Script mode for browser monitor configuration in Classic
  • Dynatrace Classic
  • How-to guide
  • 2-min read
  • Published Sep 19, 2018
In addition to the usual configuration in the UI, you can use Script mode to configure your clickpath or single-URL monitors. In this mode, you can access the underlying JSON script of your monitor. If you're a synthetic power user, this will make your life a lot easier and allow you to speed up clickpath creation and management. Use the script editor to quickly find specific events (steps), adapt locators across the whole script, or edit parts of the clickpath without rerecording.
You aren't limited to just one mode—you can switch back and forth between the UI and script modes by clicking the Clickpath/Script switch.
Access the clickpath script
To edit your clickpath browser monitor in script mode:
  1. Go to Synthetic Classic.
  2. Select the clickpath monitor you want to edit.
  3. Select the Browse button (…) and select Edit.
  4. Select the Recorded clickpath tab in the Monitor settings menu on the left.
  5. Select Script at the top.
Access the single-URL script
To edit your single-URL browser monitor in the script mode:
  2. Select the single-URL monitor you want to edit.
  4. Select the Monitor script tab in the in the Monitor settings menu on the left.
Edit the script
You can download the script (Download script as .json) or just copy it from the editor and edit it in a text editor of your choice. However, you can also edit the script directly in the browser. This provides the following benefits:
  • Autocomplete—just press Ctrl+Spacebar to see a list of suggestions.
  • Syntax highlighting makes it easier for you to write script code.
  • Instant error validation—the editor instantly shows a warning for any error in the script. Hover over the error to see what's wrong and a suggestion for how to fix it. You cannot save changes until the code is error free.
Note that you need to escape all special characters and break lines with a backslash (for example, a new line is \n, double quotes is \", and tab is \t).
You can play your changes back for clickpath scripts without saving them—just select Play back clickpath.
Script structure
Main script object
Contains the monitor script.
ElementTypeDescriptionRequired
configuration
ScriptConfig
The setup of the monitor
Optional
type
string
The type of monitor
Possible values are:
  • clickpath for clickpath monitors
  • availability for single-URL browser monitors
    These monitors are only allowed to have one event of the navigate type.
Required
version
string
Script version—use the 1.0 value here.
Required
events
Array of:
navigateEvent
interactionEvent
javaScriptEvent
selectOptionEvent
cookieEvent
keystrokesEvent
Steps of the clickpath—the first step must always be of the navigate type.
Note that an event is not the same thing as an action—only events that trigger web requests are called actions, so your script might not have as many actions as events. Synthetic actions (similar to user actions for real user monitoring) hold the performance data collected during the playback of clickpath events.
The actual JSON object of the event depends on its type:
  • navigateEvent—contains a Navigate event.
  • interactionEvent—contains a Click or Tap event.
  • javaScriptEvent—contains a JavaScript event.
  • selectOptionEvent—contains a Select option event.
  • cookieEvent—contains a Cookie event.
  • keystrokesEvent—contains a Keystroke event.
Required
The ScriptConfig object
Contains the setup of the monitor.
userAgent
string
The user agent of the request
Optional
device
customDevice
or
predefinedDevice
The emulated device of the monitor—holds either the parameters of the custom device or the name and orientation of the preconfigured device.
If not set, then the Desktop preconfigured device is used.
Optional
bandwidth
bandwidthOptions
or
predefinedBandwidth
The emulated network conditions of the monitor
If not set, then the full available bandwidth is used.
Optional
requestHeaders
requestHeader[]
The list of HTTP headers to be sent with requests of the monitor
Optional
cookies
requestCookie[]
List of cookies to be created for the monitor
These cookies are added before execution of the first step.
Optional
The customDevice object
Contains the emulated device of the monitor.
mobile
boolean
The flag of the mobile device
Set to true for mobile devices or false for a desktop or laptop.
Required
touchEnabled
boolean
The flag of the touchscreen
Set to true if the device uses touchscreen. In that case, use can set interaction event as tap.
Required
width
integer
The width of the screen in pixels
The maximum allowed width is 1920.
Required
height
integer
The height of the screen in pixels
The maximum allowed height is 1080.
Required
scaleFactor
integer
The pixel ratio of the device
Optional
The predefinedDevice object
Contains one of the preconfigured device emulations.
deviceName
string
The name of the preconfigured device—when editing in the browser, press Crtl+Spacebar to see the list of available devices.
