Managed Cluster installation parameters
  • Reference
  • 9-min read
Use these command line parameters to override the default settings of a Managed Cluster installation.
By default, no parameters are required, because the Managed installer runs in interactive mode and prompts you to confirm or override default settings. Values entered interactively always take precedence over command line parameter values.
When you run the installer in interactive mode with command line parameters, the parameter values are presented as prompts instead of defaults. Any values entered at that point take precedence.
To install a Managed Cluster in non-interactive mode with default settings, use --install-silent together with --license to provide the license key.
Default settings
  • Installation path (binaries): /opt/dynatrace-managed
  • Managed Cluster data files: /var/opt/dynatrace-managed
  • System user running Dynatrace processes: dynatrace
  • System group running Dynatrace processes: dynatrace
To list all available command line options, run the installer with --help as root:
[root@localhost]# ./dynatrace-managed-installer.sh --help
Initial configuration parameters
Use these parameters for initial server configuration. When specified, the installer generates an authentication token for the public REST API after successful installation and Managed Cluster registration.
ParameterDescription
--initial-environment <name>
Name of the first monitoring environment
--initial-first-name <name>
Administrator's first name
--initial-last-name <name>
Administrator's last name
--initial-email <email>
Administrator's email address
--initial-pass <pass>
Administrator's password
Installation mode parameters
--install
Standard interactive installation
--install-silent
Installs with default settings in non-interactive mode. Use other command line parameters to override specific defaults. Useful for automating installation
--install-new-dc-silent
Premium High Availability only. Installs in a new data center in non-interactive mode. Use other command line parameters to override specific defaults
--upgrade
Starts the update process from the command line
--system-check
Checks whether the machine and operating system meet the requirements of the new version
--restore
Restores a Dynatrace Managed installation from the backup file specified by --backup-file. Backup runs daily once configured in Dynatrace Managed
--reconfigure
Reconfigures an existing installation using setup parameters
--uninstall
Uninstalls Dynatrace Managed
--self-check
Verifies that the installer file isn't corrupt
--backup-file <path>
Full path to the backup file containing configuration and data. Used with --restore
--timeouts <component:value, ..>
Extends timeouts for specified components. Use when:
  • A specific component needs a longer timeout (for example, your OS firewall startup takes several minutes).
  • You have many environments and need more time for Server startup.
--drop-x-forwarded-for
Dynatrace uses the X-Forwarded-For header for features such as logging. Handle these headers according to security best practices, because incorrect handling may result in displaying and logging incorrect data if an attacker adds manipulated X-Forwarded-For headers to requests
Outermost reverse proxy configuration
Configure the outermost reverse proxy from which clients access Dynatrace Managed as follows:
  • Strip all X-Forwarded-For headers from all requests that target Dynatrace Managed.
  • Exclude the following request paths from this behavior. Allow requests to these paths to keep X-Forwarded-For headers, as the related features require them.
    • /bf
    • /mbeacon
    • /communication
The NGINX proxy installed with Dynatrace Managed follows these rules by default. However, you can turn off this behavior during installation if NGINX isn't the outermost proxy from which clients access Dynatrace Managed. In this case, configure the outermost proxy manually.
Timeout components
The following components can be configured with --timeouts:
ComponentDescription
proc
Base timeout in seconds. This value is added to the component-specific timeouts listed below for Nodekeeper, Cassandra, Elasticsearch, Server, ActiveGate, and NGINX
ndk
Nodekeeper startup process timeout seconds = proc + ndk
cas
Cassandra startup process timeout seconds = proc + cas
els
Elasticsearch startup process timeout seconds = proc + els
srv
Server startup process timeout seconds = proc + srv
ag
ActiveGate startup process timeout seconds = proc + ag
ngx
NGINX startup process timeout seconds = proc + ngx
fw
Firewall startup process timeout seconds = fw
Setup parameters
You can change the installation path and other settings using the following parameters:
Binaries
--binaries-dir <path>
Full path to the Dynatrace binaries directory. Using this parameter with SELinux enabled requires the semanage utility to be available on your system. Default: /opt/dynatrace-managed
Licensing
--license <license-key>
License key obtained from Dynatrace
--license-file <path>
Dynatrace license file, used when a license key isn't provided
Datastore
If you have SELinux enabled, the following parameters require the semanage utility to be available on your system.
--datastore-dir <path>
Full path to the Dynatrace installation directory. Use a dedicated drive or partition for this directory. Only Dynatrace data not configured in other stores is kept here. If no specific paths are configured for other data stores, all Dynatrace data is stored here. Default: /var/opt/dynatrace-managed
--rpl-datastore-dir <path>
Full path to Dynatrace Session Replay store. Default: /var/opt/dynatrace-managed/server/replayData
--cas-datastore-dir <path>
Full path to the Dynatrace metrics repository directory. If you specify this location, Dynatrace stores metrics data here instead of in the main data location. Default: /var/opt/dynatrace-managed/cassandra
--els-datastore-dir <path>
Full path to Dynatrace Elasticsearch store directory. Default: /var/opt/dynatrace-managed/elasticsearch
--svr-datastore-dir <path>
Full path to Dynatrace raw transaction store directory. If you specify this location, Dynatrace stores raw transaction data here instead of in the main data location. Default: /var/opt/dynatrace-managed/server/
The default path /var/opt/dynatrace-managed/server/replayData cannot be a mounting point.
