Built-in Metrics on Grail
  • Latest Dynatrace
  • Reference
  • 39-min read
Metrics on Grail supports many of the existing built-in metrics as identified below.
The expandable sections below describe differences in built-in metrics on Grail when compared to similar Metrics Classic metrics.
Renamed metric keys
Metrics on Grail introduces guidelines to improve clarity, consistency, and readability for Dynatrace-provided metrics, dimensions, and entities across the Dynatrace Platform:
  • Replacing the builtin: prefix with dt. to clearly denote Dynatrace-provided metrics and entities.
  • Preferring snake case (capacity_units) to camel case (capacityUnits) to improve readability.
  • Improving specificity to reflect underlying measurements.
Metric key (Grail)Metric key (Classic)
dt.host.uptime
builtin:host.uptime
dt.host.disk.used.percent
builtin:host.disk.usedPct
dt.process.network.sessions.reset_local
builtin:tech.generic.network.sessions.resetLocal
New and missing metric keys
By taking advantage of the improved scalability in Grail, it's no longer necessary to split, distribute, or pre-aggregate your data.
The Metrics Classic metric builtin:host.net.bytesRx represents bytes received by hosts in your environment, measured in bytes per second. It's a pre-aggregated metric based on builtin:host.net.nic.bytesRx, which measures bytes received by host-network interface pairs. Pre-aggregating the metric helps you to optimize queries and helps classic metrics distribute query load.
Consequently, the following two metric selectors return equivalent results with Metrics Classic metrics, but the query on builtin:host.net.bytesRx is faster (especially in large environments) because the host-level aggregation has already taken place.
// queries pre-aggregated host-level data
builtin:host.net.bytesRx:splitBy("dt.entity.host"):avg
// queries host- and network interface-level data
builtin:host.net.nic.bytesRx:splitBy("dt.entity.host"):avg
Grail, however, is already optimized for such high cardinality queries. Since the pre-aggregated metric builtin:host.net.bytesRx is no longer necessary, only builtin:host.net.nic.bytesRx is supported by metrics on Grail, and it can be queried as
timeseries avg(dt.host.net.nic.bytes_rx), by:{dt.entity.host}
Querying extension metrics in Grail
There are three kinds of Metrics Classic extension metrics to consider:
  1. Extensions with a builtin:tech prefix
  2. Extensions with an ext: prefix
  3. Extensions with no common prefix
For details, see below.
Type 1: Extension metrics with the builtin:tech prefix
Extension 1.0 metrics appear in Metrics Classic metrics with the prefix builtin:tech. These metrics appear in Grail instead with a legacy prefix. For example:
legacy.cassandra.KeyCache.Hit.Rate
builtin:tech.cassandra.KeyCache.Hit.Rate
This renaming applies to all Extension 1.0 metrics with the prefix builtin:tech, except for the following:
  • Generic process metrics, including all metrics with the prefix builtin:tech.generic.
  • WebSphere metrics, including all metrics with the prefix builtin:tech.websphere.
This renaming does not apply to Metrics Classic technology metrics, which can be upgraded to Grail runtime metrics, including metrics prefixed with builtin:tech.jvm, builtin:tech.go, and more.
Type 2: Extension metrics with the ext: prefix
Extension metrics with the ext: prefix are either provided by OneAgent or ActiveGate extensions, or are classic metrics for AWS integration. Regardless of the source, they behave the same way.
These can be found in Grail according to the following renaming rules:
  1. Remove the ext: prefix.
  2. Convert camelCase to snake_case.
As shown in the following examples, snake case renaming depends on the context. AWS's route53resolver and other components are proper nouns and are not renamed:
cloud.aws.dx.connection_error_count
ext:cloud.aws.dx.connectionErrorCount
cloud.aws.route53resolver.inbound_query_volume_sum
ext:cloud.aws.route53resolver.inboundQueryVolumeSum
Type 3: Extension metrics with no common prefix
These have no special renaming and can be queried as is in many cases.
cloud.gcp.cloudfunctions_googleapis_com.function.active_instances:splitBy():avg
timeseries avg(cloud.gcp.cloudfunctions_googleapis_com.function.active_instances)
Extension metrics with special characters are an exception. Escape these metrics with backticks (``) to use them in DQL.
com.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.loadavg."5min":splitBy():avg
timeseries avg(`com.dynatrace.extension.snmp-generic-cisco-device.cpm.cpu.loadavg.5min`)
Querying custom metrics on Grail
If you can't find your custom metric in Grail, try querying your metric key without the .count suffix.
You can query custom metrics with both metric selectors and DQL. However, your custom metric key might have a different name in DQL queries. For example, if you ingest a count metric with the coffees.brewed key, as shown below using the metric ingest protocol
coffees.brewing count,delta=2
Dynatrace creates and stores two metrics:
  • Classic metric coffees.brewing.count
  • Grail metric coffees.brewing
You can query the Grail metric via DQL using the original metric key:
timeseries sum(coffees.brewing)
This is different from Metrics Classic, which automatically appends count metrics with the .count suffix. You still need to use the coffees.brewing.count metric key to query the Metrics Classic metric.
coffees.brewing.count:splitBy():value
Querying calculated metrics in Grail
While calculated service metrics are supported, other calculated metrics are not yet supported on Grail.
  • Calculated RUM metrics (metrics with the prefix calc:apps) are not supported on Grail.
  • Calculated Log v1 metrics (metrics with the prefix calc:log) are not supported on Grail. See Upgrade Log Monitoring Classic to Log Management and Analytics.
Billing
dt.billing.foundation_and_discovery.usage
builtin:billing.foundation_and_discovery.usage
dt.billing.full_stack_monitoring.usage
builtin:billing.full_stack_monitoring.usage
dt.billing.infrastructure_monitoring.usage
builtin:billing.infrastructure_monitoring.usage
dt.billing.runtime_application_protection.usage
builtin:billing.runtime_application_protection.usage
dt.billing.runtime_vulnerability_analytics.usage
builtin:billing.runtime_vulnerability_analytics.usage
Cloud
AWS
Which Metrics Classic AWS metrics are not supported on Grail?
  • builtin:cloud.aws.cloudwatch.asg.errors.connect
  • builtin:cloud.aws.cloudwatch.asg.errors.lostData
  • builtin:cloud.aws.cloudwatch.asg.errors.notauth
  • builtin:cloud.aws.cloudwatch.asg.errors.service
  • builtin:cloud.aws.cloudwatch.asg.errors.throttling
  • builtin:cloud.aws.cloudwatch.asg.number
  • builtin:cloud.aws.cloudwatch.az.errors.connect
  • builtin:cloud.aws.cloudwatch.az.errors.lostData
  • builtin:cloud.aws.cloudwatch.az.errors.notauth
  • builtin:cloud.aws.cloudwatch.az.errors.service
  • builtin:cloud.aws.cloudwatch.az.errors.throttling
  • builtin:cloud.aws.cloudwatch.az.number
  • builtin:cloud.aws.cloudwatch.beanstalk.errors.connect
  • builtin:cloud.aws.cloudwatch.beanstalk.errors.lostData
  • builtin:cloud.aws.cloudwatch.beanstalk.errors.notauth
  • builtin:cloud.aws.cloudwatch.beanstalk.errors.service
  • builtin:cloud.aws.cloudwatch.beanstalk.errors.throttling
  • builtin:cloud.aws.cloudwatch.beanstalk.number
  • builtin:cloud.aws.cloudwatch.billing
  • builtin:cloud.aws.cloudwatch.cloudwatch.errors.connect
  • builtin:cloud.aws.cloudwatch.cloudwatch.errors.lostData
  • builtin:cloud.aws.cloudwatch.cloudwatch.errors.notauth
  • builtin:cloud.aws.cloudwatch.cloudwatch.errors.service
  • builtin:cloud.aws.cloudwatch.cloudwatch.errors.throttling
  • builtin:cloud.aws.cloudwatch.cloudwatch.latedata
  • builtin:cloud.aws.cloudwatch.dynamoDb.errors.connect
  • builtin:cloud.aws.cloudwatch.dynamoDb.errors.lostData
  • builtin:cloud.aws.cloudwatch.dynamoDb.errors.notauth
  • builtin:cloud.aws.cloudwatch.dynamoDb.errors.service
  • builtin:cloud.aws.cloudwatch.dynamoDb.errors.throttling
  • builtin:cloud.aws.cloudwatch.dynamoDb.number
  • builtin:cloud.aws.cloudwatch.ebs.api.failed
  • builtin:cloud.aws.cloudwatch.ebs.api.ok
  • builtin:cloud.aws.cloudwatch.ebs.errors.connect
  • builtin:cloud.aws.cloudwatch.ebs.errors.lostData
  • builtin:cloud.aws.cloudwatch.ebs.errors.notauth
  • builtin:cloud.aws.cloudwatch.ebs.errors.service
  • builtin:cloud.aws.cloudwatch.ebs.errors.throttling
  • builtin:cloud.aws.cloudwatch.ebs.number
  • builtin:cloud.aws.cloudwatch.ec2.api.failed
  • builtin:cloud.aws.cloudwatch.ec2.api.ok
  • builtin:cloud.aws.cloudwatch.ec2.errors.connect
  • builtin:cloud.aws.cloudwatch.ec2.errors.lostData
  • builtin:cloud.aws.cloudwatch.ec2.errors.notauth
  • builtin:cloud.aws.cloudwatch.ec2.errors.service
  • builtin:cloud.aws.cloudwatch.ec2.errors.throttling
  • builtin:cloud.aws.cloudwatch.ec2.number
  • builtin:cloud.aws.cloudwatch.elb.api.failed
  • builtin:cloud.aws.cloudwatch.elb.api.ok
  • builtin:cloud.aws.cloudwatch.elb.errors.connect
  • builtin:cloud.aws.cloudwatch.elb.errors.lostData
  • builtin:cloud.aws.cloudwatch.elb.errors.notauth
  • builtin:cloud.aws.cloudwatch.elb.errors.service
  • builtin:cloud.aws.cloudwatch.elb.errors.throttling
  • builtin:cloud.aws.cloudwatch.elb.number
  • builtin:cloud.aws.cloudwatch.lambda.errors.connect
  • builtin:cloud.aws.cloudwatch.lambda.errors.lostData
  • builtin:cloud.aws.cloudwatch.lambda.errors.notauth
  • builtin:cloud.aws.cloudwatch.lambda.errors.service
  • builtin:cloud.aws.cloudwatch.lambda.errors.throttling
  • builtin:cloud.aws.cloudwatch.lambda.number
  • builtin:cloud.aws.cloudwatch.polling.failures
  • builtin:cloud.aws.cloudwatch.polling.infrastructure
  • builtin:cloud.aws.cloudwatch.polling.metrics
  • builtin:cloud.aws.cloudwatch.rds.api.failed
  • builtin:cloud.aws.cloudwatch.rds.api.ok
  • builtin:cloud.aws.cloudwatch.rds.errors.connect
  • builtin:cloud.aws.cloudwatch.rds.errors.lostData
  • builtin:cloud.aws.cloudwatch.rds.errors.notauth
  • builtin:cloud.aws.cloudwatch.rds.errors.service
  • builtin:cloud.aws.cloudwatch.rds.errors.throttling
  • builtin:cloud.aws.cloudwatch.rds.number
  • builtin:cloud.aws.cloudwatch.s3.errors.connect
  • builtin:cloud.aws.cloudwatch.s3.errors.lostData
  • builtin:cloud.aws.cloudwatch.s3.errors.notauth
  • builtin:cloud.aws.cloudwatch.s3.errors.service
  • builtin:cloud.aws.cloudwatch.s3.errors.throttling
  • builtin:cloud.aws.cloudwatch.s3.number
dt.cloud.aws.alb.bytes
builtin:cloud.aws.alb.bytes
dt.cloud.aws.alb.connections.active
builtin:cloud.aws.alb.connections.active
dt.cloud.aws.alb.connections.new
builtin:cloud.aws.alb.connections.new
dt.cloud.aws.alb.errors.alb.http4xx
builtin:cloud.aws.alb.errors.alb.http4xx
dt.cloud.aws.alb.errors.alb.http5xx
builtin:cloud.aws.alb.errors.alb.http5xx
dt.cloud.aws.alb.errors.rej_con
builtin:cloud.aws.alb.errors.rejCon
dt.cloud.aws.alb.errors.targ_conn
builtin:cloud.aws.alb.errors.targConn
dt.cloud.aws.alb.errors.target.http4xx
builtin:cloud.aws.alb.errors.target.http4xx
dt.cloud.aws.alb.errors.target.http5xx
builtin:cloud.aws.alb.errors.target.http5xx
dt.cloud.aws.alb.errors.tls_neg
