Operating system requirements
  • Reference
  • 2-min read
Review the operating system requirements before installing Dynatrace Managed.
  • Dynatrace Managed requires a dedicated host. The host must not run other services that are central processing unit (CPU)- or memory-intensive, or that use ports required by Dynatrace Managed.
  • Dynatrace Managed runs on a 64-bit Linux distribution (see supported distributions below). It supports installation on physical and virtualized hosts but not in containers.
  • Dynatrace Managed requires a fixed IPv4 address. It supports only IPv4 address spaces.
  • Configure your firewall settings before installation.
  • The libraries installed with Dynatrace Managed are locale-aware. Set the system locale to an English option, for example LANG=en_US.UTF-8, to ensure correct display of text and symbols.
Supported operating systems
Linux distributionVersionsCPU architectures
Amazon Linux2, 20231x86-64
Debian11, 12x86-64
Oracle Linux8.8, 8.10, 9.2, 9.4, 10.11x86-64
Red Hat Enterprise Linux8.10, 9.4, 9.6, 9.7, 9.8, 10.01, 10.21x86-64
Rocky Linux9.2, 9.4, 10.01x86-64
SUSE Enterprise Linux12.5, 15.4, 15.5, 15.6, 15.7x86-64
Ubuntu16.04, 18.04, 20.04, 22.04, 24.04, 26.04x86-64
1
Dynatrace Managed requires manual installation of the 'libcrypt.so.1' library from the 'libxcrypt-compat.rpm' package, which is not installed by default.
Support changes
Future Dynatrace Managed operating systems support changes
The following operating systems will no longer be supported starting 01 November 2026
  • Linux: Red Hat Enterprise Linux 9.4, 9.7
    • x86-64
    • Vendor announcement
  • Linux: Ubuntu 16.04
    • x86-64
The following operating systems will no longer be supported starting 01 January 2027
  • Linux: Amazon Linux 2
    • x86-64
Past Dynatrace Managed operating systems support changes
The following operating systems are no longer supported since 01 June 2026
  • Linux: Oracle Linux 9.6
    • x86-64
  • Linux: Rocky Linux 9.6
    • x86-64
The following operating systems are no longer supported since 01 July 2026
  • Linux: SUSE Enterprise Linux 15.3
    • x86-64
