Follow this guide to start ingesting data remotely from Amazon CloudWatch.
Its main focus is on infrastructure monitoring of AWS services: Dynatrace monitoring AWS services via CloudWatch.
See What's next? for Full-Stack and Log Monitoring of your AWS services.
After you have established the initial monitoring, you can add, remove, or modify service monitoring using the Dynatrace web UI, at scale, or using the Dynatrace API.
To learn the measurements collected for each of the AWS services, see:
The Amazon Web Services infrastructure monitoring provides metrics from CloudWatch, infrastructure data available via public AWS API, and specific events. The data is collected in five-minute intervals.
Each service monitored by Dynatrace through CloudWatch, as well as log processing and analysis, consumes DDUs.
Amazon may charge you extra for CloudWatch metric queries. For details on these additional costs, please consult Amazon CloudWatch pricing online documentation.
There are three prerequisites for the AWS monitoring setup:
To manage AWS monitoring configuration, you need permissions to read and modify the builtin:cloud.aws schema.
settings:objects:read and settings:objects:write are required.See Manage user permissions with roles for details on how to manage and set permissions.
To monitor Amazon Web Services, Dynatrace needs to be able to connect to the Amazon CloudWatch API and query it periodically. At least one ActiveGate needs to be able to connect to Amazon CloudWatch to perform the monitoring tasks. Your ActiveGate needs to be deployed on an EC2 instance and be able to connect to the endpoints listed below.
From Dynatrace version 1.267+, only role-based access can be used. Key-based authorization is no longer available for new credentials. For existing key-based credentials, you can keep using keys indefinitely. We recommend switching to role-based authentication using the dedicated button on the configuration page. Dynatrace automatically checks the configuration to ensure the correct configuration of roles.
Key-based authentication is allowed only for AWS GovCloud and China partitions.
The integration accesses the following AWS API endpoints, so they must be accessible from your ActiveGate:
Environment ActiveGate version 1.329+
https://sts.<REGION>.amazonaws.com/
Environment ActiveGate version 1.328 and earlier
https://sts.amazonaws.com/
Starting with Dynatrace version 1.329, the AWS STS global endpoint is not supported. Make sure that sts.<REGION>.amazonaws.com is accessible for the regions you want to monitor.
The us-west-2 region is now the default region for ActiveGate. In case of connectivity issues, ensure that the sts.us-west-2.amazonaws.com endpoint is enabled.
See AWS STS Regionalized endpoints for details.
AWS Resource Groups Tagging
https://tagging.<REGION>.amazonaws.com/
Amazon CloudWatch
https://monitoring.<REGION>.amazonaws.com/
Amazon EC2
ec2.<REGION>.amazonaws.com
Other endpoints may be required depending on the services you need to monitor.
Consult the tables below for endpoints specific to each service you might want to monitor and for AWS Regions supported by Dynatrace AWS Monitoring.