builtin:cloud.aws.alb.errors.tlsNeg
dt.cloud.aws.alb.lcus
builtin:cloud.aws.alb.lcus
dt.cloud.aws.alb.requests
builtin:cloud.aws.alb.requests
dt.cloud.aws.alb.resp_time
builtin:cloud.aws.alb.respTime
dt.cloud.aws.asg.running
builtin:cloud.aws.asg.running
dt.cloud.aws.asg.stopped
builtin:cloud.aws.asg.stopped
dt.cloud.aws.asg.terminated
builtin:cloud.aws.asg.terminated
dt.cloud.aws.az.running
builtin:cloud.aws.az.running
dt.cloud.aws.az.stopped
builtin:cloud.aws.az.stopped
dt.cloud.aws.az.terminated
builtin:cloud.aws.az.terminated
dt.cloud.aws.dynamo.capacity_units.consumed.read
builtin:cloud.aws.dynamo.capacityUnits.consumed.read
dt.cloud.aws.dynamo.capacity_units.consumed.write
builtin:cloud.aws.dynamo.capacityUnits.consumed.write
dt.cloud.aws.dynamo.capacity_units.provisioned.read
builtin:cloud.aws.dynamo.capacityUnits.provisioned.read
dt.cloud.aws.dynamo.capacity_units.provisioned.write
builtin:cloud.aws.dynamo.capacityUnits.provisioned.write
dt.cloud.aws.dynamo.capacity_units.read
builtin:cloud.aws.dynamo.capacityUnits.read
dt.cloud.aws.dynamo.capacity_units.write
builtin:cloud.aws.dynamo.capacityUnits.write
dt.cloud.aws.dynamo.errors.system
builtin:cloud.aws.dynamo.errors.system
dt.cloud.aws.dynamo.errors.user
builtin:cloud.aws.dynamo.errors.user
dt.cloud.aws.dynamo.requests.latency
builtin:cloud.aws.dynamo.requests.latency
dt.cloud.aws.dynamo.requests.returned_items
builtin:cloud.aws.dynamo.requests.returnedItems
dt.cloud.aws.dynamo.requests.throttled
builtin:cloud.aws.dynamo.requests.throttled
dt.cloud.aws.dynamo.tables
builtin:cloud.aws.dynamo.tables
dt.cloud.aws.dynamo.throttled_events.read
builtin:cloud.aws.dynamo.throttledEvents.read
dt.cloud.aws.dynamo.throttled_events.write
builtin:cloud.aws.dynamo.throttledEvents.write
dt.cloud.aws.ebs.idle_time
builtin:cloud.aws.ebs.idleTime
dt.cloud.aws.ebs.latency.read
builtin:cloud.aws.ebs.latency.read
dt.cloud.aws.ebs.latency.write
builtin:cloud.aws.ebs.latency.write
dt.cloud.aws.ebs.ops.consumed
builtin:cloud.aws.ebs.ops.consumed
dt.cloud.aws.ebs.ops.read
builtin:cloud.aws.ebs.ops.read
dt.cloud.aws.ebs.ops.write
builtin:cloud.aws.ebs.ops.write
dt.cloud.aws.ebs.queue
builtin:cloud.aws.ebs.queue
dt.cloud.aws.ebs.throughput.percent
builtin:cloud.aws.ebs.throughput.percent
dt.cloud.aws.ebs.throughput.read
builtin:cloud.aws.ebs.throughput.read
dt.cloud.aws.ebs.throughput.write
builtin:cloud.aws.ebs.throughput.write
dt.cloud.aws.ec2.cpu.usage
builtin:cloud.aws.ec2.cpu.usage
dt.cloud.aws.ec2.disk.read_ops
builtin:cloud.aws.ec2.disk.readOps
dt.cloud.aws.ec2.disk.read_rate
builtin:cloud.aws.ec2.disk.readRate
dt.cloud.aws.ec2.disk.write_ops
builtin:cloud.aws.ec2.disk.writeOps
dt.cloud.aws.ec2.disk.write_rate
builtin:cloud.aws.ec2.disk.writeRate
dt.cloud.aws.ec2.net.rx
builtin:cloud.aws.ec2.net.rx
dt.cloud.aws.ec2.net.tx
builtin:cloud.aws.ec2.net.tx
dt.cloud.aws.elb.errors.frontend
builtin:cloud.aws.elb.errors.frontend
dt.cloud.aws.elb.errors.backend.connection
builtin:cloud.aws.elb.errors.backend.connection
dt.cloud.aws.elb.errors.backend.http2xx
builtin:cloud.aws.elb.errors.backend.http2xx
dt.cloud.aws.elb.errors.backend.http3xx
builtin:cloud.aws.elb.errors.backend.http3xx
dt.cloud.aws.elb.errors.backend.http4xx
builtin:cloud.aws.elb.errors.backend.http4xx
dt.cloud.aws.elb.errors.backend.http5xx
builtin:cloud.aws.elb.errors.backend.http5xx
dt.cloud.aws.elb.errors.elb.http4xx
builtin:cloud.aws.elb.errors.elb.http4xx
dt.cloud.aws.elb.errors.elb.http5xx
builtin:cloud.aws.elb.errors.elb.http5xx
dt.cloud.aws.elb.hosts.healthy
builtin:cloud.aws.elb.hosts.healthy
dt.cloud.aws.elb.hosts.unhealthy
builtin:cloud.aws.elb.hosts.unhealthy
dt.cloud.aws.elb.latency
builtin:cloud.aws.elb.latency
dt.cloud.aws.elb.req_compl
builtin:cloud.aws.elb.reqCompl
dt.cloud.aws.lambda.conc_executions
builtin:cloud.aws.lambda.concExecutions
dt.cloud.aws.lambda.duration
builtin:cloud.aws.lambda.duration
dt.cloud.aws.lambda.errors
builtin:cloud.aws.lambda.errors
dt.cloud.aws.lambda.errors_rate
builtin:cloud.aws.lambda.errorsRate
dt.cloud.aws.lambda.invocations
builtin:cloud.aws.lambda.invocations
dt.cloud.aws.lambda.prov_conc_executions
builtin:cloud.aws.lambda.provConcExecutions
dt.cloud.aws.lambda.prov_conc_invocations
builtin:cloud.aws.lambda.provConcInvocations
dt.cloud.aws.lambda.prov_conc_spillover_invocations
builtin:cloud.aws.lambda.provConcSpilloverInvocations
dt.cloud.aws.lambda.throttlers
builtin:cloud.aws.lambda.throttlers
dt.cloud.aws.nlb.bytes
builtin:cloud.aws.nlb.bytes
dt.cloud.aws.nlb.flow.active
builtin:cloud.aws.nlb.flow.active
dt.cloud.aws.nlb.flow.new
builtin:cloud.aws.nlb.flow.new
dt.cloud.aws.nlb.lcus
builtin:cloud.aws.nlb.lcus
dt.cloud.aws.nlb.tcp.reset.client
builtin:cloud.aws.nlb.tcp.reset.client
dt.cloud.aws.nlb.tcp.reset.elb
builtin:cloud.aws.nlb.tcp.reset.elb
dt.cloud.aws.nlb.tcp.reset.target
builtin:cloud.aws.nlb.tcp.reset.target
dt.cloud.aws.rds.connections
builtin:cloud.aws.rds.connections
dt.cloud.aws.rds.cpu.usage
builtin:cloud.aws.rds.cpu.usage
dt.cloud.aws.rds.free
builtin:cloud.aws.rds.free
dt.cloud.aws.rds.latency.read
builtin:cloud.aws.rds.latency.read
dt.cloud.aws.rds.latency.write
builtin:cloud.aws.rds.latency.write
dt.cloud.aws.rds.memory.freeable
builtin:cloud.aws.rds.memory.freeable
dt.cloud.aws.rds.memory.swap
builtin:cloud.aws.rds.memory.swap
dt.cloud.aws.rds.net.rx
builtin:cloud.aws.rds.net.rx
dt.cloud.aws.rds.net.tx
builtin:cloud.aws.rds.net.tx
dt.cloud.aws.rds.ops.read
builtin:cloud.aws.rds.ops.read
dt.cloud.aws.rds.ops.write
builtin:cloud.aws.rds.ops.write
dt.cloud.aws.rds.restarts
builtin:cloud.aws.rds.restarts
dt.cloud.aws.rds.throughput.read
builtin:cloud.aws.rds.throughput.read
dt.cloud.aws.rds.throughput.write
builtin:cloud.aws.rds.throughput.write
Azure
Which Metrics Classic Azure metrics are not supported on Grail?
  • builtin:cloud.azure.AzureStatistics.amountOfAzureResourceType
  • builtin:cloud.azure.azureEventsWebhook.invalidRequests
  • builtin:cloud.azure.azureEventsWebhook.okRequests
  • builtin:cloud.azure.azureEventsWebhook.throttledRequests
  • builtin:cloud.azure.azureEventsWebhook.unauthorizedRequests
  • builtin:cloud.azure.azureEventsWebhook.unsupportedRequests
dt.cloud.azure.api_mgmt.capacity
builtin:cloud.azure.apiMgmt.capacity
dt.cloud.azure.api_mgmt.duration
builtin:cloud.azure.apiMgmt.duration
dt.cloud.azure.api_mgmt.requests.failed
builtin:cloud.azure.apiMgmt.requests.failed
dt.cloud.azure.api_mgmt.requests.other
builtin:cloud.azure.apiMgmt.requests.other
dt.cloud.azure.api_mgmt.requests.successful
builtin:cloud.azure.apiMgmt.requests.successful
dt.cloud.azure.api_mgmt.requests.total
builtin:cloud.azure.apiMgmt.requests.total
dt.cloud.azure.api_mgmt.requests.unauth
builtin:cloud.azure.apiMgmt.requests.unauth
dt.cloud.azure.app_gateway.backend.settings.pool.host.healthy
builtin:cloud.azure.appGateway.backend.settings.pool.host.healthy
dt.cloud.azure.app_gateway.backend.settings.pool.host.unhealthy
builtin:cloud.azure.appGateway.backend.settings.pool.host.unhealthy
dt.cloud.azure.app_gateway.backend.settings.traffic.requests.failed
builtin:cloud.azure.appGateway.backend.settings.traffic.requests.failed
dt.cloud.azure.app_gateway.backend.settings.traffic.requests.total
builtin:cloud.azure.appGateway.backend.settings.traffic.requests.total
dt.cloud.azure.app_gateway.http.status.response
builtin:cloud.azure.appGateway.http.status.response
dt.cloud.azure.app_gateway.network.connections.count
builtin:cloud.azure.appGateway.network.connections.count
dt.cloud.azure.app_gateway.network.throughput
builtin:cloud.azure.appGateway.network.throughput
dt.cloud.azure.app_service.application_queue.requests
builtin:cloud.azure.appService.applicationQueue.requests
dt.cloud.azure.app_service.functions.application_queue.requests
builtin:cloud.azure.appService.functions.applicationQueue.requests
dt.cloud.azure.app_service.functions.execution.count
builtin:cloud.azure.appService.functions.execution.count
dt.cloud.azure.app_service.functions.execution.units_count
builtin:cloud.azure.appService.functions.execution.unitsCount
dt.cloud.azure.app_service.functions.http.status.http5xx
builtin:cloud.azure.appService.functions.http.status.http5xx
dt.cloud.azure.app_service.functions.io.operations.other
builtin:cloud.azure.appService.functions.io.operations.other
dt.cloud.azure.app_service.functions.io.operations.read
builtin:cloud.azure.appService.functions.io.operations.read
dt.cloud.azure.app_service.functions.io.operations.write
builtin:cloud.azure.appService.functions.io.operations.write
dt.cloud.azure.app_service.functions.io.other
builtin:cloud.azure.appService.functions.io.other
dt.cloud.azure.app_service.functions.io.read
builtin:cloud.azure.appService.functions.io.read
dt.cloud.azure.app_service.functions.io.write
builtin:cloud.azure.appService.functions.io.write
dt.cloud.azure.app_service.functions.traffic.bytes_received
builtin:cloud.azure.appService.functions.traffic.bytesReceived
dt.cloud.azure.app_service.functions.traffic.bytes_sent
builtin:cloud.azure.appService.functions.traffic.bytesSent
dt.cloud.azure.app_service.http.status.http2xx
builtin:cloud.azure.appService.http.status.http2xx
dt.cloud.azure.app_service.http.status.http403
builtin:cloud.azure.appService.http.status.http403
dt.cloud.azure.app_service.http.status.http5xx
builtin:cloud.azure.appService.http.status.http5xx
dt.cloud.azure.app_service.io.operations.other
builtin:cloud.azure.appService.io.operations.other
dt.cloud.azure.app_service.io.operations.read
builtin:cloud.azure.appService.io.operations.read
dt.cloud.azure.app_service.io.operations.write
builtin:cloud.azure.appService.io.operations.write
dt.cloud.azure.app_service.io.other
builtin:cloud.azure.appService.io.other
dt.cloud.azure.app_service.io.read
builtin:cloud.azure.appService.io.read
dt.cloud.azure.app_service.io.write
builtin:cloud.azure.appService.io.write
dt.cloud.azure.app_service.response.avg
builtin:cloud.azure.appService.response.avg
dt.cloud.azure.app_service.traffic.bytes_received
builtin:cloud.azure.appService.traffic.bytesReceived
dt.cloud.azure.app_service.traffic.bytes_sent
builtin:cloud.azure.appService.traffic.bytesSent
dt.cloud.azure.app_service.traffic.requests
builtin:cloud.azure.appService.traffic.requests
dt.cloud.azure.cosmos.available_storage
builtin:cloud.azure.cosmos.availableStorage
dt.cloud.azure.cosmos.data_usage
builtin:cloud.azure.cosmos.dataUsage
dt.cloud.azure.cosmos.document_count
builtin:cloud.azure.cosmos.documentCount
dt.cloud.azure.cosmos.document_quota
builtin:cloud.azure.cosmos.documentQuota
dt.cloud.azure.cosmos.index_usage
builtin:cloud.azure.cosmos.indexUsage
dt.cloud.azure.cosmos.metadata_requests
builtin:cloud.azure.cosmos.metadataRequests
dt.cloud.azure.cosmos.normalized_ruconsumption
builtin:cloud.azure.cosmos.normalizedRUConsumption
dt.cloud.azure.cosmos.provisioned_throughput
builtin:cloud.azure.cosmos.provisionedThroughput
dt.cloud.azure.cosmos.replication_latency
builtin:cloud.azure.cosmos.replicationLatency
dt.cloud.azure.cosmos.request_units
builtin:cloud.azure.cosmos.requestUnits
dt.cloud.azure.cosmos.requests
builtin:cloud.azure.cosmos.requests
dt.cloud.azure.cosmos.service_availability
