Requirements for private Synthetic locations in Classic
  • Dynatrace Classic
  • Reference
  • 15-min read
Ensure that the host you want to use for your private location complies with the following requirements.
End-of-support information
There are no new versions of Chromium for Red Hat/Oracle Linux/Rocky Linux 8 beyond version 133. For important security and stability reasons, we've decided to discontinue our support for installing Synthetic-enabled ActiveGate on Red Hat/Oracle Linux/Rocky Linux 8 after ActiveGate version 1.325.
To ensure the continuity and security of your synthetic monitors, we recommend migrating your Synthetic-enabled ActiveGate to one of the supported operating systems, for example, Red Hat/Oracle Linux/Rocky Linux 9.
ActiveGate version 1.325 is the last Synthetic-enabled ActiveGate supported on Red Hat/Oracle Linux/Rocky Linux 8.
Additionally, with Dynatrace version 1.326, we plan to introduce mechanisms preventing Synthetic-enabled ActiveGates on Red Hat/Oracle Linux/Rocky Linux 8 from being updated beyond version 1.325.
  • Check the latest ActiveGate release notes for the oldest supported ActiveGate versions.
Antivirus and anti-malware software
Antivirus and anti-malware software can negatively impact Dynatrace Synthetic monitoring capabilities. Such software might block the browser or Dynatrace processes that execute synthetic monitors, cause Synthetic-enabled ActiveGate installation or update failures, interfere with network communication, and impact the reliability of measurements.
To maintain stability and performance, consider adding the directories and processes listed below to the allowlist or exclude them from the policy. Keep in mind that antivirus exclusions typically prevent file scanning but don’t disable behavioral monitoring or kernel-level hooks. These remain active and can affect how the Synthetic Engine and browser interact with system libraries. As a result, even excluded processes can experience access violations or heap corruption.
Before contacting Dynatrace Support to troubleshoot issues with your private synthetic locations, ensure that antivirus or anti-malware software has been ruled out as a potential cause.
This is the minimal list of processes and directories required for Dynatrace Synthetic to operate. It's not guaranteed that the service will function correctly with only these exclusions. Collaborate with your vendor to ensure that all expected Dynatrace behaviors are properly allowed.
Directories:
  • All directories with synthetic in their path. For an overview of directories in use, see ActiveGate directories.
Processes:
  • chrome
  • vucwrapper
  • java
Operating system requirements
A freshly installed ActiveGate can run your private synthetic monitors (both HTTP and browser monitors) on the following operating systems.
Windows
Supported operating systems
Windows OSVersions
Windows Server
2016, 2019, 2022, 2025
Browser versions on Windows
On Windows, the ActiveGate installer package includes the Chrome for Testing browser used to run browser monitors. The table below shows the Chrome for Testing versions that are bundled with the respective ActiveGate versions.
ActiveGate versionIncluded browser version
1.349
153
1.347
152
1.345
151
1.3431
150
1.341
148
1.339
147
1.337
146
1.335
146
1.333
144
1.331
143
1.329
142
1.327
141
1.325
140
1
All Windows Server versions migrated to use Chrome for Testing instead of Chromium.
Unsupported Windows versions for testing purposes only
If you only want to test private Synthetic locations on a non-production host, for example, your own desktop, you can install a Synthetic-enabled ActiveGate on unsupported Windows versions such as Windows 10 or Windows 11.
As of ActiveGate version 1.263+, Synthetic-enabled ActiveGates no longer work on Windows Server 2012 for testing purposes. Google has dropped support for Windows 2012 Server with Chromium 110, which is bundled with the ActiveGate version 1.263 installation package.
Linux
Linux distributionVersions
Red Hat Enterprise Linux1
9.4, 9.6, 9.7, 9.8, 10.2
Ubuntu
20.04, 22.04, 24.04
Amazon Linux
2023
Oracle Linux2
9.6, 9.7
Rocky Linux3
9.8, 10.2
1
The Synthetic installer can be installed on all minor releases of Red Hat Enterprise Linux 9 and 10. Versions listed in this table were verified for compatibility. We recommend using them or the versions that have Extended Life-cycle Support (ELS) according to Red Hat Enterprise Linux Life Cycle.