| Endpoint | Service |
| Amazon EC2 Auto Scaling (built-in), Amazon EC2 Auto Scaling |
| AWS Lambda (built-in), AWS Lambda |
| Amazon Application and Network Load Balancer (built-in), Amazon Elastic Load Balancer (ELB) (built-in) |
| Amazon DynamoDB (built-in), Amazon DynamoDB |
| Amazon EBS (built-in), Amazon EC2 (built-in), Amazon EBS, Amazon EC2 Spot Fleet, Amazon VPC NAT Gateways, AWS Transit Gateway, AWS Site-to-Site VPN |
| Amazon RDS (built-in), Amazon Aurora, Amazon DocumentDB, Amazon Neptune, Amazon RDS |
| Amazon S3 (built-in) |
| AWS Certificate Manager Private Certificate Authority |
| Amazon API Gateway |
| AWS App Runner |
| Amazon AppStream |
| AWS AppSync |
| Amazon Athena |
| Amazon CloudFront |
| AWS CloudHSM |
| Amazon CloudSearch |
| AWS CodeBuild |
| AWS DataSync |
| Amazon DynamoDB Accelerator (DAX) |
| AWS Database Migration Service (AWS DMS) |
| AWS Direct Connect |
| Amazon Elastic Container Service (ECS), Amazon ECS Container Insights |
| Amazon Elastic File System (EFS) |
| Amazon Elastic Kubernetes Service (EKS) |
| Amazon ElastiCache (EC) |
| AWS Elastic Beanstalk |
| Amazon Elastic Transcoder |
| Amazon Elasticsearch Service (ES) |
| Amazon EventBridge |
| Amazon FSx |
| Amazon GameLift |
| AWS Glue |
| Amazon Inspector |
| Amazon Managed Streaming for Kafka |
| Amazon Lex |
| Amazon CloudWatch Logs |
| AWS Elemental MediaTailor |
| AWS Elemental MediaConnect |
| AWS Elemental MediaPackage Live |
| AWS Elemental MediaPackage Video on Demand |
| AWS OpsWorks |
| Amazon QLDB |
| Amazon Redshift |
| AWS RoboMaker |
| Amazon Route 53 |
| Amazon Route 53 Resolver |
| Amazon SageMaker Endpoints, Amazon SageMaker Endpoint Instances |
| Amazon Simple Notification Service (SNS) |
| Amazon Simple Queue Service (SQS) |
| AWS Storage Gateway |
| Amazon SWF |
| AWS Transfer Family |
| Amazon WorkMail |
| Amazon WorkSpaces |
Some AWS regions require a minimum ActiveGate version. Regions without a version note are supported by all ActiveGate versions.
us-gov-west-1: AWS GovCloud (US)us-gov-east-1: AWS GovCloud (US-East)us-east-1: US East (N. Virginia)us-east-2: US East (Ohio)us-west-1: US West (N. California)us-west-2: US West (Oregon)eu-west-1: EU (Ireland)eu-west-2: EU (London)eu-west-3: EU (Paris)eu-central-1: EU (Frankfurt)eu-central-2: EU (Zurich)eu-north-1: EU (Stockholm)eu-south-1: EU (Milan)eu-south-2: EU (Spain)ap-east-1: Asia Pacific (Hong Kong)ap-east-2: Asia Pacific (Taipei) ActiveGate version 1.331+ap-south-1: Asia Pacific (Mumbai)ap-south-2: Asia Pacific (Hyderabad)ap-southeast-1: Asia Pacific (Singapore)ap-southeast-2: Asia Pacific (Sydney)ap-southeast-3: Asia Pacific (Jakarta)ap-southeast-4: Asia Pacific (Melbourne)ap-southeast-5: Asia Pacific (Malaysia)ap-southeast-6: Asia Pacific (New Zealand)ap-southeast-7: Asia Pacific (Thailand)ap-northeast-1: Asia Pacific (Tokyo)ap-northeast-2: Asia Pacific (Seoul)ap-northeast-3: Asia Pacific (Osaka)sa-east-1: South America (Sao Paulo)cn-north-1: China (Beijing)cn-northwest-1: China (Ningxia)ca-central-1: Canada (Central)ca-west-1: Canada West (Calgary)il-central-1: Israel (Tel Aviv)me-central-1: Middle East (UAE)me-south-1: Middle East (Bahrain)mx-central-1: Mexico (Central)af-south-1: Africa (Cape Town)us-iso-east-1: US ISO Eastus-isob-east-1: US ISOB East (Ohio)us-iso-west-1: US ISO WestThe most frequent cause of certificate issues with the TLS interception proxy is a missing proxy's CA certificate in the ActiveGate truststore.
If you're still having proxy issues, see:
Make sure that the URLs are whitelisted. Otherwise, you might get communication or timeout errors.
To perform these steps, you need to have AWS admin privileges.
The AWS monitoring policy defines the minimal scope of permissions you need to give to Dynatrace to monitor the services running in your AWS account. Create it once and use it any time when enabling Dynatrace access to your AWS account. If you don't want to add permissions to all services, and just select permissions for certain services, consult the table below. The table contains a set of permissions that are required for all AWS cloud services, a list of optional permissions specific to that service.