builtin:cloud.azure.cosmos.serviceAvailability
dt.cloud.azure.event_hub.capture.backlog
builtin:cloud.azure.eventHub.capture.backlog
dt.cloud.azure.event_hub.capture.bytes
builtin:cloud.azure.eventHub.capture.bytes
dt.cloud.azure.event_hub.capture.msg
builtin:cloud.azure.eventHub.capture.msg
dt.cloud.azure.event_hub.errors.quota_exceeded
builtin:cloud.azure.eventHub.errors.quotaExceeded
dt.cloud.azure.event_hub.errors.server
builtin:cloud.azure.eventHub.errors.server
dt.cloud.azure.event_hub.errors.user
builtin:cloud.azure.eventHub.errors.user
dt.cloud.azure.event_hub.requests.incoming
builtin:cloud.azure.eventHub.requests.incoming
dt.cloud.azure.event_hub.requests.successful
builtin:cloud.azure.eventHub.requests.successful
dt.cloud.azure.event_hub.requests.throttled
builtin:cloud.azure.eventHub.requests.throttled
dt.cloud.azure.event_hub.traffic.bytes_in
builtin:cloud.azure.eventHub.traffic.bytesIn
dt.cloud.azure.event_hub.traffic.bytes_out
builtin:cloud.azure.eventHub.traffic.bytesOut
dt.cloud.azure.event_hub.traffic.msg_in
builtin:cloud.azure.eventHub.traffic.msgIn
dt.cloud.azure.event_hub.traffic.msg_out
builtin:cloud.azure.eventHub.traffic.msgOut
dt.cloud.azure.event_hub_namespace.connections.active
builtin:cloud.azure.eventHubNamespace.connections.active
dt.cloud.azure.event_hub_namespace.connections.closed
builtin:cloud.azure.eventHubNamespace.connections.closed
dt.cloud.azure.event_hub_namespace.connections.opened
builtin:cloud.azure.eventHubNamespace.connections.opened
dt.cloud.azure.iot_hub.command.abandoned
builtin:cloud.azure.iotHub.command.abandoned
dt.cloud.azure.iot_hub.command.completed
builtin:cloud.azure.iotHub.command.completed
dt.cloud.azure.iot_hub.command.rejected
builtin:cloud.azure.iotHub.command.rejected
dt.cloud.azure.iot_hub.device.connected
builtin:cloud.azure.iotHub.device.connected
dt.cloud.azure.iot_hub.device.daily_throughput_throttling
builtin:cloud.azure.iotHub.device.dailyThroughputThrottling
dt.cloud.azure.iot_hub.device.data_usage
builtin:cloud.azure.iotHub.device.dataUsage
dt.cloud.azure.iot_hub.device.registered
builtin:cloud.azure.iotHub.device.registered
dt.cloud.azure.iot_hub.event_hub.average_latency_ms
builtin:cloud.azure.iotHub.eventHub.averageLatencyMs
dt.cloud.azure.iot_hub.event_hub.built_in_event_hub.average_latency_ms
builtin:cloud.azure.iotHub.eventHub.builtInEventHub.averageLatencyMs
dt.cloud.azure.iot_hub.event_hub.built_in_event_hub.messages.delivered
builtin:cloud.azure.iotHub.eventHub.builtInEventHub.messages.delivered
dt.cloud.azure.iot_hub.event_hub.messages.delivered
builtin:cloud.azure.iotHub.eventHub.messages.delivered
dt.cloud.azure.iot_hub.messages.dropped
builtin:cloud.azure.iotHub.messages.dropped
dt.cloud.azure.iot_hub.messages.invalid_for_all_endpoints
builtin:cloud.azure.iotHub.messages.invalidForAllEndpoints
dt.cloud.azure.iot_hub.messages.orphaned
builtin:cloud.azure.iotHub.messages.orphaned
dt.cloud.azure.iot_hub.messages.send_attempts
builtin:cloud.azure.iotHub.messages.sendAttempts
dt.cloud.azure.iot_hub.messages.sent
builtin:cloud.azure.iotHub.messages.sent
dt.cloud.azure.iot_hub.messages.sent_to_fallback
builtin:cloud.azure.iotHub.messages.sentToFallback
dt.cloud.azure.iot_hub.service_bus.queues.average_latency_ms
builtin:cloud.azure.iotHub.serviceBus.queues.averageLatencyMs
dt.cloud.azure.iot_hub.service_bus.queues.messages_delivered
builtin:cloud.azure.iotHub.serviceBus.queues.messagesDelivered
dt.cloud.azure.iot_hub.service_bus.topics.average_latency_ms
builtin:cloud.azure.iotHub.serviceBus.topics.averageLatencyMs
dt.cloud.azure.iot_hub.service_bus.topics.messages_delivered
builtin:cloud.azure.iotHub.serviceBus.topics.messagesDelivered
dt.cloud.azure.iot_hub.storage_endpoints.avg_latency_ms
builtin:cloud.azure.iotHub.storageEndpoints.avgLatencyMs
dt.cloud.azure.iot_hub.storage_endpoints.blobs_written
builtin:cloud.azure.iotHub.storageEndpoints.blobsWritten
dt.cloud.azure.iot_hub.storage_endpoints.bytes_written
builtin:cloud.azure.iotHub.storageEndpoints.bytesWritten
dt.cloud.azure.iot_hub.storage_endpoints.message_delivered
builtin:cloud.azure.iotHub.storageEndpoints.messageDelivered
dt.cloud.azure.loadbalancer.availability.dip_tcp
builtin:cloud.azure.loadbalancer.availability.dipTcp
dt.cloud.azure.loadbalancer.availability.dip_udp
builtin:cloud.azure.loadbalancer.availability.dipUdp
dt.cloud.azure.loadbalancer.availability.vip
builtin:cloud.azure.loadbalancer.availability.vip
dt.cloud.azure.loadbalancer.snat_connection.est
builtin:cloud.azure.loadbalancer.snatConnection.est
dt.cloud.azure.loadbalancer.snat_connection.pending
builtin:cloud.azure.loadbalancer.snatConnection.pending
dt.cloud.azure.loadbalancer.snat_connection.rej
builtin:cloud.azure.loadbalancer.snatConnection.rej
dt.cloud.azure.loadbalancer.traffic.byte_in
builtin:cloud.azure.loadbalancer.traffic.byteIn
dt.cloud.azure.loadbalancer.traffic.byte_out
builtin:cloud.azure.loadbalancer.traffic.byteOut
dt.cloud.azure.loadbalancer.traffic.packet_in
builtin:cloud.azure.loadbalancer.traffic.packetIn
dt.cloud.azure.loadbalancer.traffic.packet_out
builtin:cloud.azure.loadbalancer.traffic.packetOut
dt.cloud.azure.loadbalancer.traffic.packet_syn_in
builtin:cloud.azure.loadbalancer.traffic.packetSynIn
dt.cloud.azure.loadbalancer.traffic.packet_syn_out
builtin:cloud.azure.loadbalancer.traffic.packetSynOut
dt.cloud.azure.redis.cache.hits
builtin:cloud.azure.redis.cache.hits
dt.cloud.azure.redis.cache.misses
builtin:cloud.azure.redis.cache.misses
dt.cloud.azure.redis.cache.read
builtin:cloud.azure.redis.cache.read
dt.cloud.azure.redis.cache.write
builtin:cloud.azure.redis.cache.write
dt.cloud.azure.redis.commands.get
builtin:cloud.azure.redis.commands.get
dt.cloud.azure.redis.commands.set
builtin:cloud.azure.redis.commands.set
dt.cloud.azure.redis.commands.total
builtin:cloud.azure.redis.commands.total
dt.cloud.azure.redis.connected
builtin:cloud.azure.redis.connected
dt.cloud.azure.redis.keys.evicted
builtin:cloud.azure.redis.keys.evicted
dt.cloud.azure.redis.keys.expired
builtin:cloud.azure.redis.keys.expired
dt.cloud.azure.redis.keys.total
builtin:cloud.azure.redis.keys.total
dt.cloud.azure.redis.load
builtin:cloud.azure.redis.load
dt.cloud.azure.redis.memory.used
builtin:cloud.azure.redis.memory.used
dt.cloud.azure.redis.memory.used_rss
builtin:cloud.azure.redis.memory.usedRss
dt.cloud.azure.redis.processor_time
builtin:cloud.azure.redis.processorTime
dt.cloud.azure.region.vms.initializing
builtin:cloud.azure.region.vms.initializing
dt.cloud.azure.region.vms.running
builtin:cloud.azure.region.vms.running
dt.cloud.azure.region.vms.stopped
builtin:cloud.azure.region.vms.stopped
dt.cloud.azure.service_bus.namespace.connections.active
builtin:cloud.azure.serviceBus.namespace.connections.active
dt.cloud.azure.service_bus.namespace.cpu
builtin:cloud.azure.serviceBus.namespace.cpu
dt.cloud.azure.service_bus.namespace.errors.server
builtin:cloud.azure.serviceBus.namespace.errors.server
dt.cloud.azure.service_bus.namespace.errors.user
builtin:cloud.azure.serviceBus.namespace.errors.user
dt.cloud.azure.service_bus.namespace.memory
builtin:cloud.azure.serviceBus.namespace.memory
dt.cloud.azure.service_bus.namespace.messages.count
builtin:cloud.azure.serviceBus.namespace.messages.count
dt.cloud.azure.service_bus.namespace.messages.count_active
builtin:cloud.azure.serviceBus.namespace.messages.countActive
dt.cloud.azure.service_bus.namespace.messages.count_dead_lettered
builtin:cloud.azure.serviceBus.namespace.messages.countDeadLettered
dt.cloud.azure.service_bus.namespace.messages.count_scheduled
builtin:cloud.azure.serviceBus.namespace.messages.countScheduled
dt.cloud.azure.service_bus.namespace.messages.incoming
builtin:cloud.azure.serviceBus.namespace.messages.incoming
dt.cloud.azure.service_bus.namespace.messages.outgoing
builtin:cloud.azure.serviceBus.namespace.messages.outgoing
dt.cloud.azure.service_bus.namespace.requests.incoming
builtin:cloud.azure.serviceBus.namespace.requests.incoming
dt.cloud.azure.service_bus.namespace.requests.successful
builtin:cloud.azure.serviceBus.namespace.requests.successful
dt.cloud.azure.service_bus.namespace.requests.throttled
builtin:cloud.azure.serviceBus.namespace.requests.throttled
dt.cloud.azure.service_bus.namespace.size
builtin:cloud.azure.serviceBus.namespace.size
dt.cloud.azure.service_bus.queue.errors.server
builtin:cloud.azure.serviceBus.queue.errors.server
dt.cloud.azure.service_bus.queue.errors.user
builtin:cloud.azure.serviceBus.queue.errors.user
dt.cloud.azure.service_bus.queue.messages.count
builtin:cloud.azure.serviceBus.queue.messages.count
dt.cloud.azure.service_bus.queue.messages.count_active
builtin:cloud.azure.serviceBus.queue.messages.countActive
dt.cloud.azure.service_bus.queue.messages.count_dead_lettered
builtin:cloud.azure.serviceBus.queue.messages.countDeadLettered
dt.cloud.azure.service_bus.queue.messages.count_scheduled
builtin:cloud.azure.serviceBus.queue.messages.countScheduled
dt.cloud.azure.service_bus.queue.messages.incoming
builtin:cloud.azure.serviceBus.queue.messages.incoming
dt.cloud.azure.service_bus.queue.messages.outgoing
builtin:cloud.azure.serviceBus.queue.messages.outgoing
dt.cloud.azure.service_bus.queue.requests.incoming
builtin:cloud.azure.serviceBus.queue.requests.incoming
dt.cloud.azure.service_bus.queue.requests.successful
builtin:cloud.azure.serviceBus.queue.requests.successful
dt.cloud.azure.service_bus.queue.requests.throttled
builtin:cloud.azure.serviceBus.queue.requests.throttled
dt.cloud.azure.service_bus.queue.size
builtin:cloud.azure.serviceBus.queue.size
dt.cloud.azure.service_bus.topic.errors.server
builtin:cloud.azure.serviceBus.topic.errors.server
dt.cloud.azure.service_bus.topic.errors.user
builtin:cloud.azure.serviceBus.topic.errors.user
dt.cloud.azure.service_bus.topic.messages.count
builtin:cloud.azure.serviceBus.topic.messages.count
dt.cloud.azure.service_bus.topic.messages.count_active
builtin:cloud.azure.serviceBus.topic.messages.countActive
dt.cloud.azure.service_bus.topic.messages.count_dead_lettered
builtin:cloud.azure.serviceBus.topic.messages.countDeadLettered
dt.cloud.azure.service_bus.topic.messages.count_scheduled
builtin:cloud.azure.serviceBus.topic.messages.countScheduled
dt.cloud.azure.service_bus.topic.messages.incoming
builtin:cloud.azure.serviceBus.topic.messages.incoming
dt.cloud.azure.service_bus.topic.messages.outgoing
builtin:cloud.azure.serviceBus.topic.messages.outgoing
dt.cloud.azure.service_bus.topic.requests.incoming
builtin:cloud.azure.serviceBus.topic.requests.incoming
dt.cloud.azure.service_bus.topic.requests.successful
builtin:cloud.azure.serviceBus.topic.requests.successful
dt.cloud.azure.service_bus.topic.requests.throttled
builtin:cloud.azure.serviceBus.topic.requests.throttled
dt.cloud.azure.service_bus.topic.size
builtin:cloud.azure.serviceBus.topic.size
dt.cloud.azure.sql_database.connections.blocked_by_firewall
builtin:cloud.azure.sqlDatabase.connections.blockedByFirewall
dt.cloud.azure.sql_database.connections.failed
builtin:cloud.azure.sqlDatabase.connections.failed
dt.cloud.azure.sql_database.connections.successful
builtin:cloud.azure.sqlDatabase.connections.successful
