Get started with Dynatrace Managed
  • How-to guide
  • 2-min read
  • Published Nov 19, 2018
Get started with Dynatrace Managed, the AI-powered observability platform for on-premises deployment, in just four steps.
Step 1 Obtain a Dynatrace Managed license
To obtain a license for Dynatrace Managed, please contact Dynatrace Sales. Our sales team will be happy to provide you with more details about the two licensing models (Dynatrace Platform Subscription and Classic Licensing) and how usage is calculated.
Once an agreement has been reached, you will receive an email with your license details and instructions for setting up a Managed cluster.
Step 2 Set up a Managed cluster
Select the Managed deployment model that best suits your needs. Based on your selected deployment model, set up a Managed cluster and create your first cluster node.
You can add more nodes at any time. A minimum of 3 nodes is required for a Managed cluster in production.
Step 3 Install ActiveGate
Install Cluster ActiveGates and/or Environment ActiveGates as required in your selected deployment model.
Step 4 Ingest observability data
Start monitoring your infrastructure and applications by ingesting data from OneAgent and OpenTelemetry into your monitoring environment.