Required
orientation
string
The orientation of the device—portrait or landscape
Desktop and laptop devices are not allowed to use the portrait orientation.
Required
The bandwidthOptions object
Contains the emulated network conditions of the monitor.
latency
integer
The latency of the network, in milliseconds
Required
download
integer
The download speed of the network, in bytes per second
Required
upload
integer
The upload speed of the network, in bytes per second
Required
The predefinedBandwidth object
Contains the pre-configured network emulations.
networkType
string
The type of the preconfigured network—when editing in the browser, press Crtl+Spacebar to see the list of available networks.
Required
The requestHeader object
Contains the list of HTTP headers to be sent with requests of the monitor.
The following headers are not allowed:
  • user-agent
  • cookie
name
string
The name of the HTTP header
Required
value
string
The value of the HTTP header
Required
The requestCookie object
Contains the list of cookies to be created for the monitor.
Every cookie must be unique within the list. However, you can use the same cookie again in other event.
name
string
The name of the cookie
The following cookie names are not allowed:
  • dtCookie
  • dtLatC
  • dtPC
  • rxVisitor
  • rxlatency
  • rxpc
  • rxsession
  • rxvt
Required
value
string
The value of the cookie—the following symbols are not allowed: ;,\".
Required
domain
string
The domain of the cookie
Required
path
string
The path to the cookie
Optional
The navigateEvent object
Contains a Navigate event.
type
string
The type of synthetic event
In this case, the event type is navigate.
Required
url
string
The URL to navigate to
Required
description
string
A short description of the event to appear in the UI
Required
wait
waitCondition
The wait condition for the event—defines how long Dynatrace should wait before the next action is executed.
Optional
validate
validationType[]
The validation rule for the event—helps you verify that your browser monitor loads the expected page content or page element.
Optional
target
targetType
The tab on which the page should open
Optional
authentication
plainAuthenticationType or secureAuthenticationType
The login credentials to bypass the browser login mask
Optional
The interactionEvent object
Contains a Click or a Tap event.
type
string
In this case, click or tap
Required
description
string
Required
button
integer
The mouse button to be used for the click
Required
wait
waitCondition
Optional
validate
validationType[]
Optional
target
targetType
The element to click/tap on
Optional
The javaScriptEvent object
Contains a JavaScript event.
type
string
In this case, javascript
Required
description
string
Required
javaScript
string
The JavaScript code to be executed in this event
Required
wait
waitCondition
Optional
target
targetType
The tab where the JavaScript code is executed
Optional
The selectOptionEvent object
Contains a Select option event.
type
string
In this case, selectOption
Required
description
string
Required
selections
listOptions[]
The options to be selected
Required
wait
waitCondition
Optional
validate
validationType[]
The validation rule for the event—helps you to verify that your browser monitor loads the expected page content or page element.
Optional
target
targetType
The selection tag of the dropdown list
Optional
The cookieEvent object
Contains a Cookie event.
type
string
cookie
Required
description
string
Required
cookies
requestCookie[]
The list of cookies to be created during the event
Required
The keystrokesEvent object
Contains a Keystroke event.
type
string
keystrokes
Required
description
string
Required
textValue
string
The text to enter
Required
masked
boolean
Indicates whether the textValue is encrypted (true) or not (false).
Required
simulateBlurEvent
boolean
Defines whether to blur the text field when it loses focus.
Set to true to trigger the blur the textValue.
Required
wait
waitCondition
Optional
validate
validationType[]
Optional
target
targetType
The object to enter the text to
Optional
The waitCondition object
Contains the wait condition for an event.
waitFor
string
The time to wait before the next event is triggered
  • page_complete—wait for the page to load completely.
  • network—wait for background network activity to complete.
  • next_action—wait for the next action.
  • time—wait for specific period of time.
  • validation—wait for a specific element to appear.
Required
milliseconds
integer
The time to wait, in milliseconds
The maximum allowed value is 60000.
Required for the time type
Not applicable otherwise
timeoutInMilliseconds
integer
The maximum amount of time to wait for a certain element to appear, in milliseconds—if exceeded, the action is marked as failed.
Required for the validation type
validation
validationType[]
The element to wait for
The validationType object
Contains the validation rule for an event or waiting rule.
type
string
The goal of the validation:
  • content_match—check page for the specific content. Not allowed for validation inside of wait condition.