dt.cloud.azure.sql_database.cpu_percent
builtin:cloud.azure.sqlDatabase.cpuPercent
dt.cloud.azure.sql_database.deadlocks
builtin:cloud.azure.sqlDatabase.deadlocks
dt.cloud.azure.sql_database.dtu.consumption_perc
builtin:cloud.azure.sqlDatabase.dtu.consumptionPerc
dt.cloud.azure.sql_database.dtu.limit.count
builtin:cloud.azure.sqlDatabase.dtu.limit.count
dt.cloud.azure.sql_database.dtu.limit.used
builtin:cloud.azure.sqlDatabase.dtu.limit.used
dt.cloud.azure.sql_database.io.data_read
builtin:cloud.azure.sqlDatabase.io.dataRead
dt.cloud.azure.sql_database.io.log_write
builtin:cloud.azure.sqlDatabase.io.logWrite
dt.cloud.azure.sql_database.sessions
builtin:cloud.azure.sqlDatabase.sessions
dt.cloud.azure.sql_database.storage.percent
builtin:cloud.azure.sqlDatabase.storage.percent
dt.cloud.azure.sql_database.storage.total_bytes
builtin:cloud.azure.sqlDatabase.storage.totalBytes
dt.cloud.azure.sql_database.storage.xtp_percent
builtin:cloud.azure.sqlDatabase.storage.xtpPercent
dt.cloud.azure.sql_database.workers
builtin:cloud.azure.sqlDatabase.workers
dt.cloud.azure.sql_elastic_pool.cpu_percent
builtin:cloud.azure.sqlElasticPool.cpuPercent
dt.cloud.azure.sql_elastic_pool.dtu.consumption
builtin:cloud.azure.sqlElasticPool.dtu.consumption
dt.cloud.azure.sql_elastic_pool.dtu.storage.limit_bytes
builtin:cloud.azure.sqlElasticPool.dtu.storage.limitBytes
dt.cloud.azure.sql_elastic_pool.dtu.storage.percent
builtin:cloud.azure.sqlElasticPool.dtu.storage.percent
dt.cloud.azure.sql_elastic_pool.dtu.storage.used_bytes
builtin:cloud.azure.sqlElasticPool.dtu.storage.usedBytes
dt.cloud.azure.sql_elastic_pool.dtu.storage.xtp_percent
builtin:cloud.azure.sqlElasticPool.dtu.storage.xtpPercent
dt.cloud.azure.sql_elastic_pool.edtu.limit
builtin:cloud.azure.sqlElasticPool.edtu.limit
dt.cloud.azure.sql_elastic_pool.edtu.used
builtin:cloud.azure.sqlElasticPool.edtu.used
dt.cloud.azure.sql_elastic_pool.io.data_read
builtin:cloud.azure.sqlElasticPool.io.dataRead
dt.cloud.azure.sql_elastic_pool.io.log_write
builtin:cloud.azure.sqlElasticPool.io.logWrite
dt.cloud.azure.sql_elastic_pool.sessions
builtin:cloud.azure.sqlElasticPool.sessions
dt.cloud.azure.sql_elastic_pool.workers
builtin:cloud.azure.sqlElasticPool.workers
dt.cloud.azure.storage.blob.capacity
builtin:cloud.azure.storage.blob.capacity
dt.cloud.azure.storage.blob.containers
builtin:cloud.azure.storage.blob.containers
dt.cloud.azure.storage.blob.entities
builtin:cloud.azure.storage.blob.entities
dt.cloud.azure.storage.blob.transactions
builtin:cloud.azure.storage.blob.transactions
dt.cloud.azure.storage.blob.transactions.network.egress
builtin:cloud.azure.storage.blob.transactions.network.egress
dt.cloud.azure.storage.blob.transactions.network.ingress
builtin:cloud.azure.storage.blob.transactions.network.ingress
dt.cloud.azure.storage.blob.transactions.network.latency.success.e2e
builtin:cloud.azure.storage.blob.transactions.network.latency.success.e2e
dt.cloud.azure.storage.blob.transactions.network.latency.success.server
builtin:cloud.azure.storage.blob.transactions.network.latency.success.server
dt.cloud.azure.storage.file.capacity
builtin:cloud.azure.storage.file.capacity
dt.cloud.azure.storage.file.containers
builtin:cloud.azure.storage.file.containers
dt.cloud.azure.storage.file.entities
builtin:cloud.azure.storage.file.entities
dt.cloud.azure.storage.file.transactions
builtin:cloud.azure.storage.file.transactions
dt.cloud.azure.storage.file.transactions.network.egress
builtin:cloud.azure.storage.file.transactions.network.egress
dt.cloud.azure.storage.file.transactions.network.ingress
builtin:cloud.azure.storage.file.transactions.network.ingress
dt.cloud.azure.storage.file.transactions.network.latency.success.e2e
builtin:cloud.azure.storage.file.transactions.network.latency.success.e2e
dt.cloud.azure.storage.file.transactions.network.latency.success.server
builtin:cloud.azure.storage.file.transactions.network.latency.success.server
dt.cloud.azure.storage.queue.capacity
builtin:cloud.azure.storage.queue.capacity
dt.cloud.azure.storage.queue.containers
builtin:cloud.azure.storage.queue.containers
dt.cloud.azure.storage.queue.entities
builtin:cloud.azure.storage.queue.entities
dt.cloud.azure.storage.queue.transactions
builtin:cloud.azure.storage.queue.transactions
dt.cloud.azure.storage.queue.transactions.network.egress
builtin:cloud.azure.storage.queue.transactions.network.egress
dt.cloud.azure.storage.queue.transactions.network.ingress
builtin:cloud.azure.storage.queue.transactions.network.ingress
dt.cloud.azure.storage.queue.transactions.network.latency.success.e2e
builtin:cloud.azure.storage.queue.transactions.network.latency.success.e2e
dt.cloud.azure.storage.queue.transactions.network.latency.success.server
builtin:cloud.azure.storage.queue.transactions.network.latency.success.server
dt.cloud.azure.storage.table.capacity
builtin:cloud.azure.storage.table.capacity
dt.cloud.azure.storage.table.containers
builtin:cloud.azure.storage.table.containers
dt.cloud.azure.storage.table.entities
builtin:cloud.azure.storage.table.entities
dt.cloud.azure.storage.table.transactions
builtin:cloud.azure.storage.table.transactions
dt.cloud.azure.storage.table.transactions.network.egress
builtin:cloud.azure.storage.table.transactions.network.egress
dt.cloud.azure.storage.table.transactions.network.ingress
builtin:cloud.azure.storage.table.transactions.network.ingress
dt.cloud.azure.storage.table.transactions.network.latency.success.server
builtin:cloud.azure.storage.table.transactions.network.latency.success.server
dt.cloud.azure.storage.table.transactions.network.latency.success.server.e2e
builtin:cloud.azure.storage.table.transactions.network.latency.success.server.e2e
dt.cloud.azure.vm.cpu_usage
builtin:cloud.azure.vm.cpuUsage
dt.cloud.azure.vm.disk.read
builtin:cloud.azure.vm.disk.read
dt.cloud.azure.vm.disk.read_ops
builtin:cloud.azure.vm.disk.readOps
dt.cloud.azure.vm.disk.write
builtin:cloud.azure.vm.disk.write
dt.cloud.azure.vm.disk.write_ops
builtin:cloud.azure.vm.disk.writeOps
dt.cloud.azure.vm.network.bytes_in
builtin:cloud.azure.vm.network.bytesIn
dt.cloud.azure.vm.network.bytes_out
builtin:cloud.azure.vm.network.bytesOut
dt.cloud.azure.vm_scale_set.cpu_usage
builtin:cloud.azure.vmScaleSet.cpuUsage
dt.cloud.azure.vm_scale_set.disk.read
builtin:cloud.azure.vmScaleSet.disk.read
dt.cloud.azure.vm_scale_set.disk.read_ops
builtin:cloud.azure.vmScaleSet.disk.readOps
dt.cloud.azure.vm_scale_set.disk.write
builtin:cloud.azure.vmScaleSet.disk.write
dt.cloud.azure.vm_scale_set.disk.write_ops
builtin:cloud.azure.vmScaleSet.disk.writeOps
dt.cloud.azure.vm_scale_set.network.bytes_in
builtin:cloud.azure.vmScaleSet.network.bytesIn
dt.cloud.azure.vm_scale_set.network.bytes_out
builtin:cloud.azure.vmScaleSet.network.bytesOut
dt.cloud.azure.vm_scale_set.vms.initializing
builtin:cloud.azure.vmScaleSet.vms.initializing
dt.cloud.azure.vm_scale_set.vms.running
builtin:cloud.azure.vmScaleSet.vms.running
dt.cloud.azure.vm_scale_set.vms.stopped
builtin:cloud.azure.vmScaleSet.vms.stopped
Cloud Foundry
Which Metrics Classic Cloud Foundry metrics are not supported on Grail?
  • builtin:cloud.cloudfoundry.auctioneer.lprFailed
  • builtin:cloud.cloudfoundry.auctioneer.lprStarted
dt.cloud.cloudfoundry.auctioneer.fetch_duration
builtin:cloud.cloudfoundry.auctioneer.fetchDuration
dt.cloud.cloudfoundry.auctioneer.task_failed
builtin:cloud.cloudfoundry.auctioneer.taskFailed
dt.cloud.cloudfoundry.http.bad_gateways
builtin:cloud.cloudfoundry.http.badGateways
dt.cloud.cloudfoundry.http.latency
builtin:cloud.cloudfoundry.http.latency
dt.cloud.cloudfoundry.http.responses5xx
builtin:cloud.cloudfoundry.http.responses5xx
dt.cloud.cloudfoundry.http.total_requests
builtin:cloud.cloudfoundry.http.totalRequests
VMware
Which Metrics Classic VMware metrics are not supported on Grail?
  • builtin:cloud.vmware.hypervisor.availability
dt.cloud.vmware.hypervisor.cpu.usage
builtin:cloud.vmware.hypervisor.cpu.usage
dt.cloud.vmware.hypervisor.disk.usage
builtin:cloud.vmware.hypervisor.disk.usage
dt.cloud.vmware.hypervisor.hostdisk.commands_aborted
builtin:cloud.vmware.hypervisor.hostdisk.commandsAborted
dt.cloud.vmware.hypervisor.hostdisk.queue_latency
builtin:cloud.vmware.hypervisor.hostdisk.queueLatency
dt.cloud.vmware.hypervisor.hostdisk.r_iops
builtin:cloud.vmware.hypervisor.hostdisk.rIops
dt.cloud.vmware.hypervisor.hostdisk.read_latency
builtin:cloud.vmware.hypervisor.hostdisk.readLatency
dt.cloud.vmware.hypervisor.hostdisk.read_rate
builtin:cloud.vmware.hypervisor.hostdisk.readRate
dt.cloud.vmware.hypervisor.hostdisk.w_iops
builtin:cloud.vmware.hypervisor.hostdisk.wIops
dt.cloud.vmware.hypervisor.hostdisk.write_latency
builtin:cloud.vmware.hypervisor.hostdisk.writeLatency
dt.cloud.vmware.hypervisor.hostdisk.write_rate
builtin:cloud.vmware.hypervisor.hostdisk.writeRate
dt.cloud.vmware.hypervisor.mem.compression_rate
builtin:cloud.vmware.hypervisor.mem.compressionRate
dt.cloud.vmware.hypervisor.mem.consumed
builtin:cloud.vmware.hypervisor.mem.consumed
dt.cloud.vmware.hypervisor.mem.decompression_rate
builtin:cloud.vmware.hypervisor.mem.decompressionRate
dt.cloud.vmware.hypervisor.mem.swap_in
builtin:cloud.vmware.hypervisor.mem.swapIn
dt.cloud.vmware.hypervisor.mem.swap_out
builtin:cloud.vmware.hypervisor.mem.swapOut
dt.cloud.vmware.hypervisor.net.rx
builtin:cloud.vmware.hypervisor.net.rx
dt.cloud.vmware.hypervisor.net.tx
builtin:cloud.vmware.hypervisor.net.tx
dt.cloud.vmware.hypervisor.nic.data_rx
builtin:cloud.vmware.hypervisor.nic.dataRx
dt.cloud.vmware.hypervisor.nic.data_tx
builtin:cloud.vmware.hypervisor.nic.dataTx
dt.cloud.vmware.hypervisor.nic.packets_rx_dropped
builtin:cloud.vmware.hypervisor.nic.packetsRxDropped
dt.cloud.vmware.hypervisor.nic.packets_tx_dropped
builtin:cloud.vmware.hypervisor.nic.packetsTxDropped
dt.cloud.vmware.hypervisor.vms.count
builtin:cloud.vmware.hypervisor.vms.count
dt.cloud.vmware.hypervisor.vms.power_off
builtin:cloud.vmware.hypervisor.vms.powerOff
dt.cloud.vmware.hypervisor.vms.suspended
builtin:cloud.vmware.hypervisor.vms.suspended
dt.cloud.vmware.vm.cpu.ready_perc
builtin:cloud.vmware.vm.cpu.readyPerc
dt.cloud.vmware.vm.cpu.swap_wait
builtin:cloud.vmware.vm.cpu.swapWait
dt.cloud.vmware.vm.cpu.usage
builtin:cloud.vmware.vm.cpu.usage
dt.cloud.vmware.vm.cpu.usage_perc
builtin:cloud.vmware.vm.cpu.usagePerc
dt.cloud.vmware.vm.disk.usage
builtin:cloud.vmware.vm.disk.usage
dt.cloud.vmware.vm.mem.active
builtin:cloud.vmware.vm.mem.active
dt.cloud.vmware.vm.mem.compression_rate
builtin:cloud.vmware.vm.mem.compressionRate
dt.cloud.vmware.vm.mem.consumed
builtin:cloud.vmware.vm.mem.consumed
dt.cloud.vmware.vm.mem.decompression_rate
builtin:cloud.vmware.vm.mem.decompressionRate
dt.cloud.vmware.vm.mem.swap_in
builtin:cloud.vmware.vm.mem.swapIn
dt.cloud.vmware.vm.mem.swap_out
builtin:cloud.vmware.vm.mem.swapOut
dt.cloud.vmware.vm.net.rx
builtin:cloud.vmware.vm.net.rx
dt.cloud.vmware.vm.net.tx
builtin:cloud.vmware.vm.net.tx
Containers
New container metrics are now available for DPS-enabled customers. The new metrics are subject to a new licensing model, as distinct from the current full-stack host units model.
