Monitor service-level objectives in Kubernetes/OpenShift
  • Dynatrace Classic
  • 2-min read
  • Published Jan 19, 2023
You can keep track of current service-level objectives related to a Kubernetes/OpenShift workload on the Kubernetes workload details pages.
  • Select SLOs on the notifications bar to display the Service-level objectives panel, which lists SLOs that are directly or indirectly connected to the workload.
Directly connected SLOs
  • An SLO is directly connected to a workload when the entity selector of an SLO meets the following criteria:
    • The entity type is set to "CLOUD_APPLICATION".
    • The entity ID is set to the workload ID.
  • To see only SLOs that are directly connected to the workload, make sure that Show only directly connected SLOs is turned on.
Indirectly connected SLOs
  • An SLO isn't directly connected to a workload when, in the entity selector of an SLO, no entity ID is provided.
    Example: When generic values such as type("CLOUD_APPLICATION"),tag("slo") are provided, the query results in all SLOs for all workloads, including the current workload.
  • To see SLOs that are not directly connected to the workload, turn off Show only directly connected SLOs.
Options
No SLOs
If no SLOs are found, you can
  • Select a different timeframe in the upper-right corner.
  • Select Add SLO to create an SLO in the SLO wizard.
Example SLO panel
Related tags
Infrastructure ObservabilityContainers
