If you analyze incidents in your environment in Dynatrace and use the problems feed and problem details page, you can improve your experience with the new
Problems, backed by data from Grail.
You can use
Problems Classic and the latest
Problems side by side. By upgrading to
Problems, you can unlock new capabilities and functionality. For example, with the latest
Problems you can:
Kubernetes or When you upgrade to the
Problems, the core backend RCA engine continues to operate unchanged, while the user experience is upgraded in the following ways:
You can continue using the
Problems Classic alongside
Problems for now. However, Dynatrace is currently in the process of complete transition from
Problems Classic to
Problems.
The problem feed allows operations and SRE users to review all incoming active problems and the history of resolved ones. The general feed layout and structure is preserved in
Problems, ensuring a smooth upgrade with little visual changes.
The problem feed layout in
Problems features a similar problem feed with a filter bar, chart, column table, and a left side panel with default filters. Additionally,
Problems introduces a number of new elements, such as:
The global problem indicator: the indicator located above the filter bar reflects the number of active and all problems (for example, 14 active/25) based on your access and applied filters. Both
Problems source and list the same generated problems, which means that the number of problems is identical between the apps.
Segments and dynamic filters: left to the filter bar, you can find segments , predefined filters used for quickly filtering the data. You can use a set of team-specific segments and choose one or more segments to apply pre-made filters relevant to your area. Additionally, you can apply your own dynamic filters in the filter bar, choose the timeframe, refresh the feed to apply new filters, and set the automatic refresh with available interval options.
Segment filters replace the Management Zone filters.
User-defined columns: you can rearrange the column order and search, hide, and display specific columns, tailoring the feed to your needs. You can customize column settings by selecting Columns.
Custom problem fields: in addition to standard fields propagated to
Problems by default, you can create and modify custom fields like app.id, aws.region to include relevant information.
Downloading table data: you can download all table data or selected rows in CSV format by selecting .
New default filters: Status, Impact, and Severity filters on the left panel, present in
Problems Classic, are also featured in
Problems. However, Severity filter in
Problems allows you to choose the level of problem severity from Informational to Critical in alignment with ITIL framework standard. A problem category can be chosen from the Category filter instead.
The global problem indicator displays a total number of currently active problems. The count is based on your platform policy-related read access within the problem events table in Grail and on the default filter that you have set in the problem feed.
In the Latest Dynatrace, the global problem indicator is always visible at top of the
Problems app and in the dock, regardless of which app you are currently working in.
Access policies that are defined on top of events reduce the number of problems you can see both in the problem feed and in the global problem indicator. Additionally, if you set a personal default problem filter directly within the problem feed, it'll also apply to the global problem indicator and impact how many active problems you see. For example, you can reduce the global active problem count by configuring the default filter categories on the side panel. You can save your new default filter by selecting as seen below:
You can also turn on email notification for problems matching the default filter by selecting > Turn on notifications.
Segment filters were introduced across the Dynatrace platform to replace Management Zones for UI-based filtering and sharing preconfigured filters to onboard your teams.
Compared to Management Zones,
Segments help your teams manage their filters by offering the ability to use variables that form dynamic conditions of include blocks. This allows you to avoid creating multiple individual configurations and helps deduplicate other segments. By defining one variable that uses Grail field values, multiple individual management zones can be replaced with a single segment config as shown below:
Instead of creating a separate management zone per AWS account ID, you can use a single segment with several selectable ID variables instead.
Aside from Segment filters, the new problem feed offers multiple ways of filtering open problems for improved triaging including the filter bar.
The filter bar offers a number of filter possibilities such as logical operators AND and OR combined with complex filter statements and the possibility to use wildcard text filtering as shown below:
Problems introduces a new feature unavailable in
Problems Classic—custom problem fields that you can define and display in the problem feed. By surfacing customer-specific information within the problem feed, operation teams can speed up the process of triaging the ownership and responsibility of incoming problems.
By configuring which event fields are extracted and propagated into a problem via
Settings, you can:
Custom problem fields can also be used in any problem DQL query in
Notebooks and
Dashboards.
Additionally, you can use
Settings to check which fields are surfaced in problems and where they come from. For example, policy-relevant fields such as cloud.region, dt.host_group.id, or k8s.cluster.name and fields related to cost allocation, such as dt.cost.costcenter or dt.cost.product, are displayed in problems by default. The owner of these default fields is listed as
Problems, indicating that they come from the app and weren't created by a user.