Metric availability:
  • The Metrics Classic metrics have been discontinued.
  • The new metrics are immediately available with OneAgent deployment.
More information:
  • License Dynatrace
  • Unlock the Power of DevSecOps with Newly Released Kubernetes Experience for Platform Engineering
  • Dynatrace Launches New Kubernetes Experience for Platform Engineering Teams
Which Metrics Classic container metrics are not supported on Grail?
  • builtin:containers.cpu.limit
  • builtin:containers.cpu.throttledMilliCores
  • builtin:containers.cpu.usageMilliCores
  • builtin:containers.cpu.usagePercent
  • builtin:containers.cpu.usageSystemMilliCores
  • builtin:containers.cpu.usageTime
  • builtin:containers.cpu.usageUserMilliCores
  • builtin:containers.memory.limitPercent
  • builtin:containers.memory.outOfMemoryKills
  • builtin:containers.memory.usagePercent
Additionally, the following Classic Extension 1.0 metrics are deprecated and likewise not supported on Grail:
  • builtin:containers.bytes_rx2
  • builtin:containers.bytes_tx2
  • builtin:containers.cpu_usage2
  • builtin:containers.devicemapper_data_space_available
  • builtin:containers.devicemapper_data_space_used
  • builtin:containers.devicemapper_metadata_space_available
  • builtin:containers.devicemapper_metadata_space_used
  • builtin:containers.memory_percent
  • builtin:containers.memory_usage2
  • builtin:containers.no_of_containers_launched
  • builtin:containers.no_of_containers_per_pgi
  • builtin:containers.no_of_containers_running
  • builtin:containers.no_of_containers_terminated
  • builtin:containers.throttled_time2
dt.containers.cpu.logical_cores
builtin:containers.cpu.logicalCores
dt.containers.cpu.shares
builtin:containers.cpu.shares
dt.containers.cpu.throttled_time
builtin:containers.cpu.throttledTime
dt.containers.cpu.throttling_ratio
builtin:containers.cpu.throttlingRatio
dt.containers.cpu.usage_system_time
builtin:containers.cpu.usageSystemTime
dt.containers.cpu.usage_user_time
builtin:containers.cpu.usageUserTime
dt.containers.memory.cache_bytes
builtin:containers.memory.cacheBytes
dt.containers.memory.limit_bytes
builtin:containers.memory.limitBytes
dt.containers.memory.physical_total_bytes
builtin:containers.memory.physicalTotalBytes
dt.containers.memory.resident_set_bytes
builtin:containers.memory.residentSetBytes
Infrastructure
For a detailed list of the host metrics and their availability, refer to Host metrics.
CPU
dt.host.cpu.ent_config
builtin:host.cpu.entConfig
dt.host.cpu.entc
builtin:host.cpu.entc
dt.host.cpu.idle
builtin:host.cpu.idle
dt.host.cpu.iowait
builtin:host.cpu.iowait
dt.host.cpu.load
builtin:host.cpu.load
dt.host.cpu.load15m
builtin:host.cpu.load15m
dt.host.cpu.load5m
builtin:host.cpu.load5m
dt.host.cpu.other
builtin:host.cpu.other
dt.host.cpu.physc
builtin:host.cpu.physc
dt.host.cpu.steal
builtin:host.cpu.steal
dt.host.cpu.system
builtin:host.cpu.system
dt.host.cpu.usage
builtin:host.cpu.usage
dt.host.cpu.user
builtin:host.cpu.user
dt.host.kernel_threads.blocked
builtin:host.kernelThreads.blocked
dt.host.kernel_threads.io_event_wait
builtin:host.kernelThreads.ioEventWait
dt.host.kernel_threads.io_message_wait
builtin:host.kernelThreads.ioMessageWait
dt.host.kernel_threads.running
builtin:host.kernelThreads.running
DNS
Which Metrics Classic DNS metrics are not supported on Grail?
  • builtin:host.dns.singleQueryTime
  • builtin:host.dns.singleQueryTimeByDnsIp
  • builtin:host.dns.singleQueryTimeByHost
dt.host.dns.errors
builtin:host.dns.errorCount
dt.host.dns.queries
builtin:host.dns.queryCount
dt.host.dns.query_time
builtin:host.dns.queryTime
dt.host.dns.orphan_count
builtin:host.dns.orphanCount
Disk
Which Metrics Classic disk metrics are not supported on Grail?
  • builtin:host.disk.throughput.read
  • builtin:host.disk.throughput.write
dt.host.disk.avail
builtin:host.disk.avail
dt.host.disk.bytes_read
builtin:host.disk.bytesRead
dt.host.disk.bytes_written
builtin:host.disk.bytesWritten
dt.host.disk.free
builtin:host.disk.free
dt.host.disk.inodes_avail
builtin:host.disk.inodesAvail
dt.host.disk.inodes_total
builtin:host.disk.inodesTotal
dt.host.disk.queue_length
builtin:host.disk.queueLength
dt.host.disk.read_ops
builtin:host.disk.readOps
dt.host.disk.read_time
builtin:host.disk.readTime
dt.host.disk.used
dt.host.disk.util_time
builtin:host.disk.utilTime
dt.host.disk.write_ops
builtin:host.disk.writeOps
dt.host.disk.write_time
builtin:host.disk.writeTime
Memory
Which Metrics Classic memory metrics are not supported on Grail?
  • builtin:host.mem.total
dt.host.memory.avail.bytes
builtin:host.mem.avail.bytes
dt.host.memory.avail.percent
builtin:host.mem.avail.pct
dt.host.memory.avail.pfps
builtin:host.mem.avail.pfps
dt.host.memory.kernel
builtin:host.mem.kernel
dt.host.memory.recl
builtin:host.mem.recl
dt.host.memory.swap.avail
builtin:host.mem.swap.avail
dt.host.memory.swap.total
builtin:host.mem.swap.total
dt.host.memory.swap.used
builtin:host.mem.swap.used
dt.host.memory.usage
builtin:host.mem.usage
dt.host.memory.used
builtin:host.mem.used
Network
Which Metrics Classic network metrics are not supported on Grail?
Many Classic host-level network metrics can be reproduced using Grail NIC-level network metrics. Learn more in the above section on new and missing metric keys.
The following Classic network metrics are planned but not yet supported on Grail:
  • builtin:host.net.nic.connectivity
  • builtin:host.net.nic.retransmission
  • builtin:host.net.nic.retransmissionIn
  • builtin:host.net.nic.retransmissionOut
  • builtin:host.net.packets.lossRate
The following Classic network metrics are not supported on Grail:
  • builtin:host.net.nic.packets.dropped
  • builtin:host.net.nic.packets.errors
  • builtin:host.net.nic.packets.traffic
  • builtin:host.net.nic.traffic
  • builtin:host.net.nic.trafficIn
  • builtin:host.net.nic.trafficOut
  • builtin:host.net.sessions.connFail
  • builtin:host.net.bytesRx
  • builtin:host.net.bytesTx
  • builtin:host.net.packets.rxBaseReceived
  • builtin:host.net.packets.rxBaseSent
  • builtin:host.net.packets.rxReceived
  • builtin:host.net.packets.rxSent
  • builtin:host.net.sessions.errRst
  • builtin:host.net.sessions.errTmout
  • builtin:host.net.sessions.local.errRst
  • builtin:host.net.sessions.local.errTmout
  • builtin:host.net.sessions.local.new
  • builtin:host.net.sessions.new
dt.host.net.nic.bytes_tx
builtin:host.net.nic.bytesTx
dt.host.net.nic.link_util_rx
builtin:host.net.nic.linkUtilRx
dt.host.net.nic.link_util_tx
builtin:host.net.nic.linkUtilTx
dt.host.net.nic.packets.dropped_rx
builtin:host.net.nic.packets.droppedRx
dt.host.net.nic.packets.dropped_tx
builtin:host.net.nic.packets.droppedTx
dt.host.net.nic.packets.errors_rx
builtin:host.net.nic.packets.errorsRx
dt.host.net.nic.packets.errors_tx
builtin:host.net.nic.packets.errorsTx
dt.host.net.nic.packets.rx
builtin:host.net.nic.packets.rx
dt.host.net.nic.packets.tx
builtin:host.net.nic.packets.tx
Availability
dt.host.availability
builtin:host.availability.state
dt.host.uptime
builtin:host.uptime
dt.osservice.availability
builtin:osservice.availability
Other
What remaining Metrics Classic infrastructure metrics are not supported on Grail?
The following Metrics Classic infrastructure metrics are planned but not yet supported on Grail:
  • builtin:host.osProcessStats.osProcessCount
  • builtin:host.osProcessStats.pgiCount
  • builtin:host.osProcessStats.pgiReportedCount
The following Classic infrastructure metrics are not supported on Grail:
  • builtin:host.availability
  • builtin:host.la.growth
  • builtin:host.la.po
  • builtin:host.la.to
  • builtin:host.osService.availability
  • builtin:host.processVisibility.topProcessesRecognizedCount
  • builtin:host.processVisibility.topProcessesSentCount
  • builtin:host.processVisibility.triggerCount
dt.host.handles.file_descriptors_max
builtin:host.handles.fileDescriptorsMax
dt.host.handles.file_descriptors_used
builtin:host.handles.fileDescriptorsUsed
Kubernetes
New Kubernetes metrics are now available for DPS-enabled customers with the launch of the new Kubernetes app. The new metrics are subject to a new licensing model, as distinct from the current full-stack host units model.
  • The old Kubernetes metrics are not available on Grail.
  • The new Kubernetes metrics are available as soon as you start monitoring your cluster with the new Kubernetes app. For more information on enabling this for your Kubernetes clusters, see Getting started with Kubernetes experience.
  • Some of the new Kubernetes metrics are only available on Grail. They have no equivalent as Classic metrics.
