Rebuild a data center
  • How-to guide
  • 8-min read
To rebuild a lost data center (DC) in a Premium High Availability deployment, follow the steps below.
Step 1
Gather information and set variables
Step 2
Remove the lost data center
Step 3
Prepare the Managed Cluster for replication
Step 4
Install second data center nodes
Step 5
Migrate Cassandra
Step 6
Migrate Elasticsearch
Step 7
Migrate the server
Step 8
Restore traffic and backup
Step 1 Gather information and set variables
Collect the values that the commands need, and then set them as environment variables.
The procedure uses the following terms:
  • Source-DC: Surviving data center that contains the Managed Cluster
  • Target-DC: Lost data center designated for recovery
  • seed node: Node in Source-DC that performs installation tasks and distributes configuration
Gather information
The commands use these variables in Cluster API calls. Gather the following information:
  • <seed-node-ip>: The IP address of the seed node from Source-DC.
    Use any node that runs in the existing data center and can perform installation tasks and distribute configuration.
  • <nodes-ips>: The list of IPv4 addresses of new nodes in Target-DC.
    Example: "176.16.0.5", "176.16.0.6", "176.16.0.7"
  • <api-token>: A valid Cluster API token. The token requires the ServiceProviderAPI scope.
    You can generate it in the Cluster Management Console (CMC). See Cluster API authentication.
  • <dynatrace-directory>: The directory where Dynatrace Managed runs on the seed node.
    The default Dynatrace Managed installation directory is /opt/dynatrace-managed.
  • <datacenter-1>: The Source-DC name must be the same as the Cassandra DC name.
    The default Cassandra DC name is datacenter1.
    Get the DC name
    To get the DC name, run this command on the seed node before you start migration:
    sudo <dynatrace-directory>/utils/cassandra-nodetool.sh status
    The response includes the Source-DC name. The example shows a DC named datacenter1:
    Datacenter: datacenter1
    Status=Up/Down
    |/ State=Normal/Leaving/Joining/Moving
    -- Address Load Tokens Owns (effective) Host ID Rack
    UN 10.176.42.20 65.54 GB 256 100.0% f053dd8d-ecf3-7834-b099-68542439817b rack1
    UN 10.176.42.244 65.47 GB 256 100.0% 2aa7e790-a423-9273-88f9-45bcd158dd6e rack1
    UN 10.176.42.168 65.47 GB 256 100.0% 48543bca-41f5-26d3-b2fd-6cfdf5c0f3b2 rack1
  • <datacenter-2>: The Target-DC name must remain unchanged. Example: dc-us-east-2.
Lost data center name
During recovery to Target-DC, use the same name as the lost data center.
Set variables
API return codes
Each Cluster API call in this procedure returns an HTTP code. Go to the next step only when the call returns 200.
Return codeWhat to do
200
Go to the next step. The current step succeeded.
207
The request is still processing. Repeat the step after a few minutes.
40x
Revise your request path and arguments, and repeat the request.
5xx
Contact support.
Set the following environment variables on the seed node in Source-DC and on every node in Target-DC:
SEED_IP=<seed-node-ip>
DT_DIR=<dynatrace-directory>
NODES_IPS=$(echo '[<nodes-ips>]')
API_TOKEN=<api-token>
SDC_NAME=<datacenter-1>
TDC_NAME=<datacenter-2>
For example:
SEED_IP=10.176.37.201
DT_DIR=/opt/dynatrace-managed
NODES_IPS=$(echo '["10.176.37.218", "10.176.37.227", "10.176.37.120"]')
API_TOKEN=R_SZOpV4RTOmjr9fFmK4x
SDC_NAME=datacenter1
TDC_NAME=dc-us-east-2
Step 2 Remove the lost data center
Stop the lost data center, remove its nodes, and then remove it from the Managed Cluster configuration.
Stop all required Dynatrace Managed services in the recommended order. See Start/stop/restart a Cluster node.
Remove nodes
  1. Go to the CMC.
  2. For each node in the unavailable data center, go to the Node details page and remove the node.
For more information on other ways to remove a node, see Remove a Cluster node.
Remove the data center from the configuration
Run the following Cluster API call only on the seed node:
curl -ikS -X POST https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/lostDatacenterCleanUp?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If the status code isn't 200 and the response doesn't suggest next steps, contact a Dynatrace product expert via live chat.
Step 3 Prepare the Managed Cluster for replication
Copy the installer to Target-DC, and then configure the Managed Cluster so it can replicate data to Target-DC.
Distribute the installer
  1. Sign in to the CMC.
  2. Go to Home for the Dynatrace Managed deployment status page.
  3. Open Add new cluster node.
  4. Copy only the wget command line from Run this command on the target host. Ignore the command in Run this installer script with root rights and don't run the installer script.
  5. Paste and run only the wget command line in your terminal window.
Prepare data for replication
curl -ikS -X POST https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/clusterReplicationPreparation?Api-Token=$API_TOKEN
Create the data center topology
curl -ikS -X POST -d "{\"newDatacenterName\" : \"$TDC_NAME\", \"nodesIp\" :$NODES_IPS}" https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/datacenterTopology?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
Open ports
To open ports to traffic from the new Target-DC nodes, run the following Cluster API call only on the seed node:
curl --noproxy '*' -ikS -X POST https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/clusterNodes/currentDc?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If successful, the status code is 200 and the response body contains a request ID. Use this ID to check the firewall rules status.