Similar to
Problems Classic,
Problems provides a problem details page that shows impact and root cause of a larger scale incident.
The details page is structured similarly to
Problems Classic, where the key important information about the problem is shown in the header, such as the problem name, its status, unique problem number (for example, P-25032996), its category (for example, Error), and its start time and duration.
Additionally, the problem header in
Problems offers a possibility to ask Dynatrace Intelligence to summarize the entire problem and provide hints about possible remediation steps. You can do so by selecting Explain problem.
In
Problems, the problem details page shows the general information at the top, the impact on the left side and surfacing the root cause on the right side.
The general information at the top of the page includes a number of KPI measures, such as the number of affected SLOs, affected frontends, affected services, infrastructure entities, and the number of affected users.
You can see the root cause identified by the Dynatrace causal AI highlighted in red both in the Impact on the left and the Root cause on the right side of the details page in the Overview tab. Aside from the general key data, the Overview tab shows a list of connected running workflows below the Visual resolution path and Comments that serves the same function as in
Problems Classic.
Additionally, problem details page in
Problems introduces other new capabilities, such as
The Visual resolution path helps you understand how Dynatrace Intelligence identified the root cause backend service. It graphically illustrates the relationships between frontends, services, and backends involved in the issue. Each node represents a Smartscape entity, such as frontend, service, or backend, where a health issue was detected.
By selecting Maximize on the top right, you can open the detailed view, complete with a timeline on the very bottom that shows when related events have been fired:
The drill-down actions available on the problem details page help you pinpoint the cause on a code level by navigating you to a specialized app like
Services or Distributed Tracing. These apps have an integrated investigation mode that allows you to work across apps by carrying over the information from the problem details page. For example:
Problem: P-2609857.
Problems.The drill-down action available to the left of the (for example, Analyze slowdown) shows the primary analysis option recommended by Dynatrace based on the identified root cause. Meanwhile, displays a list of relevance-ranked secondary actions. All the app-related actions automatically lead to a Problem investigation mode on the receiving application side, which is indicated by a
badge at the top of the page.
For example, by navigating to
Services via drill-down actions in the Root cause section, you can check the response time analysis of a detected service slowdown:
Automation and remediation triggered by <problem-number> section in Overview tab displays a list of connected workflows and their status.
Workflows offers dedicated triggers to either react to incoming active events or newly created active problems. These Workflow triggers are used to send alert notifications or implement automations on top of Dynatrace-detected situations, which allows you to automate fixes to known potential problems or receive notifications for workflows configured with a problem trigger.
Automation and remediation triggered by <problem-number> allows you to track and check the status of all connected workflows without navigating to
Workflows and checking individual configurations.
Problems and events are stored in Grail along with their record fields. The problem feed and problem details view use DQL to surface all details in a UI tailored for operations teams and SREs.
You can write DQL queries to directly access the same information within
Dashboards,
Notebooks, and
Workflows to define custom reports and implement automations on top of Dynatrace-detected events and problems:
fetch dt.davis.events shows the last state of any given alerting event with all its event fields.fetch dt.davis.events.snapshots delivers all the individual update and refresh events that were received while the event was in an active state.fetch dt.davis.problems shows the last state of any given problem with all its event fields.fetch dt.davis.problems.snapshots delivers all the individual updates that were received while the problem was in an active state.Which DQL query you should use depends on your particular use case. For example:
Slowdown events you currently have on all your services, use the dt.davis.events query.dt.davis.events.snapshots query.The same principles apply to the problem queries, which deliver all the details about problems detected and analyzed by Dynatrace Intelligence.
All four queries implicitly apply a bucket filter that only fetches events from Davis event buckets instead of loading from the much larger general event bucket.
The flexibility of querying events and problems allows you to freely create custom dashboards and reports, as shown in this example:
Integration partners building apps on top of the platform or outside of Dynatrace use the Grail Service API along with DQL to query events and problems detected by Dynatrace Intelligence.
Both the Grail Service API and the Grail Service SDK apply table-based access policies. This ensures consistency in accessing records independently of the client context like
Notebooks,
Dashboards, workflow automations, SDK, or API.
Dynatrace Classic uses Management Zones to define data access. In Latest Dynatrace we replace Management Zones by introducing two new concepts, IAM Policies and Boundaries, for configuring data access management.
