You can integrate Dynatrace with Amazon Web Services (AWS) for intelligent monitoring of services running in the Amazon Cloud. AWS integration helps you stay on top of the dynamics of your data center in the cloud.
Follow these basic steps to integrate Dynatrace Managed with Amazon Web Services (AWS):
All cloud services consume Davis data units (DDUs). The amount of DDU consumption per service instance depends on the number of monitored metrics and their dimensions (each metric dimension results in the ingestion of 1 data point; 1 data point consumes 0.001 DDUs).
Dynatrace makes Amazon API requests every five minutes. In addition to CloudWatch API calls, Dynatrace makes API calls to the monitored AWS services to learn about their instances, tags, etc. The list of called services and actions is available below in the Create the monitoring policy section.
Here's a rough estimate of AWS monitoring costs:
| AWS service | Number of metrics | Daily cost per instance (USD) |
Elastic Compute Cloud (EC2) | 7 | $0.02016 |
Elastic Block Store (EBS) | 8 | $0.02304 |
Elastic Load Balancer (ELB) | 11 | $0.03168 |
Relational Database Service (RDS) | 11 | $0.03168 |
DynamoDB | 15 | $0.06912 |
Lambda | 4 | $0.01152 |
Amazon will charge about $0.01 per 1,000 metrics requested from the CloudWatch API and include the cost in the bill for the AWS account you use with Dynatrace.
The AWS monitoring policy defines the minimal scope of permissions you need to give to Dynatrace to monitor the services running in your AWS account. Create it once and use it any time when enabling Dynatrace access to your AWS account. If you don't want to add permissions to all services, and just select permissions for certain services, consult the table below. The table contains a set of permissions that are required for All AWS cloud services and, for each cloud service, a list of optional permissions specific to that service.
"cloudwatch:GetMetricData""cloudwatch:GetMetricStatistics""cloudwatch:ListMetrics""sts:GetCallerIdentity""tag:GetResources""tag:GetTagKeys""ec2:DescribeAvailabilityZones"| Name | Permissions |
All monitored Amazon services Required |
AWS Certificate Manager Private Certificate Authority |
Amazon MQ | |
Amazon API Gateway |
AWS App Runner |
Amazon AppStream |
AWS AppSync |
Amazon Athena |
Amazon Aurora |
Amazon EC2 Auto Scaling |
Amazon EC2 Auto Scaling (built-in) |
AWS Billing | |
Amazon Keyspaces | |
AWS Chatbot | |
Amazon CloudFront |
AWS CloudHSM |
Amazon CloudSearch |
AWS CodeBuild |
Amazon Cognito | |
Amazon Connect | |
Amazon Elastic Kubernetes Service (EKS) |
AWS DataSync |
Amazon DynamoDB Accelerator (DAX) |
AWS Database Migration Service (AWS DMS) |
Amazon DocumentDB |
AWS Direct Connect |
Amazon DynamoDB |
Amazon DynamoDB (built-in) |
Amazon EBS |
Amazon EBS (built-in) |
Amazon EC2 API | |
Amazon EC2 (built-in) |
Amazon EC2 Spot Fleet |
Amazon Elastic Container Service (ECS) |
Amazon ECS Container Insights |
Amazon ElastiCache (EC) |
AWS Elastic Beanstalk |
Amazon Elastic File System (EFS) |
Amazon Elastic Inference | |
Amazon Elastic Map Reduce (EMR) |
Amazon Elasticsearch Service (ES) |
Amazon Elastic Transcoder |
Amazon Elastic Load Balancer (ELB) (built-in) |
Amazon EventBridge |
Amazon FSx |
Amazon GameLift |
AWS Glue |
Amazon Inspector |
AWS Internet of Things (IoT) | |
AWS IoT Analytics | |
Amazon Managed Streaming for Kafka |
Amazon Kinesis Data Analytics |
Amazon Data Firehose |
Amazon Kinesis Data Streams |
Amazon Kinesis Video Streams |
AWS Lambda |
AWS Lambda (built-in) |
Amazon Lex |
Amazon Application and Network Load Balancer (built-in) |
Amazon CloudWatch Logs |
AWS Elemental MediaConnect |
AWS Elemental MediaConvert |
AWS Elemental MediaPackage Live |
AWS Elemental MediaPackage Video on Demand |
AWS Elemental MediaTailor |
Amazon VPC NAT Gateways |
Amazon Neptune |
AWS OpsWorks |
Amazon Polly | |
Amazon QLDB |
Amazon RDS |
Amazon RDS (built-in) |
Amazon Redshift |
Amazon Rekognition | |
AWS RoboMaker |
Amazon Route 53 |
Amazon Route 53 Resolver |
Amazon S3 |
Amazon S3 (built-in) |
Amazon SageMaker Batch Transform Jobs | |
Amazon SageMaker Endpoint Instances |
Amazon SageMaker Endpoints |
Amazon SageMaker Ground Truth | |
Amazon SageMaker Processing Jobs | |
Amazon SageMaker Training Jobs | |
AWS Service Catalog | |
Amazon Simple Email Service (SES) | |
Amazon Simple Notification Service (SNS) |
Amazon Simple Queue Service (SQS) |
AWS Systems Manager - Run Command | |
AWS Step Functions | |
AWS Storage Gateway |
Amazon SWF |
Amazon Textract | |
AWS IoT Things Graph | |
AWS Transfer Family |
AWS Transit Gateway |
Amazon Translate | |
AWS Trusted Advisor | |
AWS API Usage | |
AWS Site-to-Site VPN |
AWS WAF Classic | |
AWS WAF | |
Amazon WorkMail |
Amazon WorkSpaces |
To get the information required for comprehensive AWS cloud-computing monitoring, Dynatrace needs to identify all the virtualized infrastructure components in your AWS environment and collect performance metrics related to those components. We use this information to understand the context of your applications, services, and hosts. For this to happen, you need to authorize Dynatrace to access your Amazon metrics.
