Send Dynatrace notifications to Slack
  • 2-min read
With a Slack problem-notification integration, your teams will always be aware of potential risks within applications, services, and infrastructure. Your teams can also use a Dynatrace-integrated Slack channel to discuss incidents, evaluate solutions, and link to similar problems.
Set up Slack integration
  1. In Slack, create an Incoming Webhook, as described in the Slack documentation.
  2. Copy the generated Webhook URL to your clipboard. The Webhook URL should look like this: https://hooks.slack.com/services/T00000000/B00000000/XXXXXXXXXXXXXXXXXXXXXXXX.
  3. In Dynatrace, go to Settings > Integration > Problem notifications.
  4. Select Add notification.
  5. Select Slack from the available notification types.
  6. Enter the following information:
    • Display name This is the freeform name of this integration that will be displayed in Dynatrace on Settings > Integration > Problem notifications when you finish this configuration.
    • URL Paste the webhook URL
    • Channel Enter the name of a Slack channel
    • Message Enter a custom message; it can contain text and problem-related placeholders
      Placeholders
      The Available placeholders section of the configuration page lists placeholders you can use for this integration. Placeholders are automatically replaced with actual values.
  7. Assign an Alerting profile.
  8. Select Send test notification to make sure your Slack integration is working.
  9. Save changes.
You will receive Dynatrace problem notifications on your Slack channel with your custom message.
Example
An example of Slack integration
Troubleshooting
  • Slack problem notifications from Dynatrace don't arrive
Related tags
Notifications Classic