2
The Synthetic installer can be installed on all minor releases of Oracle Linux 9. Versions listed in this table were verified for compatibility. We recommend using them or the latest currently supported versions according to documentation for Oracle Linux 9.
3
The Synthetic installer can be installed on all minor releases of Rocky Linux 9 and 10. Versions listed in this table were verified for compatibility. We recommend using them or the latest currently supported versions according to Rocky Linux Release and Version Guide.
Deprecated operating systems
7.91
CentOS
7.91
Amazon Linux
22
8.83
8.103
Oracle Linux
8.103
Rocky Linux
8.103
1
ActiveGate version 1.305 is the last Synthetic-enabled ActiveGate to support Red Hat/CentOS 7.
2
ActiveGate version 1.307 is the last Synthetic-enabled ActiveGate to support Amazon Linux 2.
3
ActiveGate version 1.325 is the last Synthetic-enabled ActiveGate to support Red Hat/Oracle Linux/Rocky Linux 8.
Browser versions on Linux
We strongly recommend that you keep your Linux-based Synthetic-enabled ActiveGates and browser versions updated—Dynatrace supports browser versions that are no more than two versions behind the latest Dynatrace-supported version for a specific ActiveGate release. For example, if the latest supported browser version is 103, Dynatrace supports up to browser version 101. If the provided browser version is significantly older for a specific OS, we support only the provided version. See information on updating browser automatically and manually.
On Linux, the ActiveGate installer downloads the browser dependencies that are required by the Synthetic engine. On Red Hat and Rocky, you need to enable particular repositories from which the installer downloads the dependencies. The Dynatrace web UI provides you with all the required commands. For detailed instructions, see Create a private synthetic location.
When installing ActiveGate and the browser from a custom, local repository, you need to resolve all dependencies and enable repositories as required; the custom repository can be used only for browser packages, not their dependencies. Place the browser package archive and the signature file in the custom repository for installation. If your package archive file is https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-143.0.7499.192.zip (Chrome for Testing 143 for Ubuntu on ActiveGate version 1.333), you can find the signature file by appending .sig to the URL: https://synthetic-packages.s3.amazonaws.com/Chrome/chrome-for-testing-linux64/chrome-for-testing-linux64-143.0.7499.192.zip.sig.
Due to changes in libdav1d.so.6 packet availability Chromium versions older than 130 cannot be installed on Red Hat/Rocky Linux 9. Please refer to troubleshooting guide for details.
ActiveGate versionLatest supported Chromium version Red Hat/Rocky Linux 9Latest supported Chrome for Testing version Amazon Linux 2023, Ubuntu, Oracle Linux 9, Red Hat/Rocky Linux 10
1.3491
153 Red Hat/Rocky Linux 9
153
1.347
152 Red Hat/Rocky Linux 9
152
1.345
151 Red Hat/Rocky Linux 9
151
1.343
150 Red Hat/Rocky Linux 9
150
1.341
148 Red Hat/Rocky Linux 9
148
1.339
147 Red Hat/Rocky Linux 9
147
1.337
146 Red Hat/Rocky Linux 9
146
1.335
146
1.333
144 Red Hat/Rocky Linux 9
144
1.3312
143 Red Hat/Rocky Linux 9
143
ActiveGate versionLatest supported Chromium version Red Hat/Oracle/Rocky LinuxLatest supported Chromium version Ubuntu 20 and 22Latest supported Chrome for Testing version Amazon Linux 2023, Ubuntu 24, Oracle Linux 9
1.329
142 Red Hat/Rocky Linux 9
142 Ubuntu 20.04 and 22.04
142
1.327
141 Red Hat/Rocky Linux 9
141 Ubuntu 20.04 and 22.04
141
1.325
133 Red Hat/Oracle/Rocky Linux 8, 140 Red Hat/Rocky Linux 9
140 Ubuntu 20.04 and 22.04
140
1
Red Hat/Rocky Linux 10 support introduced.