More information:
  • License Dynatrace
  • Kubernetes metric migration guide
dt.kubernetes.container.requests_cpu
builtin:kubernetes.workload.requests_cpu, builtin:kubernetes.node.requests_cpu
dt.kubernetes.container.limits_cpu
builtin:kubernetes.workload.limits_cpu, builtin:kubernetes.node.limits_cpu
dt.kubernetes.container.requests_memory
builtin:kubernetes.workload.requests_memory, builtin:kubernetes.node.requests_memory
dt.kubernetes.container.limits_memory
builtin:kubernetes.workload.limits_memory, builtin:kubernetes.node.limits_memory
dt.kubernetes.container.cpu_usage
builtin:kubernetes.workload.cpu_usage, builtin:kubernetes.node.cpu_usage
dt.kubernetes.container.cpu_throttled
builtin:kubernetes.workload.cpu_throttled, builtin:kubernetes.node.cpu_throttled
dt.kubernetes.container.memory_working_set
builtin:kubernetes.workload.memory_working_set, builtin:kubernetes.node.memory_working_set
dt.kubernetes.nodes
builtin:kubernetes.nodes
dt.kubernetes.workloads
builtin:kubernetes.workloads
dt.kubernetes.pods
builtin:kubernetes.pods, builtin:kubernetes.node.pods
dt.kubernetes.containers
builtin:kubernetes.containers
dt.kubernetes.workload.pods_desired
builtin:kubernetes.workload.pods_desired
dt.kubernetes.pod.containers_desired
builtin:kubernetes.workload.containers_desired
dt.kubernetes.events
builtin:kubernetes.events
dt.kubernetes.node.cpu_allocatable
builtin:kubernetes.node.cpu_allocatable
dt.kubernetes.node.memory_allocatable
builtin:kubernetes.node.memory_allocatable
dt.kubernetes.node.pods_allocatable
builtin:kubernetes.node.pods_allocatable
dt.kubernetes.node.conditions
builtin:kubernetes.node.conditions
dt.kubernetes.workload.conditions
builtin:kubernetes.workload.conditions
dt.kubernetes.cluster.readyz
builtin:kubernetes.cluster.readyz
dt.kubernetes.resourcequota.requests_cpu
builtin:kubernetes.resourcequota.requests_cpu
dt.kubernetes.resourcequota.requests_cpu_used
builtin:kubernetes.resourcequota.requests_cpu_used
dt.kubernetes.resourcequota.limits_cpu
builtin:kubernetes.resourcequota.limits_cpu
dt.kubernetes.resourcequota.limits_cpu_used
builtin:kubernetes.resourcequota.limits_cpu_used
dt.kubernetes.resourcequota.requests_memory
builtin:kubernetes.resourcequota.requests_memory
dt.kubernetes.resourcequota.requests_memory_used
builtin:kubernetes.resourcequota.requests_memory_used
dt.kubernetes.resourcequota.limits_memory
builtin:kubernetes.resourcequota.limits_memory
dt.kubernetes.resourcequota.limits_memory_used
builtin:kubernetes.resourcequota.limits_memory_used
dt.kubernetes.resourcequota.pods
builtin:kubernetes.resourcequota.pods
dt.kubernetes.resourcequota.pods_used
builtin:kubernetes.resourcequota.pods_used
dt.kubernetes.container.oom_kills
builtin:kubernetes.container.oom_kills
dt.kubernetes.container.restarts
builtin:kubernetes.container.restarts
dt.kubernetes.persistentvolumeclaim.available
builtin:kubernetes.persistentvolumeclaim.available
dt.kubernetes.persistentvolumeclaim.capacity
builtin:kubernetes.persistentvolumeclaim.capacity
dt.kubernetes.persistentvolumeclaim.used
builtin:kubernetes.persistentvolumeclaim.used
The following Kubernetes-related metrics are only available on Grail.
Metric key (Grail)
dt.kubernetes.pod.network_received_data
dt.kubernetes.pod.network_received_errors
dt.kubernetes.pod.network_received_packets_dropped
dt.kubernetes.pod.network_transmitted_data
dt.kubernetes.pod.network_transmitted_errors
dt.kubernetes.pod.network_transmitted_packets_dropped
Mainframe
Host (Logical partition)
dt.host.zos.gcp_time
builtin:host.zos.gcpu_time
dt.host.zos.gcp_usage
builtin:host.cpu.gcpu.usage
dt.host.zos.msu_capacity
builtin:host.cpu.msu.capacity
dt.host.zos.msu_hours
builtin:host.zos.msu_hours
dt.process.zos.msu_hours
builtin:tech.zos.msu_hours
dt.host.zos.msu_r4ha
builtin:host.cpu.msu.avg
dt.host.zos.ziip_eligible_time
builtin:host.cpu.ziip.eligible
dt.host.zos.ziip_time
builtin:host.zos.ziip_time
dt.host.zos.ziip_usage
builtin:host.zos.ziip_usage
Note: builtin:host.zos.msu_hours should be used to measure the MSU hours.
Process (Subsystem)
dt.process.zos.gcp_time
builtin:tech.generic.gcpu.time
dt.process.zos.gcp_usage
builtin:tech.generic.gcpu.usage
dt.process.zos.service_units
builtin:tech.zos.consumed_service_units
dt.process.zos.ziip_eligible_time
builtin:tech.generic.ziipEligible
dt.process.zos.ziip_time
JVM
dt.runtime.jvm.classes.loaded
builtin:tech.jvm.classes.loaded
dt.runtime.jvm.classes.total
builtin:tech.jvm.classes.total
dt.runtime.jvm.classes.unloaded
builtin:tech.jvm.classes.unloaded
dt.runtime.jvm.gc.collection_count
builtin:tech.jvm.memory.pool.collectionCount
dt.runtime.jvm.gc.collection_time
builtin:tech.jvm.memory.pool.collectionTime
dt.runtime.jvm.gc.suspension_time
builtin:tech.jvm.memory.gc.suspensionTime
dt.runtime.jvm.gc.total_activation_count
builtin:tech.jvm.memory.gc.activationCount
dt.runtime.jvm.gc.total_collection_time
builtin:tech.jvm.memory.gc.collectionTime
dt.runtime.jvm.memory.free
builtin:tech.jvm.memory.runtime.free
dt.runtime.jvm.memory.max
builtin:tech.jvm.memory.runtime.max
dt.runtime.jvm.memory_pool.committed
builtin:tech.jvm.memory.pool.committed
dt.runtime.jvm.memory_pool.max
builtin:tech.jvm.memory.pool.max
dt.runtime.jvm.memory_pool.used
builtin:tech.jvm.memory.pool.used
dt.runtime.jvm.memory.total
builtin:tech.jvm.memory.runtime.total
dt.runtime.jvm.pgi.cpu_time_suspension
builtin:tech.generic.cpu.groupSuspensionTime
dt.runtime.jvm.threads.count
builtin:tech.jvm.threads.count
WebSphere Application Server
dt.runtime.websphere.connectionpool.concurrent_waiters
builtin:tech.websphere.connectionPool.connectionPoolModule.WaitingThreadCount
dt.runtime.websphere.connectionpool.free_pool_size
builtin:tech.websphere.connectionPool.connectionPoolModule.FreePoolSize
dt.runtime.websphere.connectionpool.in_use_time
builtin:tech.websphere.connectionPool.connectionPoolModule.UseTime
dt.runtime.websphere.connectionpool.percent_used
builtin:tech.websphere.connectionPool.connectionPoolModule.PercentUsed
dt.runtime.websphere.connectionpool.pool_size
builtin:tech.websphere.connectionPool.connectionPoolModule.PoolSize
dt.runtime.websphere.connectionpool.wait_time
builtin:tech.websphere.connectionPool.connectionPoolModule.WaitTime
dt.runtime.websphere.threadpool.active_threads
builtin:tech.websphere.threadPoolModule.ActiveCount
dt.runtime.websphere.threadpool.pool_size
builtin:tech.websphere.threadPoolModule.PoolSize
dt.runtime.websphere.servlet.live_sessions
builtin:tech.websphere.servletSessionsModule.LiveCount
dt.runtime.websphere.servlet.requests
builtin:tech.websphere.webAppModule.RequestCountV2
WebSphere Liberty / z/OS Connect
builtin:tech.liberty.connectionPool.InUseTime
dt.runtime.websphere.connectionpool.liberty.connection_handles
builtin:tech.liberty.connectionPool.ConnectionHandleCount
dt.runtime.websphere.connectionpool.liberty.free_connections
builtin:tech.liberty.connectionPool.FreeConnectionCount
dt.runtime.websphere.connectionpool.liberty.managed_connections
builtin:tech.liberty.connectionPool.ManagedConnectionCount
builtin:tech.liberty.connectionPool.WaitTime
builtin:tech.liberty.ActiveThreads
builtin:tech.liberty.poolsize
builtin:tech.liberty.RequestCount
Real User Monitoring
RUM introduces numerous built-in metrics. Because it uses a different data model than RUM Classic, there are no direct equivalents for RUM Classic metrics. For replacements that serve an analogous purpose, see Upgrade from classic RUM metrics to Grail.
Runtimes
We modified the availability of technology-specific metrics in Grail, which might affect the direct relation between Metrics Classic and Grail metric keys. Select to learn more about the change.
Apache
dt.runtime.apache.connections.socket_waiting_time
builtin:tech.webserver.connections.socketWaitingTime
dt.runtime.apache.requests
builtin:tech.webserver.requests
dt.runtime.apache.threads.active
builtin:tech.webserver.threads.active
dt.runtime.apache.threads.idle
builtin:tech.webserver.threads.idle
dt.runtime.apache.threads.max
builtin:tech.webserver.threads.max
dt.runtime.apache.traffic
builtin:tech.webserver.traffic
Go
Metric key (Grail)Metric key (Classic)
dt.runtime.go.cf.auctioneer_fetch_states_duration
builtin:cloud.cloudfoundry.auctioneer.fetchDuration (filtered by process type Go)
dt.runtime.go.cf.auctioneer_lrp_auctions
builtin:cloud.cloudfoundry.auctioneer.lprFailed (filtered by process type Go)
builtin:cloud.cloudfoundry.auctioneer.lprStarted (filtered by process type Go)
dt.runtime.go.cf.auctioneer_task_auctions_failed
builtin:cloud.cloudfoundry.auctioneer.taskFailed (filtered by process type Go)
dt.runtime.go.gc.collection_count
builtin:tech.go.memory.gcCount
dt.runtime.go.gc.collection_time
dt.runtime.go.gc.suspension_time
dt.runtime.go.http.latency
builtin:tech.go.http.latency
dt.runtime.go.http.requests
builtin:tech.go.http.badGateways
builtin:tech.go.http.responses5xx
builtin:tech.go.http.totalRequests
dt.runtime.go.memory.committed
builtin:tech.go.memory.pool.committed
dt.runtime.go.memory.heap
builtin:tech.go.memory.heap.idle
builtin:tech.go.memory.heap.live
dt.runtime.go.memory.heap.object_count
builtin:tech.go.memory.heap.objCount
dt.runtime.go.memory.used
builtin:tech.go.memory.pool.used
dt.runtime.go.cgo_calls
builtin:tech.go.native.cgoCalls
dt.runtime.go.sys_calls
builtin:tech.go.native.sysCalls
dt.process.go.scheduling.g.avg_num_of_active_routines
builtin:tech.go.scheduling.g.avgNumOfActiveRoutines
dt.process.go.scheduling.g.avg_num_of_inactive_routines
builtin:tech.go.scheduling.g.avgNumOfInactiveRoutines
dt.runtime.go.scheduler.context.idle_count
builtin:tech.go.scheduling.p.idleCount
dt.runtime.go.scheduler.goroutine_count
builtin:tech.go.scheduling.g.runningCount
builtin:tech.go.scheduling.g.systemCount
dt.runtime.go.scheduler.queue_size
builtin:tech.go.scheduling.globalQSize
dt.runtime.go.scheduler.worker_thread_count
builtin:tech.go.scheduling.m.count
builtin:tech.go.scheduling.m.idlingCount
builtin:tech.go.scheduling.m.spinningCount
IIS
dt.runtime.iis.connections.socket_waiting_time
dt.runtime.iis.requests
dt.runtime.iis.threads.active
dt.runtime.iis.threads.idle
dt.runtime.iis.traffic
Java
dt.profiling.jvm.memory.allocation_bytes
builtin:tech.jvm.memory.memAllocationBytes
dt.profiling.jvm.memory.allocation_count
builtin:tech.jvm.memory.memAllocationCount
dt.profiling.jvm.memory.survivor_bytes
builtin:tech.jvm.memory.memSurvivorsBytes
dt.profiling.jvm.memory.survivor_count
builtin:tech.jvm.memory.memSurvivorsCount
dt.profiling.jvm.threads.active
builtin:tech.jvm.threads.avgActiveThreadCount
dt.profiling.jvm.threads.inactive
builtin:tech.jvm.threads.avgInactiveThreadCount
dt.profiling.jvm.threads.cpu_time
builtin:tech.jvm.threads.totalCpuTime
NGINX
dt.runtime.nginx.connections.dropped
builtin:tech.webserver.connections.dropped
dt.runtime.nginx.connections.handled
builtin:tech.webserver.connections.handled
dt.runtime.nginx.connections.reading
builtin:tech.webserver.connections.reading
dt.runtime.nginx.connections.waiting
builtin:tech.webserver.connections.waiting
dt.runtime.nginx.connections.writing
builtin:tech.webserver.connections.writing
dt.runtime.nginx.plus.cache.hits
builtin:tech.nginx.cache.hits
dt.runtime.nginx.plus.cache.max_space
builtin:tech.nginx.cache.freeSpace
dt.runtime.nginx.plus.cache.misses
builtin:tech.nginx.cache.misses
dt.runtime.nginx.plus.cache.used_space
builtin:tech.nginx.cache.usedSpace
dt.runtime.nginx.plus.server_zones.requests
builtin:tech.nginx.serverZones.requests
dt.runtime.nginx.plus.server_zones.traffic_in
builtin:tech.nginx.serverZones.trafficIn
dt.runtime.nginx.plus.server_zones.traffic_out
builtin:tech.nginx.serverZones.trafficOut
dt.runtime.nginx.plus.upstream.healthy
builtin:tech.nginx.upstream.healthy
dt.runtime.nginx.plus.upstream.requests
builtin:tech.nginx.upstream.requests
dt.runtime.nginx.plus.upstream.traffic_in
builtin:tech.nginx.upstream.trafficIn
dt.runtime.nginx.plus.upstream.traffic_out
builtin:tech.nginx.upstream.trafficOut
dt.runtime.nginx.plus.upstream.unhealthy
builtin:tech.nginx.upstream.unhealthy
dt.runtime.nginx.requests
dt.runtime.nginx.traffic
.NET
dt.runtime.clr.gc.collection_count
builtin:tech.dotnet.gc.gen0Collections
builtin:tech.dotnet.gc.gen1Collections
builtin:tech.dotnet.gc.gen2Collections
dt.runtime.clr.gc.collection_time
