Create AWS connection via Settings app
  • Latest Dynatrace
  • How-to guide
Onboard your AWS account in few steps that will generate a deployable CloudFormation template.
The CloudFormation stack will deploy core mandatory resources inside your AWS account (Dynatrace IAM monitoring role, AWS secrets, Dynatrace API integration Lambda function).
After a successful deployment, a connection from Dynatrace to your AWS account will be created. Dynatrace will then perform API calls to your AWS account to poll and push telemetry into your Dynatrace environment.
Overview
A single Dynatrace environment allows up to 500 connections. If you need to exceed this, please contact Dynatrace support for more information.
General recommendations
If you're planning to onboard AWS account(s) which are actively monitored by AWS classic monitoring (via an active classic connection), we recommend reviewing our upgrade guide, with focus on the best practices.
Limitations
  • GovCloud and China partitions are not supported.
  • AWS does not support EventBridge API destinations in all Regions. Therefore, event ingest is not available in Regions that don't support it. See EventBridge feature availability for details.
Prerequisites
Only a Dynatrace account administrator and an AWS administrator can successfully complete the initial prerequisites.
1. AWS
Actions in this section can and (should) only be performed by an AWS administrator. All necessary AWS permissions must be granted to successfully deploy the CloudFormation stacks and associated AWS resources.
In environments where full duty separation is practiced, we recommend that the Dynatrace administrator share the templates with the platform team/AWS administrators.
Core CFN stacks
  • Main deployment stack
    • Nested API client stack
    • Nested integration stack
    • Nested Monitoring IAM role stack
Conditional (nested) CFN stacks
Deployed based on user opt-in during onboarding
  • Nested StackSet roles
  • Nested Firehose Log streams stack
  • Nested AWS EventBridge integration stack
AWS resources created by the CloudFormation templates
Level 1: Main template resources (da-aws-activation.yaml)
Direct resources created in deployment region:
  1. DynatraceApiClientStack (AWS::CloudFormation::Stack)
    • Nested stack that creates API client function (Dynatrace API interaction, create/delete connection)
    • Reference: da-aws-nested-dt-api-function.yaml
  2. ReportStartedStatusResource (Custom::DynatraceApiAccessFunction)
    • Custom resource to report deployment start status to Dynatrace
  3. DynatraceIntegrationStack (AWS::CloudFormation::Stack)
    • Nested stack for core integration
    • Reference: da-aws-nested-integration.yaml
  4. DynatraceStackSetRoleStack (AWS::CloudFormation::Stack)
    • Conditional: Only created if log or event ingest is enabled
    • Creates StackSet administration and execution roles
    • Reference: da-aws-nested-stackset-role.yaml
  5. DynatraceLogIngestStackSet (AWS::CloudFormation::StackSet)
    • Conditional: Only if pDtLogsIngestEnabled = 'TRUE'
    • Deploys log ingestion infrastructure to specified regions
    • Reference: da-aws-stack-logs.yaml
  6. DynatraceEventIngestStackSet (AWS::CloudFormation::StackSet)
    • Conditional: Only if pDtEventsIngestEnabled = 'TRUE'
    • Deploys event ingestion infrastructure to specified regions
    • Reference: da-aws-stack-events.yaml
  7. ReportCompleteStatusResource (Custom::DynatraceApiAccessFunction)
    • Custom resource to report deployment completion status to Dynatrace
Level 2: Nested stack resources
From DynatraceApiClientStack (da-aws-nested-dt-api-function.yaml)—expected resources:
  • Lambda Function: Dynatrace API client function
  • IAM Role: Lambda execution role