System user
To make the configuration as secure as possible, Dynatrace creates a unique Linux system user for Dynatrace Managed services.
The system user:
  • Has only the read, write, and execute permissions needed for required files
  • Has no home directory
  • Has a nologin shell
  • Has login disabled
These measures limit what an attacker can do if system security is compromised. If you use a default user account, set it up with the same principles.
The following parameters specify a system user who is authorized to run Dynatrace processes.
--system-user <user:group>
Username and group name of the system user authorized to run Dynatrace processes. Default: dynatrace:dynatrace
--system-user-id <UID:GID>
User ID and group ID of the system user authorized to run Dynatrace processes. Default: 1011:1011
You can specify one or both parameters.
  • The user/group name and user ID/group ID must be identical on all Cluster nodes to ensure proper access to shared storage (for example, backup).
  • If you override the default user and group settings, the modified values automatically propagate as the new default to subsequent nodes added to the Managed Cluster.
Connectivity to Mission Control
--network-proxy
If your machine uses a network proxy to connect to the internet, put the address here in the following format: protocol://[user:password@]server-address:port. Default: none
--network-proxy-cert-file
If your machine uses an HTTPS network proxy with a self-signed certificate, extend the trusted certificate store. Provide the full path to a public SSL certificate file in PEM format
--registration-token
Token used for registration in Mission Control (optional for regular installation)
Managed Cluster
--cluster-ip
If your machine has more than one network interface, decide which network interface to use for Managed Cluster traffic and enter its IPv4 address here
--cluster-nodes <id:ip, ..>
You can specify the node ID with the IP address. Use this when you restore a Managed Cluster and you must attach a replacement node that has a different IP address than the original
--seed-ip <ip>
IPv4 address of the seed node in the Managed Cluster
--seed-auth <auth-token>
Authentication token for connection to the seed node. You'll find this token after you sign in to the seed node, on the Download node installer page. This token is valid for three hours
--rack-dc <data-center>
For rack-aware deployments, provide the data center that contains the rack where you want to add the node. Always use it together with --rack-name, and set it to the same value as --datacenter; otherwise, the installer refuses to proceed
--rack-name <rack>
For rack-aware deployments, provide the name of the rack where you want to add the node. Accepts only letters, digits, and hyphens, up to 80 characters, with no leading hyphen. Defaults to rack1 when omitted, as long as the Managed Cluster holds one rack name or fewer; once a second rack name exists, an omitted value is rejected instead
OneAgent
--install-agent <on|off>
Turn on or turn off installation of the self-monitoring OneAgent. Default: on
--agent-system-user <user:group>
Name:group of the system user who should run the self-monitoring OneAgent. Use only if the default user for OneAgent cannot be used
--agent-dir <path>
Allows installation of self-monitoring OneAgent to a different directory. For example, on Linux: /bin/sh Managed-installer.sh --agent-dir /opt/dt/self-monitoring.
With --agent-dir set to /data/dynatrace/, the installer creates the symbolic link /opt/dynatrace/oneagent -> /data/dynatrace and places all OneAgent files into the specified directory (in this example, /data/dynatrace). Remove this symbolic link manually after you uninstall OneAgent. Using this parameter on Linux when SELinux is enabled requires the semanage binary to be available on your system.
Certificate parameters
Command line parameters can also help you install or update SSL/TLS certificates on Dynatrace Managed. For more information on installing fully qualified digital certificates, see Configure SSL certificate for Managed Cluster.
--ssl-protocols "<protocols>"
Space-separated list of protocols accepted by SSL connections. Replaces the default list
--ssl-ciphers "<ciphers>"
Definition of ciphers accepted by SSL connections. Replaces the default definition. This definition must first be validated with an openssl ciphers command
--ciphers-autoupdate <on|off>
Turn on or turn off cipher autoupdate, which sets default values for protocols and ciphers accepted by SSL connections on each upgrade or reconfiguration. Default for new nodes: on
Other parameters
--hosts <on|off>
Turn on or turn off altering of the /etc/hosts file. Default: on
--enable-ipv6-webhooks <on|off>
Dynatrace Managed version 1.346+ Turn on or turn off IPv6 endpoints for webhook problem notifications. Set on to turn on IPv6 endpoints or off to turn them off when you install or update a Cluster node, and use the same value on every node. Each node needs outbound IPv6 connectivity to the webhook endpoint. Default: off
--sudo-cmd "<cmd>"
Command that should be used for executing system commands with superuser privileges. Should contain the variable $CMD (typed as \$CMD). By default the following is used: /usr/bin/sudo \$CMD. For example:
dynatrace-managed.sh --sudo-cmd "/usr/bin/pbrun \$CMD"
--no-start
Upgrade only. Use this parameter when you don't want Dynatrace Managed to start immediately following an upgrade
--unregister
Use this parameter when uninstalling a Managed Cluster to unregister the Managed Cluster and release the license from Mission Control
--version
Print version information
--tmp-dir <path>
Full path to the directory for installer temp files