"cloudwatch:GetMetricData""cloudwatch:GetMetricStatistics""cloudwatch:ListMetrics""sts:GetCallerIdentity""tag:GetResources""tag:GetTagKeys""ec2:DescribeAvailabilityZones"| Name | Permissions |
All monitored Amazon services Required |
Amazon MQ | |
AWS App Runner |
Amazon AppStream |
AWS AppSync |
Amazon Athena |
Amazon Aurora |
Amazon EC2 Auto Scaling (built-in) |
AWS Billing | |
Amazon Keyspaces | |
AWS Chatbot | |
Amazon CloudFront |
AWS CloudHSM |
AWS CodeBuild |
Amazon Cognito | |
Amazon Connect | |
AWS DataSync |
Amazon DocumentDB |
Amazon DynamoDB |
Amazon DynamoDB (built-in) |
Amazon EBS |
Amazon EBS (built-in) |
Amazon EC2 API | |
Amazon EC2 (built-in) |
Amazon EC2 Spot Fleet |
Amazon Elastic Container Service (ECS) |
Amazon Elastic Inference | |
Amazon Elastic Map Reduce (EMR) |
Amazon FSx |
Amazon GameLift |
AWS Glue |
Amazon Inspector |
AWS Internet of Things (IoT) | |
AWS IoT Analytics | |
Amazon Kinesis Data Analytics |
Amazon Data Firehose |
Amazon Kinesis Data Streams |
Amazon Kinesis Video Streams |
AWS Lambda |
AWS Lambda (built-in) |
Amazon Lex |
Amazon Application and Network Load Balancer (built-in) |
AWS Elemental MediaConvert |
Amazon VPC NAT Gateways |
Amazon Neptune |
AWS OpsWorks |
Amazon Polly | |
Amazon QLDB |
Amazon RDS |
Amazon RDS (built-in) |
Amazon Redshift |
Amazon Rekognition | |
AWS RoboMaker |
Amazon Route 53 |
Amazon S3 |
Amazon SageMaker Batch Transform Jobs | |
Amazon SageMaker Endpoints |
Amazon SageMaker Ground Truth | |
Amazon SageMaker Processing Jobs | |
Amazon SageMaker Training Jobs | |
AWS Service Catalog | |
Amazon Simple Email Service (SES) | |
AWS Systems Manager - Run Command | |
AWS Step Functions | |
Amazon SWF |
Amazon Textract | |
AWS IoT Things Graph | |
AWS Transit Gateway |
Amazon Translate | |
AWS Trusted Advisor | |
AWS API Usage | |
AWS WAF Classic | |
AWS WAF | |
Amazon WorkMail |
Amazon WorkSpaces |
To get the information required for comprehensive AWS cloud-computing monitoring, you have to authorize Dynatrace to access your Amazon metrics. Dynatrace will identify all the virtualized infrastructure components in your AWS environment and collect performance metrics related to those components.
Next, select the deployment model that best describes your environment and follow the procedure for that model.
You won't be able to monitor the AWS cloud services without an AWS-hosted Environment ActiveGate.
The instructions below are applicable whether or not the account hosting your ActiveGate is the same as your monitored account. In a typical setup, you need to create two CloudFormation stacks using CloudFormation templates:
To monitor multiple accounts, use the role_based_access_AG_account_multiple_monitoring_roles_template.yml and repeat the Create a role for ActiveGate on the account that hosts ActiveGate steps to create a stack for each monitored account.
You will need:
You can also create a stack via CLI using the command below:
aws cloudformation create-stack \--capabilities CAPABILITY_NAMED_IAM \--stack-name <stack_name> \--template-body <file:///home/user/template_file.yaml> \--parameters ParameterKey=ActiveGateRoleName,ParameterValue=<role_name> ParameterKey=AssumePolicyName,ParameterValue=<policy_name> ParameterKey=MonitoringRoleName,ParameterValue=<monitoring_role_name> ParameterKey=MonitoredAccountID,ParameterValue=<monitored_account_id>
After the Dynatrace_ActiveGate_role is created on the account hosting the ActiveGate, create a role for the account to be monitored.