  • Secrets Manager Secret: Storage for Dynatrace API token
  • KMS Key (Conditional): Customer Managed Key if pUseCMK = 'TRUE'
  • KMS Alias (Conditional): Alias for the CMK
  • Lambda Log Group: CloudWatch Logs for the Lambda function
From DynatraceIntegrationStack (da-aws-nested-integration.yaml)—expected resources:
  • IAM Role: Dynatrace monitoring role with trust relationship to Dynatrace account
  • IAM Policy: Monitoring permissions policy
  • Custom Resource: To establish connection with Dynatrace
From DynatraceStackSetRoleStack (da-aws-nested-stackset-role.yaml)—expected resources:
  • IAM Role: StackSet administration role
  • IAM Role: StackSet execution role
  • IAM Policies: Attached to both roles
Level 3: Deployed core resources (management region)
Minimum resources (no log/event ingest enabled), deployed only on a single region (management region):
  • Two custom resources: Report deployment start and finish status
  • Lambda function + IAM roles + Secrets Manager: Created/delete connection, store dynatrace platform tokens in Secret Manager
  • Dynatrace monitoring IAM role: Dynatrace monitoring role with trust relationship to Dynatrace account
Level 4: StackSet-deployed resources (conditional per region)
From DynatraceLogIngestStackSet (da-aws-stack-logs.yaml); deployed to each region in pDtLogsIngestRegions list. Expected resources per region:
  • Kinesis Data Firehose Delivery Stream: For log forwarding to Dynatrace
  • IAM Role: Firehose delivery role
  • S3 Bucket: Backup/buffer bucket for failed deliveries
  • Secrets Manager Secret: Dynatrace ingest token storage
  • KMS Key (conditional): If pUseCMK = 'TRUE'
From DynatraceEventIngestStackSet (da-aws-stack-events.yaml); deployed to each region in pDtEventsIngestRegions list. Expected resources per region:
  • EventBridge Rule: To capture AWS events
  • EventBridge API Destination: Dynatrace endpoint
  • EventBridge Connection: Authentication for API destination
  • IAM Role: EventBridge execution role
AWS IAM permission policy for deploying the CloudFormation stacks
Make sure that an AWS user, or a role, used for the CloudFormation stacks deployment is granted with the following (minimum) permission policies.
To allow the least privilege—restricting users creating the AWS connections that follow a specific naming pattern, use the value for <Deployment-Stack-Name-Prefix>. This ensures that any connection created must adhere to this exact naming convention.
"Version": "2012-10-17",
"Statement": [
"Sid": "cloudformation0",
"Effect": "Allow",
"Action": [
"cloudformation:CreateStack",
"cloudformation:DescribeStacks",
"cloudformation:UpdateStack",
"cloudformation:ListStacks",
"cloudformation:DescribeStackResources",
"cloudformation:DeleteStack",
"cloudformation:CreateChangeSet",
"cloudformation:DescribeChangeSet",
"cloudformation:ExecuteChangeSet",
"cloudformation:CreateStackInstances",
"cloudformation:ListStackInstances",
"cloudformation:DescribeStackInstance",
"cloudformation:DeleteStackInstances",
"cloudformation:CreateStackSet",
"cloudformation:UpdateStackSet",
"cloudformation:DescribeStackSet",
"cloudformation:DescribeStackSetOperation",
"cloudformation:ListStackSetOperationResults",
"cloudformation:DeleteStackSet",
"cloudformation:TagResource",
"cloudformation:UntagResource"
"Resource": [
"arn:aws:cloudformation:*:<AWS-Account-ID>:stackset-target/*",
"arn:aws:cloudformation:<Deployment-Region>:<AWS-Account-ID>:stackset/Dynatrace*:*",
"arn:aws:cloudformation:<Deployment-Region>:<AWS-Account-ID>:stack/<Deployment-Stack-Name-Prefix>*/*",
"arn:aws:cloudformation:*:<AWS-Account-ID>:stack/StackSet-Dynatrace*/*",
"arn:aws:cloudformation:*:<AWS-Account-ID>:type/resource/*"
"Sid": "cloudformation1",
"Effect": "Allow",