Make sure that your Environment ActiveGate or Managed Cluster has a working connection to AWS. Configure your proxy for Managed or ActiveGate, or allow access to *.amazonaws.com in your firewall settings.
Dynatrace supports two authentication methods:
Dynatrace can be deployed with or without Environment ActiveGate. Make sure that you meet one of the following deployment requirements:
The instructions below apply whether or not the account hosting your ActiveGate is the same as your monitored account.
In a typical setup, you need to create two CloudFormation stacks using CloudFormation templates:
Dynatrace Managed Server installed on an Amazon EC2 host. It must be able to assume a role within your AWS account that allows it to read the Dynatrace monitoring data.
The ID of the AWS account that hosts the ActiveGate (for example, the account that hosts your Dynatrace components, which in this case is the one hosting Environment ActiveGate or Dynatrace Managed Server).
The Amazon Web Services monitored account ID (the account you want to monitor).
The name of the role with which your Environment ActiveGate or Dynatrace Managed Server was started.
The External ID.
To enable access to your Amazon account using role-based access, follow the steps below.
Create a role for ActiveGate on the account that hosts ActiveGate
Create a monitoring role for Dynatrace on your monitored account
role_based_access_AG_account_template.yml.For each account you want to monitor, in the Resource section of the template above, add a new item to the !Sub array in the following format: 'arn:aws:iam::<new_monitored_account_id>:role/<new_monitoring_role_name>'.
Be sure to replace the placeholders (<new_monitored_account_id> and <new_monitoring_role_name>) with your own values.
Run the command below, making sure to replace the parameter values with your actual values.
You need to remove the angle brackets (< and >).
aws cloudformation create-stack \--capabilities CAPABILITY_NAMED_IAM \--stack-name <stack_name> \--template-body <file:///home/user/template_file.yaml> \--parameters ParameterKey=ActiveGateRoleName,ParameterValue=<role_name> ParameterKey=AssumePolicyName,ParameterValue=<policy_name> ParameterKey=MonitoringRoleName,ParameterValue=<monitoring_role_name> ParameterKey=MonitoredAccountID,ParameterValue=<monitored_account_id>
Go to the Amazon EC2 console, right-click an instance hosting your Environment ActiveGate, and select Security > Modify IAM role.
Select the role you created at step 1 (for example, Dynatrace_ActiveGate_role), and select Apply.
After the Dynatrace_ActiveGate_role is created on the account hosting the ActiveGate, create a role for the account to be monitored.
Create a YAML file and paste the content from the github role_based_access_monitored_account_template.yml.
Create the stack in your Amazon Console or using the CLI.
In your Amazon Console, go to CloudFormation.
Go to Stacks and create a new stack with new resources.
Select Template is ready, upload the template you created above, and select Next.
In Parameters, enter:
Optionally, adapt other parameters as needed.
aws cloudformation create-stack \--capabilities CAPABILITY_NAMED_IAM \--stack-name <stack_name> \--template-body <file:///home/user/template_file.yaml> \--parameters ParameterKey=ExternalID,ParameterValue=<external_id> ParameterKey=ActiveGateRoleName,ParameterValue=<activegate_role_name> ParameterKey=ActiveGateAccountID,ParameterValue=<activegate_account_id>ParameterKey=RoleName,ParameterValue=<role_name> ParameterKey=PolicyName,ParameterValue=<policy_name>
Key-based authentication is only allowed for AWS GovCloud and China partitions.