These new concepts apply to
Problems and event records in Grail, meaning that access policies can be used to restrict a user's ability to see problems to a smaller defined subset.
Since defining policies on records within Grail is restricted to a subset of well-defined record fields, called Record level permissions in Grail, it's important that those fields are properly set and enriched in
Problems.
If you need to use one or more custom fields in
Problems to define the access scope, we recommend using the dt.security_context field. There are several ways to add a dt.security_context field to a problem or an event:
Problems.dt.security_context processor) field within the Problems or Davis event pipeline.
Anomaly Detection setting or OneAgent), you can use the source side tagging on the agent side to add the security context field directly to the source.Causal AI used in the latest root cause engine follows the Smartscape topology on Grail data, which allows the root cause engine to merge alerts along the topology for components that call each other directly.
Upgrading the root cause engine is a separate step. If your environment is in Group 1 or Group 2 and runs only or mostly on OpenTelemetry, you can request it via a support ticket or by contacting your Dynatrace account team.
The latest version of the root cause engine introduces the following changes:
| Topic | Classic root cause engine | Latest root cause engine |
| OpenTelemetry services | Can't be identified as a root cause. | Can be identified as the root cause and can be merged into one problem. |
| Databases | The database service is only seen from the caller. | The database instance can be identified as the root cause if it's monitored and alerted on. |
| Components without an alert | Probes metrics on demand and can blame these components. | Every component needs its own alert to be identified and merged. |
| External services and third-party APIs | Can be identified as the root cause. | Can't be identified as the root cause. A failing provider shows up as a problem on the calling services. |
| Grouping in time | Only events created within 5 minute (start timestamps) of each other can be merged. | Only directly connected alerts created within about 15 minutes (start timestamps) of each other can be merged. |
| Problem field of the root cause | root_cause_entity_id, root_cause_entity_name | root_cause.smartscape_entity |
For more information, see Root cause analysis for OpenTelemetry services, frontends, and databases.
While
Problems doesn't require you to upgrade to Dynatrace Platform Subscription (DPS), you need DPS to be able to utilize the full potential of the improved problem analysis on the Latest Dynatrace. To use the full scope of the Latest Dynatrace and
Problems functionality, ensure that your license agreement includes Dynatrace Platform Subscription (DPS).
Before you start your transition from
Problems Classic to the
Problems, we recommend familiarizing yourself with related concepts of the Dynatrace platform:
Some of the
Problems Classic concepts and behaviors are not carried forward:
Problems Classic aren't migrated.
Problems.The Latest Dynatrace is introducing a couple of new concepts and capabilities that differ between
Problems app. It's vital to understand the differences before upgrading.
Problems Classic exposes problem information through a dedicated UI with limited options for reuse outside the app. Problem details, timelines, and impact context are primarily consumed within the
Problems Classic experience.
Problems app, all problem and event records are stored directly in Grail, making them available across the Dynatrace platform.Grail stores problem and event data in tables, allowing you to query, join, and analyze it consistently alongside other observability data. You can access problem data using DQL from
Problems,
Dashboards,
Notebooks, and
Workflows, without relying on app-specific or legacy views. This unified data layer allows you to explore problem timelines, impact context, and related events from a single source, using the same query language and tooling as the rest of the platform.
With the Latest Dynatrace, filtering problems is based on segments that replace static Management Zone–based filtering used in
Problems Classic.
Segments provide a dynamic and multidimensional way to filter problem data across apps. They're designed to scale for enterprise environments and can be defined based on logical structure such as applications, environments, ownership, or responsibilities. Segments support logical expressions like AND, OR, and wildcard matching and adapt automatically as your environment changes. Unlike Management Zones, segments aren't applied globally, but are carried over when navigating between apps using Open with drill-downs, which allows to preserve the investigation context.
Problems Classic exposes a fixed set of problem attributes that can't be extended to include organization-specific metadata. Meanwhile, in the latest
Problems, you can define custom problem fields to display selected event attributes directly in problem records. This allows you to surface business, ownership, or infrastructure metadata directly in the problem feed.
Custom problem fields are record fields that aren't propagated to a detected problem by default and have to be configured and subscribed to by the user. Fields modified by the user are also counted as Custom problem fields.
To upgrade, you need to install the new
Problems app. To do so