"Action": [
"cloudformation:GetTemplate",
"cloudformation:ValidateTemplate",
"cloudformation:GetTemplateSummary"
"Resource": [
"Sid": "lambda",
"Effect": "Allow",
"Action": [
"lambda:CreateFunction",
"lambda:UpdateFunctionCode",
"lambda:UpdateFunctionConfiguration",
"lambda:GetFunction",
"lambda:InvokeFunction",
"lambda:DeleteFunction",
"lambda:TagResource",
"lambda:UntagResource"
"Resource": [
"arn:aws:lambda:<Deployment-Region>:<AWS-Account-ID>:function:DynatraceApiClientFunction*"
"Sid": "iam",
"Effect": "Allow",
"Action": [
"iam:CreatePolicy",
"iam:CreatePolicyVersion",
"iam:DeletePolicyVersion",
"iam:DeletePolicy",
"iam:CreateRole",
"iam:UpdateRole",
"iam:DeleteRole",
"iam:PassRole",
"iam:AttachRolePolicy",
"iam:PutRolePolicy",
"iam:DetachRolePolicy",
"iam:GetRole",
"iam:GetPolicy",
"iam:ListPolicyVersions",
"iam:TagPolicy",
"iam:TagRole",
"iam:UntagPolicy",
"iam:UntagRole",
"iam:GetRolePolicy",
"iam:UpdateAssumeRolePolicy",
"iam:DeleteRolePolicy"
"Resource": [
"arn:aws:iam::<AWS-Account-ID>:policy/<Deployment-Stack-Name-Prefix>*",
"arn:aws:iam::<AWS-Account-ID>:role/<Deployment-Stack-Name-Prefix>*",
"arn:aws:iam::<AWS-Account-ID>:role/Dynatrace*",
"arn:aws:iam::<AWS-Account-ID>:policy/Dynatrace*"
"Sid": "s3",
"Effect": "Allow",
"Action": [
"s3:GetObject",
"s3:CreateBucket",
"s3:DeleteBucket",
"s3:PutLifecycleConfiguration",
"s3:PutBucketTagging"
"Resource": [
"arn:aws:s3:::dynatrace*"
"Sid": "secretsmanager",
"Effect": "Allow",
"Action": [
"secretsmanager:CreateSecret",
"secretsmanager:DescribeSecret",
"secretsmanager:UpdateSecret",
"secretsmanager:GetSecretValue",
"secretsmanager:PutSecretValue",
"secretsmanager:TagResource",
"secretsmanager:DeleteSecret",
"secretsmanager:PutResourcePolicy",
"secretsmanager:DeleteResourcePolicy"
"Resource": [
"arn:aws:secretsmanager:<Deployment-Region>:<AWS-Account-ID>:secret:DynatraceAPIAccessToken*",
"arn:aws:secretsmanager:<Deployment-Region>:<AWS-Account-ID>:secret:DynatraceAPIPlatformToken*",
"arn:aws:secretsmanager:<Deployment-Region>:<AWS-Account-ID>:secret:/dynatrace/*"
"Sid": "kms0",
"Effect": "Allow",
"Action": [
"kms:CreateKey",
"kms:TagResource",
"kms:UntagResource"
"Resource": "*",
"Condition": {
"StringEquals": {
"aws:RequestTag/dt:CreatedBy": "Dynatrace"
"Sid": "kms1",
"Effect": "Allow",
"Action": [
"kms:CreateGrant",
"kms:RevokeGrant",
"kms:DescribeKey",
"kms:GetKeyPolicy",
"kms:PutKeyPolicy",
"kms:ScheduleKeyDeletion"
"Resource": "*",
"Condition": {
"StringEquals": {
"aws:ResourceTag/dt:CreatedBy": "Dynatrace"
"Sid": "kms2",
"Effect": "Allow",
"Action": [
"kms:CreateAlias",
"kms:DeleteAlias",
"kms:UpdateAlias"
"Resource": [
"arn:aws:kms:<Deployment-Region>:<AWS-Account-ID>:key/*"
"Condition": {
"StringEquals": {
"Sid": "kms3",
"Effect": "Allow",
"Action": [
"kms:CreateAlias",
"kms:DeleteAlias",
"kms:UpdateAlias"
"Resource": "arn:aws:kms:<Deployment-Region>:<AWS-Account-ID>:alias/dynatrace/*/keys/aws/integration/*"
"Sid": "logs0",
"Effect": "Allow",
"Action": [
"logs:DescribeLogGroups"
"Resource": "*"
"Sid": "logs1",
"Effect": "Allow",
"Action": [
"logs:DeleteLogGroup",
"logs:CreateLogGroup",
"logs:DeleteLogStream",
"logs:CreateLogStream",
"logs:DescribeLogStreams",
"logs:PutRetentionPolicy",
"logs:ListTagsForResource",
"logs:DescribeIndexPolicies",
"logs:AssociateKmsKey",
"logs:DisassociateKmsKey",
"logs:PutLogEvents",
"logs:TagResource"
"Resource": [
"arn:aws:logs:<Deployment-Region>:<AWS-Account-ID>:log-group:/aws/lambda/<Deployment-Stack-Name-Prefix>*",
"arn:aws:logs:<Deployment-Region>:<AWS-Account-ID>:log-group:/aws/lambda/DynatraceApiClientFunction-*"
At this point all, the AWS IAM baseline prerequisites have been completed. Keep in mind that the IAM role/user permissions are needed for each onboarded AWS account.