In this scenario, you have to create an AWS monitoring policy and generate a key pair with that policy.
AWS IAM permissions boundaries may prohibit AWS actions required by Dynatrace. If you use an IAM permissions boundary on your AWS account, make sure that the actions from that policy are allowed in all AWS Regions within that permissions boundary.
To create the AWS monitoring policy
{"Version": "2012-10-17","Statement": [{"Sid": "VisualEditor0","Effect": "Allow","Action": ["acm-pca:ListCertificateAuthorities","apigateway:GET","apprunner:ListServices","appstream:DescribeFleets","appsync:ListGraphqlApis","athena:ListWorkGroups","autoscaling:DescribeAutoScalingGroups","cloudformation:ListStackResources","cloudfront:ListDistributions","cloudhsm:DescribeClusters","cloudsearch:DescribeDomains","cloudwatch:GetMetricData","cloudwatch:GetMetricStatistics","cloudwatch:ListMetrics","codebuild:ListProjects","datasync:ListTasks","dax:DescribeClusters","directconnect:DescribeConnections","dms:DescribeReplicationInstances","dynamodb:ListTables","dynamodb:ListTagsOfResource","ec2:DescribeAvailabilityZones","ec2:DescribeInstances","ec2:DescribeNatGateways","ec2:DescribeSpotFleetRequests","ec2:DescribeTransitGateways","ec2:DescribeVolumes","ec2:DescribeVpnConnections","ecs:ListClusters","eks:ListClusters","elasticache:DescribeCacheClusters","elasticbeanstalk:DescribeEnvironmentResources","elasticbeanstalk:DescribeEnvironments","elasticfilesystem:DescribeFileSystems","elasticloadbalancing:DescribeInstanceHealth","elasticloadbalancing:DescribeListeners","elasticloadbalancing:DescribeLoadBalancers","elasticloadbalancing:DescribeRules","elasticloadbalancing:DescribeTags","elasticloadbalancing:DescribeTargetHealth","elasticmapreduce:ListClusters","elastictranscoder:ListPipelines","es:ListDomainNames","events:ListEventBuses","firehose:ListDeliveryStreams","fsx:DescribeFileSystems","gamelift:ListFleets","glue:GetJobs","inspector:ListAssessmentTemplates","kafka:ListClusters","kinesis:ListStreams","kinesisanalytics:ListApplications","kinesisvideo:ListStreams","lambda:ListFunctions","lambda:ListTags","lex:GetBots","logs:DescribeLogGroups","mediaconnect:ListFlows","mediaconvert:DescribeEndpoints","mediapackage-vod:ListPackagingConfigurations","mediapackage:ListChannels","mediatailor:ListPlaybackConfigurations","opsworks:DescribeStacks","qldb:ListLedgers","rds:DescribeDBClusters","rds:DescribeDBInstances","rds:DescribeEvents","rds:ListTagsForResource","redshift:DescribeClusters","robomaker:ListSimulationJobs","route53:ListHostedZones","route53resolver:ListResolverEndpoints","s3:ListAllMyBuckets","sagemaker:ListEndpoints","sns:ListTopics","sqs:ListQueues","storagegateway:ListGateways","sts:GetCallerIdentity","swf:ListDomains","tag:GetResources","tag:GetTagKeys","transfer:ListServers","workmail:ListOrganizations","workspaces:DescribeWorkspaces"],"Resource": "*"}]}
Dynatrace can use access keys to make secure REST or Query protocol requests to the AWS service API. You'll need to generate an Access key ID and a Secret access key that Dynatrace can use to get metrics from Amazon Web Services.
Once you've granted AWS access to Dynatrace, it's time to connect Dynatrace to your Amazon AWS account.
In Dynatrace, go to Settings > Cloud and virtualization > AWS and select Connect new instance.
Select the authentication method that you set up.
For role-based access, select Role-based authentication.
Dynatrace_monitoring_role).For key-based access, select Key-based authentication.
Select Connect to verify and save the connection.
Once the connection is successfully verified and saved, your AWS account will be listed in the Cloud and virtualization settings page.
You should soon begin to see AWS cloud monitoring data.
If your AWS account is on a different partition than the default aws partition, you can select it and Dynatrace will connect to it instead.
To change your AWS partition
You can alter the scope and content of your monitoring depending on your preferences by using tags and listing services needed.
We recommend that you limit the scope of your AWS monitoring and reduce the number API calls to Amazon. You can use tagging to limit the AWS resources (AWS service instances) that are monitored by Dynatrace.
To configure metric events for alerting, follow this guide.
Once your credentials are saved, you can decide which services will be monitored. To select your preferred services