dt.runtime.clr.gc.suspension_time
dt.runtime.clr.gc.time_percentage
builtin:tech.dotnet.gc.timePercentage
dt.runtime.clr.jit.time_percentage
builtin:tech.dotnet.jit.timePercentage
dt.profiling.clr.threads.count
builtin:tech.dotnet.managedThreads.avgNumOfActiveThreads
dt.runtime.clr.memory.consumption
builtin:tech.dotnet.memory.gen0Consumption
builtin:tech.dotnet.memory.gen1Consumption
builtin:tech.dotnet.memory.gen2Consumption
builtin:tech.dotnet.memory.LOHConsumption
dt.runtime.clr.threadpool.queued_work_items
builtin:tech.dotnet.threadpool.queuedWorkItems
dt.runtime.clr.threadpool.threads
builtin:tech.dotnet.threadpool.ioCompletionThreads
builtin:tech.dotnet.threadpool.workerThreads
Node.js
dt.process.nodejs.avg_number_of_active_threads
builtin:tech.nodejs.avgNumberOfActiveThreads
dt.runtime.nodejs.eventloop.active_handles
builtin:tech.nodejs.uvLoop.activeHandles
dt.runtime.nodejs.eventloop.utilization
builtin:tech.nodejs.uvLoop.utilization
dt.runtime.nodejs.gc.collection_time
dt.runtime.nodejs.gc.suspension_time
dt.runtime.nodejs.memory.used
builtin:tech.nodejs.v8heap.used
dt.runtime.nodejs.memory.total
builtin:tech.nodejs.v8heap.total
PHP
dt.runtime.php.gc.collected_count
builtin:tech.php.phpGc.collectedCount
dt.runtime.php.gc.duration_ms
builtin:tech.php.phpGc.durationMs
dt.runtime.php.gc.effectiveness
builtin:tech.php.phpGc.effectiveness
dt.runtime.php.jit.buffer_free
builtin:tech.php.phpOpcache.jit.bufferFree
dt.runtime.php.jit.buffer_size
builtin:tech.php.phpOpcache.jit.bufferSize
dt.runtime.php.opcache.blocklist_misses
builtin:tech.php.phpOpcache.statistics.blocklistMisses
dt.runtime.php.opcache.cached_keys
builtin:tech.php.phpOpcache.statistics.cachedKeys
dt.runtime.php.opcache.cached_scripts
builtin:tech.php.phpOpcache.statistics.cachedScripts
dt.runtime.php.opcache.hits
builtin:tech.php.phpOpcache.statistics.hits
dt.runtime.php.opcache.max_cached_keys
builtin:tech.php.phpOpcache.statistics.maxCachedCachedKeys
dt.runtime.php.opcache.memory.free
builtin:tech.php.phpOpcache.memory.free
dt.runtime.php.opcache.memory.used
builtin:tech.php.phpOpcache.memory.used
dt.runtime.php.opcache.memory.wasted
builtin:tech.php.phpOpcache.memory.wasted
dt.runtime.php.opcache.misses
builtin:tech.php.phpOpcache.statistics.misses
dt.runtime.php.opcache.number_of_strings
builtin:tech.php.phpOpcache.strings.numberOfStrings
dt.runtime.php.opcache.restarts_hash
builtin:tech.php.phpOpcache.restarts.hash
dt.runtime.php.opcache.restarts_manual
builtin:tech.php.phpOpcache.restarts.manual
dt.runtime.php.opcache.restarts_out_of_memory
builtin:tech.php.phpOpcache.restarts.outOfMemory
dt.runtime.php.opcache.strings_buffer_size
builtin:tech.php.phpOpcache.strings.bufferSize
dt.runtime.php.opcache.strings_used_memory
builtin:tech.php.phpOpcache.strings.usedMemory
dt.process.php.threads.avg_num_of_active_threads
builtin:tech.php.threads.avgNumOfActiveThreads
dt.process.php.threads.avg_num_of_inactive_threads
builtin:tech.php.threads.avgNumOfInactiveThreads
Processes
Process metrics replace Metrics Classic generic technology metrics with the prefix builtin:tech.generic.
Which Metrics Classic generic technology metrics are not supported on Grail?
The following Metrics Classic generic technology metrics are planned but not yet supported on Grail:
  • builtin:tech.generic.network.packets.retransmission
  • builtin:tech.generic.network.packets.retransmissionIn
  • builtin:tech.generic.network.packets.retransmissionOut
  • builtin:tech.generic.network.sessions.connectivity
The following Metrics Classic generic technology metrics are not supported on Grail:
  • builtin:tech.generic.network.traffic.traffic
  • builtin:tech.generic.network.traffic.trafficIn
  • builtin:tech.generic.network.traffic.trafficOut
  • builtin:process.bytesReceived
  • builtin:process.bytesSent
  • builtin:process.cpu
  • builtin:process.memory
  • builtin:tech.customDevice.count
dt.process.availability
builtin:pgi.availability.state
dt.process.cpu.usage
builtin:tech.generic.cpu.usage
dt.process.handles.file_descriptors_max
builtin:tech.generic.handles.fileDescriptorsMax
dt.process.handles.file_descriptors_percent_used
builtin:tech.generic.handles.fileDescriptorsPercentUsed
dt.process.handles.file_descriptors_used
builtin:tech.generic.handles.fileDescriptorsUsed
dt.process.io.bytes_read
builtin:tech.generic.io.bytesRead
dt.process.io.bytes_written
builtin:tech.generic.io.bytesWritten
dt.process.io.bytes_total
builtin:tech.generic.io.bytesTotal
dt.process.io.req_bytes_read
builtin:tech.generic.io.reqBytesRead
dt.process.io.req_bytes_write
builtin:tech.generic.io.reqBytesWrite
dt.process.memory.exhausted_memory
builtin:tech.generic.mem.exhaustedMem
dt.process.memory.page_faults
builtin:tech.generic.mem.pageFaults
dt.process.memory.usage
builtin:tech.generic.mem.usage
dt.process.memory.working_set_size
builtin:tech.generic.mem.workingSetSize
dt.process.network.bytes_rx
builtin:tech.generic.network.bytesRx
dt.process.network.bytes_tx
builtin:tech.generic.network.bytesTx
dt.process.network.latency
builtin:tech.generic.network.latency
dt.process.network.load
builtin:tech.generic.network.load
dt.process.network.packets.base_re_rx
builtin:tech.generic.network.packets.baseReRx
dt.process.network.packets.base_re_rx_aggr
builtin:tech.generic.network.packets.baseReRxAggr
dt.process.network.packets.base_re_tx
builtin:tech.generic.network.packets.baseReTx
dt.process.network.packets.base_re_tx_aggr
builtin:tech.generic.network.packets.baseReTxAggr
dt.process.network.packets.re_rx
builtin:tech.generic.network.packets.reRx
dt.process.network.packets.re_rx_aggr
builtin:tech.generic.network.packets.reRxAggr
dt.process.network.packets.re_tx
builtin:tech.generic.network.packets.reTx
dt.process.network.packets.re_tx_aggr
builtin:tech.generic.network.packets.reTxAggr
dt.process.network.packets.rx
builtin:tech.generic.network.packets.rx
dt.process.network.packets.tx
builtin:tech.generic.network.packets.tx
dt.process.network.round_trip
builtin:tech.generic.network.roundTrip
dt.process.network.sessions.new
builtin:tech.generic.network.sessions.new
dt.process.network.sessions.new_aggr
builtin:tech.generic.network.sessions.newAggr
dt.process.network.sessions.new_local
builtin:tech.generic.network.sessions.newLocal
dt.process.network.sessions.reset
builtin:tech.generic.network.sessions.reset
dt.process.network.sessions.reset_aggr
builtin:tech.generic.network.sessions.resetAggr
dt.process.network.sessions.reset_local
builtin:tech.generic.network.sessions.resetLocal
dt.process.network.sessions.timeout
builtin:tech.generic.network.sessions.timeout
dt.process.network.sessions.timeout_aggr
builtin:tech.generic.network.sessions.timeoutAggr
dt.process.network.sessions.timeout_local
builtin:tech.generic.network.sessions.timeoutLocal
dt.process.network.throughput
builtin:tech.generic.network.throughput
dt.process.threads_exhausted
builtin:tech.generic.threadsExhausted
dt.process.process_count
builtin:tech.generic.processCount
Nettracer
Which Metrics Classic nettracer metrics are not supported on Grail?
The following Metrics Classic nettracer metrics are planned but not yet supported on Grail:
  • builtin:tech.nettracer.retr_percentage
The following Metrics Classic nettracer metrics are not supported on Grail:
  • builtin:tech.nettracer.traffic
  • builtin:tech.nettracer.traffic_rx
  • builtin:tech.nettracer.traffic_tx
dt.process.nettracer.bytes_rx
builtin:tech.nettracer.bytes_rx
dt.process.nettracer.bytes_tx
builtin:tech.nettracer.bytes_tx
dt.process.nettracer.pkts_retr
builtin:tech.nettracer.pkts_retr
dt.process.nettracer.pkts_rx
builtin:tech.nettracer.pkts_rx
dt.process.nettracer.pkts_tx
builtin:tech.nettracer.pkts_tx
dt.process.nettracer.rtt
builtin:tech.nettracer.rtt
Security
Security metrics have been replaced with security events. Consequently, security metrics are not supported on Grail. This affects all metrics with the prefix builtin:security.
Services
Service metrics on Grail cover three areas: endpoint request metrics, message processing metrics, and service mesh metrics. These are the built-in metrics produced automatically by Dynatrace for your services—no configuration required.
For common splits such as namespace, cluster, or cloud region, use the out-of-the-box primary Grail fields available as dimensions on these metrics. You don't need calculated service metrics for these use cases.
We modified the availability of service metrics in Grail, which might affect the direct relation between Metrics Classic and Grail metric keys. Select to learn more about the change.
Endpoint metrics
Per-endpoint request metrics for throughput, failure count, and response time. These metrics are produced automatically for every detected endpoint on SDv1 services (with Enhanced endpoints activated) and SDv2 services. A single query works across both detection versions.
For details on how to use these metrics in dashboards, SLOs, and alerting, see Enable endpoint metrics in Service Detection v1. For migration guidance from Classic service metrics, see Upgrade from Classic service metrics to Grail.
Metric key (Grail)DescriptionMetric key (Classic)
dt.service.request.count
The number of requests to the endpoint.
Classic metric keys
builtin:service.errors.client.successCount
builtin:service.errors.fivexx.count
builtin:service.errors.fivexx.rate
builtin:service.errors.fivexx.successCount
builtin:service.errors.fourxx.count
builtin:service.errors.fourxx.rate
builtin:service.errors.fourxx.successCount
builtin:service.errors.server.count
builtin:service.errors.server.rate
builtin:service.errors.server.successCount
builtin:service.errors.total.rate
builtin:service.errors.total.successCount
builtin:service.keyRequest.count.client
builtin:service.keyRequest.count.server
builtin:service.keyRequest.count.total
builtin:service.keyRequest.errors.client.successCount
builtin:service.keyRequest.errors.fivexx.count
builtin:service.keyRequest.errors.fivexx.rate
builtin:service.keyRequest.errors.fivexx.successCount
builtin:service.keyRequest.errors.fourxx.count
builtin:service.keyRequest.errors.fourxx.rate
builtin:service.keyRequest.errors.fourxx.successCount
builtin:service.keyRequest.errors.server.count
builtin:service.keyRequest.errors.server.rate
builtin:service.keyRequest.errors.server.successCount
builtin:service.keyRequest.successes.server.rate
builtin:service.request.count
builtin:service.request.count_chart
builtin:service.request.count_service_aggregation
builtin:service.requestCount.client
builtin:service.requestCount.server
builtin:service.requestCount.total
builtin:service.successes.server.rate
dt.service.request.failure_count
The number of failed requests to the endpoint.
Classic metric keys
builtin:service.errors.client.count
builtin:service.errors.client.rate
builtin:service.errors.total.count
builtin:service.keyRequest.errors.client.count
builtin:service.keyRequest.errors.client.rate
builtin:service.request.failure_count
builtin:service.request.failure_count_chart
builtin:service.request.failure_count_service_aggregation
dt.service.request.response_time
The response time of requests to the endpoint.
Classic metric keys
builtin:service.keyRequest.response.client
builtin:service.keyRequest.response.server
builtin:service.keyRequest.response.time
builtin:service.request.response_time
builtin:service.request.response_time_chart
builtin:service.request.response_time_service_aggregation
builtin:service.response.client
builtin:service.response.server
builtin:service.response.time
dt.service.request.failure_count includes zero-count data points for successful requests. These entries exist by design to support distinguishing three states: failures occurred, no failures occurred, and no requests at all. Normal timeseries queries don't return zero-count entries.
Dimensions
The following dimensions are available on dt.service.request.* endpoint metrics. Use them to filter and split metrics by endpoint, HTTP status, failure state, or infrastructure context.
DimensionDescriptionExample values
endpoint.name
The name of the endpoint
GET /api/orders/{id}
dt.entity.service
The service identifier
SERVICE-1234567890ABCDEF
service.name
The service name
order-service
dt.service.name
The Dynatrace service name
order-service
http.request.method
The HTTP request method.
