Visualizations and tiles
The dashboards discussed in this documentation are classic dashboards created using the dashboarding functionality integrated with previous Dynatrace.
- For more about classic dashboards, see Dashboards Classic.
- For more about dashboards created with the Dashboards app in the latest Dynatrace, see Dashboards.
Dynatrace offers a number of specialized tiles that you can add to your dashboards, as well as various data visualizations you can configure in the Data explorer and then pin to your dashboards as tiles.
Visualizations
You can create data visualizations in the Data explorer and then pin them to your dashboards as tiles. If you're new to creating visualizations, see Data explorer quick start for a quick walkthrough.
Tiles
- For descriptions of tiles that are ready to drag to your dashboard and use with minimal configuration, see Available tiles.
- For instructions on pinning tiles to your dashboard, see Pin tiles to your dashboard.
- For instructions on creating filtered tiles, Filter tiles.
