Data Explorer offers ten visualization types. You select and configure a visualization here, and a visualization you pin to a dashboard keeps its settings as a dashboard tile.
Metric values over time as lines, columns, or areas.
Metric values over time as stacked columns.
Metric values over time as stacked areas.
One metric as a pie or doughnut chart.
One metric merged into a single aggregate value.
Query results as table rows, with one metric per column.
One metric as a ranked list of results.
One metric as a value distribution in buckets.
One cell per result, colored by threshold.
A histogram metric's values as counts per bucket.
Select a visualization from the list in the upper-left corner of Data Explorer. When you switch visualizations, settings that don't apply to the new visualization are ignored, and an information icon in the list warns you. If you switch back, you might need to reconfigure them.
To choose which metrics of a multi-metric query a visualization shows, select the letter next to a metric or .
For how each visualization looks as a dashboard tile, see Visualizations in the Dashboards section.
A graph shows metric values over time as lines, columns, or areas. A graph can show any selection of metrics in the query, with up to 20 series per metric.
Chart mode is a dropdown next to the color palette of each metric, and sets the metric to Line, Column chart, Area, Stacked column, or Stacked area.
Baselines, correlated metrics, and focus are graph actions rather than settings. See Add a baseline, Add correlated metrics, and Focus on a metric series.
For how the tile looks, see Graph tiles.
Shared settings that apply: Unit and format, resolution, legend, connect gaps, rename, color palette, color override, axes, and thresholds. See Shared settings.
A stacked column chart shows metric values over time as stacked columns. Your metric selection controls which metrics are stacked, and only metrics with the same unit can be stacked.
For how the tile looks, see Stacked column tiles.
A stacked area chart shows metric values over time as stacked areas. Your metric selection controls which metrics are stacked, and only metrics with the same unit can be stacked.
For how the tile looks, see Stacked area tiles.
A pie shows query results as a pie or doughnut chart. By default, it shows the first metric of a multi-metric query. Thresholds don't apply to a pie.
For how the tile looks, see Pie tiles.
Shared settings that apply: Unit and format, legend, fold transformation, rename, color palette, and color override. See Shared settings.
A single value shows one metric and merges all its dimensions into a single aggregate.
Show trend shows the trend in the tile, based on the first and last data points of the selected timeframe.
Show sparkline shows a sparkline in the tile.
Threshold background reflects the threshold color in the tile background when turned on.
For how the tile looks, see Single value tiles.
Shared settings that apply: Unit and format, fold transformation, rename, and thresholds. See Shared settings.
A table shows query results as rows, with one metric per column. A table can show any selection of metrics in the query, and shows 100 rows by default.
ASC or DESC.The Columns section turns individual columns on or off. The selection also applies to table tiles.
In Data Explorer, results are limited to 100 rows by default. Limit sets another value, and Limit > Maximum removes the limit, as does removing :limit(100) in advanced mode. For the row limit on a table tile, see Table tiles.
Page controls are at the bottom of the Result section, and on table tiles. For the page size of a table tile, see Table tiles.
For how the tile looks, see Table tiles.
A top list shows a ranked list of results. A top list doesn't show multiple metrics: only the metric selected in the query editor runs, and the first metric is selected by default.
For how the tile looks, see Top list tiles.
Shared settings that apply: Unit and format, fold transformation, rename, color override, and thresholds. See Shared settings.
A heatmap shows the value distribution in buckets. By default, it shows the first metric of a multi-metric query.
Y axis shows the Y axis by value or split by dimensions. Buckets sets the number of buckets on each axis. The default is Auto; clear a number to return to Auto.
For how the tile looks, see Heatmap tiles.
Shared settings that apply: Unit and format, resolution, legend, show labels, rename, color palette, and thresholds. See Shared settings.
A honeycomb shows one cell per result, colored by threshold. By default, it shows the first metric of a multi-metric query and 100 cells. To show more, use Limit > Maximum, or remove :limit(100) from the query in advanced mode. Hover over a cell on a tile to see details, and select it for drilldown options.
Show hive works with Show legend:
For how the tile looks, see Honeycomb tiles.
Shared settings that apply: Unit and format, legend, show labels, fold transformation, rename, color palette, and thresholds. See Shared settings.
A histogram shows the value distribution of a histogram metric, such as response times or request sizes, so you can see value distributions, percentiles, and outliers at a glance. The visualization requires a histogram metric, whose metric key ends in .histogram.