GET, POST, PUT
http.response.status_code
The HTTP response status code
200, 404, 500
failed
Whether the request failed. Not applicable to dt.service.request.failure_count—every request counted by that metric is a failure by definition.
true, false
Primary Grail fields are available as dimensions for filtering by infrastructure context without topology joins:
k8s.cluster.name
The Kubernetes cluster name
prod-cluster
k8s.namespace.name
The Kubernetes namespace
payment-services
aws.account.id
The AWS account identifier
123456789012
aws.region
The AWS region
us-east-1
azure.location
The Azure region
eastus
azure.resource.group
The Azure resource group
demo-backend-rg
azure.subscription
The Azure subscription
27e9b03f-...
gcp.project.id
The GCP project identifier
dynatrace-gcp-extension
gcp.region
The GCP region
us-central1
dt.host_group.id
The host group identifier
myHostGroup
Primary Grail tags (primary_tags.*) are also available as dimensions, providing your customer-defined organizational taxonomy on service metrics.
Message processing metrics
Messaging metrics track queue and topic interactions. These metrics are Grail-only—there are no Classic equivalents. For details on using these metrics in Services Services, see Messaging.
dt.service.messaging.publish.count
The number of messages sent to queues or topics.
dt.service.messaging.receive.count
The number of messages received from queues or topics.
dt.service.messaging.process.count
The number of messages successfully processed.
dt.service.messaging.process.duration
The time spent processing messages.
dt.service.messaging.process.failure_count
The number of messages that failed processing.
Dimensions
The following dimensions are available on dt.service.messaging.* metrics. Use them to filter and split metrics by destination, messaging system, or infrastructure context.
messaging.destination.name
The name of the queue or topic
authorQueue, orderEvents
dt.entity.service
service.name
The service name
order-service
dt.service.name
order-service
messaging.system
The messaging platform
kafka, rabbitmq, aws_sqs
k8s.cluster.name
prod-cluster
k8s.namespace.name
payment-services
aws.account.id
123456789012
aws.region
The AWS region
us-east-1
azure.location
The Azure region
eastus
demo-backend-rg
azure.subscription
27e9b03f-...
gcp.project.id
gcp.region
The GCP region
us-central1
dt.host_group.id
myHostGroup
Primary Grail tags (primary_tags.*) are also available as dimensions, providing your customer-defined organizational taxonomy on messaging metrics.
Service mesh metrics
dt.service.request.service_mesh.count
builtin:service.request.service_mesh.count
builtin:service.request.service_mesh.count_service_aggregation
dt.service.request.service_mesh.failure_count
builtin:service.request.service_mesh.failure_count
builtin:service.request.service_mesh.failure_count_service_aggregation
dt.service.request.service_mesh.response_time
builtin:service.request.service_mesh.response_time
builtin:service.request.service_mesh.response_time_service_aggregation
Calculated service metrics
Calculated service metrics are being deprecated
Calculated service metrics will be deprecated in a future release. No deprecation date is set yet. For new use cases, use the built-in endpoint metrics above or create metrics via metric extraction from span data in OpenPipeline. Existing calculated service metrics continue to work. For details, see Calculated metrics for Services.
service.<my_calculated_service_metric>
calc:service:<my_calculated_service_metric>
Dimensions in Grail
With the upgrade of calculated service metrics to Grail, the existing dimension is mantained and any placeholders used in the dimension value are separated into additional distinct metric dimensions, that allow you to do querying in a simplified and more powerful way. The following sections list the availability of dimensions once you enable a calculated service metric in Grail.
New dimensions
The following dimensions are added to calculated service metrics in Grail. They apply only to full requests, unless specified differently.
  • aws.tags.*
  • azure.tags.*
  • dt.cost.costcenter 1
  • dt.cost.product 1
  • dt.entity.kubernetes_cluster
  • dt.entity.process_group 1
  • dt.host_group.id
  • dt.security_context 1
  • dt.service.name 1
  • failed (true or false) 1
  • gcp.tags.*
  • k8s.cluster.name
  • k8s.cluster.uid
  • k8s.namespace.annotation.*
  • k8s.namespace.label.*
  • k8s.namespace.name
  • k8s.pod.annotation.*
  • k8s.pod.label.*
  • k8s.workload.name
  • k8s.workload.annotation.*
  • k8s.workload.kind
  • k8s.workload.label.*
  • primary_tags.*
  • service.name
1
Applicable to both full and external requests. To learn more about requests types, see Glossary - request.
Dimensions automatically converted from Classic metric placeholders
In Grail, placeholders used in the Dimension value pattern are mapped to distinct dimension keys, allowing more flexibility and powerful querying. The following Grail dimension keys are automatically created from the placeholders contained in your Classic dimension, according to Global field reference.
Metric dimension (Grail): Metric placeholder (Classic)
  • cics.transaction.system_id: CICS:SystemId
  • cics.transaction.task_id: CICS:TaskId (INTEGER)
  • cics.transaction.user_id: CICS:UserId
  • code.function: RMI:Method
  • code.namespace: RMI:Class
  • ctg.request.gateway_url: CTG:GatewayURL
  • ctg.request.server_id: CTG:ServerName
  • custom_service.method: CustomService:Method
  • custom_service.name: CustomService:Class
  • db.connection_string: Database:URL
  • db.namespace: Database:Name
  • db.query.text: Database-Statement
  • db.system: Database:Type
  • deployment.release_build_version: Request:ApplicationBuildVersion
  • deployment.release_product: Request:ApplicationProduct
  • deployment.release_stage: Request:ApplicationStage
  • deployment.release_version: Request:ApplicationReleaseVersion
  • endpoint.name: Request:Name
  • exception.message: Exception:Message
  • exception.type: Exception:Class
  • http.request.method: HTTP-Method
  • http.response.status_code: HTTP-Status
  • http.server_name: Service:WebServerName
  • ibm.cics.program: CICS:ProgramName
  • messaging.akka.actor.path: AKKA:ActorPath
  • messaging.akka.actor.system: AKKA:ActorSystem
  • messaging.akka.actor.type: AKKA:ActorClassName
  • messaging.akka.message.type: AKKA:ActorMessageType
  • messaging.source.kind: Messaging:DestinationType
  • messaging.source.name: Messaging:QueueName
  • messaging.source.temporary: Messaging:IsTemporary
  • messaging.system: Messaging:QueueVendor
  • request_attribute.attribute_name: RequestAttribute:, BEGINS_WITH
  • rpc.method: Remote:Method
  • rpc.namespace: Service:WebServiceNamespace
  • rpc.service: Service:WebServiceName
  • server.address: Database:Host
  • servlet.context.name: Service:WebApplicationId
  • servlet.context.path: Service:WebContextRoot
  • url.domain: URL:Host
  • url.full: URL
  • url.path: URL:Path
  • url.port: URL:Port
  • url.query: URL:Query
  • zos.transaction.id: CICS:TransactionId
  • zos.transaction.id: CTG:TransactionId
  • zos.transaction.id: IMS:TransactionId
Unsupported placeholders
The following placeholders are not mapped to distinct Grail metric dimension keys because they either do not align with the Dynatrace Semantic Dictionary used in Grail or represent concepts that are no longer relevant within the context of Grail metrics. Placeholder values remain accessible through the dimension created when the calculated service metric was initially defined. If needed, you can use string operations to extract and work with the specific placeholder values.
  • AzureFunctions:FunctionName
  • AzureFunctions:SiteName
  • ESB:ApplicationName
  • ESB:LibraryName
  • ESB:MessageFlowName
  • HTTP-StatusClass
    Go to the settings and modify the metric definition to use HTTP-Status instead. These placeholders are then automatically converted.
  • IMS:ProgramName
  • IMS:UserId
  • Remote:Endpoint
  • Request:Failure
  • Request:IsKeyRequest
  • Request:Type
  • Relative-URL
    Go to the settings and modify the metric definition to use URL:Path and URL:Query instead. These placeholders are then automatically converted.
  • Service:Istance
  • Service:Name
    In Notebooks, use entityName(dt.entity.service) to obtain comparable results.
  • Service:Port
  • Service:PublicDomainName
  • WebService:Endpoint
  • WebService:Method
    Go to the settings and modify the metric definition to use Request:Name instead. This placeholder is then automatically converted.
Synthetic Monitoring
HTTP monitor metrics
dt.synthetic.http.response_size
builtin:synthetic.http.responseSize.geo
dt.synthetic.http.duration
builtin:synthetic.http.duration.geo
dt.synthetic.http.dns
builtin:synthetic.http.dns.geo
dt.synthetic.http.tcp_connect_time
builtin:synthetic.http.tcpConnectTime.geo
dt.synthetic.http.tls_handshake_time
builtin:synthetic.http.tlsHandshakeTime.geo
dt.synthetic.http.time_to_first_byte
builtin:synthetic.http.timeToFirstByte.geo
dt.synthetic.http.redirects_count
builtin:synthetic.http.redirectsCount.geo
dt.synthetic.http.redirects_time
builtin:synthetic.http.redirectsTime.geo
dt.synthetic.http.executions
builtin:synthetic.http.execution.status
dt.synthetic.http.duration_threshold
builtin:synthetic.http.durationThreshold
dt.synthetic.http.request.duration
builtin:synthetic.http.request.duration.geo
dt.synthetic.http.request.response_size
builtin:synthetic.http.request.responseSize.geo
dt.synthetic.http.request.tcp_connect_time
builtin:synthetic.http.request.tcpConnectTime.geo
dt.synthetic.http.request.tls_handshake_time
builtin:synthetic.http.request.tlsHandshakeTime.geo
dt.synthetic.http.request.time_to_first_byte
builtin:synthetic.http.request.timeToFirstByte.geo
dt.synthetic.http.request.dns
builtin:synthetic.http.request.dns.geo
dt.synthetic.http.request.redirects_count
builtin:synthetic.http.request.redirectsCount.geo
dt.synthetic.http.request.redirects_time
builtin:synthetic.http.request.redirectsTime.geo
dt.synthetic.http.request.duration_threshold
builtin:synthetic.http.request.durationThreshold
dt.synthetic.http.request.executions
N/A
dt.synthetic.http.availability
N/A
dt.synthetic.http.waiting_time
N/A
dt.synthetic.http.request.waiting_time
N/A
Browser monitor metrics
dt.synthetic.browser.executions
N/A
dt.synthetic.browser.event.executions
N/A
dt.synthetic.browser.availability
N/A
dt.synthetic.browser.event.duration
N/A
dt.synthetic.browser.duration
N/A
Third party metrics
dt.synthetic.third_party.response_time
builtin:synthetic.external.responseTime.geo
dt.synthetic.third_party.quality
builtin:synthetic.external.quality.geo
dt.synthetic.third_party.step.response_time
builtin:synthetic.external.step.responseTime.geo
dt.synthetic.third_party.executions
N/A
dt.synthetic.third_party.step.executions
N/A
dt.synthetic.third_party.availability
N/A
Network availability monitors metrics
Common monitor metrics
dt.synthetic.multi_protocol.execution_time
builtin:synthetic.multiProtocol.executionTime
dt.synthetic.multi_protocol.success_rate
builtin:synthetic.multiProtocol.successRate
dt.synthetic.multi_protocol.availability
builtin:synthetic.multiProtocol.availability
dt.synthetic.multi_protocol.executions
builtin:synthetic.multiProtocol.executions
Common step metrics
dt.synthetic.multi_protocol.step.execution_time
builtin:synthetic.multiProtocol.step.executionTime
dt.synthetic.multi_protocol.step.success_rate
builtin:synthetic.multiProtocol.step.successRate
dt.synthetic.multi_protocol.step.availability
builtin:synthetic.multiProtocol.step.availability
dt.synthetic.multi_protocol.step.executions
builtin:synthetic.multiProtocol.step.executions
Common request metrics
dt.synthetic.multi_protocol.request.availability
builtin:synthetic.multiProtocol.request.availability
dt.synthetic.multi_protocol.request.executions
builtin:synthetic.multiProtocol.request.executions
ICMP metrics
dt.synthetic.multi_protocol.icmp.success_rate
builtin:synthetic.multiProtocol.icmp.successRate
dt.synthetic.multi_protocol.icmp.packets_sent
builtin:synthetic.multiProtocol.icmp.packetsSent
dt.synthetic.multi_protocol.icmp.packets_received
builtin:synthetic.multiProtocol.icmp.packetsReceived
dt.synthetic.multi_protocol.icmp.round_trip_time
builtin:synthetic.multiProtocol.icmp.roundTripTime
dt.synthetic.multi_protocol.icmp.request_execution_time
builtin:synthetic.multiProtocol.icmp.requestExecutionTime
TCP metrics
dt.synthetic.multi_protocol.tcp.connection_time
builtin:synthetic.multiProtocol.tcp.connectionTime
DNS metrics
dt.synthetic.multi_protocol.dns.resolution_time
builtin:synthetic.multiProtocol.dns.resolutionTime
Unsupported metrics
The following categories of Metrics Classic metrics are not supported on Grail:
  • A2TM metrics, including all metrics with the prefix builtin:a2tm.
  • Lima metrics, including all metrics with the prefix builtin:lima.
  • Classic Logs metrics, including all metrics with the prefix builtin:log.
  • NAM metrics, including all metrics with the prefix builtin:nam.
  • Span metrics, including all metrics with the prefix builtin:span.
  • RUM Classic metrics, including all metrics with the prefix builtin:apps. For details, see Real User Monitoring.
Related tags
Dynatrace Platform
