Dynatrace offers several out-of-the-box integrations that automatically push problem notifications to third-party incident-management and ChatOps systems.
If however your third-party system isn't supported with an out-of-the-box integration, you can easily set up a customizable webhook integration. Using this approach, whenever Dynatrace detects a problem in your environment that affects real users, a webhook triggers an HTTP POST request to a target URL that you specify.
The payload message of the HTTP POST request is completely customizable. By default, requests use valid JSON syntax–except when you define a different HTTP content type header, in which case you define a different HTTP content type header and Dynatrace skips the JSON validation and doesn't escape the payload based on JSON syntax.
Information placeholders, such as {ProblemTitle} and {State}, are used to fill the custom JSON with the dynamic information of each detected problem.
To integrate problem-notifications using a custom webhook:
https://[2001:db8::1]:8443/webhook. To use IPv6 endpoints, set the installer parameter --enable-ipv6-webhooks on on every cluster node. For details, see Customize Managed Cluster installation. Each node requires outbound IPv6 connectivity to the endpoint. IPv4 webhook URLs continue to work without changes.The Available placeholders section of the configuration page lists placeholders you can use for this integration. Placeholders are automatically replaced with problem-related information such as problem state or title.
Here is a valid JSON web hook problem-notification definition example:
{"ImpactedEntities": {ImpactedEntities},"ImpactedEntity": "{ImpactedEntity}","PID": "{PID}","ProblemDetailsHTML": "{ProblemDetailsHTML}","ProblemDetailsJSON": {ProblemDetailsJSON},"ProblemID": "{ProblemID}","ProblemImpact": "{ProblemImpact}","ProblemTitle": "{ProblemTitle}","Problem URL": "https://example.com","State": "{State}","Tags": "{Tags}"}
{ImpactedEntities} and {ProblemDetailsJSON} are JSON data types and must not have quotes around them.
After a problem has been detected, the placeholders are populated with the actual values and results, as shown in this example payload:
{"ImpactedEntities": [{"type": "HOST", "name": "MyHost1", "entity": "HOST-XXXXXXXXXXXXX" },{"type": "SERVICE", "name": "MyService1", "entity": "SERVICE-XXXXXXXXXXXXX"}],"ImpactedEntity": "MyHost1, MyService1","PID": "99999","ProblemDetailsHTML": "<h1>Dynatrace problem notification test run details</h1>","ProblemDetailsJSON": {"ID" : "99999" },"ProblemID": "999","ProblemImpact": "INFRASTRUCTURE","ProblemTitle": "Dynatrace problem notification test run","Problem URL": "https://example.com","State": "OPEN","Tags": "testtag1, testtag2"}
