Syntax
asDuration(value)
Parameters
Returns
The data type of the returned value is duration.
Examples
Example 1
data record(a = 15s),
record(a = 3.14),
record(a = timeframe(from: "2019-08-01T09:30:00.000-0400", to: "2019-08-01T16:00:00.000-0400")),
record(a = "42"),
record(a = "42s")
| fieldsAdd type(a), asDuration(a)
Query result:
atype(a)asDuration(a)
15 sduration15 s
3.14doublenull
start: 2019-08-01T13:30:00.000Z
end: 2019-08-01T20:00:00.000Z
timeframenull
42stringnull
42sstringnull
asIp
You can use this function to cast to an IP address.
Syntax
asIp(expression)
Parameters
Returns
The data type of the returned value is ip.
Examples
Example 1
data record(a = ip("127.0.0.1")),
record(a = "10.0.0.1")
| fieldsAdd type(a), asIp(a)
Query result:
asLong
Returns long value if the value is long, otherwise null.
Syntax
asLong(value)
Parameters
Returns
The data type of the returned value is long.
Examples
Example 1
data record(a = 3),
record(a = 3.14),
record(a = "3")
| fieldsAdd type(a), asLong(a)
Query result:
asNumber
Returns the same value if the value is integer, long, double, otherwise, returns null.
Syntax
asNumber(value)
Parameters
Returns
The data type of the returned value is double or long.
Examples
Example 1
data record(a = 3),
record(a = 3.14),
record(a = "3.14")
| fieldsAdd type(a), asNumber(a)
Query result:
asRecord
Returns record value if the value is record, otherwise, returns null.
Syntax
asRecord(value)
Parameters
Returns
The data type of the returned value is record.
Examples
Example 1
data record(a = record(b = 3)),
record(a = 3.14),
record(a = "3"),
| fieldsAdd type(a), asRecord(a)
Query result:
atype(a)asRecord(a)
b: 3recordb: 3
3.14doublenull
3stringnull
[2, 3, 7, 7, 1]arraynull
asString
Returns string value if the value is string, otherwise, returns null.
Syntax
asString(value)
Parameters
Returns
The data type of the returned value is string.
Examples
Example 1
data record(a = array(1, 2, 3)),
record(a = 3.14),
record(a = record(content = "A nested record"))
| fieldsAdd type(a), asString(a)
Query result:
atype(a)asString(a)
[1, 2, 3]arraynull
3.14doublenull
DQL is awesome!stringDQL is awesome!
content: A nested recordrecordnull
asTimeframe
Returns timeframe value if the value is timeframe, otherwise returns null.
Syntax
asTimeframe(value)
Parameters
Returns
The data type of the returned value is timeframe.
Examples
Example 1
data record(timeframe = timeframe(from: "2019-08-01T09:30:00.000-0400", to: "2019-08-01T16:00:00.000-0400")),
record(timeframe = timeframe(from: - 24h, to: - 2h)),
record(timeframe = "2019-08-01T15:30:00.000-0400/2019-08-01T22:00:00.000-0400")
| fieldsAdd type(timeframe), asTimeframe(timeframe)
Query result:
asTimestamp
Returns timestamp value if the value is timestamp, otherwise, returns null.
Alternatively use the toTimestamp function to convert a long, double or string value to a value of type timestamp.
Syntax
asTimestamp(value)
Parameters
Returns
The data type of the returned value is timestamp.
Examples
Example 1
data record(timestamp = timestamp(2019, 8, 1, 13, 30, 0)),
record(timestamp = 1564666200000000000),
record(timestamp = "2019-08-01T09:30:00.000-0400")
| fieldsAdd type(timestamp), asTimestamp(timestamp)
Query result:
asUid
Returns a uid value if the value is uid, otherwise returns null.
Syntax
asUid(value)
Parameters
Returns
The data type of the returned value is uid.
Examples
Example 1
data record(a = uid64(123)), record(a = 123)
| fields asUid(a)
Query result:
decode
The decode function allows encoding binary data and strings into a string representation, and the opposite way. There are two types of decode functions, BASE64 and BASE16.
Syntax
decodeBase64ToBinary(expression)
decodeBase64ToString(expression)
decodeBase16ToBinary(expression)
decodeBase16ToString(expression)
Parameters
Returns
The data type of the returned value is binary or string.