  • element_match—check page for the specific element.
Required
match
string
The content to look for on the page
Regular expressions are allowed. In that case set isRegex as true.
Required for content_match
Optional for element_match
isRegex
boolean
Defines whether match is a plain text (false) or regular expression (true).
Optional
failIfFound
boolean
The condition of the validation:
  • false—validation succeeds if the specified content/element is found.
  • true—validation fails if the specified content/element is found.
Required
target
targetType
The element to look for on the page
Required for element_match
Optional for content_match
The plainAuthenticationType object
Plain login credentials to bypass the browser login mask during a Navigate event
type
string
The type of authentication—http_authentication or webform.
webform authentication type is not allowed in clickpath monitors.
Optional
username
string
The username to log in with.
Required
password
string
The password to log in with.
It contains not the actual password, but a unique ID of it, and the password itself is stored in Dynatrace and found by the ID. If you change the ID, the stored password becomes unavailable.
To change the password, set the masked property as false and type in the new password.
Required
masked
boolean
The flag of the masked password
true means that the password is encrypted and stored, and the password field shows the ID of the password to encrypt the password.
Set false to type in a new password.
Optional
The secureAuthenticationType object
The login credentials to bypass the browser login mask during a Navigate event.
type
string
The type of authentication—http_authentication, webform, or kerberos.
Optional
credential
credentialType
The credential object that contains the username and password.
Required
domain
string
Kerberos domain.
Required for kerberos
authServerAllowlist
string
List of allowed servers for kerberos authentication. Wildcards can be used. Exact details are provided in the Chrome Enterprise documentation.
The credentialType object
The credentials from the credential vault.
id
string
The ID of the credentials in the credential vault.
Required
credentialField
string
The type of authentication—username or password.
Optional
The listOptions object
Contains the options to be selected in the Select option event.
index
integer
The index of the option to be selected
Required
value
string
The value of the option to be selected
Required
The targetType object
Contains the target tab or element of the event.
window
string
The tab of the target
Optional
locators
locatorType[]
The list of locators identifying the desired element
Optional
The locatorType object
Contains an element of a page to look for.
type
string
Defines where to look for the element:
  • css—in CSS selector
  • dom—in JavaScript code
Required
value
string
The name of the element to be found
Required
This is a model of the script JSON, showing all the possible elements. It has to be adjusted to be used as an actual script. To get an example of a real monitor, you can check the script of an existing monitor.
"configuration": {
"userAgent": "string",
"device": {
"mobile": true,
"touchEnabled": true,
"width": 375,
"height": 667,
"scaleFactor": 2,
"deviceName": "string",
"orientation": "portrait"
"bandwidth": {
"latency": 1,
"download": 1,
"upload": 1,
"networkType": "WiFi"
"requestHeaders": {
"addHeaders": [
"name": "string",
"value": "string"
"toRequests": ["string"]
"cookies": [
"name": "string",
"value": "string",
"domain": "string",
"path": "string"
"version": "1.0",
"type": "clickpath",
"events": [
"type": "navigate",
"url": "string",
"description": "string",
"wait": {
"waitFor": "page_complete"
"authentication": {
"type": "basic",
"masked": true,
"username": "string",
"password": "string"
"validate": [
"type": "content_match",
"failIfFound": true,
"isRegex": false,
"match": "string"
"target": {
"window": "string"
"type": "click",
"button": 0,
"wait": {
"waitFor": "network"
"target": {
"locators": [
"type": "css",
"value": "string"
"type": "dom",
"value": "string"
"validate": [
"type": "element_match",
"failIfFound": false,
"target": {
"locators": [
"type": "css",
"value": "string"
"type": "javascript",
"javaScript": "string",
"wait": {
"waitFor": "time",
"milliseconds": 2000
"target": {
"window": "string"
"type": "selectOption",
"selections": [
"index": 1,
"value": "string"
"wait": {
"waitFor": "validation",
"validation": {
"match": "string",
"target": {
"locators": [
"type": "dom",
"value": "string"
"timeoutInMilliseconds": 60000
"type": "cookie",
"cookies": [
"name": "string",
"value": "string",
"domain": "string",
"path": "string"
"type": "keystrokes",
"textValue": "string",
"masked": false,
"simulateBlurEvent": true,
"wait": {
"waitFor": "next_action"
Related tags
Digital ExperienceSynthetic ClassicSynthetic Classic
