Availability calculated based on the execution status of visits- 100% for code=0: HEALTHY, SCRIPT_FINISH, SKIPPED- 0% for error status codes such as 1401 - CONSTRAINT_VIOLATED
Duration between start and end time of visit execution (in milliseconds)Metric available only if visit execution took place; both start time and end time must be available.
dt.entity.multiprotocol_monitor``dt.entity.synthetic_location``dt.synthetic.monitored_entity_ids``dt.security_context``dt.maintenance_window_ids``result.state``result.status.code``result.status.message``multi_protocol.result.state (deprecated, use result.state)multi_protocol.result.status.code(deprecated, use result.status.code)multi_protocol.result.status (deprecated, use result.status.message)
Ratio of executed steps that didn't fail (successes + skips) to all executed stepsWe take into account steps that were actually executed rather than steps intended to be executed. For example, with 2 successful steps, 1 failed step, and 8 not started, the ratio is 2/3, or 66.67%.
dt.entity.multiprotocol_monitor``dt.entity.synthetic_location``dt.synthetic.monitored_entity_ids``dt.security_context``step.id``request.type``multi_protocol.step.id (deprecated, use step.id)multi_protocol.request.type (deprecated, use request.type)
Availability calculated based on the execution status of steps- 100% for code=0: HEALTHY, SCRIPT_FINISH, SKIPPED- 0% for error status codes such as 1401 - CONSTRAINT_VIOLATED
Duration between start and end time of step execution (in milliseconds)Metric available only if step execution took place, with a well-defined end time; therefore, it's not available for skipped steps.
dt.entity.multiprotocol_monitor``dt.entity.synthetic_location``dt.synthetic.monitored_entity_ids``dt.security_context``step.id``request.type``result.state``result.status.code``result.status.message``multi_protocol.step.id (deprecated, use step.id)multi_protocol.request.type (deprecated, use request.type)multi_protocol.result.state (deprecated, use result.state)multi_protocol.result.status (deprecated, use result.status.message)multi_protocol.result.status.code(deprecated, use result.status.code)
Ratio of executed requests that didn't fail to all executed requests.If a step doesn't have executed requests (because nothing matches its definition in a monitor configuration), we return the value 100%.For example, with 2 successful requests and 1 failed request, the ratio is 2/3, or 66.67%.
dt.entity.multiprotocol_monitor``dt.entity.synthetic_location``dt.entity.host (only for monitors with filter defined)dt.synthetic.monitored_entity_ids``dt.security_context``step.id``request.id``request.target.address``request.type``multi_protocol.step.id (deprecated, use step.id)multi_protocol.request.id (deprecated, use request.id)multi_protocol.request.target_address (deprecated, use request.target.address)multi_protocol.request.type (deprecated, use request.type)
Availability calculated based on the execution status of requests- 100% for code=0: HEALTHY, SCRIPT_FINISH, SKIPPED- 0% for error status codes such as 1401 - CONSTRAINT_VIOLATED
dt.entity.multiprotocol_monitor``dt.entity.synthetic_location``dt.entity.host (only for monitors with filter defined)dt.synthetic.monitored_entity_ids``dt.security_context``step.id``request.id``request.target.address``request.type``result.state``result.status.code``result.status.message``multi_protocol.step.id (deprecated, use step.id)multi_protocol.request.id (deprecated, use request.id)multi_protocol.request.target_address (deprecated, use request.target.address)multi_protocol.request.type (deprecated, use request.type)multi_protocol.result.state (deprecated, use result.state)multi_protocol.result.status (deprecated, use result.status.message)multi_protocol.result.status.code(deprecated, use result.status.code)
dt.entity.multiprotocol_monitor``dt.entity.synthetic_location``dt.entity.host (only for monitors with filter defined)dt.security_context``step.id``request.id``request.target.address``request.type``multi_protocol.step.id (deprecated, use step.id)multi_protocol.request.id (deprecated, use request.id)multi_protocol.request.target_address (deprecated, use request.target.address)multi_protocol.request.type (deprecated, use request.type)
Ratio of received packets to sent packetsDoesn't take into account the configured number of packets to be sent.For example, out of 10 packets to be sent, if 5 were sent and 4 were received, the ratio is 4/5, or 80.00%.
Duration between start and end time of request handling (in milliseconds)This metric is always provided, even if actual request execution did not take place (for example, because of exceptions or timeouts).Diagnostic metric—allows for validation of external ping process execution time.