Verify firewall rules
Set the request ID environment variable only on the seed node. Use the request ID from the response in the previous API call.
REQ_ID=<topology-configuration-request-id>
To check the firewall rules status, run the following Cluster API call only on the seed node:
curl -ikS https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/clusterNodes/currentDc/$REQ_ID?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If the status code from this call isn't 200, try again after a few minutes.
Step 4 Install second data center nodes
Install Cluster nodes on all hosts in Target-DC. Then check for the Nodekeeper service to verify that all nodes installed successfully in Target-DC.
Install nodes in the target data center
Run the following command on every node in Target-DC. Follow the prompts for a typical node installation.
sudo /bin/sh ./managed-installer.sh --install-new-dc --premium-ha on --datacenter $TDC_NAME --seed-auth $API_TOKEN
For rack-aware deployments, also add the --rack-dc <data-center> and --rack-name <rack> parameters, which assign the node to a data center and a rack. For the parameter descriptions, go to Managed Cluster installation parameters.
Target-DC's rack layout comes from the --rack-name value you pass for each node, not from Source-DC. Target-DC can become rack-aware whether Source-DC is rack-aware or not. For the full procedure, go to Combine Premium High Availability with rack awareness.
The node installation takes about three to five minutes. The expected output is:
Installation in new data center completed successfully after 2 minutes 51 seconds.
Check Nodekeeper in the target data center
Run the following Cluster API call only on the seed node when all nodes in Target-DC finish installing:
curl -ikS https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/nodekeeper/healthCheck?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If the status code isn't 200, try again after a few minutes.
Step 5 Migrate Cassandra
Reconfigure Cassandra in Source-DC and Target-DC for cross data center replication. Then trigger data synchronization, rebuild Cassandra data, and verify Cassandra state.
The Cassandra migration can take minutes to hours, depending on your metric storage size.
Trigger migration
To start migration of Cassandra in Target-DC, run the following Cluster API call only on the seed node:
curl -ikS -X POST https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/cassandra/newDc?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If successful, the status code is 200 and the response body contains a request ID. Use this ID to check the migration status. Set the request ID environment variable only on the seed node.
REQ_ID=<migration-new-datacenter-request-id>
Check migration status
To check the migration status, run the following Cluster API call only on the seed node:
curl -ikS -X GET https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/cassandra/newDc/$REQ_ID?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
Start the Cassandra rebuild
Depending on the size of your Cassandra database, the rebuild can take several hours.
To rebuild Cassandra data in Target-DC, run the following Cluster API call only on the seed node:
curl -ikS -X POST https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/cassandra/rebuild?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If successful, the status code is 200. If the status code isn't 200 and the response doesn't suggest next steps, contact a Dynatrace product expert via live chat.
Check the rebuild status
To check the rebuild status, run the following Cluster API call only on the seed node:
curl -ikS -X GET https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/cassandra/rebuild?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If the status code isn't 200, try again after approximately 15 minutes.
If the response has an error flag set to true, contact a Dynatrace product expert via live chat.
Step 6 Migrate Elasticsearch
Migrate Elasticsearch to Target-DC, and then verify the configuration and data migration. The Elasticsearch migration can take minutes or hours, depending on your Elasticsearch storage.
Migrate Elasticsearch to the target data center
Start Elasticsearch. Run the following command on every node in Target-DC in sequence:
sudo $DT_DIR/launcher/elasticsearch.sh start
To start migration of Elasticsearch to Target-DC, run the following Cluster API call only on the seed node:
curl -ikS -X POST https://$SEED_IP/api/v1.0/onpremise/multiDc/restore/elasticsearch/recover?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
Verify progress and status
To check the migration status of Elasticsearch, run the following Cluster API call only on the seed node:
curl -ikS -X GET https://$SEED_IP/api/v1.0/onpremise/multiDc/restore/elasticsearch/recover?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
Verify data migration
To verify the Elasticsearch data migration, run the following Cluster API call only on the seed node:
curl -ikS -X GET https://$SEED_IP/api/v1.0/onpremise/multiDc/migration/elasticsearch/indexMigrationStatus?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
Step 7 Migrate the server
Migrate the server, refresh the authorization tokens for OneAgent connectivity, and start NGINX in Target-DC. Then refresh the installers in Source-DC for adding nodes.
Start the Managed Cluster in the target data center
Start the Managed Cluster in Target-DC by running the following Cluster API call only on the seed node:
curl -ikS -X POST https://$SEED_IP/api/v1.0/onpremise/multiDc/restore/server/recovery?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
If successful, the status code is 200 and the response body contains a request ID. Use this ID to check Managed Cluster readiness. Set the request ID environment variable only on the seed node.
REQ_ID=<migration-server-request-id>
Check Managed Cluster readiness
To check whether the Managed Cluster is ready, run the following Cluster API call only on the seed node:
curl -ikS -X GET https://$SEED_IP/api/v1.0/onpremise/multiDc/restore/server/recovery/$REQ_ID?Api-Token=$API_TOKEN -H "accept: application/json" -H "Content-Type: application/json"
Step 8 Restore traffic and backup
  1. Restore OneAgent traffic.
    For details, see Cluster node capabilities.
  2. Turn on backup in one of the data centers. Migration turns off backup.
    For details, see Back up and restore a Managed Cluster.
Go to the Deployment status page in the Cluster Management Console and confirm that it lists both data centers with all nodes healthy.
Related topics
  • Multi-data center high availability
  • Multi-data center failover