Examples
Example 1
data record(content = "RFFMIGlzIGF3ZXNvbWUh"),
record(content = "RHluYXRyYWNlIFF1ZXJ5IExhbmd1YWdl")
| fieldsAdd decodeBase64ToString(content)
Query result:
Example 2
data record(content = "44514c20697320617765736f6d6521"),
record(content = "44796e617472616365205175657279204c616e6775616765")
| fieldsAdd decodeBase16ToString(content)
Query result:
encode
The encode function allows encoding binary data and strings into a string representation, and the opposite way. There are two types of encode functions, BASE64 and BASE16.
Syntax
encodeBase64(expression)
encodeBase16(expression)
Parameters
Returns
Examples
Example 1
data record(content = "DQL is awesome!"),
record(content = "Dynatrace Query Language")
| fieldsAdd encodeBase16(content),
encodeBase64(content)
Query result:
getHighBits
Extracts the most significant bits of an expression. It accepts uid or ip expression types. For all other types, it returns null.
Syntax
getHighBits(expression)
Parameters
Returns
Examples
Example 1
record(a = uid128(123, 456)),
record(a = uuid(123, 456)),
record(a = ip("192.168.0.1")),
record(a = ip("2001:0db8:0000:0000:0000:8a2e:0370:7334")),
record(a = ip("::1")),
record(a = 1),
record(a = true),
record(a = "foo")
| fields a, getHighBits(a)
Query result:
getLowBits
Extracts the least significant bits of an expression. It accepts uid or ip expression types. For all other types, it returns null.
Syntax
getLowBits(expression)
Parameters
Returns
Examples
Example 1
record(a = 1),
record(a = true),
record(a = "foo")
| fields a, getLowBits(a)
Query result:
hexStringToNumber
Converts a hexadecimal string to a number.
Syntax
hexStringToNumber(expression)
Parameters
Returns
Examples
Example 1
data record(a = "0x7f"),
record(a = "100"),
record(a = "0X80000000")
| fieldsAdd hexStringToNumber(a)
Query result:
isUid128
Tests if a uid value is of subtype uid128.
Syntax
isUid128(expression)
Parameters
Returns
Examples
Example 1
record(a = toUid("000000000000007c")),
record(a = toUid("000000000000007c00000000000001c8")),
record(a = toUid("00000000-0000-007c-0000-0000000001c8"))
| fieldsAdd isUid128(a)
Query result:
isUid64
Tests if a uid value is of subtype uid64.
Syntax
isUid64(expression)
Parameters
Returns
Examples
Example 1
| fieldsAdd isUid64(a)
Query result:
isUuid
Tests if a uid value is of subtype uuid.
Syntax
isUuid(expression)
Parameters
Returns
Examples
Example 1
| fieldsAdd isUuid(a)
Query result:
numberToHexString
Converts a number to a hexadecimal string.
Syntax
numberToHexString(expression)
Parameters
Returns
Examples
Example 1
data record(a = 127),
record(a = 256),
record(a = 2147483648)
| fieldsAdd numberToHexString(a)
Query result:
toArray
Returns the value if it is an array. Otherwise, converts a value to the single element array holding that value.
Syntax
toArray(value)
Parameters
Returns
Examples
Example 1
record(a = 3.14)
| fieldsAdd type(a), toArray(a)
Query result:
toBoolean
Converts a value to Boolean if the value is of a suitable type. If the argument is an array, the element at position 0 is converted.
Use asBoolean(value) function to return if the value is boolean or variant<boolean>, otherwise null.
Converts string values true or TRUE to a Boolean true.The comparison is case insensitive. Converts other values to Boolean false. Converts numeric value 0 to Boolean false. Converts other numeric values to Boolean true.
Syntax
toBoolean(value)
Parameters
Returns
Examples
Example 1
record(a = "true"),
record(a = "yes"),
record(a = 0),
record(a = 1),
record(a = 2)
| fieldsAdd type(a), toBoolean(a)
Query result:
toDouble
Converts a value to double if the value is of a suitable type. If the argument is an array, the element at position 0 is converted.
Use asDouble(value) function to return if the value is double or variant<double>, otherwise null.
Syntax
toDouble(value)
Parameters
Returns
Examples
Example 1
data record(a = 3),
record(a = 3.14),
record(a = "3.14"),
record(a = true),
record(a = toTimestamp("2019-08-01T09:30:00.000-0400")),
record(a = 15s),
record(a = ip("10.0.0.1"))
| fieldsAdd type(a), toDouble(a)
Query result:
toDuration
Converts a value to duration if the value is of a suitable type. If the argument is an array, the element at position 0 is converted.
Syntax
toDuration(value)
Parameters
Returns
Examples
Example 1
record(a = 3.14),
record(a = "42"),
record(a = "42s")
| fieldsAdd type(a), toDuration(a)
Query result:
toIp
You can use this function to convert an expression to an IP address.