We recommend that an AWS administrator pre-create those IAM constructs programmatically.
2. Dynatrace
Actions in this section can and (should) only be performed by the Dynatrace account administrator.
The new AWS Platform Monitoring has been integrated with the core Dynatrace Identity and Access Management (IAM) design.
Learn more about the basic concepts:
  • Users, service users
  • Local groups, policies
  • Platform tokens for service users
In this documentation section context:
A built-in user with View and manage users and groups permission.
CloudsAdmins
A customer-created custom IAM group where its members will be able to create and manage AWS connections in Settings Settings.
CloudAdmin
An IAM user, member of the CloudsAdmins group. The name is used here solely for context; any Dynatrace IAM user can be used.
Service user
A non-interactive IAM identity, against which platform tokens will be created.
Platform token
The authentication and authorization secrets used to establish a secure communication with the Dynatrace APIs. In our context, two platform tokens are to be created:
  • Settings PT—allows the creation and management of an AWS connection.
  • Ingest PT—allows the programmatic ingest of push-based telemetry from AWS.
Data-Acquisition Cloud Integrations All
A Dynatrace-created built-in IAM policy that contains all the permission scopes required to support the creation and management of multi-cloud (AWS/Azure/GCP) connections from Settings Settings. When using the new connection wizard, it automatically creates a new service user and linked platform tokens. It also binds all required permissions to allow connection creation and management, and telemetry ingest.
Interactive IAM identity (IAM user)
If you just created a new Dynatrace Account with a trial environment, you can skip steps 1 and 2, as your IAM user is considered an Admin. When the Account and its associated environments are towards promotion to production, we do recommended to adhere the below IAM best practices.
  1. Create the CloudsAdmins group.
    Once the CloudsAdmins group is created, select Permissions > Scope and add the Data-Acquisition Cloud Integrations All and Standard User policies.
    Apply Account-Wide or Environment-Wide, then select Save.
    Validate: The CloudsAdmins Permissions section should show:
    • Data-Acquisition Cloud Integrations All
    • Standard User
  2. Assign your CloudAdmin IAM user (or any other Dynatrace IAM user) as a member of the CloudsAdmins group.
The Data-Acquisition Cloud Integrations All policy must be added to the CloudsAdmin group as it is, with its full set of permissions, and is the only supported and recommended policy for platform-o11y-teams who will manage the cloud connections in Settings Settings.
The Data-Acquisition Cloud Integrations All is a Dynatrace-created built-in IAM read-only policy. Dynatrace updates this policy globally and, based on platform evolution, in order to align with new product features and enhancements.
The policy contains permission scopes that are paramount to successfully monitoring connection health and displaying connection telemetry status counters and events.
Limiting this policy in any way is unsupported. It can prevent Settings Settings from functioning correctly, from showing an incorrect connection status, or from displaying telemetry status counters or events.
Example for unsupported limitations:
  • Restricting its permission scopes in any other way, for example using dt.security.context conditions.
  • Copying its permissions into a custom, customer-managed policy that narrows them, for example with dt.security.context conditions or boundaries.
Onboarding
Before you start, make sure all prerequisites are completed.
  1. Log in to Dynatrace as the IAM user (member of the CloudsAdmins IAM group) and open Settings Settings.
  2. Go to Collect and capture > Cloud and virtualization > AWS and select New connection.
If the button is grayed out, it means you do not have the proper permissions to create a connection. Please, contact your administrator.
1. Select connection model
  1. Enter a friendly connection name that is unique (for example, MyEastProd3Account).
  2. Enter the AWS Account ID where you intend to deploy the connection.
  3. Choose the Deployment region.
    The deployment region is the AWS Region from which the CloudFormation stack will be deployed.
    If you plan to use the event ingest option, make sure to select a deployment region that supports EventBridge API destinations.
  4. Select Next.
2. Select observability option
  1. Choose the Recommended observability path. Two paths are currently supported:
    • Recommended: The monitoring configuration is an opinionated (immutable) option, only monitored Regions are customizable. Per AWS member account, this flow provides:
      • AWS account resources inventory using Clouds Clouds (for supported AWS services).
      • AWS account resources topology, depicted as rich resource entities using Clouds Clouds (for supported AWS services).
      • Amazon CloudWatch API metric polling (per enabled region) for our recommended services (automatically opted-in).
      • The Regions that were selected, allowing the AWS administrator to deploy Amazon Data Firehose streams for logs ingest as stacksets on the AWS Organizations Console.