The chart shows one bar per bucket, labeled by its value range. The first and last buckets are open-ended. Each bar shows the count of that bucket alone, not the cumulative counts that the :histogram transformation returns. For the transformation and for percentiles, see Analyze an explicit histogram.
For how the tile looks, see Histogram tiles.
Shared settings that apply: Unit and format, resolution, legend, rename, color palette, color override, and thresholds. See Shared settings.
These options appear in the Settings section. Its contents depend on the selected visualization.
| Setting | Visualizations | Description |
Resolution | Graph, Stacked column, Stacked area, Heatmap, Histogram | X axis (time) granularity; |
Show legend | Graph, Stacked column, Stacked area, Pie, Heatmap, Honeycomb, Histogram | Shows a legend; in a heatmap, the legend matches colors to the value range |
Show labels | Heatmap, Honeycomb | Shows a count for each heatmap bucket, or a label and value in each honeycomb cell |
Connect gaps | Graph, Stacked column, Stacked area | Connects gaps in the chart when turned on (off by default) |
Fold transformation | Pie, Single value, Table, Top list, Honeycomb | Combines a timeseries into a single data point; default |
The Settings section also lists options for each metric in the query.
Rename | All | Display name on the chart and in the legend, or the column heading in a table; the query keeps the original metric name. Set it with the pencil icon next to the metric name. |
Chart mode | Graph | Dropdown next to the color palette with |
Color palette | Graph, Stacked column, Stacked area, Pie, Heatmap, Honeycomb, Histogram | Color palette for the metric |
Color override | Graph, Stacked column, Stacked area, Pie, Top list, Histogram | Fixed color for one series, such as a selected host, that overrides the palette |
Some resolutions are unavailable for some timeframes. If you select an incompatible combination, Dynatrace applies a resolution automatically and displays a message such as Auto-resolution applied. Resolution value of [6 hours] applied. Selected timeframe doesn't allow for [5 minutes] resolution. Select a different resolution to override it.
For the data point limit of a dashboard tile, see Tile behavior.
Connect gaps draws a continuous line across intervals without data. It's available for Graph, Stacked column, and Stacked area.
The legend is active: select a legend entry to turn the display of that entry on or off.
Auto selects the most appropriate time aggregation for the metric.Last value, Average, Count, Maximum, Minimum, Sum, Median, Value, Percentile 10th, Percentile 75th, Percentile 90th.Last value shows the last reported value instead of an aggregation.The fold transformation affects the resolution:
Auto in a table, single value, top list, or honeycomb, the Inf (infinity) resolution is used for backward compatibility. If the metric selector doesn't support Inf, the fold transformation is added to the end of the query.fold is used.All metric selectors use the same total value mechanism, fold or Inf, so adding a selector that requires fold might change the results of the other selectors. To see the query Data Explorer sends, select > Copy request in the Result section.
You set Unit and Format for each metric. These settings control how values are displayed, and also apply to values you export to a CSV file.
| Setting | Values | Description |
Unit |
Format |
| Decimal places; |
In advanced mode, use :setUnit(<unit>) to select from a wider range of units.
Dynatrace uses this order-of-magnitude notation:
| Notation | Factor | Meaning |
| Kilo, thousand |
| Mega, million |
| Giga, billion |
| Tera, trillion |
Examples:
Auto selects a readable unit such as GiB, or GB for a decimal base, which is used when the metric defines no base. Select B, KiB, MiB, or GiB for a fixed unit, or None for raw bytes.Auto with Format 0.00 shows exact amounts; k (thousand), M (million), or G (billion) with Format 0 shows large amounts without cents.Auto with Format None shows an exact count; k, M, G, or T with Format 0.0, 0.00, or 0.000 shows a rough count.The Axes section is available for Graph, Stacked column, and Stacked area. The section lists the X axis and each Y axis.
Name | Text | Axis name, shown vertically next to a Y axis and horizontally under the X axis; the X axis has no name by default. Set it with the pencil icon next to the axis. |
Axis metric | Metrics | Metrics plotted on that Y axis |
Visibility | Hides or shows the axis | |
Position |
| Side of the chart for a Y axis; default |
Min, Max |
| Range of a Y axis (default |
Add Y axis | Button | Adds a Y axis for a metric, unavailable when every metric already has an axis; only the first two metrics get a Y axis automatically |
The Threshold section sets threshold values and colors for every visualization except Pie, and the colors also apply to dashboard tiles.
MiB values without the unit. If you change Unit later, the thresholds aren't adjusted. With Unit Auto, enter thresholds in the base unit, such as bytes.For missing series and empty table cells, see Troubleshoot results.