2
Ubuntu Server 20.04 and 22.04 migrated to use Chrome for Testing.
File Access Policy Daemon framework (fapolicyd)
If not configured correctly, the File Access Policy Daemon (fapolicyd) can potentially affect Dynatrace Synthetic monitoring capabilities. Similarly to antivirus or anti-malware software, fapolicyd might block the browser or Dynatrace processes responsible for executing synthetic monitors.
To ensure proper stability and performance, consider adding directories and processes to the allowed list or excluding them from the policy. For more detailed information, refer to the Red Hat documentation on fapolicyd. Prior to contacting Dynatrace support to troubleshoot issues with your private synthetic locations, make sure that fapolicyd was excluded as a source of problems.
File Access Policy Daemon framework can be run in debug mode where all denials are logged, making tracking down missing rules and troubleshooting issues easier. For more detailed information about its debug mode, refer to the documentation on troubleshooting problems related to fapolicyd
Hardware requirements
General considerations
  • Note that a Synthetic-enabled ActiveGate has more demanding hardware and system requirements than a regular Environment or Cluster ActiveGate. We strongly recommend using a Synthetic-enabled ActiveGate exclusively for synthetic monitoring purposes.
  • Any additional component running on the host should be taken into account when planning resources provisioning. For instance, if the location is monitored by OneAgent or another deep monitoring solution, memory (RAM) requirements will increase.
  • To change the size of a Synthetic-enabled ActiveGate, for example, after upgrading from size S to meet size M requirements, you must uninstall and reinstall it. Reinstallation applies the correct memory limits based on available hardware. Although the Synthetic Engine detects the new size at startup, without reinstallation it keeps the original limits, which can cause instability under heavier load.
Sizing guide
Based on the number of tests executed per hour, Synthetic-enabled ActiveGates need to meet the following hardware requirements.
Limit values
The estimated limits listed in the table below were determined in our internal tests. The actual values might vary depending on the complexity of your monitors.
XS node
While XS nodes can be used on Windows Server-based ActiveGates, they may not be the best fit due to the higher hardware demands of the browser. For optimal performance and to prepare for future enhancements, we recommend having at least 8 GB of RAM and 25 GB of free disk space.
On Linux systems with only 4 GB of RAM, the increasing resource requirements of the browser, combined with the installation of third-party tools on the host, may lead to occasional memory shortages. Upgrading to 8 GB of RAM is strongly recommended to help ensure a smoother and more reliable experience.
Node with browser monitor supportBrowserless node
Minimum CPUs
2 vCPU
1 vCPU
Minimum free disk space
20 GB
17 GB
Minimum RAM
4 GB
4 GB
Minimum free RAM
3 GB
2,7 GB
Minimum disk IOPS (Windows)
100
100
Estimated maximum number of HTTP monitor executions/h1
300k
300k
Estimated maximum number of high-resource HTTP monitor2 executions/h
10k
10k
Estimated maximum number of browser monitor executions/h
300
Estimated maximum number of NAM ICMP monitor packets/h3 5
500k
500k
Estimated maximum number of NAM TCP monitor requests/h4 6
1M
1M
Estimated maximum number of NAM DNS monitor request/h4 7
100k
100k
Footnotes
1
Calculated as 5000 monitor executions (maximum for a single environment) run once every minute (maximum frequency).
2
These are HTTP monitors on private locations with any of: pre- or post-execution scripts, OAuth2 authorization, Kerberos authentication.
3
For NAM monitors using ICMP request type, capacity is related to number of ICMP echo requests (packets) that are being sent during monitors execution. As this number of packets-to-be-sent may significantly vary among defined monitors, using the number of monitor executions as a capacity limit would be inaccurate.
4
For NAM monitors using TCP and DNS request types, capacity is related to the number of network connections (requests) that are being sent during monitors execution. As this number of requests may significantly vary among defined monitors, using the number of monitor executions as a capacity limit would be inaccurate.
