How to scale the OTel Collector
  • Latest Dynatrace
  • How-to guide
  • 10-min read
When the OTel Collector's CPU or memory usage exceeds a threshold that would put it at risk of being overloaded if there were a burst of traffic, it is recommended to find ways to either increase the resources allotted to the Collector, or to scale processing to multiple Collector instances. We will primarily focus on solutions available in Kubernetes here. Note that the guidance and examples in this documentation are generalized and may not give optimal performance for your specific case; you will need to analyze your systems to determine the best way to scale them.
For more general information in the OpenTelemetry documentation, please see the Scaling the OTel Collector page on the OpenTelemetry website.
Determining when to scale
You will want to consider scaling when you begin to approach the limits of the resources that have been allotted to your Collector. Self-monitoring metrics available through the Collector and metrics available from the host environment (e.g. Kubernetes) will be helpful to track this. See our page on OTel Collector self-monitoring for more information on collecting this data. The following are a few metrics worth paying attention to:
  • otelcol_processor_refused_spans: If you have the Memory Limiter Processor enabled, this metric (or the equivalent for other signals) will indicate that the Collector needs more memory to continue processing its current load.
  • otelcol_exporter_queue_capacity and otelcol_exporter_queue_size: Once the exporter queue size starts to get close to or exceed the queue capacity, that indicates the Collector is having trouble sending data to the backend. This is either because workers are not becoming available to send the data, or the backend itself is overloaded. You may need to increase the processing power available to the Collector to continue processing this volume of data.
  • k8s.resource_quota.used: If you are monitoring your Kubernetes cluster with the Kubernetes Cluster Receiver, this can be used to determine the amount of CPU/memory quota your Collector has used.
  • container.cpu.usage and container.memory.usage: If you are monitoring your cluster with the Kubelet Stats Receiver, these can tell you if a given Collector container is nearing or hitting its quota limits.
Scaling the Collector
Kubernetes comes with multiple object types capable of scaling the Collector based on the needs of specific scenarios. For simple scaling, Deployments or ReplicaSets can be used to create a pool of Collectors that can be scheduled by Kubernetes without too much forethought. For more general information on Collector deployment architectures, see our guide on Deploy the Dynatrace OTel Collector.
Most of the advice in this document applies to horizontally scaling the Collector by creating more Collector instances or spreading instances across machines. However, if your current deployment uses a single Collector instance to do all your processing, you should first determine if vertically scaling the Collector is sufficient for your anticipated load. Vertically scaling the Collector has a lower cap on the amount of processing power and memory that can be given to the Collector, but is also simpler. In Kubernetes, you can do this by raising the CPU and memory limits on the Collector pod.
For scaling Prometheus scraping, we recommend using the standard Prometheus deployment with the Target Allocator to handle large metric volumes.
Scaling stateless Collectors
It's comparatively easy to scale stateless Collectors: since it doesn't matter which data goes to which Collector, the decision about which Collector to send a payload to can be made regardless of the contents of the data. As a result, any standard load balancer for a given transmission protocol should work.
The simplest way to balance load is through a Kubernetes Service object that points to multiple replicas of an Collector pod deployed through any standard type of Kubernetes workload such as a Deployment, ReplicaSet, StatefulSet, or DaemonSet. For short-lived connections, this will distribute load among the Collectors accessible through the service fairly evenly. Note that long-lived connections, such as those over HTTP/2 or gRPC, will keep a connection open to a single Collector and therefore may make the load between Collectors uneven.
For more complex cases, such as handling gRPC connections, a Service with type LoadBalancer can offer more control over how load is balanced. LoadBalancer Services are able to leverage a separate load balancer to determine which Collector a connection is routed to. Service meshes such as Istio or Linkerd can also help with load balancing, as they have detailed control over network connections inside the cluster.
For cases where your deployment topology matters, for example with gateway Collectors deployed through a DaemonSet, you can use a Service object with specialized routing settings to only send data to Collectors running on the same node as the source of the data. On Kubernetes version 1.26+, this is done by configuring a service to only accept traffic internal to a node.
Scaling stateful processing using non-pooled Collectors
When using the Collector to do stateful processing, it's important that the same data is always sent to the same Collector. You can increase the throughput of your pipeline while still following this rule by choosing certain Collectors to handle certain data. This can be done by choosing a particular deployment pattern for Collectors, or by assigning data sources to Collectors:
  • Sidecar Collectors: If an Collector is deployed as a sidecar and is coupled to an application, then all the data from that application will go through the sidecar Collector and can be processed with stateful operations.
  • DaemonSet Collectors: An agent Collector deployed to a Kubernetes node (such as through a DaemonSet) can be used for stateful processing if a given application on the node always sends its data to the Collector. Note that this assumes there is only a single Collector per node.
  • Single Collector: If you only need to run a single Collector for a given set of data sources, this Collector can be used for stateful processing since all data will flow through the same Collector. You may choose this if you decide to send a particular signal or data from a chosen set of applications to a given Collector. Note that for high-availability, redundant Collector instances must be kept as backups and not receive data unless the first Collector goes down. Additionally, processing will be reset if a redundant Collector is activated.