aws cloudformation create-stack \--capabilities CAPABILITY_NAMED_IAM \--stack-name <stack_name> \--template-body <file:///home/user/template_file.yaml> \--parameters ParameterKey=ExternalID,ParameterValue=<external_id> ParameterKey=ActiveGateRoleName,ParameterValue=<activegate_role_name> ParameterKey=ActiveGateAccountID,ParameterValue=<activegate_account_id>
Starting with ActiveGate version 1.217, AWS monitoring is enabled by default. For configuration details, see Customize ActiveGate properties. The following configuration settings refer to earlier ActiveGate versions.
Edit the custom.properties file of your Environment ActiveGate.
Make the following property settings:
[aws_monitoring]use_aws_proxy_role = falseaws_monitoring_enabled = true
If the ActiveGate is dedicated to AWS monitoring, you also need to set the MSGrouter property as follows:
[collector]MSGrouter = false
Save the file and restart the ActiveGate main service.
Only for AWS GovCloud and China partitions is key-based authentication allowed.
In this scenario you have to create an AWS monitoring policy and generate a key pair with that policy.
AWS Identity and Access Management (IAM) permission boundaries may deny AWS actions required by Dynatrace. If you use IAM permission boundary on your AWS account, make sure that actions from policy are allowed in all AWS Regions within permission boundary.
To create the AWS monitoring policy
{"Version": "2012-10-17","Statement": [{"Sid": "VisualEditor0","Effect": "Allow","Action": ["acm-pca:ListCertificateAuthorities","apigateway:GET","apprunner:ListServices","appstream:DescribeFleets","appsync:ListGraphqlApis","athena:ListWorkGroups","autoscaling:DescribeAutoScalingGroups","cloudformation:ListStackResources","cloudfront:ListDistributions","cloudhsm:DescribeClusters","cloudsearch:DescribeDomains","cloudwatch:GetMetricData","cloudwatch:GetMetricStatistics","cloudwatch:ListMetrics","codebuild:ListProjects","datasync:ListTasks","dax:DescribeClusters","directconnect:DescribeConnections","dms:DescribeReplicationInstances","dynamodb:ListTables","dynamodb:ListTagsOfResource","ec2:DescribeAvailabilityZones","ec2:DescribeInstances","ec2:DescribeNatGateways","ec2:DescribeSpotFleetRequests","ec2:DescribeTransitGateways","ec2:DescribeVolumes","ec2:DescribeVpnConnections","ecs:ListClusters","eks:ListClusters","elasticache:DescribeCacheClusters","elasticbeanstalk:DescribeEnvironmentResources","elasticbeanstalk:DescribeEnvironments","elasticfilesystem:DescribeFileSystems","elasticloadbalancing:DescribeInstanceHealth","elasticloadbalancing:DescribeListeners","elasticloadbalancing:DescribeLoadBalancers","elasticloadbalancing:DescribeRules","elasticloadbalancing:DescribeTags","elasticloadbalancing:DescribeTargetHealth","elasticmapreduce:ListClusters","elastictranscoder:ListPipelines","es:ListDomainNames","events:ListEventBuses","firehose:ListDeliveryStreams","fsx:DescribeFileSystems","gamelift:ListFleets","glue:GetJobs","inspector:ListAssessmentTemplates","kafka:ListClusters","kinesis:ListStreams","kinesisanalytics:ListApplications","kinesisvideo:ListStreams","lambda:ListFunctions","lambda:ListTags","lex:GetBots","logs:DescribeLogGroups","mediaconnect:ListFlows","mediaconvert:DescribeEndpoints","mediapackage-vod:ListPackagingConfigurations","mediapackage:ListChannels","mediatailor:ListPlaybackConfigurations","opsworks:DescribeStacks","qldb:ListLedgers","rds:DescribeDBClusters","rds:DescribeDBInstances","rds:DescribeEvents","rds:ListTagsForResource","redshift:DescribeClusters","robomaker:ListSimulationJobs","route53:ListHostedZones","route53resolver:ListResolverEndpoints","s3:ListAllMyBuckets","sagemaker:ListEndpoints","sns:ListTopics","sqs:ListQueues","storagegateway:ListGateways","sts:GetCallerIdentity","swf:ListDomains","tag:GetResources","tag:GetTagKeys","transfer:ListServers","workmail:ListOrganizations","workspaces:DescribeWorkspaces"],"Resource": "*"}]}
You'll need to generate an Access key and a Secret access key that Dynatrace can use to get metrics from Amazon Web Services.
