Metrics Classic
In Dynatrace, you have various types of metrics at your disposal:
- Built-in metrics provided by OneAgent. These have the
builtin:
prefix in the metric key. - Log metrics automatically ingested in Grail. These have the
log.
prefix in the metric key. - Extension metrics provided by OneAgent or ActiveGate extensions. These have the
ext:
prefix in the metric key. - Calculated metrics you create. These have the
calc:
prefix in the metric key. - USQL custom metrics you create: user session custom metrics (
uscm.
prefix) and user action custom metrics (uacm.
prefix). These metrics are based on metadata extracted from user session and user action data. - Custom metrics you can feed to Dynatrace via metric ingestion. These don't have any fixed prefix, as the ingestion protocol is completely flexible.
- Infrastructure metrics and other periodic metrics are captured every 10 seconds and stored as 1-minute aggregates. Typically, this includes a min/max/count/sum/average of the measured metric.
- Service and web request metrics do not have a frequency. Dynatrace captures the transactions and displays medians and 90th percentiles. RUM and service analysis pages are based on this data.
- For custom metrics ingestion, the standard resolution is 1 minute, but you can also get statistic summaries.
Ingestion
Push custom data to Dynatrace.
Built-in metrics
Get an overview of metrics available out of the box.
Self-monitoring metrics
Get an overview of self-monitoring metrics available out of the box.
Metric browser
Get an overview of all metrics available in your environment.