Scaling pooled stateful Collectors with the Load Balancing Exporter
Scaling a horizontally-scaled pool of stateful Collectors likely necessitates using the Load Balancing Exporter. The Load Balancing Exporter turns the Collector into an OTLP-aware load balancer that allows you to route data to a specific downstream Collector based on information inside an OTLP payload such as a metric name.
Note that for metrics, the Load Balancing Exporter component has a Development stability level. It is not recommended for production use at this time.
Stateful processors
You will want to consider using the exporter if you are scaling and using any of the following stateful components. We only cover components included in the Dynatrace Collector here, you will need to determine the best default for any other stateful components you use. You can also configure which part of the data is used for routing. The best key to use depends on your use-case, but we give recommendations below.
  • The Cumulative to Delta Processor: Data points for the same metric are required to be sent to the same Collector for the collection period of the metric. The metric_name key is therefore a good default for routing.
  • The Tail Sampling Processor: In order to make a decision about whether to sample a trace, the processor must be able to see all spans within the trace. Therefore, all spans must be sent to the same Collector, and we recommend routing by the traceID key to accomplish this.
  • The Span Metrics Connector: The connector needs to see all spans from a service in order to emit metrics about its performance. Therefore we highly recommend routing by the service key.
Configuring the Load Balancing Exporter
There are two important elements involved with configuring the Load Balancing Exporter: the key used to route the data, and the method the exporter uses to find Collectors in the pool.
Configuring the routing key is done by setting the routing_key option. The defaults for each signal are:
  • Traces: traceID
  • Metrics: service
  • Logs: traceID if present, otherwise a random trace ID. The routing_key option will not override this behavior and will have no effect on how logs are routed.
We recommend you leave these as the default or set them based on the recommendations in the Stateful processors section above.
The other important configuration option is the resolver key, which is used by the exporter to determine which Collectors are available to forward data to. In Kubernetes, we recommend using the k8s resolver since it is Kubernetes-native. Specifically, it supports dynamically updating the pool based on which Collector pods are running, and will add or remove Collectors if the number of replicas changes. It will also remove Collectors that become unhealthy, ensuring high-availability requirements are met if retries are also configured through the retry_on_failure option.
Note that configuring the static resolver with a set pool of Collectors can cause data loss if an Collector goes down and is not replaced before the retry limit is met. The Collectors configured in the pool are set for the lifetime of the load-balancing Collector.
Resiliency
The load balancing exporter comes with resiliency options to help mitigate the risk of data loss. These options are both for dealing with a fluctuating number of downstream Collectors as well as issues sending data to a particular Collector. The upstream docs cover these in detail and explain how and when to use them.
Scaling load balancer Collectors
Since the Load Balancing Exporter uses a deterministic hash to determine which downstream Collector to send data to, load-balancing Collectors can be considered stateless and can therefore be scaled using the approaches outlined in the Scaling stateless OTel Collectors section. Note that if the resolver for the load-balancing Collectors update their downstream pools at different times, this may result in data meant for a single Collector momentarily being sent to multiple Collectors.
Demo configuration
extensions:
health_check:
endpoint: 0.0.0.0:13133
receivers:
otlp:
protocols:
grpc:
endpoint: 0.0.0.0:4317
http:
endpoint: 0.0.0.0:4318
exporters:
load_balancing/traces:
protocol:
otlp:
resolver:
k8s:
service: traces-receiver.default
ports:
- 4317
load_balancing/logs:
protocol:
otlp:
resolver:
k8s:
service: logs-receiver.default
ports:
- 4317
load_balancing/metrics:
retry_on_failure:
enabled: true
initial_interval: 5s
max_interval: 30s
max_elapsed_time: 300s
sending_queue:
enabled: true
num_consumers: 10
queue_size: 1000
sizer: requests
protocol:
otlp:
resolver:
k8s:
service: metrics-receiver.default
ports:
- 4317
service:
extensions: [health_check]
pipelines:
metrics:
receivers: [otlp]
processors: []
exporters:
- load_balancing/metrics
traces:
receivers: [otlp]
processors: []
exporters:
- load_balancing/traces
logs:
receivers: [otlp]
processors: []
exporters:
- load_balancing/logs
Configuration validation
Validate your settings to avoid any configuration issues.
Components
For our configuration, we use the following components.
Receivers
Under receivers, we configure the otlp receiver to receive data over gRPC and HTTP.
Exporters
In the exporters section, we configure three load_balancing exporters, one for each signal. The exporters are all configured to use the k8s resolver, which uses a Kubernetes service to determine the pool of Collectors to send data to. One reason to split further processing by signal is that each signal likely receives different amounts of traffic: for example, you may receive a large amount of logs, some traces, and relatively few metrics. Therefore, you would want the Collector pool that processes logs to be bigger than the one that processes metrics; extra Collectors allocated for processing fewer metrics may waste resources.
Service pipelines
In our pipelines, we receive data over OTLP and export it through the Load Balancing Exporter for the particular signal, without doing any additional processing. Since this Collector is exclusively for load balancing, we want to do as little processing as possible so it can handle as much data as possible.
Related topics
  • Batch OTLP requests with the OTel Collector
  • Apply memory limits to the OTel Collector
Related tags
Application Observability