    • Advanced: The most fine-grained path monitoring configuration. Allows the full customization any monitoring setting to meet advanced use cases.
    Regardless of the selected path, customizing all the supported monitoring settings is possible post-onboarding.
    The topology signal is an auto-enabled signal; you can't disable it.
  2. Choose the monitored AWS Regions you want to monitor.
    The monitored regions are the AWS Regions in which Dynatrace can securely poll metrics, topology and push logs from.
    You need to enable us-east-1 regardless of your desired monitored regions, since global AWS resources reside in us-east-1.
  3. Select Next.
After a successful onboarding, you'll be able to customize monitored AWS Regions and all other supported monitoring settings, per AWS member account.
3. Get platform tokens for service users
Generating tokens in this step automatically creates a service user, platform tokens, and binds all the required policies.
  1. Generate the settings and ingest tokens. Alternatively, you may also paste pre-existing tokens.
    If you don't have the required permissions to generate tokens automatically, see Create settings platform tokens and follow the steps.
  2. Select Download and Next.
    If the download button is grayed out, that means that the Dynatrace token fields are not populated with platform tokens.
4. Finalize
  1. Go to the AWS Console and log in to the designated AWS account with an AWS IAM user that has all the needed permissions to deploy the CloudFormation stacks.
  2. Select Deploy the CloudFormation in AWS Console.
    If you practice roles duty separation, the Dynatrace admin may have no access/permissions to the AWS environment.
    In this case, select the Copy Deployment Link.
    Share this deeplink and the downloaded platform tokens CSV file with your platform team and/or AWS Admins.
    This will allow them to deploy the CloudFormation stack with the wizard configurations that you have set.
  3. Copy the settings and ingest tokens from the downloaded CSV file (the file name will follow the connection friendly name) and paste them into the corresponding CloudFormation parameters (settings token, ingest token).
  4. Deploy the stack.
  5. When the CloudFormation stacks deployment finishes successfully (which can take up to 15 minutes), go back to the wizard and confirm.
If the CloudFormation stack deployment failed, see Troubleshooting.
5. Configure Health alerts and Warning signalsOptional
You can configure Health alerts and Warning signals now or later.
Health alerts and warning signals help you monitor your infrastructure by providing clear, actionable insights. These features reduce the noise from infrastructure issues and improve alerting capabilities, so you can focus on what matters most. This is achieved through better categorization of detected malfunctions.
  • For critical events, a Health alert is raised, triggering a Dynatrace Problems investigation.
  • For non-critical situations, a Warning signal informs you of a potential challenge.
For details, see Health alerts and warning signals.
Successful onboarding involves two elements:
  • In Settings Settings > Collect and capture > Cloud and virtualization > AWS, the new AWS connection is Healthy.
  • In the AWS CloudFormation console, the CloudFormation stacks are in CREATE_COMPLETE status.
What's next?
  • Go to Clouds Clouds. AWS resources with telemetry should start to appear shortly.
  • See Manage your AWS connections Settings app to learn how to manage your newly created connection.
  • Configure CloudWatch log group subscriptions.
Troubleshooting
The New connection functionality is disabled. When I hover on it, I see a message that I don't have the permissions.
Make sure that your Dynatrace IAM user has the proper permission scopes to create and manage a connection. For details, see the Create the Dynatrace IAM baseline section.
The CloudFormation stack did not complete successfully. How do I troubleshoot for the root cause?
If your CloudFormation deployment fails, it's often related to a lack of AWS IAM permissions, AWS Service limits being reached, or Service Control Policies configured in your AWS Organizations.
To run our troubleshooting helper script to discover the root cause
  1. Open AWS CloudShell in the AWS Management Console.
    Alternatively, you can run bash with AWS CLI installed.
  2. Download the script:
    wget -q https://dynatrace-data-acquisition.s3.us-east-1.amazonaws.com/aws/deployment/cfn/da-activation-check.sh -O da-activation-check.sh && chmod +x ./da-activation-check.sh
  3. Run the script to analyze the failure reason and script output ./da-activation-check.sh --stack-name <activation-stack-name>.
    The activation main stack name follows the AWS connection name specified the Dynatrace connections list, for example, connection name: MyEastProd3Account
To find the failure reason manually
  1. Go to the AWS Management Console > CloudFormation stack events and search for the root cause.
  2. Also search nested stacks and stackset instances (if logs/events ingest was enabled) for failed events.
If you encounter an error that you cannot resolve on your own, open a Dynatrace support ticket providing the script output.