Terraform templates are an alternative way of creating and configuring AWS roles. For detailed instructions on how to create AWS roles with Terraform, see Configuring AWS role-based access with Terraform
You can create, activate, and manage multiple monitoring connections. Each connection is defined by the credentials and/or access tokens required for Dynatrace to be able to pull in the data.
Allowing for multiple connections and configurations makes it possible to monitor even extremely complex environments. With such an approach, you don't need to configure everything at once. Instead, you can gradually add monitoring configurations to your existing setup. Such an architecture also makes it easy to react to the dynamic changes of the monitored environment, without needing to reconfigure the unaffected elements.
If you've followed all the prior steps, you're ready to configure Amazon Web Services monitoring.
To add a new AWS connection
Go to Settings > Cloud and virtualization > AWS. The page lists AWS connections already configured.
If you haven't provided an ActiveGate required for AWS monitoring (check Prerequisites for details), the respective information will be provided on the screen and you will not be able to continue with the configuration process.
You can go back to changing the already configured connections at any later point in time.
Select Connect new instance and complete the following fields.
Enabled toggle—make sure it's selected if you want to monitor this configuration.
Connection name—enter a descriptive name for the connection.
Authentication method—select Role-based authentication.
IAM role…—enter the name of the role you created in Amazon for Dynatrace (either Dynatrace_monitoring_role or a customized role name, if you created one). Remember to always use the role that contains all required permissions.
Your Amazon account ID—enter your Amazon account ID (the account you want Dynatrace to pull metrics from).
Select Connect to verify and save the connection.
If your AWS account is on a different partition than the default AWS partition, you can use the AWS partition list to select your partition.
You can limit the data acquired from the CloudWatch by defining a tag-based filter of specific resources. See Limit API calls to AWS using tags for more details on tag-based filtering.
After Dynatrace connects to your AWS environment, it immediately starts monitoring selected AWS services. Classic (formerly 'built-in') AWS metrics lists the metrics of AWS cloud services monitored by default.
In addition to AWS services, it's also possible to monitor all other AWS cloud services. AWS cloud services are enabled for monitoring per AWS connection.
To add a service to monitoring:
You can add multiple cloud services by repeating the steps above.
After you add a service, Dynatrace automatically starts collecting a set of metrics for this particular service.
Recommended metrics:
Apart from the recommended metrics, most services have the possibility of enabling optional metrics that can be added and configured manually.
To see the complete list of AWS cloud services and learn about the metrics collected for each of them, see All AWS cloud services.
Alternatively, you can check the list of supported AWS Services within in-product Dynatrace Hub (search for AWS) or in the web version of Dynatrace Hub.
After you select the cloud services and save your changes, monitoring of the newly added services starts automatically.
Within minutes, you'll see the data on your dashboards.
To see the core measurements per each of the AWS connections
You can also build your own dashboard from the metrics collected for your AWS instances. For details on building dashboards, see Dashboards.
Dynatrace OneAgent offers unparalleled depth of insight into hosts, containers, and code. To learn more, see Set up Dynatrace on Amazon Web Services.
After you set up AWS monitoring, you can:
This method of monitoring does not require an ActiveGate. Dynatrace integration with Amazon CloudWatch Metric Streams provides a simple and safe way to ingest AWS metrics. Amazon CloudWatch Metric Streams allows all metrics issued in a given AWS region to be streamed through Kinesis Firehose to the Dynatrace API. For details, see Amazon CloudWatch Metric Streams.
It is also possible to trace AWS Lambda .NET Core functions with OpenTelemetry .NET.