5
During load tests that helped to establish capacity limits, NAM ICMP monitors were exclusively scheduled on location; monitors had the following characteristic. Actual capacity may be different for other environments (for example, those where monitored targets respond slower or are failing to provide a response within timeout limit or other type of monitors are executed at the same time). Monitors were using default settings (including default timeouts settings and single packet per-request) and were scheduled every 1 minute. There were multiple target hosts used during tests; all of them were responding properly with average RTT around 200ms.
6
During load tests that helped to establish capacity limits, NAM TCP monitors were exclusively scheduled on location; monitors had the following characteristic. Actual capacity may be different for other environments (for example, those where monitored targets respond slower or are failing to provide a response within timeout limit or other type of monitors are executed at the same time). Monitors were using default settings (including default timeouts settings) and were scheduled every 1 minute. There were multiple target hosts and ports used during tests; all of them were responding properly with average TCP connection time around 200ms.
7
During load tests that helped to establish capacity limits, NAM DNS monitors were exclusively scheduled on location; monitors had the following characteristic. Actual capacity may be different for other environments (for example, those where monitored targets respond slower or are failing to provide a response within timeout limit or other type of monitors are executed at the same time). Please note that DNS server used during resolution should be able to handle incoming requests and may not consider the incoming traffic as a subject to throttling or rejection (for example, due to detection as bot-originated). Monitors were using default settings (including default timeouts settings and UDP as a transport) and were scheduled every 1 minute. There were multiple resolution targets used during tests; all of them were resolved properly with average DNS resolution time around 10ms. Publicly available DNS servers were used: Google (8.8.8.8 and 8.8.4.4) and Cloudflare (1.1.1.1 and 1.1.1.2)
Minimum CPUs
4 vCPU
2 vCPU
25 GB
22 GB
Minimum RAM
8 GB
8 GB
Minimum free RAM
5 GB
4 GB
200
200
300k
300k
20k
20k
650
1M
1M
2M
2M
200k
200k
Footnotes
1
2
3
4
5
6
7
Minimum CPUs
8 vCPU
4 vCPU
30 GB
23 GB
Minimum RAM
16 GB
16 GB
Minimum free RAM
8 GB
6,5 GB
400
400
300k
300k
60k
60k
1200
1.5M
1.5M
3M
3M
300k
300k
Footnotes
1
2
3
4
5
6
7
Minimum CPUs
16 vCPU
8 vCPU
40 GB
25 GB
Minimum RAM
32 GB
32 GB
Minimum free RAM
12 GB
10 GB
750
750
300k
300k
100k
100k
2200
2M
2M
4M
4M
400k
400k
Footnotes
1
2
3
4
5
6
7
Storage and file system permissions
The table below shows the default installation locations (Linux and Windows) of various ActiveGate directories and the minimum size requirements. This information is compiled from details in ActiveGate directories.
Installation parameterDefault pathMin. sizeNotes
<INSTALL>
  • /opt/dynatrace/
  • %PROGRAMFILES%\dynatrace
600 MB
For executable files, libraries, and related files
  • 300 MB for ActiveGate
  • 270 MB for Private Synthetic files
<LOGS>
  • /var/log/dynatrace
  • %PROGRAMDATA%\dynatrace
1.7 GB
  • 500 MB for ActiveGate logs
  • 1 GB for Private Synthetic logs
  • 200 MB for autoupdater logs
<CONFIG>
  • /var/lib/dynatrace
1 MB
<TEMP>
  • /var/tmp/dynatrace
21 GB1
  • 1 GB for ActiveGate temporary files (without cached OneAgent installers and container images)
  • 20 GB for Private Synthetic temporary files (including execution logs, cache, and screenshots)
1
For an XS ActiveGate—more space is required for execution logs on larger ActiveGates.
Permissions for /tmp
Synthetic-enabled ActiveGate requires write access to the /tmp directory during runtime. Its dependencies, including xvfb, utilize /tmp for storing temporary files and runtime data. Lack of write permissions to this directory may result in unexpected failures or degraded functionality. Ensure that the host environment provides sufficient access rights and available space in /tmp to support these operations reliably.
Related topics
  • ActiveGate directories
Related tags
Digital ExperienceSynthetic ClassicSynthetic Classic