The root cause of the CloudFormation deployment failure is an invalid or expired token. What can I do?
The best way to solve this issue is to delete the failed stack and repeat the deployment specifying valid tokens as parameters. You can start the deployment from the Dynatrace Settings Settings web UI to generate a new API token.
The root cause of the CloudFormation deployment failures are related to permissions, as I can see messages indicating that I'm not authorized to perform X or Y. What can I do?
If you can see in the CloudFormation stack error messages, such as "User: arn:aws: <...> is not authorized to perform: <...> on resource: <...>", it's because you haven't included the proper user/role permissions required from our policy. Update the setup by adding the required AWS permissions, clean the current setup, and restart the process.
To learn how to clean the current setup, see The CloudFormation stack did not complete successfully. I fixed the issue. How do I clean the current setup and start over?
The root cause of the CloudFormation deployment failure is that the 'Account XXX has not enabled 'Region-XYZ'. What can I do?
If you see, in the CloudFormation stack, error messages such as "Account XXX has not enabled [Region-XYZ]: ...", clean the current setup, enable that Region or remove it from the deployment parameters, and restart the process.
The root cause of the CloudFormation deployment failure is the creation of the Firehose DeliveryStream. What can I do?
If you see, in the CloudFormation stack, error messages such as "You are not subscribed to this service" or "The AWS Access key Id needs a subscription for the service (Service Firehose)", this is because new services, such as Firehose, require it to be enabled on some new accounts. See how to resolve problems when accessing a service in the AWS Management Console.
After enabling it, clean the current setup and restart the process again.
The CFN templates are all pulled from a Dynatrace S3 bucket on us-east-1, but my organization policy does not permit access to us-east-1. What can I do?
Our CFN templates are public, so we recommend that you create an S3 bucket on your region of choice and copy all templates to this bucket. You will need to change all nested stacks links to your bucket. This will allow you to sucessfully deploy the CFN integration directly from the AWS Console.
Note: The wizard supports only the onboarding of an AWS account that has access to the Dynatrace bucket located on us-east-1.
The root causes of the CloudFormation deployment failures are 404 or 400 errors. What can I do?
Check that the Settings Platform token used for the deployment of the CFN stack has the correct permissions. If the error remains, open a Dynatrace support ticket.
In the AWS CloudFormation console, delete the master Dynatrace stack. The main stack name follows the connection name in our example MyEastProd3Account. Follow the AWS guidelines on deleting stacks.
Once the stack and its nested stacks are completely deleted
  1. In Dynatrace, go to Settings Settings > Cloud and virtualization > AWS.
  2. Find and select the connection action menu on the right .
  3. Select Delete.
  4. You are now able to start the wizard and create a new connection.
Is it possible to scope the Data-Acquisition Cloud Integrations All policy to the specific cloud provider in order to practice least privilige?
Yes, the policy document contains remarked lines with the constructs that can be used to successfully create a policy boundary.
Not all resources created are properly tagged in Dynatrace.
Even if your organization enforces tagging via Service Control Policies or IAM, some of the resources created by CloudFormation do not support tag propagation. For details, please see AWS CloudFormation resource tagging.
I have enabled logs push-based ingest via Firehose, but I cannot seem to locate log records on Dynatrace.
Looking at the Destination error logs tab (AWS Firehose console), if you get this message:
Delivery to the endpoint was unsuccessful. See Troubleshooting HTTP Endpoints in the Firehose documentation for more information. Response received with status code. 403: "requestId":"xxxx,"errorMessage":"The authorization token does not provide the necessary permissions. details: missing_scopes=[data-acquisition:logs:ingest]
Verify that
  1. The platform ingest token is assigned with the correct permission scope (data-acquisition:logs:ingest).
  2. The Dynatrace service user linked to the token is also assigned with same token permission scope (data-acquisition:logs:ingest).
  3. The platform ingest token has not expired or was deleted.
  4. The service user has not been deleted.
  5. The platform token environment scope is adjusted to the correct Dynatrace environment.
When creating the platform token, why is the "service user" option grayed out?
Your IAM user might not have permission to create platform tokens for (existing) service users. Contact you Dynatrace Admin to learn if the prerequisites were followed. In this case, a specific permission scope must be granted.
Related tags
Infrastructure Observability