TCP monitor dimensions
Name
Type
Description
Example value
request.tcp_port_number
string
TCP request port number, as provided in monitor configuration
665
multi_protocol.request.tcp_port_number
string
TCP request port number, as provided in monitor configuration (deprecated, use request.tcp_port_number)
dt.entity.multiprotocol_monitor``dt.entity.synthetic_location``dt.entity.host (only for monitors with filter defined)dt.security_context``step.id``request.id``request.target.address``request.type``multi_protocol.step.id (deprecated, use step.id)multi_protocol.request.id (deprecated, use request.id)multi_protocol.request.target_address (deprecated, use request.target.address)multi_protocol.request.type (deprecated, use request.type)request.tcp_port_number``multi_protocol.request.tcp_port_number (deprecated, use: request.tcp_port_number)
Duration between start time (socket creation and connection) and end time (when confection is successfully established) in millisecondsMetric available only if request execution took place (with no exceptions or timeouts), with a well-defined end time
DNS monitor dimensions
Name
Type
Description
Example value
request.dns_record_type
string
DNS record type to be queried by request, as provided in configuration
A, AAAA, CNAME
multi_protocol.request.dns_record_type
string
DNS record type to be queried by request, as provided in configuration (deprecated, use request.dns_record_type)
dt.entity.multiprotocol_monitor``dt.entity.synthetic_location``dt.entity.host (only for monitors with filter defined)dt.security_context``step.id``request.id``request.target.address``request.type``multi_protocol.step.id (deprecated, use step.id)multi_protocol.request.id (deprecated, use request.id)multi_protocol.request.target_address (deprecated, use request.target.address)multi_protocol.request.type (deprecated, use request.type)request.dns_record_type``multi_protocol.request.dns_record_type (deprecated, use: request.dns_record_type)
Duration between start and end time of the request to the DNS server, in millisecondsMetric available only if request execution took place (with no exceptions or timeouts), with a well-defined end time
DQL queries to extract data
Use DQL queries to extract data with metrics and dimensions.
The following examples use Notebooks to demonstrate how to work with the results of network availability monitors. They use result metrics as a starting point to explore possibilities of extracting and interpreting data with DQL.
Host entity status for ICMP requests
The monitor MULTIPROTOCOL_MONITOR-5C2F92334DF71A90 executes ICMP requests and filters monitored hosts with "targetFilter": "hostGroup == e2e-synthetic-private-location" (which resolves to about 26 hosts).
By using the dt.synthetic.multi_protocol.request.executions metric and splitting it by the dt.entity.host and result.status.message dimensions, we can display the status of the connection to a particular monitored host entity in this host group. Some hosts do not fulfill the expected success rate; instead of being HEALTHY, their requests are marked as CONSTRAINT_VIOLATED.
Timeseries status = avg(dt.synthetic.multi_protocol.request.executions),
The monitor MULTIPROTOCOL_MONITOR-548C3CD54183CED9 executes ICMP requests to hosts with the explicitly defined IP addresses, 18.x.x.x, 10.x.x.x, and 34.x.x.x. Each of these IP addresses maps to a distinct host.
We use the sum of the dt.synthetic.multi_protocol.icmp.packets_sent and the sum of the dt.synthetic.multi_protocol.icmp.packets_received metrics to get insight into how many packets were sent and received.
We split results by the request.target_address dimension and filter data for 18.x.x.x and 10.x.x.x only.
For 18.x.x.x, the same number of packets were received as were sent, but for 10.x.x.x, all packets are lost and none were received.
The monitor MULTIPROTOCOL_MONITOR-74E68F22FF5E9227 executes TCP requests to hosts from a host group that resolves to the IP addresses 18.x.x.x, 34.x.x.x, and 44.x.x.x.
To display the status of the TCP connection for an IP-port pair, we use the dt.synthetic.multi_protocol.request.executions metric and splitting it by the dimensions:
In this example:
Each host has the ports 22 (SSH) and 8080 (HTTP server) open, and each connection to the hosts on these ports succeeds with the HEALTHY status.
No service uses the standard HTTP port 80. Therefore, connections to all hosts on that port fail with the TCP socket connection error status.
Note that results of this query can be limited to just successful requests by filtering by the multi_protocol.result.status.code dimension (code == 0).
timeseries status = sum(dt.synthetic.multi_protocol.request.executions),
In this example, instead of IP addresses, we split the results by monitored host entity IDs.
To check typical time taken for a successful connection to the target port for a host, we use the average of the dt.synthetic.multi_protocol.tcp.connection_time metric split by the dimensions:
dt.entity.host
Only ports 22 (SSH) and 8080 (HTTP server) are open, and these are the only ports for which dt.synthetic.multi_protocol.tcp.connection_time is available. The hosts are effectively in different geographical locations (Ohio, Oregon, and North Virginia in the United States), so a difference in connection times is expected.
Unexpected problem that's usually related to monitor's execution components.
1401 CONSTRAINT_VIOLATED
Constraint conditions that were defined in monitor's configuration were not met.
1604 VALIDATION_ERROR
Improper monitor configuration detected.
12013 UNKNOWN_HOST
Error in the hostname
IP address of the host cannot be determined. Possible causes:- Invalid hostname- DNS server unreachable- DNS cache issues- Firewall or proxy interference
12033 Execution timeout
Server operates slowly.
Timeout of request execution. Possible causes:- Network issues- Slow or unresponsive server or service- Connection blocked by firewall rules- Timeout is too small.
TCP monitor execution statuses
Code / message
Example
Description
22000 TCP socket connection error
Service is not listening on a specified port.
This status means that the host was identified and available but the TCP connection could not be established or was unexpectedly closed. Additional explanation for the exact exception is provided. The status is used if a java.net.SocketException is thrown during the connection attempt. Possible causes:- Service is not listening on the specified port.- Service reached resource or connection limit.- Service became unavailable during the socket connection process.