Syntax
toIp(expression)
Parameters
Returns
Examples
Example 1
record(a = "10.0.0.1"),
record(a = "300.0.0.1"),
record(a = 1234567890)
| fieldsAdd type(a), toIp(a)
Query result:
toLong
Converts a value to long if the value is of a suitable type. If the argument is an array, the element at position 0 is converted.
Syntax
toLong(value)
Parameters
Returns
Examples
Example 1
data record(a = 3),
record(a = 3.14),
record(a = "3"),
record(a = true),
record(a = false),
record(a = ip("10.0.0.1")),
record(a = 15s),
| fieldsAdd type(a), toLong(a)
Query result:
toString
Returns the string representation of a value.
Syntax
toString(value)
Parameters
Returns
Examples
Example 1
record(a = true),
record(a = 3),
record(a = 3.14),
record(a = 5m),
record(a = toIp("127.0.0.1")),
record(a = timeframe(from: now() - 5m, to: now())),
| fieldsAdd type(a), toString(a)
Query result:
toTimeframe
Converts a value to timeframe if the value is of a suitable type. If the argument is an array, the element at position 0 is converted.
Syntax
toTimeframe(value)
Parameters
Returns
Examples
Example 1
record(timeframe = "2019-08-01T09:30:00.000-0400/2019-08-01T16:00:00.000-0400")
| fieldsAdd type(timeframe), toTimeframe(timeframe)
Query result:
toTimestamp
Converts a value to timestamp if the value is of a suitable type. If the argument is an ARRAY, the element at position 0 is converted.
Use asTimestamp(<value>) function to return if the value is timestamp or variant<timestamp>, otherwise null.
Syntax
toTimestamp(value)
Parameters
Returns
Examples
Example 1
data record(timestamp = toTimestamp("2019-08-01T09:30:00.000-0400")),
| fieldsAdd type(timestamp), toTimestamp(timestamp)
Query result:
toUid
Converts a value to uid if the value is of a suitable type.
Syntax
toUid(value)
Parameters
Returns
Examples
Example 1
data record(a = "550e8400-e29b-41d4-a716-446655440000", b = 123, c = uid64(456), d=array(123))
| fields toUid(a), toUid(b), toUid(c), toUid(d)
Query result:
type
Returns the type of a value as a string.
Syntax
type(expression [, withSubtype])
Parameters
Returns
Examples
Example 1
record(a = true),
record(a = 3),
record(a = 3.14),
record(a = 5m),
record(a = toIp("2001:0db8:0000:0000:0000:8a2e:0370:7334")),
record(a = record(content = "A nested record")),
| fieldsAdd type(a), type(a, withSubtype:true)
Query result:
uid128
Creates a uid of subtype uid128 from two long expressions.
Syntax
uid128(mostSignificantBits, leastSignificantBits)
Parameters
Returns
Examples
Example 1
data record(a = 123, b = 456)
| fields uid128(a, b)
Query result:
uid64
Creates a uid of subtype uid64 from a long expression.
Syntax
uid64(expression)
Parameters
Returns
Examples
Example 1
data record(a = 123)
| fields uid64(a)
Query result:
uuid
Creates a uid of subtype uuid from two long expressions.
Syntax
uuid(mostSignificantBits, leastSignificantBits)
Parameters
Returns
Examples
Example 1
| fields uuid(a, b)
Query result:
smartscapeId
Preview
Creates a smartscapeId from the given string and long expression.
Syntax
smartscapeId(type, numericId)
Parameters
Returns
The data type of the returned value is smartscapeId.
Examples
Example 1
data record(a = "HOST", b = 123)
| fields smartscapeId(a, b)
Query result:
asSmartscapeId
Preview
Returns smartscapeId value if the value is smartscapeId, otherwise returns null.
Syntax
asSmartscapeId(value)
Parameters
Returns
The data type of the returned value can be smartscapeId or null.
Examples
Example 1
data record(a = "SERVICE-00590715D82398FE"),
record(a = toSmartscapeId("SERVICE-00590715D82398FE")),
record(a = 1)
| fieldsAdd type(a), asSmartscapeId(a)
Query result:
toSmartscapeId
Preview
Converts a value to smartscapeId if the value is of a suitable type. If the argument is an array, only the element at position 0 is converted.
Syntax
toSmartscapeId(value)
Parameters
Returns
Examples
Example 1
data record(a = "SERVICE-02E04D7E459555EC", b = array("DISK-000392498B505BD0"))
| fields toSmartscapeId(a), toSmartscapeId(b)
Query result:
Related tags
Dynatrace Platform
